Date/Time: Thu, 28 Nov 2024 13:50:10 +0000
Alert markers on the chart?
View Count: 234
[2023-04-26 14:37:50] |
MeowthTradez - Posts: 44 |
I just added "add symbol alert" to the right click menu to set alerts on the chart and it works but they are kind of invisible until they hit. Is there a way to make alerts you've set show on the chart?
[2023-04-26 15:05:24] |
For the "Symbol Alerts" you can view them in the "Alerts Manager" under the "Symbol Alert" page. Refer to the following: Alerts Manager: Introduction For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
