Date/Time: Thu, 28 Nov 2024 15:35:28 +0000
quantity hotkey
View Count: 564
[2023-04-21 12:01:08] |
User175554 - Posts: 10 |
I've tried youtube as well as looking through replies on the support board and have found nothing regarding hotkey quantity. How would I create hotkeys for example " CTRL + B + 3" to buy 3 market. and "CTRL + S + 3" to sell market and so on? Thanks! |
[2023-04-21 12:19:52] |
Sierra_Chart Engineering - Posts: 17201 |
What you need to do is set up a keyboard shortcut for the Order Quantity buttons and then you configure those buttons for the quantities that you want to use. Refer to: Basic Trading and the Trade Window: Main/C >> Order Quantity Buttons Basic Trading and the Trade Window: Keyboard Shortcuts for Preset Order Quantities So you first need to change the Order Quantity and then you can use another keyboard shortcut for buy market or sell market. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
