Date/Time: Thu, 28 Nov 2024 16:38:09 +0000
[Programming Help] - Is it possible to connect data for Stock Options from Interactive Broker to Sierra Chart?
View Count: 278
[2023-04-16 13:16:21]
User328099 - Posts: 14
Is it possible to connect stock options data from Interactive brokers to Sierra Chart so I can use it and trade on Sierra chart (if yes) can it be done while using Sierra Charts Stock data (both at the same time)?
there was this ticket: Stocks & options trading with Sierra charts which stated: "With Interactive Brokers options you are going to have a lot of difficulties with that which we will not help with." It was not clear what that means, does this means its your system supports this but its hard due to configurations, or does this mean Sierra chart does not support stock options data to populate on Sierra Chart from Interactive Brokers?
Date Time Of Last Edit: 2023-04-16 14:32:54
