Date/Time: Thu, 28 Nov 2024 13:47:43 +0000
Chartbook Path
View Count: 262
[2023-04-24 12:04:53]
eticket - Posts: 3
In 2021, I used Sierra Chart with my Infinity/TransAct brokerage account but, since then, I stopped trading and Infinity was bought out by a different company. I want to use Sierra Chart now with SC Data, which is delayed. When I open my chartbooks, I see the path at the top: C:\SierraChart\SierraChartTransActMA\Data\.
How do I change the path so I can open chartbooks from a different location (C:\SierraChart\Data)?
Do I need to uninstall/reinstall Sierra Chart?
Thank you!
eticket
[2023-04-24 16:15:25]
John - SC Support - Posts: 36350
It really does not matter that you have your Sierra Chart under that folder.
But, if you really want to move it, then it is not that difficult. Follow these instructions:
Transferring Sierra Chart Settings and Data From Existing Installation to New Installation: Simple Transfer/Copy of Sierra Chart Installation to Another Folder or Computer System
