Date/Time: Thu, 28 Nov 2024 16:48:31 +0000
[Programming Help] - STUDY VALUES NOT SHOWING IN COMPACT TOOL VALUES WINDOW
View Count: 301
[2023-04-17 11:49:27] |
User725605 - Posts: 60 |
I tried the user discussion forum without success. So, I am now trying Programming please. Any studies on my chart in the subgraphs below price when clicked on are NOT showing any value in my Compact Tool Value Window. This option was working fine a few days ago and mysteriously stopped. Please kindly advise how to get the values from all studies in all subgraphs below price to show again in the tools value window. |
[2023-04-17 12:30:44] |
Sierra_Chart Engineering - Posts: 17204 |
Do you see the study values in the Window >> Chart Values Window?
[2023-04-17 13:03:23] |
In the Chart Values Window... yes and they are moving but I cannot hover over them to see the changes as per below or when I had the Compact Tools Value Window up top on my charts working. I also see them in the TOOLS Value Window and here I can see the dynamic changes as I hover over the study. |
[2023-04-17 13:39:45] |
Can you provide us the chart that you are working with where this issue is occurring by following these instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-04-17 14:53:36] |
File attached
TEST FOR SIERRA.Cht - Attached On 2023-04-17 14:52:53 UTC - Size: 4.17 KB - 239 views |
[2023-04-17 17:07:47] |
Check that the option for Tools >> Tool Settings >> Chart Values >> Compact Tool Values Window Shows Chart Region 1 Values Only is set to Yes. Refer to the information here: Chart Drawing Tools: Compact Tool Values Window Shows Chart Region 1 Values Only (Tool Settings >> Chart Values >> Chart Values) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
