Date/Time: Thu, 28 Nov 2024 13:54:13 +0000
Trading DOM flatten and reverse functions do not work. (IBKR -> Sierra Chart Connection)
View Count: 392
[2023-04-21 17:11:57] |
JohnSmith24601 - Posts: 8 |
Hi, I have successfully connected IBKR's paper account to Sierra Chart. I can place orders from the trading DOM perfectly fine, as they do show up on my IBKR paper account and start accumulating unrealized profit/loss. However, it seems like the flatten and reverse functions on the trading DOM do not work for whatever reason. Currently if I want to flatten the positions, I need to do it via the "Trade Positions" window. But the downside of that is it asks for confirmation every time, which makes things super slow. Also, there is no reverse function on the Trade Positions window...
[2023-04-21 20:06:52] |
We wonder if this is somehow related to the fact that it is a "paper" account and not a live account. Please try the Flatten button again and after you do so, check your "Trade >> Trade Service Log" and see if states anything in there as to why the "Flatten" is not working. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-04-21 23:29:16] |
Ah okay, thanks! I'll try that with the live account later, as I'm still moving the funds around. Will come back to this thread in a few days!
[2023-04-25 10:25:34] |
Sierra_Chart Engineering - Posts: 17201 |
If the chart you are trading from does not show the position, then this would be the issue. Refer to: Interactive Brokers Trading Service: Trade Position Line or Quantity Disappearing or Displaying Zero Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
