Date/Time: Thu, 28 Nov 2024 15:39:21 +0000
How to link differently
View Count: 320
[2023-04-20 11:54:02] |
TopGunTrader - Posts: 172 |
Hi, I'm enjoying your linking especially with DOM and fast charts however I can't seem to link to other longer term charts with different scales. For example DOM set to constant 15 point range and tick/range/sec chart next to it linked and all works however I want to have a longer time frame chart 30m, 60m etc linked to the same scroll position however KEEP ITS OWN scale 15 point range on an hourly chart is ridiculous! How can I do this I've tried over and over and can't get the 60m chart to simply be in the same position as the DOM. Also when I hit hotkey to recenter DOM windows don't move until I scroll the DOM can't get hotkey to move all the linked windows instantly. |
[2023-04-20 12:20:21] |
Basically I want the current price lined up with other charts I might have 75 point scale on hourly chart and 25 point on 5 min chart.
[2023-04-20 14:50:55] |
You can do what you are wanting using the Linking functionality. You would have to set the Scale settings so that the current price is always centered. Refer to the following for how to do this: Chart Scale and Scale Adjusting: Constant Range Scale Modes >> Re-Center To The Last Price On Every Update For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
