Date/Time: Thu, 28 Nov 2024 13:57:36 +0000
Trial Extension Request
View Count: 282
[2023-04-24 00:00:37]
User654026 - Posts: 1
I was unable to make full usage out of my trial. Would it be possible to have my trial extended? Thank you so much for your consideration!
[2023-04-24 04:38:47]
Sierra_Chart Engineering - Posts: 17201
Your account has been activated and the usage time extended if necessary.
If Sierra Chart is running, it will automatically be activated within about three minutes. However, you may need to exit from the Sierra Chart charting and trading software by selecting "File >> Exit". And then open Sierra Chart through the icon on your desktop or through the desktop Start menu.
After your Sierra Chart usage time ends you need to pay for additional usage time through "Help >> Add Usage Credit".
