Date/Time: Thu, 28 Nov 2024 15:35:43 +0000
TWS/IB Connection Error
View Count: 655
[2023-04-18 15:19:09] |
User654047 - Posts: 11 |
Hello, I'm getting this error (below) while connecting to Interactive brokers for trading purposes. I have TWS Build 10.14.1c and this was downloaded today and most upto date that I can access from UK - I believe. Can you advise on this ? Ive followed all the setting details that i can see for SC connections to TWS/IB Interactive Brokers | Connecting to 127.0.0.1:7496 | 2023-04-18 10:13:58.573 IB TWS socket (9) | Creating socket. | 2023-04-18 10:13:58.573 IB TWS socket (9) | New receive buffer size: 5242880 | 2023-04-18 10:13:58.573 IB TWS socket (9) | Connecting to IP: 127.0.0.1. | 2023-04-18 10:13:58.573 Interactive Brokers | Sending API sign: API | 2023-04-18 10:13:59.085 Interactive Brokers | Sending client version: v100..176 +PACEAPI. Waiting for acceptance. | 2023-04-18 10:13:59.085 Interactive Brokers | TWS server version: 167 | 2023-04-18 10:13:59.089 Interactive Brokers | A newer version of Trader Workstation is required to connect. The minimum required TWS server version: 176 | 2023-04-18 10:13:59.089 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-04-18 10:13:59.089 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-04-18 10:13:59.089 IB TWS socket (9) | CloseSocket call. | 2023-04-18 10:13:59.114 Interactive Brokers | Disconnected. | 2023-04-18 10:13:59.114 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-04-18 10:13:59.114 IB TWS socket (9) | Shutdown started. Waiting for graceful close. | 2023-04-18 10:13:59.114 IB TWS socket (9) | Socket gracefully closed by remote side. | 2023-04-18 10:13:59.114 IB TWS socket (9) | Closed. | 2023-04-18 10:13:59.114 |
[2023-04-18 15:32:26] |
Sierra_Chart Engineering - Posts: 17201 |
If you are getting this error there must be a newer version available to you: Interactive Brokers | A newer version of Trader Workstation is required to connect. The minimum required TWS server version: 176 | 2023-04-18 10:13:59.089 *
It should not matter your location. The internal server version is going to be 176. Ask Interactive Brokers about this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-04-18 15:32:42
