Date/Time: Thu, 28 Nov 2024 15:41:43 +0000
Cann't change "Days to load" - Keeps going back to 120
View Count: 285
[2023-04-21 09:46:44]
User714262 - Posts: 8
When I change the Session start time to 08:59:59 and press "Apply all" it changes back to 08:30 after 1 second.
Same when I want to change the intraday days to 2 instead of 120, it updates / loading, and then 1 second late it updates/loading again and it's back to 120.
I also tried to change to an Intraday chart instead of an INtraday chart only, but it's the same thing, I also tried to search the forum if someone had this problem before but I did not find anything.
How can I make it less? My 1 min Footprint chart doesn't need 120 days in it.
https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=79690
imageimage2.png / V - Attached On 2023-04-21 09:40:59 UTC - Size: 115.44 KB - 76 views
[2023-04-21 10:37:23]
Sierra_Chart Engineering - Posts: 17201
That chart is being referenced by chart number 15. Refer to:
Unable to Change the Bar Time Period for Charts
