Date/Time: Thu, 28 Nov 2024 13:34:18 +0000
Eurex Data incomplet
View Count: 338
[2023-04-22 06:07:27]
User956379 - Posts: 23
Hi Sierra Support, I've "paired" Sierra with IB so I can trade directly from the chart and don't have to connect to IB once a month to avoid any delayed data. So far, I have used the SC Data. I have also traded EUREX's FDAX with delayed data so far. This no longer seems possible? I now receive the data only very incompletely. What is this related to or what needs to be done to get the FDAX displayed correctly?
[2023-04-22 10:29:41]
Sierra_Chart Engineering - Posts: 17201
Activate the EUREX exchange through the Denali Data Feed:
Denali Exchange Data Feed: *Setup Instructions: All Other Exchanges*
After that:
Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". You just need to do this once per symbol and not for each chart.
[2023-04-22 10:49:48]
I dont want to activate the Eurex because i only need delayed Data from the Eurex. As i was connected with the SC Data and not with IB i get delayed Data from the Eurex.
I get incomplete data from the Eurex since i paired sierra with IB.
Is there any other solution to get complete delyed Data from Eurex i had as i used SC Data?
[2023-04-22 16:50:28]
Not while connected to Interactive Brokers. You need to use a separate installation of Sierra Chart set to use SC Data - All Services.
Refer to:
Using Multiple Data and Trading Services at the Same Time
Date Time Of Last Edit: 2023-04-22 16:51:28
