Date/Time: Thu, 28 Nov 2024 11:38:42 +0000
[User Discussion] - Ninja trader charts replication
View Count: 584
[2023-04-26 19:42:41]
User478380 - Posts: 184
hello
please see attached image.
thanks.
imageninja charts replication.png / V - Attached On 2023-04-26 19:42:33 UTC - Size: 293.8 KB - 132 views
[2023-04-27 04:25:47]
Tony - Posts: 522
You don't need to detach any chart, save all the charts in one Chart Book,
Window --> Maximize
name each chart (1000 tick, 2000 tick etc.) at:
Chart Settings --> Display --> Chart Display Items --> Title Bar Name --> 1000 tick
and then set:
General Settings --> Window Tab --> Use MDI Window Tabs --> Yes
General Settings --> Window Tab --> Show MDI Window Tabs At (List) --> Bottom
That should reproduce what you saw in Ninja
Date Time Of Last Edit: 2023-04-27 04:32:30
[2023-04-27 08:38:36]
I am encountering several issues with what you suggested. When the tabs appear at the bottom of the screen, clicking CNTRL + TAB doesnt move to the next tab in sequence. Hence, if I have my tabs arranged as 1000t, 2000, 4000t, 8000t, 16000t and I am on the 2000t chart, if I click cntrl+tab it will move to say the 16000t and then back to the 2000t and then back to the 1000t and then to the 8000t. There doesnt seem to be a logic to how the tabs are moving. In Ninja, when you click CNTRL+TAB, the next chart in the sequence is highlighted which is totally logical. Is this a system bug with Sierra and if not how can it be fixed so that I can tab through the charts in a logical order?
Thanks !
Date Time Of Last Edit: 2023-04-27 09:54:12
[2023-04-30 00:07:45]
Do you have an update on my previous comment please?
Also, is it possible to have several tabs under one chart and several under a second one? Currently the tabs appear next ot each other in a row and not under a specific chart.
I think this is the only issue that I currently have open. All the other issues I have marked with a # in the title to highlight the fact that they have been resolved.
Many thanks
Meyer
[2023-05-01 16:14:39]
John - SC Support - Posts: 36350
The default keyboard shortcuts for "Next Chart" and "Previous Chart" are "F9" and "F4" respectively. This will move you to the next/previous chart in the tab list. If you want to change the keyboard shortcuts, then refer to the following:
Global Settings Menu: Customize Keyboard Shortcuts (Global Settings menu)
What you are seeing is the only option, apart from making two rows, or having a single row that scrolls. Refer to the following:
General Settings Window: Support Multiple Rows for MDI Tabs (Global Settings >> General Settings >> Windows >> Window Tabs)
