Date/Time: Thu, 28 Nov 2024 16:53:49 +0000
I can't deactivate Color Candlestick High-Low Using the Outline Colors
View Count: 311
[2023-04-15 22:34:38] |
ayobo21 - Posts: 11 |
[2023-04-17 15:15:15] |
You can only make this change on the Global Graphics Settings. Make sure you are opening Global Settings >> Graphics Settings and then select the Other tab and make the change there.
