Date/Time: Thu, 28 Nov 2024 13:48:50 +0000
# Chart issues which I can't set
View Count: 380
[2023-04-25 21:58:38] |
User478380 - Posts: 184 |
Hi Please see attached image Thanks! |
CHART QUESTIONS.png / V - Attached On 2023-04-25 21:58:17 UTC - Size: 67.47 KB - 106 views |
[2023-04-25 22:22:55] |
JohnR - User831573 - Posts: 306 |
For your 1st ? -> There is an option under the Chart Settings popup window - Select Region tab then change the option for the region you want. In your case it would be Region Number 1. See Attached. For # 2 - I think that is based on your background color and the Crosshairs color. For the closing price, I believe it is based on the last bar & last price / color. Hope this helps JohnR |
sierrachart_Region data line.jpg / V - Attached On 2023-04-25 22:22:42 UTC - Size: 338.18 KB - 80 views |
[2023-04-26 09:53:29] |
58LesPaul - Posts: 429 |
1. Global Settings > Customize Chart Header 2. Global Settings > Last Trade Price Box Last Trade Price Box Foreground Last Trade Price Box Outline Chart Values: Color of the Price and Times Boxes |
[2023-04-26 13:53:59] |
Hi, Please see attached file. Thanks! |
header.png / V - Attached On 2023-04-26 13:53:52 UTC - Size: 26.07 KB - 81 views |
[2023-04-26 13:56:43] |
Hi, I cant see a last trade price box in global settings - see image please. Thanks |
global settings.png / V - Attached On 2023-04-26 13:56:36 UTC - Size: 34.51 KB - 84 views |
[2023-04-26 14:02:04] |
Graphic settings
[2023-04-26 14:41:11] |
Hi Please see attached. Thanks! |
CROSSHIAR.png / V - Attached On 2023-04-26 14:41:04 UTC - Size: 66.99 KB - 82 views |
[2023-04-26 15:10:24] |
Graphics Settings >> Chart Values: Color of the Price and Time Boxes Refer to the following: Graphics Settings: Chart Values: Color of the Price and Time Boxes As you can see, the color of the text is set by the background color. With regards to the item in the bottom right corner, refer to the following: Working With Charts: Chart Settings Indicators at Lower Right of Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-04-26 20:08:53] |
Thanks for resolving this issue.
