Date/Time: Thu, 28 Nov 2024 13:40:33 +0000
# Font size of main window menus
View Count: 381
[2023-04-25 13:08:01] |
User478380 - Posts: 184 |
Hi How can I change the font size of the menus in the main window please? I have already changed ALL the font field in global settings > graphic settings > font but the size of the menu name is unaffected. I even tried increasing the display resolution in windows to 150% but even that doesn't do anything to the size of the menu names See attached image for further details. Thanks in advance! |
MENU NAMES.jpg / V - Attached On 2023-04-25 13:07:28 UTC - Size: 132.59 KB - 113 views |
[2023-04-25 15:02:48] |
This is controlled by the Operating System. In Windows 10, if you can find it, there is a setting for "Make Text Bigger" that will do what you want.
[2023-04-26 15:35:08] |
Thank you for resolving this issue very quickly !
