Date/Time: Thu, 28 Nov 2024 13:53:48 +0000
How to avoid the volume surge at the start of the equity market for cumulative Delta Vol
View Count: 460
[2023-04-26 23:10:44] |
Ragy - Posts: 29 |
I am reaching out to see if there is a way to avoid my chart showing the cumulative Delta Volume to have this massive surge in volume at 9:30 AM at the start/open of the equity market. I literally have to scroll all the way to the right until this surge is completely hidden and the chart looks normal and I am able to spot the divergence between the price and the Cumulative Delta. I tried to set to "No" for Reset at Start of Trading Day, and Reset at Both Session Start Times, but it did not work. See attached picture for example.
Capture 1.PNG / V - Attached On 2023-04-26 23:10:05 UTC - Size: 66.2 KB - 91 views |
[2023-04-27 10:39:45] |
Sierra_Chart Engineering - Posts: 17201 |
One thing you can do is adjust the Session Times of the chart to not include, trading during the first 5 or 10 seconds. Refer to: Chart Session Times Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
