Date/Time: Tue, 26 Nov 2024 22:16:10 +0000
I have set up with CTS sim ,,,, they told me to contact you to have Sierra set
View Count: 963
[2014-06-22 23:34:05] |
User84455 - Posts: 32 |
How do I do so,,,,,you told me to contact CTS so I did so for free demo trial
[2014-06-23 02:03:30] |
Your Sierra Chart account will work with CTS T4. Your Sierra Chart account has usage time on it. You need to follow the setup instructions here to use CTS T4: http://www.sierrachart.com/index.php?l=doc/CTS_T4.php#SetupInstructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
