Date/Time: Thu, 28 Nov 2024 13:46:38 +0000
NQTV depth and consolidated tape
View Count: 434
[2023-04-24 12:09:48] |
User193408 - Posts: 41 |
hello Sierra, quick question just to be sure to understand : you will soon bring the consolidated tape volumes of nasdaq / nyse / amex. on the other hand we have NQTV for depth. is it ok to say that the NQTV depth just relates to the nasdaq exchange volume ? thank you
[2023-04-24 16:20:18] |
You are correct. The NQTV data is just the NASDAQ exchange volume and market depth data.
[2023-04-24 17:22:00] |
thank you - would be a super mess on your side to have the consolidated depth ?
[2023-04-24 17:43:44] |
We are working on it. The goal is to bring it all together, but that it going to take a bit of time.
[2023-04-24 17:50:18] |
you really mean nasdaq / nyse / amex consolidated depth ? if yes : love you guys :)
[2023-04-24 17:59:23] |
Sierra_Chart Engineering - Posts: 17201 |
No there will not be consolidated market depth data. Market depth will only be from NASDAQ.
