Date/Time: Thu, 28 Nov 2024 15:47:39 +0000
The Denali Data Feed is active, why do I see delayed data?
View Count: 525
[2023-04-17 19:13:30] |
User840964 - Posts: 46 |
"The Denali Data Feed is active", why do I see delayed data? On SPY for example? |
[2023-04-18 03:50:10] |
Sierra_Chart Engineering - Posts: 17201 |
What is one of the symbols that is delayed?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-04-18 03:50:19
[2023-04-18 07:58:57] |
On 17 April way before 04:00 PM EDT, when the U.S. market was still open, every symbol I was watching showed "DD: 02:00:??(delayed)". Some of them are: SPY, SPX500, SCHW, BABA. |
[2023-04-18 09:03:33] |
Right now you can only get the real-time data for NASDAQ stock symbols. And you need to append -USCT to the end. For example: SCHW-USCT Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-04-18 09:03:46
[2023-04-18 13:07:37] |
Using the -USCT suffix I can't get data under 60 minutes, the program shows the error as to the attached image. When I subscibed for data someone of your colleages told me to use the -NQTV suffix. |
USCT-SC.png / V - Attached On 2023-04-18 13:07:05 UTC - Size: 13.35 KB - 84 views |
[2023-04-18 13:16:00] |
You are running an old version of Sierra Chart. You must update to the latest version. Instructions: Software Download: Fast Update We are mistaken. You do need to use the suffix -NQTV. Use that suffix. Not -USCT. We did not correctly interpret the exchange you had active on your account. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-04-18 13:17:56
[2023-04-18 14:04:26] |
Updated to the latest version, now the market is running its main session and nothing has changed.
[2023-04-18 14:46:54] |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. Tell us about *one* symbol only. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-04-18 15:06:11] |
Software version: 2492 64-bit | 2023-04-18 17:03:14.183 Primary Thread ID: 1252 | 2023-04-18 17:03:14.183 Usage end date: 2023-05-05 | 2023-04-18 17:03:14.183 Enabled for: Sierra Chart Historical Data Service. | 2023-04-18 17:03:14.183 Enabled for: Denali Real-Time Exchange Data Feed. | 2023-04-18 17:03:14.183 Enabled for: Delayed Denali Exchange Data Feed. | 2023-04-18 17:03:14.183 Enabled for exchange2: fairx_exchange.data | 2023-04-18 17:03:14.183 Enabled for exchange2: NASDAQ US stock data | 2023-04-18 17:03:14.183 Allow Support for Sierra Chart Data Feeds is enabled. | 2023-04-18 17:03:14.183 Current selected Data/Trading service: SC Data - All Services | 2023-04-18 17:03:14.183 Custom symbol settings values: enabled | 2023-04-18 17:03:14.183 Chart Update Interval: 500 | 2023-04-18 17:03:14.183 Intraday Data Storage Time Unit: 1 | 2023-04-18 17:03:14.183 Time Zone: +00:00:00 (UTC+00) | 2023-04-18 17:03:14.183 2023-04-18 17:03:14 Local computer time in UTC | 2023-04-18 17:03:14.183 2023-04-18 17:03:14 Local computer time in SC Time Zone | 2023-04-18 17:03:14.183 2023-04-18 13:27:05 Server time in UTC | 2023-04-18 17:03:14.183 Local computer UTC time and Server UTC time difference: 7248 seconds. | 2023-04-18 17:03:14.183 Notice: Your computer's clock is off by 7248 seconds. For help with this, press the 'Send for Analysis' button. | 2023-04-18 17:03:14.183 Program path: C:\Program Files (x86)\SierraChart\ | 2023-04-18 17:03:14.183 Data Files path: C:\Program Files (x86)\SierraChart\Data\ | 2023-04-18 17:03:14.183 OS Version Number: 10.0 | 2023-04-18 17:03:14.183 Locale Setting: C | 2023-04-18 17:03:14.183 DLLs: BABB-a5_64.dll, BABB-a9_64.dll, BABB-b4_64.dll, BABB-g12_64.dll, BABB-g7_64.dll, BABB-h2_64.dll, BABB-m10_64.dll, BABB-n11_64.dll, BABB-n8_64.dll, BABB-p3_64.dll, BABB-r1_64.dll, BABB-t13_64.dll, BABB-t6_64.dll, CFG_64.dll, Hopen_64.dll, Sk1_64.dll, Sk5_64.dll, SkD_64.dll, SkS15_64.dll, SkW_64.dll, Tx_64.dll, UserContributedStudies_64.dll, z0416-a35_64.dll, z0416-c13_64.dll, z0416-e15_64.dll, z0416-f31_64.dll, z0416-g5_64.dll, z0416-h2_64.dll, z0416-i9_64.dll, z0416-l14_64.dll, z0416-l16_64.dll, z0416-l30_64.dll | 2023-04-18 17:03:14.184 Allowed protected custom studies: | 2023-04-18 17:03:14.184 Crash reporter started: true | 2023-04-18 17:03:14.184 MARA-NQTV 5 Min #1 | Reloading chart. | 2023-04-18 17:03:23.265 MARA-NQTV Daily #2 | Reloading chart. | 2023-04-18 17:03:23.291 MARA-NQTV Weekly #3 | Reloading chart. | 2023-04-18 17:03:23.303 MARA-NQTV Daily #4 | Reloading chart. | 2023-04-18 17:03:23.306 Added historical Daily data request for MARA-NQTV to the queue. | 2023-04-18 17:03:23.792 Triggering next historical data download in queue. | 2023-04-18 17:03:23.792 HD Request # 55 | Downloading Historical Daily chart data for MARA-NQTV. Starting date: 2023-04-13. Service: nasdaq_exchange.data | 2023-04-18 17:03:23.796 HD Request # 55 | Requesting historical Daily data for MARA starting at 2023-04-12. SC External HD service. | 2023-04-18 17:03:24.287 HD Request # 55 | Receiving historical Daily data for MARA-NQTV starting at 2023-04-13. | 2023-04-18 17:03:24.852 HD Request # 55 | Writing historical Daily data to the file MARA-NQTV.dly. | 2023-04-18 17:03:24.852 HD Request # 55 | Bytes received: 194 | 2023-04-18 17:03:24.858 HD Request # 55 | Received 4 Daily data records from 2023-04-13 00:00:00 to 2023-04-17 00:00:00 (5.0 days) and wrote 3 records for MARA-NQTV | 2023-04-18 17:03:24.858 HD Request # 55 | Completion time: 1s. | 2023-04-18 17:03:24.858 HD Request # 55 | Daily data download complete for MARA-NQTV. Unique request ID: 55 | 2023-04-18 17:03:24.858 Removing historical data download ID 55. | 2023-04-18 17:03:24.858 Triggering next historical data download in queue. | 2023-04-18 17:03:24.858 No download requests in the queue to start downloads for. | 2023-04-18 17:03:24.858 MARA-NQTV[M] Daily #2 | Reloading chart. | 2023-04-18 17:03:25.292 MARA-NQTV[M] Weekly #3 | Reloading chart. | 2023-04-18 17:03:25.313 MARA-NQTV[M] Daily #4 | Reloading chart. | 2023-04-18 17:03:25.318 SC Data - All Services | Connected to server complete. | 2023-04-18 17:05:03.319 Triggering next historical data download in queue. | 2023-04-18 17:05:03.319 Triggering next historical data download in queue. | 2023-04-18 17:05:03.319 Triggering next historical data download in queue. | 2023-04-18 17:05:03.319 Triggering next historical data download in queue. | 2023-04-18 17:05:03.319 Subscribing to symbol for symbol alert. KWEB-NQTV | 2023-04-18 17:05:03.319 Mapping KWEB-NQTV to KWEB-NQTV. Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Using symbol data fast lookup vector | 2023-04-18 17:05:03.319 Denali Data Feed | Starting real-time market data updates for: KWEB-NQTV (KWEB-NQTV). ID: 1 Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Connecting to the server ds25.sierracharts.com. Port 443 | 2023-04-18 17:05:03.319 Denali Data Feed | Requesting security definition data for: KWEB-NQTV (KWEB-NQTV). ID: 1 | 2023-04-18 17:05:03.319 Subscribing to symbol for symbol alert. KWEB-NQTV | 2023-04-18 17:05:03.319 Subscribing to symbol for symbol alert. TSLA-NQTV | 2023-04-18 17:05:03.319 Mapping TSLA-NQTV to TSLA-NQTV. Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Starting real-time market data updates for: TSLA-NQTV (TSLA-NQTV). ID: 2 Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Requesting security definition data for: TSLA-NQTV (TSLA-NQTV). ID: 2 | 2023-04-18 17:05:03.319 Subscribing to symbol for symbol alert. SPY-NQTV | 2023-04-18 17:05:03.319 Mapping SPY-NQTV to SPY-NQTV. Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Starting real-time market data updates for: SPY-NQTV (SPY-NQTV). ID: 3 Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Requesting security definition data for: SPY-NQTV (SPY-NQTV). ID: 3 | 2023-04-18 17:05:03.319 Subscribing to symbol for symbol alert. META-NQTV | 2023-04-18 17:05:03.319 Mapping META-NQTV to META-NQTV. Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Starting real-time market data updates for: META-NQTV (META-NQTV). ID: 4 Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Requesting security definition data for: META-NQTV (META-NQTV). ID: 4 | 2023-04-18 17:05:03.319 Subscribing to symbol for symbol alert. IWM-NQTV | 2023-04-18 17:05:03.319 Mapping IWM-NQTV to IWM-NQTV. Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Starting real-time market data updates for: IWM-NQTV (IWM-NQTV). ID: 5 Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Requesting security definition data for: IWM-NQTV (IWM-NQTV). ID: 5 | 2023-04-18 17:05:03.319 Subscribing to symbol for symbol alert. KRE-NQTV | 2023-04-18 17:05:03.319 Mapping KRE-NQTV to KRE-NQTV. Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Starting real-time market data updates for: KRE-NQTV (KRE-NQTV). ID: 6 Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Requesting security definition data for: KRE-NQTV (KRE-NQTV). ID: 6 | 2023-04-18 17:05:03.319 Subscribing to symbol for symbol alert. AAPL-NQTV | 2023-04-18 17:05:03.319 Mapping AAPL-NQTV to AAPL-NQTV. Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Starting real-time market data updates for: AAPL-NQTV (AAPL-NQTV). ID: 7 Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Requesting security definition data for: AAPL-NQTV (AAPL-NQTV). ID: 7 | 2023-04-18 17:05:03.319 Subscribing to symbol for symbol alert. BABA-NQTV | 2023-04-18 17:05:03.319 Mapping BABA-NQTV to BABA-NQTV. Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Starting real-time market data updates for: BABA-NQTV (BABA-NQTV). ID: 8 Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Requesting security definition data for: BABA-NQTV (BABA-NQTV). ID: 8 | 2023-04-18 17:05:03.319 Subscribing to symbol for symbol alert. C-NQTV | 2023-04-18 17:05:03.319 Mapping C-NQTV to C-NQTV. Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Starting real-time market data updates for: C-NQTV (C-NQTV). ID: 9 Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Requesting security definition data for: C-NQTV (C-NQTV). ID: 9 | 2023-04-18 17:05:03.319 Subscribing to symbol for symbol alert. WFC-NQTV | 2023-04-18 17:05:03.319 Mapping WFC-NQTV to WFC-NQTV. Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Starting real-time market data updates for: WFC-NQTV (WFC-NQTV). ID: 10 Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Requesting security definition data for: WFC-NQTV (WFC-NQTV). ID: 10 | 2023-04-18 17:05:03.319 Subscribing to symbol for symbol alert. GDX-NQTV | 2023-04-18 17:05:03.319 Mapping GDX-NQTV to GDX-NQTV. Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Starting real-time market data updates for: GDX-NQTV (GDX-NQTV). ID: 11 Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Requesting security definition data for: GDX-NQTV (GDX-NQTV). ID: 11 | 2023-04-18 17:05:03.319 Subscribing to symbol for symbol alert. XLF-NQTV | 2023-04-18 17:05:03.319 Mapping XLF-NQTV to XLF-NQTV. Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Starting real-time market data updates for: XLF-NQTV (XLF-NQTV). ID: 12 Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Requesting security definition data for: XLF-NQTV (XLF-NQTV). ID: 12 | 2023-04-18 17:05:03.319 Subscribing to symbol for symbol alert. EWZ-NQTV | 2023-04-18 17:05:03.319 Mapping EWZ-NQTV to EWZ-NQTV. Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Starting real-time market data updates for: EWZ-NQTV (EWZ-NQTV). ID: 13 Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Requesting security definition data for: EWZ-NQTV (EWZ-NQTV). ID: 13 | 2023-04-18 17:05:03.319 Subscribing to symbol for symbol alert. MARA-NQTV | 2023-04-18 17:05:03.319 Mapping MARA-NQTV to MARA-NQTV. Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Starting real-time market data updates for: MARA-NQTV (MARA-NQTV). ID: 14 Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Requesting security definition data for: MARA-NQTV (MARA-NQTV). ID: 14 | 2023-04-18 17:05:03.319 Subscribing to symbol for symbol alert. GOLD-NQTV | 2023-04-18 17:05:03.319 Mapping GOLD-NQTV to GOLD-NQTV. Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Starting real-time market data updates for: GOLD-NQTV (GOLD-NQTV). ID: 15 Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Requesting security definition data for: GOLD-NQTV (GOLD-NQTV). ID: 15 | 2023-04-18 17:05:03.319 Subscribing to symbol for symbol alert. SLV-NQTV | 2023-04-18 17:05:03.319 Mapping SLV-NQTV to SLV-NQTV. Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Starting real-time market data updates for: SLV-NQTV (SLV-NQTV). ID: 16 Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Requesting security definition data for: SLV-NQTV (SLV-NQTV). ID: 16 | 2023-04-18 17:05:03.319 Subscribing to symbol for symbol alert. QQQ-NQTV | 2023-04-18 17:05:03.319 Mapping QQQ-NQTV to QQQ-NQTV. Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Starting real-time market data updates for: QQQ-NQTV (QQQ-NQTV). ID: 17 Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Requesting security definition data for: QQQ-NQTV (QQQ-NQTV). ID: 17 | 2023-04-18 17:05:03.319 Subscribing to symbol for symbol alert. IAU-NQTV | 2023-04-18 17:05:03.319 Mapping IAU-NQTV to IAU-NQTV. Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Starting real-time market data updates for: IAU-NQTV (IAU-NQTV). ID: 18 Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Requesting security definition data for: IAU-NQTV (IAU-NQTV). ID: 18 | 2023-04-18 17:05:03.319 Subscribing to symbol for symbol alert. XLE-NQTV | 2023-04-18 17:05:03.319 Mapping XLE-NQTV to XLE-NQTV. Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Starting real-time market data updates for: XLE-NQTV (XLE-NQTV). ID: 19 Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Requesting security definition data for: XLE-NQTV (XLE-NQTV). ID: 19 | 2023-04-18 17:05:03.319 Subscribing to symbol for symbol alert. PBR-NQTV | 2023-04-18 17:05:03.319 Mapping PBR-NQTV to PBR-NQTV. Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Starting real-time market data updates for: PBR-NQTV (PBR-NQTV). ID: 20 Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Requesting security definition data for: PBR-NQTV (PBR-NQTV). ID: 20 | 2023-04-18 17:05:03.319 Subscribing to symbol for symbol alert. CCL-NQTV | 2023-04-18 17:05:03.319 Mapping CCL-NQTV to CCL-NQTV. Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Starting real-time market data updates for: CCL-NQTV (CCL-NQTV). ID: 21 Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Requesting security definition data for: CCL-NQTV (CCL-NQTV). ID: 21 | 2023-04-18 17:05:03.319 Subscribing to symbol for symbol alert. FXI-NQTV | 2023-04-18 17:05:03.319 Mapping FXI-NQTV to FXI-NQTV. Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Starting real-time market data updates for: FXI-NQTV (FXI-NQTV). ID: 22 Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Requesting security definition data for: FXI-NQTV (FXI-NQTV). ID: 22 | 2023-04-18 17:05:03.319 Subscribing to symbol for symbol alert. AMD-NQTV | 2023-04-18 17:05:03.319 Mapping AMD-NQTV to AMD-NQTV. Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Starting real-time market data updates for: AMD-NQTV (AMD-NQTV). ID: 23 Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Requesting security definition data for: AMD-NQTV (AMD-NQTV). ID: 23 | 2023-04-18 17:05:03.319 Subscribing to symbol for symbol alert. AMD-NQTV | 2023-04-18 17:05:03.319 Subscribing to symbol for symbol alert. MU-NQTV | 2023-04-18 17:05:03.319 Mapping MU-NQTV to MU-NQTV. Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Starting real-time market data updates for: MU-NQTV (MU-NQTV). ID: 24 Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Requesting security definition data for: MU-NQTV (MU-NQTV). ID: 24 | 2023-04-18 17:05:03.319 Subscribing to symbol for symbol alert. TEVA-NQTV | 2023-04-18 17:05:03.319 Mapping TEVA-NQTV to TEVA-NQTV. Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Starting real-time market data updates for: TEVA-NQTV (TEVA-NQTV). ID: 25 Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Requesting security definition data for: TEVA-NQTV (TEVA-NQTV). ID: 25 | 2023-04-18 17:05:03.319 Subscribing to symbol for symbol alert. JD-NQTV | 2023-04-18 17:05:03.319 Mapping JD-NQTV to JD-NQTV. Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Starting real-time market data updates for: JD-NQTV (JD-NQTV). ID: 26 Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Requesting security definition data for: JD-NQTV (JD-NQTV). ID: 26 | 2023-04-18 17:05:03.319 Subscribing to symbol for symbol alert. ARKK-NQTV | 2023-04-18 17:05:03.319 Mapping ARKK-NQTV to ARKK-NQTV. Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Starting real-time market data updates for: ARKK-NQTV (ARKK-NQTV). ID: 27 Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Requesting security definition data for: ARKK-NQTV (ARKK-NQTV). ID: 27 | 2023-04-18 17:05:03.319 Subscribing to symbol for symbol alert. ARKK-NQTV | 2023-04-18 17:05:03.319 Subscribing to symbol for symbol alert. PLUG-NQTV | 2023-04-18 17:05:03.319 Mapping PLUG-NQTV to PLUG-NQTV. Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Starting real-time market data updates for: PLUG-NQTV (PLUG-NQTV). ID: 28 Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Requesting security definition data for: PLUG-NQTV (PLUG-NQTV). ID: 28 | 2023-04-18 17:05:03.319 Subscribing to symbol for symbol alert. PFE-NQTV | 2023-04-18 17:05:03.319 Mapping PFE-NQTV to PFE-NQTV. Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Starting real-time market data updates for: PFE-NQTV (PFE-NQTV). ID: 29 Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Requesting security definition data for: PFE-NQTV (PFE-NQTV). ID: 29 | 2023-04-18 17:05:03.319 Subscribing to symbol for symbol alert. PFE-NQTV | 2023-04-18 17:05:03.319 Subscribing to symbol for symbol alert. CSCO-NQTV | 2023-04-18 17:05:03.319 Mapping CSCO-NQTV to CSCO-NQTV. Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Starting real-time market data updates for: CSCO-NQTV (CSCO-NQTV). ID: 30 Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Requesting security definition data for: CSCO-NQTV (CSCO-NQTV). ID: 30 | 2023-04-18 17:05:03.319 Subscribing to symbol for symbol alert. CSCO-NQTV | 2023-04-18 17:05:03.319 Subscribing to symbol for symbol alert. BABA-NQTV | 2023-04-18 17:05:03.319 Subscribing to symbol for symbol alert. GPS-NQTV | 2023-04-18 17:05:03.319 Mapping GPS-NQTV to GPS-NQTV. Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Starting real-time market data updates for: GPS-NQTV (GPS-NQTV). ID: 31 Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Requesting security definition data for: GPS-NQTV (GPS-NQTV). ID: 31 | 2023-04-18 17:05:03.319 Subscribing to symbol for symbol alert. KRE-NQTV | 2023-04-18 17:05:03.319 Subscribing to symbol for symbol alert. RIOT-NQTV | 2023-04-18 17:05:03.319 Mapping RIOT-NQTV to RIOT-NQTV. Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Starting real-time market data updates for: RIOT-NQTV (RIOT-NQTV). ID: 32 Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Requesting security definition data for: RIOT-NQTV (RIOT-NQTV). ID: 32 | 2023-04-18 17:05:03.319 Subscribing to symbol for symbol alert. CPNG-NQTV | 2023-04-18 17:05:03.319 Mapping CPNG-NQTV to CPNG-NQTV. Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Starting real-time market data updates for: CPNG-NQTV (CPNG-NQTV). ID: 33 Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Requesting security definition data for: CPNG-NQTV (CPNG-NQTV). ID: 33 | 2023-04-18 17:05:03.319 Subscribing to symbol for symbol alert. CPNG-NQTV | 2023-04-18 17:05:03.319 Subscribing to symbol for symbol alert. NVDA-NQTV | 2023-04-18 17:05:03.319 Mapping NVDA-NQTV to NVDA-NQTV. Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Starting real-time market data updates for: NVDA-NQTV (NVDA-NQTV). ID: 34 Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Requesting security definition data for: NVDA-NQTV (NVDA-NQTV). ID: 34 | 2023-04-18 17:05:03.319 Subscribing to symbol for symbol alert. KGC-NQTV | 2023-04-18 17:05:03.319 Mapping KGC-NQTV to KGC-NQTV. Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Starting real-time market data updates for: KGC-NQTV (KGC-NQTV). ID: 35 Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Requesting security definition data for: KGC-NQTV (KGC-NQTV). ID: 35 | 2023-04-18 17:05:03.319 Subscribing to symbol for symbol alert. TSLA-NQTV | 2023-04-18 17:05:03.319 Subscribing to symbol for symbol alert. AAPL-NQTV | 2023-04-18 17:05:03.319 Subscribing to symbol for symbol alert. PEP-NQTV | 2023-04-18 17:05:03.319 Mapping PEP-NQTV to PEP-NQTV. Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Starting real-time market data updates for: PEP-NQTV (PEP-NQTV). ID: 36 Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Requesting security definition data for: PEP-NQTV (PEP-NQTV). ID: 36 | 2023-04-18 17:05:03.319 Subscribing to symbol for symbol alert. EEM-NQTV | 2023-04-18 17:05:03.319 Mapping EEM-NQTV to EEM-NQTV. Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Starting real-time market data updates for: EEM-NQTV (EEM-NQTV). ID: 37 Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Requesting security definition data for: EEM-NQTV (EEM-NQTV). ID: 37 | 2023-04-18 17:05:03.319 Subscribing to symbol for symbol alert. EEM-NQTV | 2023-04-18 17:05:03.319 Subscribing to symbol for symbol alert. SPY-NQTV | 2023-04-18 17:05:03.319 Subscribing to symbol for symbol alert. QQQ-NQTV | 2023-04-18 17:05:03.319 Subscribing to symbol for symbol alert. IWM-NQTV | 2023-04-18 17:05:03.319 Subscribing to symbol for symbol alert. JPM-NQTV | 2023-04-18 17:05:03.319 Mapping JPM-NQTV to JPM-NQTV. Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Starting real-time market data updates for: JPM-NQTV (JPM-NQTV). ID: 38 Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Requesting security definition data for: JPM-NQTV (JPM-NQTV). ID: 38 | 2023-04-18 17:05:03.319 Subscribing to symbol for symbol alert. JPM-NQTV | 2023-04-18 17:05:03.319 Subscribing to symbol for symbol alert. XLE-NQTV | 2023-04-18 17:05:03.319 Subscribing to symbol for symbol alert. JD-NQTV | 2023-04-18 17:05:03.319 Subscribing to symbol for symbol alert. WFC-NQTV | 2023-04-18 17:05:03.319 Subscribing to symbol for symbol alert. GDX-NQTV | 2023-04-18 17:05:03.319 Subscribing to symbol for symbol alert. PLUG-NQTV | 2023-04-18 17:05:03.319 Subscribing to symbol for symbol alert. EWZ-NQTV | 2023-04-18 17:05:03.319 Subscribing to symbol for symbol alert. FXI-NQTV | 2023-04-18 17:05:03.319 Subscribing to symbol for symbol alert. AMC-NQTV | 2023-04-18 17:05:03.319 Mapping AMC-NQTV to AMC-NQTV. Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Starting real-time market data updates for: AMC-NQTV (AMC-NQTV). ID: 39 Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Requesting security definition data for: AMC-NQTV (AMC-NQTV). ID: 39 | 2023-04-18 17:05:03.319 Subscribing to symbol for symbol alert. AMC-NQTV | 2023-04-18 17:05:03.319 Subscribing to symbol for symbol alert. GOLD-NQTV | 2023-04-18 17:05:03.319 Subscribing to symbol for symbol alert. CCL-NQTV | 2023-04-18 17:05:03.319 Subscribing to symbol for symbol alert. XLF-NQTV | 2023-04-18 17:05:03.319 Subscribing to symbol for symbol alert. SLV-NQTV | 2023-04-18 17:05:03.319 Subscribing to symbol for symbol alert. PLTR-NQTV | 2023-04-18 17:05:03.319 Mapping PLTR-NQTV to PLTR-NQTV. Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Starting real-time market data updates for: PLTR-NQTV (PLTR-NQTV). ID: 40 Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Requesting security definition data for: PLTR-NQTV (PLTR-NQTV). ID: 40 | 2023-04-18 17:05:03.319 Subscribing to symbol for symbol alert. PLTR-NQTV | 2023-04-18 17:05:03.319 Subscribing to symbol for symbol alert. PBR-NQTV | 2023-04-18 17:05:03.319 Subscribing to symbol for symbol alert. NVDA-NQTV | 2023-04-18 17:05:03.319 Subscribing to symbol for symbol alert. MU-NQTV | 2023-04-18 17:05:03.319 Subscribing to symbol for symbol alert. GLD-NQTV | 2023-04-18 17:05:03.319 Mapping GLD-NQTV to GLD-NQTV. Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Starting real-time market data updates for: GLD-NQTV (GLD-NQTV). ID: 41 Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Requesting security definition data for: GLD-NQTV (GLD-NQTV). ID: 41 | 2023-04-18 17:05:03.319 Subscribing to symbol for symbol alert. GLD-NQTV | 2023-04-18 17:05:03.319 Subscribing to symbol for symbol alert. XBI-NQTV | 2023-04-18 17:05:03.319 Mapping XBI-NQTV to XBI-NQTV. Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Starting real-time market data updates for: XBI-NQTV (XBI-NQTV). ID: 42 Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Requesting security definition data for: XBI-NQTV (XBI-NQTV). ID: 42 | 2023-04-18 17:05:03.319 Subscribing to symbol for symbol alert. XBI-NQTV | 2023-04-18 17:05:03.319 Subscribing to symbol for symbol alert. XLV-NQTV | 2023-04-18 17:05:03.319 Mapping XLV-NQTV to XLV-NQTV. Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Starting real-time market data updates for: XLV-NQTV (XLV-NQTV). ID: 43 Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Requesting security definition data for: XLV-NQTV (XLV-NQTV). ID: 43 | 2023-04-18 17:05:03.319 Subscribing to symbol for symbol alert. XLV-NQTV | 2023-04-18 17:05:03.319 Subscribing to symbol for symbol alert. TLT-NQTV | 2023-04-18 17:05:03.319 Mapping TLT-NQTV to TLT-NQTV. Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.319 Denali Data Feed | Starting real-time market data updates for: TLT-NQTV (TLT-NQTV). ID: 44 Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.320 Denali Data Feed | Requesting security definition data for: TLT-NQTV (TLT-NQTV). ID: 44 | 2023-04-18 17:05:03.320 Subscribing to symbol for symbol alert. TLT-NQTV | 2023-04-18 17:05:03.320 Subscribing to symbol for symbol alert. UPST-NQTV | 2023-04-18 17:05:03.320 Mapping UPST-NQTV to UPST-NQTV. Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.320 Denali Data Feed | Starting real-time market data updates for: UPST-NQTV (UPST-NQTV). ID: 45 Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.320 Denali Data Feed | Requesting security definition data for: UPST-NQTV (UPST-NQTV). ID: 45 | 2023-04-18 17:05:03.320 Subscribing to symbol for symbol alert. UPST-NQTV | 2023-04-18 17:05:03.320 Subscribing to symbol for symbol alert. CHPT-NQTV | 2023-04-18 17:05:03.320 Mapping CHPT-NQTV to CHPT-NQTV. Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.320 Denali Data Feed | Starting real-time market data updates for: CHPT-NQTV (CHPT-NQTV). ID: 46 Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.320 Denali Data Feed | Requesting security definition data for: CHPT-NQTV (CHPT-NQTV). ID: 46 | 2023-04-18 17:05:03.320 Subscribing to symbol for symbol alert. CHPT-NQTV | 2023-04-18 17:05:03.320 Subscribing to symbol for symbol alert. NCLH-NQTV | 2023-04-18 17:05:03.320 Mapping NCLH-NQTV to NCLH-NQTV. Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.320 Denali Data Feed | Starting real-time market data updates for: NCLH-NQTV (NCLH-NQTV). ID: 47 Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.320 Denali Data Feed | Requesting security definition data for: NCLH-NQTV (NCLH-NQTV). ID: 47 | 2023-04-18 17:05:03.320 Subscribing to symbol for symbol alert. NCLH-NQTV | 2023-04-18 17:05:03.320 Subscribing to symbol for symbol alert. IAU-NQTV | 2023-04-18 17:05:03.320 Subscribing to symbol for symbol alert. LAZR-NQTV | 2023-04-18 17:05:03.320 Mapping LAZR-NQTV to LAZR-NQTV. Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.320 Denali Data Feed | Starting real-time market data updates for: LAZR-NQTV (LAZR-NQTV). ID: 48 Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.320 Denali Data Feed | Requesting security definition data for: LAZR-NQTV (LAZR-NQTV). ID: 48 | 2023-04-18 17:05:03.320 Subscribing to symbol for symbol alert. LAZR-NQTV | 2023-04-18 17:05:03.320 Subscribing to symbol for symbol alert. C-NQTV | 2023-04-18 17:05:03.320 Subscribing to symbol for symbol alert. GPS-NQTV | 2023-04-18 17:05:03.320 Subscribing to symbol for symbol alert. KGC-NQTV | 2023-04-18 17:05:03.320 Subscribing to symbol for symbol alert. MARA-NQTV | 2023-04-18 17:05:03.320 Subscribing to symbol for symbol alert. RIOT-NQTV | 2023-04-18 17:05:03.320 Subscribing to symbol for symbol alert. TEVA-NQTV | 2023-04-18 17:05:03.320 Subscribing to symbol for symbol alert. META-NQTV | 2023-04-18 17:05:03.320 Subscribing to symbol for symbol alert. SHOP-NQTV | 2023-04-18 17:05:03.320 Mapping SHOP-NQTV to SHOP-NQTV. Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.320 Denali Data Feed | Starting real-time market data updates for: SHOP-NQTV (SHOP-NQTV). ID: 49 Service code: nasdaq_exchange.data | 2023-04-18 17:05:03.320 Denali Data Feed | Requesting security definition data for: SHOP-NQTV (SHOP-NQTV). ID: 49 | 2023-04-18 17:05:03.320 Subscribing to symbol for symbol alert. SHOP-NQTV | 2023-04-18 17:05:03.320 Notice: Not connected to Live trading account to receive CME realtime futures data at non-professional fees. | 2023-04-18 17:05:03.320 No download requests in the queue to start downloads for. | 2023-04-18 17:05:03.321 No download requests in the queue to start downloads for. | 2023-04-18 17:05:03.321 No download requests in the queue to start downloads for. | 2023-04-18 17:05:03.321 No download requests in the queue to start downloads for. | 2023-04-18 17:05:03.321 DTC Client socket (2) | Creating socket. | 2023-04-18 17:05:03.325 DTC Client socket (2) | New receive buffer size: 5242880 | 2023-04-18 17:05:03.326 DTC Client socket (2) | Connecting to IP: 38.65.8.115. | 2023-04-18 17:05:03.326 Denali Data Feed | Network connection to server complete. | 2023-04-18 17:05:03.469 Denali Data Feed | Starting socket receive thread. | 2023-04-18 17:05:03.469 Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high | 2023-04-18 17:05:03.469 Denali Data Feed | Setting DTC encoding to Binary VLS | 2023-04-18 17:05:03.608 Denali Data Feed | Sending logon request message. | 2023-04-18 17:05:03.608 Added historical Intraday data request for MARA-NQTV to the queue. | 2023-04-18 17:05:03.765 Intraday data recording state for symbol MARA-NQTV is set to download 'Pending'. | 2023-04-18 17:05:03.765 Triggering next historical data download in queue. | 2023-04-18 17:05:03.765 Delaying start of download for MARA-NQTV. | 2023-04-18 17:05:03.770 Denali Data Feed | Received logon response. | 2023-04-18 17:05:04.324 Denali Data Feed | Server Name: SC Realtime Server. | 2023-04-18 17:05:04.324 Denali Data Feed | Server protocol version: 8. Client protocol version: 8 | 2023-04-18 17:05:04.324 Denali Data Feed | Successfully connected. | 2023-04-18 17:05:04.324 Denali Data Feed | Trading is not supported. | 2023-04-18 17:05:04.324 Denali Data Feed | Restarting real-time data updates for symbol: AAPL-NQTV -> AAPL-NQTV | 2023-04-18 17:05:04.324 Denali Data Feed | Restarting real-time data updates for symbol: AMC-NQTV -> AMC-NQTV | 2023-04-18 17:05:04.324 Denali Data Feed | Restarting real-time data updates for symbol: AMD-NQTV -> AMD-NQTV | 2023-04-18 17:05:04.324 Denali Data Feed | Restarting real-time data updates for symbol: ARKK-NQTV -> ARKK-NQTV | 2023-04-18 17:05:04.324 Denali Data Feed | Restarting real-time data updates for symbol: BABA-NQTV -> BABA-NQTV | 2023-04-18 17:05:04.324 Denali Data Feed | Restarting real-time data updates for symbol: C-NQTV -> C-NQTV | 2023-04-18 17:05:04.324 Denali Data Feed | Restarting real-time data updates for symbol: CCL-NQTV -> CCL-NQTV | 2023-04-18 17:05:04.324 Denali Data Feed | Restarting real-time data updates for symbol: CHPT-NQTV -> CHPT-NQTV | 2023-04-18 17:05:04.324 Denali Data Feed | Restarting real-time data updates for symbol: CPNG-NQTV -> CPNG-NQTV | 2023-04-18 17:05:04.324 Denali Data Feed | Restarting real-time data updates for symbol: CSCO-NQTV -> CSCO-NQTV | 2023-04-18 17:05:04.324 Denali Data Feed | Restarting real-time data updates for symbol: EEM-NQTV -> EEM-NQTV | 2023-04-18 17:05:04.324 Denali Data Feed | Restarting real-time data updates for symbol: EWZ-NQTV -> EWZ-NQTV | 2023-04-18 17:05:04.324 Denali Data Feed | Restarting real-time data updates for symbol: FXI-NQTV -> FXI-NQTV | 2023-04-18 17:05:04.324 Denali Data Feed | Restarting real-time data updates for symbol: GDX-NQTV -> GDX-NQTV | 2023-04-18 17:05:04.324 Denali Data Feed | Restarting real-time data updates for symbol: GLD-NQTV -> GLD-NQTV | 2023-04-18 17:05:04.324 Denali Data Feed | Restarting real-time data updates for symbol: GOLD-NQTV -> GOLD-NQTV | 2023-04-18 17:05:04.324 Denali Data Feed | Restarting real-time data updates for symbol: GPS-NQTV -> GPS-NQTV | 2023-04-18 17:05:04.324 Denali Data Feed | Restarting real-time data updates for symbol: IAU-NQTV -> IAU-NQTV | 2023-04-18 17:05:04.324 Denali Data Feed | Restarting real-time data updates for symbol: IWM-NQTV -> IWM-NQTV | 2023-04-18 17:05:04.324 Denali Data Feed | Restarting real-time data updates for symbol: JD-NQTV -> JD-NQTV | 2023-04-18 17:05:04.324 Denali Data Feed | Restarting real-time data updates for symbol: JPM-NQTV -> JPM-NQTV | 2023-04-18 17:05:04.324 Denali Data Feed | Restarting real-time data updates for symbol: KGC-NQTV -> KGC-NQTV | 2023-04-18 17:05:04.324 Denali Data Feed | Restarting real-time data updates for symbol: KRE-NQTV -> KRE-NQTV | 2023-04-18 17:05:04.324 Denali Data Feed | Restarting real-time data updates for symbol: KWEB-NQTV -> KWEB-NQTV | 2023-04-18 17:05:04.324 Denali Data Feed | Restarting real-time data updates for symbol: LAZR-NQTV -> LAZR-NQTV | 2023-04-18 17:05:04.324 Denali Data Feed | Restarting real-time data updates for symbol: MARA-NQTV -> MARA-NQTV | 2023-04-18 17:05:04.324 Denali Data Feed | Restarting real-time data updates for symbol: META-NQTV -> META-NQTV | 2023-04-18 17:05:04.324 Denali Data Feed | Restarting real-time data updates for symbol: MU-NQTV -> MU-NQTV | 2023-04-18 17:05:04.324 Denali Data Feed | Restarting real-time data updates for symbol: NCLH-NQTV -> NCLH-NQTV | 2023-04-18 17:05:04.324 Denali Data Feed | Restarting real-time data updates for symbol: NVDA-NQTV -> NVDA-NQTV | 2023-04-18 17:05:04.324 Denali Data Feed | Restarting real-time data updates for symbol: PBR-NQTV -> PBR-NQTV | 2023-04-18 17:05:04.324 Denali Data Feed | Restarting real-time data updates for symbol: PEP-NQTV -> PEP-NQTV | 2023-04-18 17:05:04.324 Denali Data Feed | Restarting real-time data updates for symbol: PFE-NQTV -> PFE-NQTV | 2023-04-18 17:05:04.324 Denali Data Feed | Restarting real-time data updates for symbol: PLTR-NQTV -> PLTR-NQTV | 2023-04-18 17:05:04.324 Denali Data Feed | Restarting real-time data updates for symbol: PLUG-NQTV -> PLUG-NQTV | 2023-04-18 17:05:04.324 Denali Data Feed | Restarting real-time data updates for symbol: QQQ-NQTV -> QQQ-NQTV | 2023-04-18 17:05:04.324 Denali Data Feed | Restarting real-time data updates for symbol: RIOT-NQTV -> RIOT-NQTV | 2023-04-18 17:05:04.324 Denali Data Feed | Restarting real-time data updates for symbol: SHOP-NQTV -> SHOP-NQTV | 2023-04-18 17:05:04.324 Denali Data Feed | Restarting real-time data updates for symbol: SLV-NQTV -> SLV-NQTV | 2023-04-18 17:05:04.324 Denali Data Feed | Restarting real-time data updates for symbol: SPY-NQTV -> SPY-NQTV | 2023-04-18 17:05:04.324 Denali Data Feed | Restarting real-time data updates for symbol: TEVA-NQTV -> TEVA-NQTV | 2023-04-18 17:05:04.324 Denali Data Feed | Restarting real-time data updates for symbol: TLT-NQTV -> TLT-NQTV | 2023-04-18 17:05:04.324 Denali Data Feed | Restarting real-time data updates for symbol: TSLA-NQTV -> TSLA-NQTV | 2023-04-18 17:05:04.324 Denali Data Feed | Restarting real-time data updates for symbol: UPST-NQTV -> UPST-NQTV | 2023-04-18 17:05:04.324 Denali Data Feed | Restarting real-time data updates for symbol: WFC-NQTV -> WFC-NQTV | 2023-04-18 17:05:04.324 Denali Data Feed | Restarting real-time data updates for symbol: XBI-NQTV -> XBI-NQTV | 2023-04-18 17:05:04.324 Denali Data Feed | Restarting real-time data updates for symbol: XLE-NQTV -> XLE-NQTV | 2023-04-18 17:05:04.324 Denali Data Feed | Restarting real-time data updates for symbol: XLF-NQTV -> XLF-NQTV | 2023-04-18 17:05:04.324 Denali Data Feed | Restarting real-time data updates for symbol: XLV-NQTV -> XLV-NQTV | 2023-04-18 17:05:04.324 Denali Data Feed | Received security definition for symbol AAPL-NQTV | 2023-04-18 17:05:04.558 Denali Data Feed | Received security definition for symbol AMC-NQTV | 2023-04-18 17:05:04.558 Denali Data Feed | Received security definition for symbol AMD-NQTV | 2023-04-18 17:05:04.558 Denali Data Feed | Received security definition for symbol ARKK-NQTV | 2023-04-18 17:05:04.558 Denali Data Feed | Received security definition for symbol BABA-NQTV | 2023-04-18 17:05:04.558 Denali Data Feed | Received security definition for symbol C-NQTV | 2023-04-18 17:05:04.558 Denali Data Feed | Received security definition for symbol CCL-NQTV | 2023-04-18 17:05:04.558 Denali Data Feed | Received security definition for symbol CHPT-NQTV | 2023-04-18 17:05:04.558 Denali Data Feed | Received security definition for symbol CPNG-NQTV | 2023-04-18 17:05:04.558 Denali Data Feed | Received security definition for symbol CSCO-NQTV | 2023-04-18 17:05:04.558 Denali Data Feed | Received security definition for symbol EEM-NQTV | 2023-04-18 17:05:04.558 Denali Data Feed | Received security definition for symbol EWZ-NQTV | 2023-04-18 17:05:04.674 Denali Data Feed | Received security definition for symbol FXI-NQTV | 2023-04-18 17:05:04.674 Denali Data Feed | Received security definition for symbol GDX-NQTV | 2023-04-18 17:05:04.674 Denali Data Feed | Received security definition for symbol GLD-NQTV | 2023-04-18 17:05:04.674 Denali Data Feed | Received security definition for symbol GOLD-NQTV | 2023-04-18 17:05:04.674 Denali Data Feed | Received security definition for symbol GPS-NQTV | 2023-04-18 17:05:04.674 Denali Data Feed | Received security definition for symbol IAU-NQTV | 2023-04-18 17:05:04.674 Denali Data Feed | Received security definition for symbol IWM-NQTV | 2023-04-18 17:05:04.674 Denali Data Feed | Received security definition for symbol JD-NQTV | 2023-04-18 17:05:04.674 Denali Data Feed | Received security definition for symbol JPM-NQTV | 2023-04-18 17:05:04.674 Denali Data Feed | Received security definition for symbol KGC-NQTV | 2023-04-18 17:05:04.674 Denali Data Feed | Received security definition for symbol KRE-NQTV | 2023-04-18 17:05:04.803 Denali Data Feed | Received security definition for symbol KWEB-NQTV | 2023-04-18 17:05:04.803 Denali Data Feed | Received security definition for symbol LAZR-NQTV | 2023-04-18 17:05:04.803 Denali Data Feed | Received security definition for symbol MARA-NQTV | 2023-04-18 17:05:04.803 Denali Data Feed | Received security definition for symbol META-NQTV | 2023-04-18 17:05:04.803 Denali Data Feed | Received security definition for symbol MU-NQTV | 2023-04-18 17:05:04.803 Denali Data Feed | Received security definition for symbol NCLH-NQTV | 2023-04-18 17:05:04.803 Denali Data Feed | Received security definition for symbol NVDA-NQTV | 2023-04-18 17:05:04.803 Denali Data Feed | Received security definition for symbol PBR-NQTV | 2023-04-18 17:05:04.803 Denali Data Feed | Received security definition for symbol PEP-NQTV | 2023-04-18 17:05:04.803 Denali Data Feed | Received security definition for symbol PFE-NQTV | 2023-04-18 17:05:04.803 Denali Data Feed | Received security definition for symbol PLTR-NQTV | 2023-04-18 17:05:04.803 Denali Data Feed | Received security definition for symbol PLUG-NQTV | 2023-04-18 17:05:04.803 Denali Data Feed | Received security definition for symbol QQQ-NQTV | 2023-04-18 17:05:04.803 Denali Data Feed | Received security definition for symbol RIOT-NQTV | 2023-04-18 17:05:04.803 Denali Data Feed | Received security definition for symbol SHOP-NQTV | 2023-04-18 17:05:04.803 Denali Data Feed | Received security definition for symbol SLV-NQTV | 2023-04-18 17:05:04.803 Denali Data Feed | Received security definition for symbol SPY-NQTV | 2023-04-18 17:05:04.803 Denali Data Feed | Received security definition for symbol TEVA-NQTV | 2023-04-18 17:05:04.803 Denali Data Feed | Received security definition for symbol TLT-NQTV | 2023-04-18 17:05:04.803 Denali Data Feed | Received security definition for symbol TSLA-NQTV | 2023-04-18 17:05:04.803 Denali Data Feed | Received security definition for symbol UPST-NQTV | 2023-04-18 17:05:04.803 Denali Data Feed | Received security definition for symbol WFC-NQTV | 2023-04-18 17:05:04.803 Denali Data Feed | Received security definition for symbol XBI-NQTV | 2023-04-18 17:05:04.803 Denali Data Feed | Received security definition for symbol XLE-NQTV | 2023-04-18 17:05:04.803 Denali Data Feed | Received security definition for symbol XLF-NQTV | 2023-04-18 17:05:04.803 Denali Data Feed | Received security definition for symbol XLV-NQTV | 2023-04-18 17:05:04.803 HD Request # 56 | Downloading Intraday chart data for MARA-NQTV to the file MARA-NQTV.scid. Service: nasdaq_exchange.data | 2023-04-18 17:05:09.002 HD Request # 56 | Download start date-time: 2023-04-18 15:02:07.000000. File last date-time: 2023-04-18 15:02:07.000000 | 2023-04-18 17:05:09.002 HD Request # 56 | Using server: ds25.sierracharts.com port 10150 | 2023-04-18 17:05:09.002 Socket (3) | Creating socket. | 2023-04-18 17:05:09.002 Socket (3) | New receive buffer size: 5242880 | 2023-04-18 17:05:09.002 Socket (3) | Connecting to IP: 38.65.8.115. | 2023-04-18 17:05:09.002 HD Request # 56 | Setting DTC encoding to Binary VLS | 2023-04-18 17:05:09.273 HD Request # 56 | Sending historical data logon request message. | 2023-04-18 17:05:09.273 HD Request # 56 | Requesting Intraday data. Start date-time: 2023-04-18 15:02:07. Record interval: 1. Symbol: MARA-NQTV | 2023-04-18 17:05:09.813 HD Request # 56 | Decompressing data. | 2023-04-18 17:05:09.944 HD Request # 56 | Receiving Intraday data for MARA-NQTV starting at 2023-04-18 15:02:07.415000 | 2023-04-18 17:05:09.953 Socket (3) | CloseSocket call. | 2023-04-18 17:05:09.953 Socket (3) | Shutdown started. Waiting for graceful close. | 2023-04-18 17:05:09.954 Historical data download thread signaled to stop. | 2023-04-18 17:05:09.954 HD Request # 56 | Timestamp of first Intraday data file record written: 2023-04-18 15:02:07.415000. | 2023-04-18 17:05:09.954 HD Request # 56 | Received 28 Intraday data records from 2023-04-18 15:02:07.415000 to 2023-04-18 15:04:00.047000 (112.6 seconds. Delay: 2.0 hours) and wrote 28 records for MARA-NQTV | 2023-04-18 17:05:09.954 HD Request # 56 | Add time&sales data | Remembered last file record date-time: 2023-04-18 15:04:00.047000 | 2023-04-18 17:05:09.954 HD Request # 56 | Completion time: 0s. | 2023-04-18 17:05:09.954 HD Request # 56 | Intraday data download complete for MARA-NQTV. Unique request ID: 56 | 2023-04-18 17:05:09.954 Removing historical data download ID 56. | 2023-04-18 17:05:09.954 Real-time Intraday chart data file updates started for MARA-NQTV | 2023-04-18 17:05:09.954 Opened cached Intraday file: C:\Program Files (x86)\SierraChart\Data\MARA-NQTV.scid. Thread ID: 1252 | 2023-04-18 17:05:09.954 Intraday chart data file opened for MARA-NQTV | 2023-04-18 17:05:09.954 HD Request # 56 | Enabling Intraday chart updating for symbol. | 2023-04-18 17:05:09.954 Triggering next historical data download in queue. | 2023-04-18 17:05:09.954 No download requests in the queue to start downloads for. | 2023-04-18 17:05:09.954 Socket (3) | Socket gracefully closed by remote side. | 2023-04-18 17:05:10.093 Socket (3) | Closed. | 2023-04-18 17:05:10.093 DTC Client socket (1) | Timed out waiting for shutdown. Performing an immediate socket close. | 2023-04-18 17:05:17.065 DTC Client socket (1) | Closed. | 2023-04-18 17:05:17.065 |
[2023-04-19 03:55:51] |
We do not see any problems in this Message Log. If a chart is not updating, refer to: Intraday Chart or Chart Bars Not Updating | Blank Intraday Chart | "Currently no data to display" message for Intraday Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-04-19 03:56:04
[2023-04-19 06:48:27] |
I always keep 16 to 20 charts open together. What seemed odd to me is that *all of them* show "DD: 02:00:??(delayed)" during the market main session.
[2023-04-19 08:11:20] |
Local computer UTC time and Server UTC time difference: 7248 seconds. | 2023-04-18 17:03:14.183 Notice: Your computer's clock is off by 7248 seconds. Refer to help topic 38: Incorrect Date and/or Time Display, Missing Historical Intraday Data, Chart Not Updating Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-04-19 08:12:35
