Date/Time: Thu, 28 Nov 2024 15:48:26 +0000
[User Discussion] - Ray not stable: anchor points moved forward automatically
View Count: 334
[2023-04-14 22:16:38]
User809555 - Posts: 11
this post is meant to help the users and maybe the Sierra Chart team.
I want to point out an issue I've found today which I didn't read explicitly written in this webpage:
Lines/Rays or Other Chart Drawings Move After Drawing Them
So this problem occurred to me in a H1 chart(1 hour chart). I saw a big difference between yesterday and today in the placement of the green trend line. See picture 1 and 2(sorry for the upload but I couldn't do otherwise).
Basically what I think happened is that at least the 1st anchor point got automatically moved forward since it belonged to a day no longer loaded by the chart because it had "days to load" set to 30. Unfortunately in pic number 3 you can't see the 1st anchor point but only the 2nd since I've made a bad screenshot at the time(and now I've changed the chart settings loading 60 days) but I can assure you that both the 1st and the 2nd anchor points were anchored "nowhere", touching nothing at all, and it's impossible I could have done that. The fact is I've drawn those rays at the beginning of the contract, so that is more than 30 days ago. I double checked and I saw that the trend began on 13th of March(maybe 1 or 2 day earlier).
I hope this will be of help.
image1.jpg / V - Attached On 2023-04-14 21:46:45 UTC - Size: 433.43 KB - 84 views
image2.jpg / V - Attached On 2023-04-14 21:46:53 UTC - Size: 510.11 KB - 66 views
image3.jpg / V - Attached On 2023-04-14 21:47:03 UTC - Size: 482.33 KB - 69 views
