Date/Time: Thu, 28 Nov 2024 14:01:00 +0000
Show Zig Zag text in region
View Count: 340
[2023-04-26 22:42:30]
58LesPaul - Posts: 429
I have the Zig Zag study on region 1 with the price bars. The text for volume on each swing sometimes doesn't appear on the chart, it is either above or below the chart area. I have tried all the scale positions to get the chart to include the volume text inside the chart. Is there a way to accomplish this?
[2023-04-27 05:13:50]
User688525 - Posts: 259
Did you try adjusting the "Scale Padding Percentage" to a value such as 15 or 20?
[2023-04-27 14:26:45]
John - SC Support - Posts: 36350
Since the Zig Zag values are actually drawn as "drawings", they do not get taken into consideration when determining the scale region.
As stated above, the solution is to modify the "Scale Padding Percentage" for that chart so that there is additional space at the top and bottom such that the text can be seen. Refer to the following:
Chart Scale and Scale Adjusting: Scale Padding Percentage (Scale Settings)
