Date/Time: Thu, 28 Nov 2024 15:31:55 +0000
Locking zero line of 2 oscillators
View Count: 349
[2023-04-18 16:36:06] |
User75949 - Posts: 118 |
Does anyone knows how to lock the zero line of 2 oscillators as those (in the attached image) in region 2 ? I've put the left scale for the second indicator, but the point is that when you scroll the chart left or right and you encounter a large value the zero line doesn't coincide any more and you have to manually readjust the thing making it not actually usable... The 2 oscillators are a zig zag oscillator and a zig zag cumulative volume, but the problem appears for any other 2 oscillators together on the same region. In the next version it would be great to have a setting that lets you to lock the zero line. Anyway I hope someone has found a way to get the result already on what we have now. tks regards R. |
Attachment Deleted. 2023-04-18_18-26-59.jpg / V - Attached On 2023-04-18 16:28:29 UTC - Size: 309.22 KB - 75 views |
[2023-04-18 17:04:09] |
If you want to have the scale set so that it will not move up or down as you scroll, then refer to the following: Chart Scale and Scale Adjusting: Using Fixed Values for Top and Bottom of Scale Range For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-04-18 21:27:13] |
Tks for the suggestion, but unfortunately even if I put both the scales (left and right) on "Scale range: User defined with auto Set" , when I scroll the chart left and right they move by themself on "Scale Range: User Defined" and the zero line are not locked... everything still moves up and down..
[2023-04-18 22:34:10] |
Part of the issue is that the Left Side Scale does not work with regions other than the first one (main price graph region). But apart from that, you should be able to get the right-side scale to lock and not move when you scroll. This works just fine for us. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
