Date/Time: Thu, 28 Nov 2024 15:37:10 +0000
[Programming Help] - not working: skip BarIndex based on study input
View Count: 285
[2023-04-20 21:18:17] |
jomo88 - Posts: 47 |
why cant i specifiy the amount of bar indexes to skip based on an input? first code section works, second example does not with input_VARIABLE for (int BarIndex = sc.UpdateStartIndex; BarIndex < sc.ArraySize; BarIndex++) { if (BarIndex <= 100) { turn everything off (wait for moving averages to stabilize) } else { now let algo run } } ..... HOWEVER .... ..... the following code does not work... ............... for (int BarIndex = sc.UpdateStartIndex; BarIndex < sc.ArraySize; BarIndex++) { if (BarIndex <= input_VARIABLE) { turn everything off (wait for moving averages to stabilize) } else { now let algo run } } |
[2023-04-20 23:28:02] |
User719512 - Posts: 267 |
Have you tried: if (BarIndex <= input_VARIABLE.GetInt()) |
[2023-04-21 00:32:04] |
I had a bug But thank you for making me double check, I was able to spot it Cheers |
