Date/Time: Thu, 28 Nov 2024 13:56:07 +0000
Denali data
View Count: 350
[2023-04-17 22:25:48] |
User831355 - Posts: 14 |
Subject updated from 'Sierra technical support' to 'Denali data' -------------------------------------------------------------------------------- Hi , I Do not get daily volume by end of daily session ....Thks |
[2023-04-18 01:59:32] |
Sierra_Chart Engineering - Posts: 17201 |
Can you provide us a screenshot of what you are seeing regarding this so we can understand this better: I Do not get daily volume by end of daily session
[2023-04-23 07:37:00] |
https://www.sierrachart.com/image.php?Image=1682235167788.png This is an image for my daily chart , note that volume after session close volume is not shown . Daily volume value after morning session is very important to me , i get it in my trading view account. |
[2023-04-23 13:53:02] |
We do not know why there is no volume for the latest day for that symbol, but we would expect it to be available, by Monday morning.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-04-23 13:53:22
[2023-04-23 21:50:49] |
Pl ask server data Denali to add the volume by end of daily session as other servers do . If they fail , then I will change to other server. |
[2023-04-24 04:41:59] |
This data is not from the Denali Data Feed. It comes from another data provider.
