Date/Time: Thu, 28 Nov 2024 16:30:55 +0000
Show order fills not working in Rithmic account set up.
View Count: 445
[2023-04-16 12:39:52] |
User910963 - Posts: 80 |
I have started trading with a Rithmic and I can no longer see my order fills even though its checked. I have referred to the documentation to no avail yet. Any ideas?
[2023-04-17 15:27:57] |
Are the Order Fills actually showing in the Trade Activity Log? Refer to the following: Trade Activity Log: Viewing Historical Trade Activity For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-04-18 02:00:44] |
Yes they are showing in the TAL.
[2023-04-18 02:02:24] |
I'd like to see a graphical representation of the order fills if possible. I was told it was a limitation with my current set up but I'd like the closest thing.
[2023-04-18 15:00:46] |
If the fills are present in the Trade Activity Log, then you should be able to see them on the chart. Refer to the following: Chart Trading and the Chart DOM: Displaying Order Fills on the Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
