Date/Time: Tue, 26 Nov 2024 22:32:34 +0000
I have a problem. Please answer in Russian
View Count: 1258
[2014-06-22 22:05:04] |
User85106 - Posts: 2 |
I have a problem with the connection with the trial version rhythmic. is such a mistake http://SSMaker.ru/56b0822a/ |
[2014-06-23 02:43:00] |
Your account has been activated and/or reset. A restart is necessary if Sierra Chart is already running. Exit the Sierra Chart charting and trading software by selecting "File >> Exit". Open Sierra Chart through the icon on your desktop or through the desktop Start menu. We will provide a response in Russian as soon as we can. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-06-23 02:43:21
