Date/Time: Thu, 28 Nov 2024 13:39:39 +0000
studies horizontal lines
View Count: 261
[2023-04-25 15:52:14]
User885239 - Posts: 3
I have the horizontal tool on a ohl chart. Using the instructions on the site. However with an input for line one at 4140 line two at 4130 in region 1, All lines group up as one clump. The chart bars do not show up. If I input region 2 all lines appear at the bottom of the chart also as a clump. At no time is the actual input value showing in the proper price on the chart.Suggestions?
Jay Mayer
[2023-04-25 15:54:11]
John - SC Support - Posts: 36350
Are you using the Horizontal Lines study or drawing Horizontal lines?
It sounds like you are using the study and you might have some subgraphs for lines turned on that are at a value of 1. If this is the case, then the system is trying to display values at 4140, 4130, and 1, which will compress your chart so that the value at 1 can be seen. Make sure any line that is not being used is set to "Ignore" in the subgraph. Refer to the following:
Chart Studies: Subgraphs Tab >> Draw Style
