Date/Time: Fri, 22 Nov 2024 08:24:36 +0000
Your new version 969 not working
View Count: 2071
[2013-05-02 13:10:19]
raja - Posts: 20
It is corrupted
pls check
bala
[2013-05-02 16:07:48]
Please describe the specific problem you are having.
[2013-05-02 16:14:50]
Sierra Chart - Max - Posts: 5729
From email:
It keeps hanging
also when you change symbol on a chart - it keeps loading
in a circular fashion - never ends
Sierra Chart Support
[2013-05-02 16:34:35]
1. Not sure what is meant by "Hanging". Please be more descriptive.
2. For the reloading problem, we will need to test your Chartbook you are using. Please provide it by following these steps here:
https://www.sierrachart.com/index.php?l=PostingInformation.php#AttachFile
3. For now go back to a prior version. Follow the instructions here:
http://www.sierrachart.com/index.php?l=doc/download.php#Downgrading
Date Time Of Last Edit: 2013-05-02 17:05:15
[2013-05-02 20:25:44]
2. Below is the reason for the reloading problem. This is from the version 964 Release notes:
If an ACSIL (Advanced Custom Study Interface and Language) study function you are using makes a call to an sc. function that takes a copy of a Date-Time ( SCDateTime) type or returns one, then you will need to recompile and build a new DLL on this version or higher. Otherwise, there could be unexpected problems with the calling of these functions. If you did not develop the custom study, then you will need to contact the developer of it about this.
Date Time Of Last Edit: 2013-05-02 20:27:12
[2013-05-02 20:42:38]
1. This "hanging" problem is also due to the reason we give in post #5. You will need to recompile custom studies you are using, on the newer versions.
Date Time Of Last Edit: 2013-05-02 20:43:16
