Date/Time: Thu, 28 Nov 2024 15:54:15 +0000
Get value of grouped FlattoFlat Trades from Statistic or calculate it in Spreadsheet
View Count: 271
[2023-04-18 07:18:21] |
Bartezz - Posts: 18 |
Hi, i would like to limit Trade Counts per Day for ex. max 5 Trades (not Fills), how can i access FlattoFlat trades from Spreadsheet or Caluclate it byself? Or is there maybe another solution to Limit grouped Trades for Day in Spreadsheet? Regards Bartosz |
[2023-04-18 13:49:03] |
Sierra_Chart Engineering - Posts: 17201 |
We will check on this. We can add this to the Spreadsheet. A field, which indicates the number of flat to flat completed trades.
[2023-04-18 14:45:58] |
This is going to be added to an upcoming version in about a week or two.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-04-18 14:46:05
[2023-04-18 19:00:41] |
Great! Thank you very much!!!
