Date/Time: Thu, 28 Nov 2024 13:46:19 +0000
[Programming Help] - Formula Help
View Count: 315
[2023-04-24 08:42:46] |
User135370 - Posts: 162 |
I am using the "Period OHLC Variable Period"study to chart the weekly high and low , I want an audible alert for a cross of the high and low. =CROSSOVER(SG2,C) =CROSSOVER(SG3,C) This is them individually, how do I make them an OR formula? i.e When Close (c) crosses SG2 (High) or SG3 (Low) Help can't figure it out |
[2023-04-24 13:20:40] |
Sawtooth - Posts: 4120 |
Try this: =OR(CROSSOVER(C,SG2),CROSSOVER(C,SG3)) |
[2023-04-24 13:55:05] |
Thank you that is awesome, worked like a charm. If I wanted it equal to rather than crossover do you know how I can do that? I.e the last price is equal To the high or low Many thanks for your time |
[2023-04-24 16:34:25] |
You would have to add another option to test the equal to option. Such as the following: =OR(CROSSOVER(C,SG2),CROSSOVER(C,SG3), C = SG2, C = SG3) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-04-25 21:26:32] |
Thank you both, worked.
