Date/Time: Mon, 25 Nov 2024 11:55:12 +0000
Custom Calculated Symbol(Spread)
View Count: 533
[2023-04-25 13:53:41] |
User841161 - Posts: 221 |
I made a custom calculated symbol with a 3ES - 2NQ (Emini S&P - Nasdaq) spread. There is no exchange traded spread for this. Can this custom spread symbol be traded as a spread directly off the chart or trading DOM as a spread?
[2023-04-25 15:08:05] |
Refer to the following: Spread Order Entry Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-04-26 16:33:19] |
k, when I made spread order study for 3 mesm-2*mnq, under study put spread entry price at -13700.50, spread entry operator put Less or Equal, for some reason it placed order right away, not sure why spread wasnt at or below -13700.50.
Date Time Of Last Edit: 2023-04-27 02:34:13
[2023-04-26 16:34:35] |
Sorry here is picture of study.
SpreadOrder.png / V - Attached On 2023-04-26 16:34:16 UTC - Size: 109.57 KB - 108 views |
[2023-04-27 09:04:41] |
Sierra_Chart Engineering - Posts: 17172 |
We will need to test this.
[2023-05-16 18:27:46] |
We apologize for the delay. We are doing some testing now of this.
[2023-05-16 20:51:09] |
We have looked into this extensively and we could not reproduce the problem. What we have done is as follows two the Spread Order Entry study: 1. We identified a problem where the order quantities after triggering that are displayed in the Chart Region where the study is, were just showing a zero's. This is a bug that has been fixed. 2. There was no price multiplier in the case of Teton order routing applied to orders for symbols different than the chart, but that did not affect order fills in any way. This was just a display issue in the Trade Orders window. This is fixed. 3. We added what price the spread was at when the study triggered, to the on chart display. This will help debug an issue like this in the future. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-03-06 10:45:15] |
User918104 - Posts: 4 |
I'm using a 3 charts Study combined with the Spread Order Entry study. How can i calculate the risk and expected profit based on the combined price scale ? Can you give a formula that would help me have an idea of the tick value for two or three different symbols ? (lets take for example ES - NQ) Thank you! |
