Date/Time: Thu, 28 Nov 2024 16:38:57 +0000
First instalation problems.
View Count: 238
[2023-04-18 13:01:16] |
Andrej Bábsky - Posts: 3 |
Halo to evererybody, I am doing first installation of Sierra Chart. Can you help me please. When trying to download Sierra Chart software for first time, in the process a error message stops the download and is sayiny "Error saving downloaded files to local system. Stopping installation. Check log. Press 'install' to retry." My computer is ok. This link does not work: https://www.sierrachart.com/downloads/ZipFiles/SierraChart1928.zip Sincerly, Andrej |
Attachment Deleted. Private File |
[2023-04-18 13:04:44] |
Sierra_Chart Engineering - Posts: 17204 |
Install Sierra Chart using this zip installer: https://www.sierrachart.com/downloads/ZipFiles/SierraChart2493.zip Where are you trying to install Sierra Chart to on your system? It may be an incorrect location. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-04-18 13:04:53
