Date/Time: Mon, 16 Sep 2024 19:08:32 +0000
FlattenAndCancelAllOrders does not work in trade simulation mode
View Count: 1015
[2014-06-21 19:10:53] |
@sstfrederik - Posts: 404 |
FlattenAndCancelAllOrders in ACSIl is not working in TSM. Have an ACSIL script where it is called but not executed and also have a ACS button where it is not executed. In live mode it works fine, but when id want to backtest it fails. Any leads? Thanks. |
[2014-06-21 20:07:45] |
Make sure that sc.SendOrdersToTradeService is set to FALSE. Otherwise, it will get ignored when in Trade Simulation Mode. This is a recent change.
[2014-06-22 15:10:12] |
thanks. that solved it. if (sc.GlobalTradeSimulationIsOn == 1) { SendOrdersToService.SetYesNo(false); } |
