Date/Time: Thu, 28 Nov 2024 13:38:35 +0000
Trade DOM P&L column change from points to actual Dollar amount while in the trade.How to?
View Count: 450
[2023-04-26 15:24:29] |
Jimmyz83 - Posts: 52 |
I cant find how to change the column from Points to the actual dollar profit and loss while in the trade. Can you tell me where the setting is? Thank you
[2023-04-26 15:54:50] |
If you are referring to the "Profit/Loss" column in the DOM, then you need to click on the words "Profit/Loss" at the top of the column and this toggles between the different display options. Note that you have to have an open trade in order to do this, as the Profit/Loss needs to be displayed. Refer to the information here: Chart Trading and the Chart DOM: Chart DOM Position Profit and Loss Column For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
