Date/Time: Thu, 28 Nov 2024 15:55:27 +0000
Early testing of US equity consolidated tape data
View Count: 369
[2023-04-19 09:47:29] |
funbun - Posts: 90 |
I usually record a session of two data providers side by side and then analyze the video frame by frame. This lets me capture and measure the latency between the two. I measured the new SC stream against a competitor that's known to have a very stable and low latency feed (hint, rhymes with signal) Not only SC feed is much faster, sometimes I could spot the difference with a naked eye (more than 50ms) The discrepancy regarding the Bid/Ask lines on the chart is even larger, it actually feels like looking into the future :) We've waited long but it was definitely worth it, Bravo team. |
[2023-04-19 10:20:31] |
Sierra_Chart Engineering - Posts: 17201 |
Yes this all does make sense. It certainly is a low latency feed. We notice about a 150 ms improvement over the previous Sierra Chart Exchange Data Feed.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-04-19 10:20:37
