Date/Time: Thu, 28 Nov 2024 13:38:40 +0000
Chart isn't showing current data
View Count: 386
[2023-04-24 01:32:37] |
factorx - Posts: 3 |
Hi, I attached the link with a screenshot of my chart. Right now the chart data is stuck with the data from the end of last trading week. There should already be 2 new 4 hour candlesticks on the chart and there isn't so it's not showing the current price action/data feed. My data feed is on and connected it's green. What is the problem why I'm not getting current live price data feed and how do I fix it? Thanks https://www.sierrachart.com/image.php?Image=1682299780304.png |
[2023-04-24 04:05:50] |
Sierra_Chart Engineering - Posts: 17201 |
Refer to: FXCM Data Issue Sunday 2023-04-23 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
