Date/Time: Thu, 28 Nov 2024 15:35:52 +0000
Custom Symbol
View Count: 334
[2023-04-19 14:06:29] |
User841161 - Posts: 221 |
Why does custom symbol chart only display to 16:00 and not entire 24 hours. It appears my start session time is 17:00 and my end session time is 16:59. My Custom symbol is 3*5{ESM23_FUT_CME}-2*2{NQM23__FUT_CME}. https://www.sierrachart.com/image.php?Image=1681912686742.png |
[2023-04-19 15:04:33] |
Please tell us the settings for the following items within "Chart >> Chart Settings >> Session Times": - Session Start Time: - Session End Time: - Use Evening Session: - Evening Start Time: - Evening End Time: For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-04-19 15:24:57] |
https://www.sierrachart.com/image.php?Image=1681917853986.png
[2023-04-20 10:21:44] |
Sierra_Chart Engineering - Posts: 17201 |
Is historical data set to be downloaded for the custom calculated symbol? Refer to: Custom Calculated Symbols: Instructions In particular step 11. Are you missing any historical data for the symbols which are part of the custom calculated symbols? Make sure the data is complete for those components symbols. Open charts for them showing the full 24 hours, and refer to if you need to download missing data for them: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Retrying the Download When There is Data in the Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-04-20 10:23:15
