Date/Time: Wed, 15 Jan 2025 12:57:12 +0000
[User Discussion] - Market session statistics
View Count: 1887
[2014-06-21 06:11:07]
User11644 - Posts: 16
This kind of session analysis functionality would be very useful addition to the excellent Sierra Chart software. Would Sierra be able to implement similar indicators to the ones referenced here:
http://www.linnsoft.com/homework
IRT makes it relatively easy for a trader to see how often a market closes gaps etc without needing to learn how to code. Please consider adding similar functionality or tutorials on how this can be done with Sierra.
[2014-06-23 17:19:47]
Is this something you would consider?
[2014-06-23 18:06:02]
ganz - Posts: 1048
hi
I used I/RT for years, so ...
in order to be honest would you ask Mr. Linn to add some trading functionality to IR/T vs SC already has?
cheers ...
[2014-06-23 18:51:51]
Sorry but I don't understand the question. I'm a big fan off Sierra and hope to use and pay for this software for a long time. I do see value in the advanced market stats in my link hence my request for SC to consider something similar.
[2014-06-23 19:19:42]
ganz - Posts: 1048
User11644
the thread was marked as [User Discussion] so we can talk
also in case you will be more specific then somebody could bring you some help, imho
[2014-06-23 19:30:52]
Happy to talk. I am looking for statistics including the following:
- Change By Day Of Week
- How often does price gap up or down on a given instrument ? And when it does, how often is that gap closed?
- What is the maximum distance that price moves from the open of the day session each day?
- What is the average max move?
- What is the median max move?
- How often does price open in previous days range?
- When opening opening in range, how often does it touch both the previous days high and low?
Many thanks
[2014-06-24 01:24:12]
ganz - Posts: 1048
User11644
what are exact equations/formulas ?
[2014-06-25 06:09:24]
Thanks for your help. I will try to find the equations/formulas and post an update.
[2017-06-28 19:39:50]
User565119 - Posts: 33
Was there ever an update on this? Would love some of these statistics.
