Date/Time: Tue, 26 Nov 2024 22:35:10 +0000
OEC connection down?
View Count: 1044
[2014-06-22 10:28:07] |
RMF2 - Posts: 43 |
Is the OEC connection down, again? I'm getting these log entries when I try to connect: OEC FIX/FAST - Connecting to trading server prod.openecry.com:9400. | 2014-06-22 06:24:21 OEC FIX Trading socket (0) - Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-06-22 06:24:21 OEC FIX Trading socket (1008) - Connected. | 2014-06-22 06:24:21 OEC FIX Trading socket (1008) - Starting SSL connection. | 2014-06-22 06:24:21 OEC FIX Trading socket (1008) - SSL connection established. | 2014-06-22 06:24:22 OEC FIX Trading: Sending the Logon message. | 2014-06-22 06:24:22 OEC FIX Trading: Received a Logout message. | 2014-06-22 06:24:22 OEC FIX Trading: Sending a Logout message. Text = Received Logout message. | 2014-06-22 06:24:22 OEC FIX Trading socket (1008) - SSL shutdown indicates not able to send 'close notify'. | 2014-06-22 06:24:22 OEC FIX Trading socket (1008) - SSL has been shut down. | 2014-06-22 06:24:22 OEC FIX Trading socket (1008) - SSL object has been freed. SSL state is now disconnected. | 2014-06-22 06:24:22 OEC FIX Trading socket (1008) - Shutdown and closed. | 2014-06-22 06:24:22 OEC FIX Trading: Logged out and disconnected. | 2014-06-22 06:24:22 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-22 06:24:22 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-22 06:24:22 Disconnected from Open E Cry. | 2014-06-22 06:24:23 Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-22 06:24:23 Please advise. Thank you. |
[2014-06-22 15:49:25] |
Refer to this section here: http://www.sierrachart.com/index.php?l=doc/openecry.php#ServerAvailability Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
