Date/Time: Thu, 28 Nov 2024 15:47:46 +0000
Which package?
View Count: 281
[2023-04-20 22:07:55] |
Jack Tops - Posts: 2 |
Will the MBO package #12 cover the LIVE data feed for SPY and QQQ? What else would I need to get if not?
[2023-04-21 13:53:36] |
To get the live data for SPY and QQQ right now, you would need to be on one of the Integrated Packages (10, 11, or 12) and go through the Setup for the Denali Exchange Data Feed for the NASDAQ TotalView exchange. Follow the instructions here: Denali Exchange Data Feed: *Setup Instructions: All Other Exchanges* You only need Package 12 if you want to get the MBO data. Otherwise packages 10 and 11 give you the same data with Market Depth (just not MBO). Also be aware that we now have another U.S. Equities exchange option called "U.S. Equities Consolidated Tape". The reason you can not use this right now is that we do not have data for instruments that have their primary exchange as the NYSE or AMEX. We should have the NYSE within the next few days to a week. Also, this exchange does not have Market Depth information. It does have the advantage of having the full volumes from all exchanges for an instrument, whereas the NASDAQ TotalView only has volume information from the NASDAQ exchange itself. For more information on the NASDAQ TotalView exchange, refer to the following: Denali Exchange Data Feed: Nasdaq TotalView Data Feed Notes For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
