Date/Time: Thu, 28 Nov 2024 16:29:49 +0000
NUMBERS BARS study: Can you add the following option?
View Count: 298
[2023-04-18 07:25:49] |
User525997 - Posts: 20 |
In the study settings (ln:15) of Numbers Bars "Determine Maximum/Minimum Values for Coloring From" I would like to have the option "Visual Bars". Currently there is the option bar data or daily data. For multiple reasons e.g. an abnormal high volume or delta in one bar will have big visual effect when using the option daily data. Thank You. |
[2023-04-18 15:14:48] |
We have set this as a "Feature Request".
