Date/Time: Thu, 28 Nov 2024 13:56:22 +0000
Editing Quoteboard fields crashes Sierra
View Count: 245
[2023-04-26 21:16:48] |
Brookwood - Posts: 26 |
This now happens consistently: When trying to edit headers or fields in my master quoteboard (I am attempting to save a modified version as my new default)the program freezes and must be terminated through the Task Manager. (I have the sense that it is a graphics issue but that's just a hunch.) My system is an I-7 6600K with 64 GB of memory and a Quadro K4200 graphics card running SC 2482. Thanks in advance-- I can paste-in the results of the results of the debugged .DMP crash dump file upon request. Date Time Of Last Edit: 2023-04-26 21:30:54
[2023-04-26 23:45:39] |
Sierra_Chart Engineering - Posts: 17201 |
Provide us the Chartbook you are using. Instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile And tell us the exact steps you are performing to make this happen. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-04-26 23:45:45
