Date/Time: Thu, 28 Nov 2024 15:39:07 +0000
Trade Dom Color Questions
View Count: 290
[2023-04-19 17:51:12] |
EquanimousTrading - Posts: 3 |
Graphics Settings: Trade Dom Ask Depth Quantities: How to make the text transparent? Graphics Settings: Trade Dom Values Scale Text (color of price): How to change the background of just this column? --- Volume By Price Study: how to make "Volume Numbers Text Color and Size" Transparent |
[2023-04-19 20:10:38] |
There is no option to make these transparent. Graphics Settings: Trade Dom Values Scale Text (color of price): How to change the background of just this column?
The price on the Trade DOM uses the "Trade DOM Text Color". There is not a single Background option for just the Price column. The Price column uses the general background of the Trade window (Trade DOM Background Color). But you will not see this unless you deselect the "Enable" option for these two items: - Trade DOM Ask Background - Trade DOM Bid Background You could then change the background for the other columns how you want them to be. Also, do not forget that if you are making the changes through the "Chart Specific" Graphics Options (Chart >> Graphics Options) that they will not apply unless you disable the option for "Use Global Graphics Settings Instead of These Settings". Refer to the following for the Trade DOM Graphics Settings: Customizing Fonts, Colors, Line Styles, and Widths for Chart Trading, Chart DOM, and Trade DOM: Trade DOM Colors, Line Styles, and Line Widths For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
