Date/Time: Thu, 28 Nov 2024 13:51:01 +0000
Replay mode
View Count: 275
[2023-04-22 17:00:38]
Tin43 - Posts: 90
Hi...
I was wondering if this feature is available...
In Replay mode if I have 2 charts in a Chartbook I can replay both independently.. for example one chart 5 minutes and the other one 15 minutes. But if i link the replay mode for the two charts is where i found "my problem" (in bar by bar mode) if i linked them, they will automatically skip to the next bar independently of the time...
Example... when it is 10:00 in a five minute chart, if i click one time, it skips to 10:05... but the 15 minute chart skips to 10:15. I'm 2 bars in advance in the 15 minute chart.
What I want to know if there is a way to advance in the lowest time frame chart but the other synchronize when the lowest TF chart reach the next bar in the Higher Tf chart.
Example.. it's 10:00 in the 5 minute chart and in the 15 minute chart.. (in bar by bar mode) I click 3 times in the 5 minute chart to reach 10:15, and THEN the 15 minute chart advance 1 bar (not 3) from 10:00 to 10:15.
You can say maybe i'm lazy, but i'm too focused on backtesting that it's a pain in my neck to remember when to synchronize the other chart. And not only that.. with that mode I "can see" the future.. iy you know what I mean.
I want to know if this is possible because i need it for 1MTF, 5MTF and 15MTF.. it's too much to be focused on for me.
Big thanks and apologies for my English.
[2023-04-24 08:19:43]
Tin43 - Posts: 90
Find the solution!
If this happens to you... use Replay Both charts but do NOT select bar by bar... Select the mode By time and set the time to the lowest time frame you are using in your charts!
