Date/Time: Thu, 28 Nov 2024 16:44:19 +0000
Quote Spreadsheet Settings - Fields Missing
View Count: 243
[2023-04-17 19:00:02]
Luchs - Posts: 21
When I go to Quote Spreadsheet Settings then I can't find a lot of the fields which are described on https://www.sierrachart.com/index.php?page=doc/GettingQuotes.html#FieldDescriptions. Nor on the left nor on the right side.
For instance, I can't find Percent from High, and all the Comments are missing. Also Daily Range per Ticks/Currency etc. I do not find. What could be the reason?
[2023-04-18 03:45:24]
Sierra_Chart Engineering - Posts: 17204
These fields are not supported on Quote Spreadsheets.
