Date/Time: Thu, 28 Nov 2024 13:43:49 +0000
[User Discussion] - Rest order
View Count: 331
[2023-04-25 16:03:07]
User640766 - Posts: 1
How do I put an order in before my entering point is touch. . I would like to put in a long order 5 ticks above where the bar is at this time. I want to enter my order when the bar is 5 ticks from where I am now. I guest this would be a resting order
[2023-04-25 20:51:43]
Sawtooth - Posts: 4120
This is called a Buy Stop entry.
The easiest way to do this is to use the DOM or the ChartDOM.
If you use the settings in the attached pic, at Global Settings >> ChartDOM Settings >> Order Types tab,
the order types used will be automatic.
imageChartDOM settings.PNG / V - Attached On 2023-04-25 20:50:12 UTC - Size: 14.11 KB - 66 views
