Date/Time: Thu, 28 Nov 2024 13:56:05 +0000
SetGraphicsSetting() GRAPHICS_SETTING_CHART_BACKGROUND = 3 not working
View Count: 483
[2023-04-21 04:51:53] |
User719512 - Posts: 267 |
Hi Sierra Engineering, According to latest release notes, the new API for GetGraphicsSetting()/SetGraphicsSetting() are now supported. My testing (using v2493) shows that GRAPHICS_SETTING_CHART_BACKGROUND is not setting the background color for the chart. Can you confirm this should be working? Also, are all enums in GraphicsSettingsEnum supported at this time? Thank you. Date Time Of Last Edit: 2023-04-21 15:05:21
[2023-04-21 08:00:39] |
Sierra_Chart Engineering - Posts: 17201 |
The function works properly but we know why there is a problem and we are resolving this now. It will no longer be possible to use sc structure member variables to set whether global graphic settings are used or not , or to change colors. These new functions must be used instead. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-04-21 12:44:59] |
Update Sierra Chart to the latest prerelease to resolve the issue.
[2023-04-21 15:38:02] |
Thank you for the quick fix on this. Works as expected now.
[2023-04-21 23:37:39] |
Tony - Posts: 522 |
what are the names of the new functions? I couldn't find them here: https://www.sierrachart.com/index.php?page=doc/ACSIL_Members_Functions.html Thanks so much! Date Time Of Last Edit: 2023-04-21 23:37:56
[2023-04-22 10:36:20] |
Here is more information about this in the version notes here: https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer2494 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
