Date/Time: Tue, 26 Nov 2024 22:33:54 +0000
Problem With Replay of CL With SC Data
View Count: 1494
[2014-06-20 23:31:06]
ged - Posts: 233
Replay of CL is very poor, not sure why.
I have SC Tick Data. The replay is insufferably slow. When it does finally move it jumps ahead a full five minute bar. In other words, it is not useable in this condition.
I've not encountered this before and don't know how to fix it.
[2014-06-21 04:54:58]
You need to be sure you have tick by tick data in the data file. Refer to this page:
http://www.sierrachart.com/index.php?l=doc/doc_TickbyTickDataConfiguration.php
Since you are using the Sierra Chart Exchange Data Feed, you will get historical Intraday tick by tick data even when not connected to the main trading service.
Since it is the weekend, to ensure you get the data from the Sierra Chart Exchange Data Feed, select File >> Disconnect.
And re-download the data according to the instructions we have linked to.
[2014-06-22 03:42:15]
ged - Posts: 233
Actually, the settings prescribed in the link above were (and are) the settings that I am using.
For whatever reason(s), when I enter the replay environment and to to a past date, whether a couple of months ago or earlier in June, the replay just appears to be frozen.
I can manually make it skip to the next bar, but that is all.
[2014-06-22 05:17:47]
What is the symbol of the chart?
Do you have enabled one of the Continuous Contract options in Chart >> Chart Settings? If not, then what you see would make sense.
Refer to:
http://www.sierrachart.com/index.php?l=doc/doc_ContinuousFuturesContractCharts.html
[2014-06-22 20:00:33]
ged - Posts: 233
Apparently I do not have the continuous contract settings set properly.
I have six charts in this chart book; have re-downloaded tick data for each chart; and set the the continuous options setting to "volume based rollover - back adjusted".
I want to do a replay just 10 days back, so set days to download for each chart to 10 days.
The replay is still not working properly; each bar is very slow/intermittent.
I expect I still do not have some setting(s) properly set.
Here is the Message Log:
Software version: 1143 | 2014-06-22 09:08:32
Usage end date: 2014-07-31 | 2014-06-22 09:08:32
Enabled for: Advanced Features. | 2014-06-22 09:08:32
Enabled for: Sierra Chart Historical Data Service. | 2014-06-22 09:08:32
Enabled for: Sierra Chart Real-Time Exchange Data Feed. | 2014-06-22 09:08:32
Enabled for: CME, CBOT, NYMEX, COMEX exchanges. | 2014-06-22 09:08:32
Enabled for: US EQUITIES exchanges. | 2014-06-22 09:08:32
Received 1 data feed usernames. | 2014-06-22 09:08:32
Allow Support for Sierra Chart Data Feeds is enabled. | 2014-06-22 09:08:32
Active service: Interactive Brokers | 2014-06-22 09:08:32
Time Zone: -07:00:00 (PST-08PDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2014-06-22 09:08:32
2014-06-22 09:08:32 Local computer clock time | 2014-06-22 09:08:32
2014-06-22 16:08:32 GMT time | 2014-06-22 09:08:32
2014-06-22 09:08:32 Time zone adjusted time | 2014-06-22 09:08:32
Time difference to server time: 0 seconds. | 2014-06-22 09:08:32
Program path: C:\SierraChart\ | 2014-06-22 09:08:32
Data Files path: C:\SierraChart\Data\ | 2014-06-22 09:08:32
OS Version Number: 6.1 | 2014-06-22 09:08:32
Checking for new symbol settings for ib | 2014-06-22 09:08:32
Symbol settings are up-to-date for ib | 2014-06-22 09:08:32
Date rule based rollover from CL-201308-NYMEX to next contract occurs at 2013-07-19 | 2014-06-22 09:08:50
Date rule based rollover from CL-201309-NYMEX to next contract occurs at 2013-08-19 | 2014-06-22 09:08:50
Date rule based rollover from CL-201310-NYMEX to next contract occurs at 2013-09-19 | 2014-06-22 09:08:50
Date rule based rollover from CL-201311-NYMEX to next contract occurs at 2013-10-21 | 2014-06-22 09:08:50
Date rule based rollover from CL-201312-NYMEX to next contract occurs at 2013-11-19 | 2014-06-22 09:08:50
Date rule based rollover from CL-201401-NYMEX to next contract occurs at 2013-12-19 | 2014-06-22 09:08:50
Date rule based rollover from CL-201402-NYMEX to next contract occurs at 2014-01-20 | 2014-06-22 09:08:50
Date rule based rollover from CL-201403-NYMEX to next contract occurs at 2014-02-19 | 2014-06-22 09:08:50
Date rule based rollover from CL-201404-NYMEX to next contract occurs at 2014-03-19 | 2014-06-22 09:08:50
Date rule based rollover from CL-201405-NYMEX to next contract occurs at 2014-04-21 | 2014-06-22 09:08:50
Date rule based rollover from CL-201406-NYMEX to next contract occurs at 2014-05-19 | 2014-06-22 09:08:50
Date rule based rollover from CL-201407-NYMEX to next contract occurs at 2014-06-19 | 2014-06-22 09:08:50
Date rule based rollover from CL-201408-NYMEX to next contract occurs at 2014-07-21 | 2014-06-22 09:08:50
Checking Intraday data file for symbol CL-201308-NYMEX for the date range from 2013-06-19 to 2013-07-19 | 2014-06-22 09:08:50
Checking Daily data file for symbol CLQ13 for the date range from 2013-06-19 to 2013-07-19 | 2014-06-22 09:08:50
Checking Intraday data file for symbol CL-201309-NYMEX for the date range from 2013-07-19 to 2013-08-19 | 2014-06-22 09:08:50
Checking Daily data file for symbol CLU13 for the date range from 2013-07-19 to 2013-08-19 | 2014-06-22 09:08:50
Checking Intraday data file for symbol CL-201310-NYMEX for the date range from 2013-08-19 to 2013-09-19 | 2014-06-22 09:08:50
Checking Daily data file for symbol CLV13 for the date range from 2013-08-19 to 2013-09-19 | 2014-06-22 09:08:50
Checking Intraday data file for symbol CL-201311-NYMEX for the date range from 2013-09-19 to 2013-10-21 | 2014-06-22 09:08:50
Checking Daily data file for symbol CLX13 for the date range from 2013-09-19 to 2013-10-21 | 2014-06-22 09:08:50
Checking Intraday data file for symbol CL-201312-NYMEX for the date range from 2013-10-21 to 2013-11-19 | 2014-06-22 09:08:50
Checking Daily data file for symbol CLZ13 for the date range from 2013-10-21 to 2013-11-19 | 2014-06-22 09:08:50
Checking Intraday data file for symbol CL-201401-NYMEX for the date range from 2013-11-19 to 2013-12-19 | 2014-06-22 09:08:50
Checking Daily data file for symbol CLF14 for the date range from 2013-11-19 to 2013-12-19 | 2014-06-22 09:08:50
Checking Intraday data file for symbol CL-201402-NYMEX for the date range from 2013-12-19 to 2014-01-20 | 2014-06-22 09:08:50
Checking Daily data file for symbol CLG14 for the date range from 2013-12-19 to 2014-01-20 | 2014-06-22 09:08:50
Checking Intraday data file for symbol CL-201403-NYMEX for the date range from 2014-01-20 to 2014-02-19 | 2014-06-22 09:08:50
Checking Daily data file for symbol CLH14 for the date range from 2014-01-20 to 2014-02-19 | 2014-06-22 09:08:50
Checking Intraday data file for symbol CL-201404-NYMEX for the date range from 2014-02-19 to 2014-03-19 | 2014-06-22 09:08:51
Checking Daily data file for symbol CLJ14 for the date range from 2014-02-19 to 2014-03-19 | 2014-06-22 09:08:51
Checking Intraday data file for symbol CL-201405-NYMEX for the date range from 2014-03-19 to 2014-04-21 | 2014-06-22 09:08:51
Checking Daily data file for symbol CLK14 for the date range from 2014-03-19 to 2014-04-21 | 2014-06-22 09:08:51
Checking Intraday data file for symbol CL-201406-NYMEX for the date range from 2014-04-21 to 2014-05-19 | 2014-06-22 09:08:51
Daily data file for symbol CL-201406-NYMEX existed and is empty. Skipping download. | 2014-06-22 09:08:51
Checking Intraday data file for symbol CL-201407-NYMEX for the date range from 2014-05-19 to 2014-06-19 | 2014-06-22 09:08:51
Checking Daily data file for symbol CLN14 for the date range from 2014-05-19 to 2014-06-19 | 2014-06-22 09:08:51
Checking Intraday data file for symbol CL-201408-NYMEX for the date range from 2014-06-19 to 0 | 2014-06-22 09:08:51
Checking Daily data file for symbol CLQ14 for the date range from 2014-06-19 to 0 | 2014-06-22 09:08:51
Symbols used for CL-201408-NYMEX continuous contract chart: | 2014-06-22 09:08:51
CL-201308-NYMEX | 2014-06-22 09:08:51
CL-201309-NYMEX | 2014-06-22 09:08:51
CL-201310-NYMEX | 2014-06-22 09:08:51
CL-201311-NYMEX | 2014-06-22 09:08:51
CL-201312-NYMEX | 2014-06-22 09:08:51
CL-201401-NYMEX | 2014-06-22 09:08:51
CL-201402-NYMEX | 2014-06-22 09:08:51
CL-201403-NYMEX | 2014-06-22 09:08:51
CL-201404-NYMEX | 2014-06-22 09:08:51
CL-201405-NYMEX | 2014-06-22 09:08:51
CL-201406-NYMEX | 2014-06-22 09:08:51
CL-201407-NYMEX | 2014-06-22 09:08:51
CL-201408-NYMEX | 2014-06-22 09:08:51
Volume based rollover from CL-201308-NYMEX to CL-201309-NYMEX occurs at 2013-07-18 | 2014-06-22 09:08:51
Volume based rollover from CL-201309-NYMEX to CL-201310-NYMEX occurs at 2013-08-16 | 2014-06-22 09:08:51
Volume based rollover from CL-201310-NYMEX to CL-201311-NYMEX occurs at 2013-09-18 | 2014-06-22 09:08:51
Volume based rollover from CL-201311-NYMEX to CL-201312-NYMEX occurs at 2013-10-18 | 2014-06-22 09:08:51
Volume based rollover from CL-201312-NYMEX to CL-201401-NYMEX occurs at 2013-11-19 | 2014-06-22 09:08:51
Volume based rollover from CL-201401-NYMEX to CL-201402-NYMEX occurs at 2013-12-17 | 2014-06-22 09:08:51
Volume based rollover from CL-201402-NYMEX to CL-201403-NYMEX occurs at 2014-01-17 | 2014-06-22 09:08:51
Volume based rollover from CL-201403-NYMEX to CL-201404-NYMEX occurs at 2014-02-18 | 2014-06-22 09:08:51
Volume based rollover from CL-201404-NYMEX to CL-201405-NYMEX occurs at 2014-03-18 | 2014-06-22 09:08:51
Volume based rollover from CL-201405-NYMEX to CL-201406-NYMEX occurs at 2014-04-22 | 2014-06-22 09:08:51
Volume based rollover from CL-201406-NYMEX to CL-201407-NYMEX occurs at 0 | 2014-06-22 09:08:51
Using date based transition from CL-201406-NYMEX to CL-201407-NYMEX because volume based transition could not be determined. | 2014-06-22 09:08:51
Volume based rollover from CL-201407-NYMEX to CL-201408-NYMEX occurs at 2014-06-18 | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 5 Min #2: Performing continuous futures contract back adjustment calculations. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 5 Min #2: CL-201308-NYMEX Open price on 2013-07-18 is 106.56. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 5 Min #2: CL-201309-NYMEX Open price on 2013-07-18 is 106.35. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 5 Min #2: CL-201308-NYMEX price difference to CL-201309-NYMEX is -0.20999999. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 5 Min #2: CL-201309-NYMEX Open price on 2013-08-16 is 107.18. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 5 Min #2: CL-201310-NYMEX Open price on 2013-08-16 is 107.01. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 5 Min #2: CL-201309-NYMEX price difference to CL-201310-NYMEX is -0.17. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 5 Min #2: CL-201310-NYMEX Open price on 2013-09-18 is 105.53. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 5 Min #2: CL-201311-NYMEX Open price on 2013-09-18 is 104.77. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 5 Min #2: CL-201310-NYMEX price difference to CL-201311-NYMEX is -0.75999999. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 5 Min #2: CL-201311-NYMEX Open price on 2013-10-18 is 100.72. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 5 Min #2: CL-201312-NYMEX Open price on 2013-10-18 is 101. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 5 Min #2: CL-201311-NYMEX price difference to CL-201312-NYMEX is 0.28. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 5 Min #2: CL-201312-NYMEX Open price on 2013-11-19 is 93. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 5 Min #2: CL-201401-NYMEX Open price on 2013-11-19 is 93.64. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 5 Min #2: CL-201312-NYMEX price difference to CL-201401-NYMEX is 0.63999999. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 5 Min #2: CL-201401-NYMEX Open price on 2013-12-17 is 97.3. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 5 Min #2: CL-201402-NYMEX Open price on 2013-12-17 is 97.54. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 5 Min #2: CL-201401-NYMEX price difference to CL-201402-NYMEX is 0.23999999. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 5 Min #2: CL-201402-NYMEX Open price on 2014-01-17 is 94.17. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 5 Min #2: CL-201403-NYMEX Open price on 2014-01-17 is 94.29. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 5 Min #2: CL-201402-NYMEX price difference to CL-201403-NYMEX is 0.12. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 5 Min #2: CL-201403-NYMEX Open price on 2014-02-18 is 100.32. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 5 Min #2: CL-201404-NYMEX Open price on 2014-02-18 is 100.12. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 5 Min #2: CL-201403-NYMEX price difference to CL-201404-NYMEX is -0.2. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 5 Min #2: CL-201404-NYMEX Open price on 2014-03-18 is 97.97. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 5 Min #2: CL-201405-NYMEX Open price on 2014-03-18 is 97.46. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 5 Min #2: CL-201404-NYMEX price difference to CL-201405-NYMEX is -0.50999999. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 5 Min #2: CL-201405-NYMEX Open price on 2014-04-22 is 104.36. | 2014-06-22 09:08:51
Error while getting daily open price with date 2014-04-25 from file. C:\SierraChart\Data\CLM14.dly. Error: Encountered end of file. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 5 Min #2: CL-201405-NYMEX price difference to CL-201406-NYMEX is 0. | 2014-06-22 09:08:51
Error while getting daily open price with date 2014-05-22 from file. C:\SierraChart\Data\CLM14.dly. Error: Encountered end of file. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 5 Min #2: CL-201407-NYMEX Open price on 2014-05-19 is 101.68. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 5 Min #2: CL-201406-NYMEX price difference to CL-201407-NYMEX is 0. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 5 Min #2: CL-201407-NYMEX Open price on 2014-06-18 is 106.6. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 5 Min #2: CL-201408-NYMEX Open price on 2014-06-18 is 106.06. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 5 Min #2: CL-201407-NYMEX price difference to CL-201408-NYMEX is -0.54000002. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 5 Min #2: Back adjust amount for symbol CL-201308-NYMEX is -1.1100001. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 5 Min #2: Back adjust amount for symbol CL-201309-NYMEX is -0.90000004. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 5 Min #2: Back adjust amount for symbol CL-201310-NYMEX is -0.73000002. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 5 Min #2: Back adjust amount for symbol CL-201311-NYMEX is 0.029999912. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 5 Min #2: Back adjust amount for symbol CL-201312-NYMEX is -0.25. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 5 Min #2: Back adjust amount for symbol CL-201401-NYMEX is -0.89000005. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 5 Min #2: Back adjust amount for symbol CL-201402-NYMEX is -1.13. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 5 Min #2: Back adjust amount for symbol CL-201403-NYMEX is -1.25. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 5 Min #2: Back adjust amount for symbol CL-201404-NYMEX is -1.05. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 5 Min #2: Back adjust amount for symbol CL-201405-NYMEX is -0.54000002. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 5 Min #2: Back adjust amount for symbol CL-201406-NYMEX is -0.54000002. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 5 Min #2: Back adjust amount for symbol CL-201407-NYMEX is -0.54000002. | 2014-06-22 09:08:51
Date rule based rollover from CL-201308-NYMEX to next contract occurs at 2013-07-19 | 2014-06-22 09:08:51
Date rule based rollover from CL-201309-NYMEX to next contract occurs at 2013-08-19 | 2014-06-22 09:08:51
Date rule based rollover from CL-201310-NYMEX to next contract occurs at 2013-09-19 | 2014-06-22 09:08:51
Date rule based rollover from CL-201311-NYMEX to next contract occurs at 2013-10-21 | 2014-06-22 09:08:51
Date rule based rollover from CL-201312-NYMEX to next contract occurs at 2013-11-19 | 2014-06-22 09:08:51
Date rule based rollover from CL-201401-NYMEX to next contract occurs at 2013-12-19 | 2014-06-22 09:08:51
Date rule based rollover from CL-201402-NYMEX to next contract occurs at 2014-01-20 | 2014-06-22 09:08:51
Date rule based rollover from CL-201403-NYMEX to next contract occurs at 2014-02-19 | 2014-06-22 09:08:51
Date rule based rollover from CL-201404-NYMEX to next contract occurs at 2014-03-19 | 2014-06-22 09:08:51
Date rule based rollover from CL-201405-NYMEX to next contract occurs at 2014-04-21 | 2014-06-22 09:08:51
Date rule based rollover from CL-201406-NYMEX to next contract occurs at 2014-05-19 | 2014-06-22 09:08:51
Date rule based rollover from CL-201407-NYMEX to next contract occurs at 2014-06-19 | 2014-06-22 09:08:51
Date rule based rollover from CL-201408-NYMEX to next contract occurs at 2014-07-21 | 2014-06-22 09:08:51
Checking Intraday data file for symbol CL-201308-NYMEX for the date range from 2013-06-19 to 2013-07-19 | 2014-06-22 09:08:51
Checking Daily data file for symbol CLQ13 for the date range from 2013-06-19 to 2013-07-19 | 2014-06-22 09:08:51
Checking Intraday data file for symbol CL-201309-NYMEX for the date range from 2013-07-19 to 2013-08-19 | 2014-06-22 09:08:51
Checking Daily data file for symbol CLU13 for the date range from 2013-07-19 to 2013-08-19 | 2014-06-22 09:08:51
Checking Intraday data file for symbol CL-201310-NYMEX for the date range from 2013-08-19 to 2013-09-19 | 2014-06-22 09:08:51
Checking Daily data file for symbol CLV13 for the date range from 2013-08-19 to 2013-09-19 | 2014-06-22 09:08:51
Checking Intraday data file for symbol CL-201311-NYMEX for the date range from 2013-09-19 to 2013-10-21 | 2014-06-22 09:08:51
Checking Daily data file for symbol CLX13 for the date range from 2013-09-19 to 2013-10-21 | 2014-06-22 09:08:51
Checking Intraday data file for symbol CL-201312-NYMEX for the date range from 2013-10-21 to 2013-11-19 | 2014-06-22 09:08:51
Checking Daily data file for symbol CLZ13 for the date range from 2013-10-21 to 2013-11-19 | 2014-06-22 09:08:51
Checking Intraday data file for symbol CL-201401-NYMEX for the date range from 2013-11-19 to 2013-12-19 | 2014-06-22 09:08:51
Checking Daily data file for symbol CLF14 for the date range from 2013-11-19 to 2013-12-19 | 2014-06-22 09:08:51
Checking Intraday data file for symbol CL-201402-NYMEX for the date range from 2013-12-19 to 2014-01-20 | 2014-06-22 09:08:51
Checking Daily data file for symbol CLG14 for the date range from 2013-12-19 to 2014-01-20 | 2014-06-22 09:08:51
Checking Intraday data file for symbol CL-201403-NYMEX for the date range from 2014-01-20 to 2014-02-19 | 2014-06-22 09:08:51
Checking Daily data file for symbol CLH14 for the date range from 2014-01-20 to 2014-02-19 | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 1 Min #3: Performing continuous futures contract back adjustment calculations. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 1 Min #3: CL-201308-NYMEX Open price on 2013-07-18 is 106.56. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 1 Min #3: CL-201309-NYMEX Open price on 2013-07-18 is 106.35. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 1 Min #3: CL-201308-NYMEX price difference to CL-201309-NYMEX is -0.20999999. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 1 Min #3: CL-201309-NYMEX Open price on 2013-08-16 is 107.18. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 1 Min #3: CL-201310-NYMEX Open price on 2013-08-16 is 107.01. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 1 Min #3: CL-201309-NYMEX price difference to CL-201310-NYMEX is -0.17. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 1 Min #3: CL-201310-NYMEX Open price on 2013-09-18 is 105.53. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 1 Min #3: CL-201311-NYMEX Open price on 2013-09-18 is 104.77. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 1 Min #3: CL-201310-NYMEX price difference to CL-201311-NYMEX is -0.75999999. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 1 Min #3: CL-201311-NYMEX Open price on 2013-10-18 is 100.72. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 1 Min #3: CL-201312-NYMEX Open price on 2013-10-18 is 101. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 1 Min #3: CL-201311-NYMEX price difference to CL-201312-NYMEX is 0.28. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 1 Min #3: CL-201312-NYMEX Open price on 2013-11-19 is 93. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 1 Min #3: CL-201401-NYMEX Open price on 2013-11-19 is 93.64. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 1 Min #3: CL-201312-NYMEX price difference to CL-201401-NYMEX is 0.63999999. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 1 Min #3: CL-201401-NYMEX Open price on 2013-12-17 is 97.3. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 1 Min #3: CL-201402-NYMEX Open price on 2013-12-17 is 97.54. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 1 Min #3: CL-201401-NYMEX price difference to CL-201402-NYMEX is 0.23999999. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 1 Min #3: CL-201402-NYMEX Open price on 2014-01-17 is 94.17. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 1 Min #3: CL-201403-NYMEX Open price on 2014-01-17 is 94.29. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 1 Min #3: CL-201402-NYMEX price difference to CL-201403-NYMEX is 0.12. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 1 Min #3: CL-201403-NYMEX Open price on 2014-02-18 is 100.32. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 1 Min #3: CL-201404-NYMEX Open price on 2014-02-18 is 100.12. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 1 Min #3: CL-201403-NYMEX price difference to CL-201404-NYMEX is -0.2. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 1 Min #3: CL-201404-NYMEX Open price on 2014-03-18 is 97.97. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 1 Min #3: CL-201405-NYMEX Open price on 2014-03-18 is 97.46. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 1 Min #3: CL-201404-NYMEX price difference to CL-201405-NYMEX is -0.50999999. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 1 Min #3: CL-201405-NYMEX Open price on 2014-04-22 is 104.36. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 1 Min #3: CL-201405-NYMEX price difference to CL-201406-NYMEX is 0. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 1 Min #3: CL-201407-NYMEX Open price on 2014-05-19 is 101.68. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 1 Min #3: CL-201406-NYMEX price difference to CL-201407-NYMEX is 0. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 1 Min #3: CL-201407-NYMEX Open price on 2014-06-18 is 106.6. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 1 Min #3: CL-201408-NYMEX Open price on 2014-06-18 is 106.06. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 1 Min #3: CL-201407-NYMEX price difference to CL-201408-NYMEX is -0.54000002. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 1 Min #3: Back adjust amount for symbol CL-201308-NYMEX is -1.1100001. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 1 Min #3: Back adjust amount for symbol CL-201309-NYMEX is -0.90000004. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 1 Min #3: Back adjust amount for symbol CL-201310-NYMEX is -0.73000002. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 1 Min #3: Back adjust amount for symbol CL-201311-NYMEX is 0.029999912. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 1 Min #3: Back adjust amount for symbol CL-201312-NYMEX is -0.25. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 1 Min #3: Back adjust amount for symbol CL-201401-NYMEX is -0.89000005. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 1 Min #3: Back adjust amount for symbol CL-201402-NYMEX is -1.13. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 1 Min #3: Back adjust amount for symbol CL-201403-NYMEX is -1.25. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 1 Min #3: Back adjust amount for symbol CL-201404-NYMEX is -1.05. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 1 Min #3: Back adjust amount for symbol CL-201405-NYMEX is -0.54000002. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 1 Min #3: Back adjust amount for symbol CL-201406-NYMEX is -0.54000002. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 1 Min #3: Back adjust amount for symbol CL-201407-NYMEX is -0.54000002. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 30 Min #7: Performing continuous futures contract back adjustment calculations. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 30 Min #7: CL-201308-NYMEX Open price on 2013-07-18 is 106.56. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 30 Min #7: CL-201309-NYMEX Open price on 2013-07-18 is 106.35. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 30 Min #7: CL-201308-NYMEX price difference to CL-201309-NYMEX is -0.20999999. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 30 Min #7: CL-201309-NYMEX Open price on 2013-08-16 is 107.18. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 30 Min #7: CL-201310-NYMEX Open price on 2013-08-16 is 107.01. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 30 Min #7: CL-201309-NYMEX price difference to CL-201310-NYMEX is -0.17. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 30 Min #7: CL-201310-NYMEX Open price on 2013-09-18 is 105.53. | 2014-06-22 09:08:51
CL-201408-NYMEX [CBV] 30 Min #7: CL-201311-NYMEX Open price on 2013-09-18 is 104.77. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 30 Min #7: CL-201310-NYMEX price difference to CL-201311-NYMEX is -0.75999999. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 30 Min #7: CL-201311-NYMEX Open price on 2013-10-18 is 100.72. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 30 Min #7: CL-201312-NYMEX Open price on 2013-10-18 is 101. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 30 Min #7: CL-201311-NYMEX price difference to CL-201312-NYMEX is 0.28. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 30 Min #7: CL-201312-NYMEX Open price on 2013-11-19 is 93. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 30 Min #7: CL-201401-NYMEX Open price on 2013-11-19 is 93.64. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 30 Min #7: CL-201312-NYMEX price difference to CL-201401-NYMEX is 0.63999999. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 30 Min #7: CL-201401-NYMEX Open price on 2013-12-17 is 97.3. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 30 Min #7: CL-201402-NYMEX Open price on 2013-12-17 is 97.54. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 30 Min #7: CL-201401-NYMEX price difference to CL-201402-NYMEX is 0.23999999. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 30 Min #7: CL-201402-NYMEX Open price on 2014-01-17 is 94.17. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 30 Min #7: CL-201403-NYMEX Open price on 2014-01-17 is 94.29. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 30 Min #7: CL-201402-NYMEX price difference to CL-201403-NYMEX is 0.12. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 30 Min #7: CL-201403-NYMEX Open price on 2014-02-18 is 100.32. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 30 Min #7: CL-201404-NYMEX Open price on 2014-02-18 is 100.12. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 30 Min #7: CL-201403-NYMEX price difference to CL-201404-NYMEX is -0.2. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 30 Min #7: CL-201404-NYMEX Open price on 2014-03-18 is 97.97. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 30 Min #7: CL-201405-NYMEX Open price on 2014-03-18 is 97.46. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 30 Min #7: CL-201404-NYMEX price difference to CL-201405-NYMEX is -0.50999999. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 30 Min #7: CL-201405-NYMEX Open price on 2014-04-22 is 104.36. | 2014-06-22 09:08:52
Error while getting daily open price with date 2014-04-25 from file. C:\SierraChart\Data\CLM14.dly. Error: Encountered end of file. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 30 Min #7: CL-201405-NYMEX price difference to CL-201406-NYMEX is 0. | 2014-06-22 09:08:52
Error while getting daily open price with date 2014-05-22 from file. C:\SierraChart\Data\CLM14.dly. Error: Encountered end of file. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 30 Min #7: CL-201407-NYMEX Open price on 2014-05-19 is 101.68. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 30 Min #7: CL-201406-NYMEX price difference to CL-201407-NYMEX is 0. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 30 Min #7: CL-201407-NYMEX Open price on 2014-06-18 is 106.6. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 30 Min #7: CL-201408-NYMEX Open price on 2014-06-18 is 106.06. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 30 Min #7: CL-201407-NYMEX price difference to CL-201408-NYMEX is -0.54000002. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 30 Min #7: Back adjust amount for symbol CL-201308-NYMEX is -1.1100001. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 30 Min #7: Back adjust amount for symbol CL-201309-NYMEX is -0.90000004. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 30 Min #7: Back adjust amount for symbol CL-201310-NYMEX is -0.73000002. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 30 Min #7: Back adjust amount for symbol CL-201311-NYMEX is 0.029999912. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 30 Min #7: Back adjust amount for symbol CL-201312-NYMEX is -0.25. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 30 Min #7: Back adjust amount for symbol CL-201401-NYMEX is -0.89000005. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 30 Min #7: Back adjust amount for symbol CL-201402-NYMEX is -1.13. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 30 Min #7: Back adjust amount for symbol CL-201403-NYMEX is -1.25. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 30 Min #7: Back adjust amount for symbol CL-201404-NYMEX is -1.05. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 30 Min #7: Back adjust amount for symbol CL-201405-NYMEX is -0.54000002. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 30 Min #7: Back adjust amount for symbol CL-201406-NYMEX is -0.54000002. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 30 Min #7: Back adjust amount for symbol CL-201407-NYMEX is -0.54000002. | 2014-06-22 09:08:52
Date rule based rollover from CL-201308-NYMEX to next contract occurs at 2013-07-19 | 2014-06-22 09:08:52
Date rule based rollover from CL-201309-NYMEX to next contract occurs at 2013-08-19 | 2014-06-22 09:08:52
Date rule based rollover from CL-201310-NYMEX to next contract occurs at 2013-09-19 | 2014-06-22 09:08:52
Date rule based rollover from CL-201311-NYMEX to next contract occurs at 2013-10-21 | 2014-06-22 09:08:52
Date rule based rollover from CL-201312-NYMEX to next contract occurs at 2013-11-19 | 2014-06-22 09:08:52
Date rule based rollover from CL-201401-NYMEX to next contract occurs at 2013-12-19 | 2014-06-22 09:08:52
Date rule based rollover from CL-201402-NYMEX to next contract occurs at 2014-01-20 | 2014-06-22 09:08:52
Date rule based rollover from CL-201403-NYMEX to next contract occurs at 2014-02-19 | 2014-06-22 09:08:52
Date rule based rollover from CL-201404-NYMEX to next contract occurs at 2014-03-19 | 2014-06-22 09:08:52
Date rule based rollover from CL-201405-NYMEX to next contract occurs at 2014-04-21 | 2014-06-22 09:08:52
Date rule based rollover from CL-201406-NYMEX to next contract occurs at 2014-05-19 | 2014-06-22 09:08:52
Date rule based rollover from CL-201407-NYMEX to next contract occurs at 2014-06-19 | 2014-06-22 09:08:52
Date rule based rollover from CL-201408-NYMEX to next contract occurs at 2014-07-21 | 2014-06-22 09:08:52
Checking Intraday data file for symbol CL-201308-NYMEX for the date range from 2013-06-19 to 2013-07-19 | 2014-06-22 09:08:52
Checking Daily data file for symbol CLQ13 for the date range from 2013-06-19 to 2013-07-19 | 2014-06-22 09:08:52
Checking Intraday data file for symbol CL-201309-NYMEX for the date range from 2013-07-19 to 2013-08-19 | 2014-06-22 09:08:52
Checking Daily data file for symbol CLU13 for the date range from 2013-07-19 to 2013-08-19 | 2014-06-22 09:08:52
Checking Intraday data file for symbol CL-201310-NYMEX for the date range from 2013-08-19 to 2013-09-19 | 2014-06-22 09:08:52
Checking Daily data file for symbol CLV13 for the date range from 2013-08-19 to 2013-09-19 | 2014-06-22 09:08:52
Checking Intraday data file for symbol CL-201311-NYMEX for the date range from 2013-09-19 to 2013-10-21 | 2014-06-22 09:08:52
Checking Daily data file for symbol CLX13 for the date range from 2013-09-19 to 2013-10-21 | 2014-06-22 09:08:52
Checking Intraday data file for symbol CL-201312-NYMEX for the date range from 2013-10-21 to 2013-11-19 | 2014-06-22 09:08:52
Checking Daily data file for symbol CLZ13 for the date range from 2013-10-21 to 2013-11-19 | 2014-06-22 09:08:52
Checking Intraday data file for symbol CL-201401-NYMEX for the date range from 2013-11-19 to 2013-12-19 | 2014-06-22 09:08:52
Checking Daily data file for symbol CLF14 for the date range from 2013-11-19 to 2013-12-19 | 2014-06-22 09:08:52
Checking Intraday data file for symbol CL-201402-NYMEX for the date range from 2013-12-19 to 2014-01-20 | 2014-06-22 09:08:52
Checking Daily data file for symbol CLG14 for the date range from 2013-12-19 to 2014-01-20 | 2014-06-22 09:08:52
Checking Intraday data file for symbol CL-201403-NYMEX for the date range from 2014-01-20 to 2014-02-19 | 2014-06-22 09:08:52
Checking Daily data file for symbol CLH14 for the date range from 2014-01-20 to 2014-02-19 | 2014-06-22 09:08:52
Checking Intraday data file for symbol CL-201404-NYMEX for the date range from 2014-02-19 to 2014-03-19 | 2014-06-22 09:08:52
Checking Daily data file for symbol CLJ14 for the date range from 2014-02-19 to 2014-03-19 | 2014-06-22 09:08:52
Checking Intraday data file for symbol CL-201405-NYMEX for the date range from 2014-03-19 to 2014-04-21 | 2014-06-22 09:08:52
Checking Daily data file for symbol CLK14 for the date range from 2014-03-19 to 2014-04-21 | 2014-06-22 09:08:52
Checking Intraday data file for symbol CL-201406-NYMEX for the date range from 2014-04-21 to 2014-05-19 | 2014-06-22 09:08:52
Daily data file for symbol CL-201406-NYMEX existed and is empty. Skipping download. | 2014-06-22 09:08:52
Checking Intraday data file for symbol CL-201407-NYMEX for the date range from 2014-05-19 to 2014-06-19 | 2014-06-22 09:08:52
Checking Daily data file for symbol CLN14 for the date range from 2014-05-19 to 2014-06-19 | 2014-06-22 09:08:52
Checking Intraday data file for symbol CL-201408-NYMEX for the date range from 2014-06-19 to 0 | 2014-06-22 09:08:52
Checking Daily data file for symbol CLQ14 for the date range from 2014-06-19 to 0 | 2014-06-22 09:08:52
Symbols used for CL-201408-NYMEX continuous contract chart: | 2014-06-22 09:08:52
CL-201308-NYMEX | 2014-06-22 09:08:52
CL-201309-NYMEX | 2014-06-22 09:08:52
CL-201310-NYMEX | 2014-06-22 09:08:52
CL-201311-NYMEX | 2014-06-22 09:08:52
CL-201312-NYMEX | 2014-06-22 09:08:52
CL-201401-NYMEX | 2014-06-22 09:08:52
CL-201402-NYMEX | 2014-06-22 09:08:52
CL-201403-NYMEX | 2014-06-22 09:08:52
CL-201404-NYMEX | 2014-06-22 09:08:52
CL-201405-NYMEX | 2014-06-22 09:08:52
CL-201406-NYMEX | 2014-06-22 09:08:52
CL-201407-NYMEX | 2014-06-22 09:08:52
CL-201408-NYMEX | 2014-06-22 09:08:52
Volume based rollover from CL-201308-NYMEX to CL-201309-NYMEX occurs at 2013-07-18 | 2014-06-22 09:08:52
Volume based rollover from CL-201309-NYMEX to CL-201310-NYMEX occurs at 2013-08-16 | 2014-06-22 09:08:52
Volume based rollover from CL-201310-NYMEX to CL-201311-NYMEX occurs at 2013-09-18 | 2014-06-22 09:08:52
Volume based rollover from CL-201311-NYMEX to CL-201312-NYMEX occurs at 2013-10-18 | 2014-06-22 09:08:52
Volume based rollover from CL-201312-NYMEX to CL-201401-NYMEX occurs at 2013-11-19 | 2014-06-22 09:08:52
Volume based rollover from CL-201401-NYMEX to CL-201402-NYMEX occurs at 2013-12-17 | 2014-06-22 09:08:52
Volume based rollover from CL-201402-NYMEX to CL-201403-NYMEX occurs at 2014-01-17 | 2014-06-22 09:08:52
Volume based rollover from CL-201403-NYMEX to CL-201404-NYMEX occurs at 2014-02-18 | 2014-06-22 09:08:52
Volume based rollover from CL-201404-NYMEX to CL-201405-NYMEX occurs at 2014-03-18 | 2014-06-22 09:08:52
Volume based rollover from CL-201405-NYMEX to CL-201406-NYMEX occurs at 2014-04-22 | 2014-06-22 09:08:52
Volume based rollover from CL-201406-NYMEX to CL-201407-NYMEX occurs at 0 | 2014-06-22 09:08:52
Using date based transition from CL-201406-NYMEX to CL-201407-NYMEX because volume based transition could not be determined. | 2014-06-22 09:08:52
Volume based rollover from CL-201407-NYMEX to CL-201408-NYMEX occurs at 2014-06-18 | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 15 Min #8: Performing continuous futures contract back adjustment calculations. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 15 Min #8: CL-201308-NYMEX Open price on 2013-07-18 is 106.56. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 15 Min #8: CL-201309-NYMEX Open price on 2013-07-18 is 106.35. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 15 Min #8: CL-201308-NYMEX price difference to CL-201309-NYMEX is -0.20999999. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 15 Min #8: CL-201309-NYMEX Open price on 2013-08-16 is 107.18. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 15 Min #8: CL-201310-NYMEX Open price on 2013-08-16 is 107.01. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 15 Min #8: CL-201309-NYMEX price difference to CL-201310-NYMEX is -0.17. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 15 Min #8: CL-201310-NYMEX Open price on 2013-09-18 is 105.53. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 15 Min #8: CL-201311-NYMEX Open price on 2013-09-18 is 104.77. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 15 Min #8: CL-201310-NYMEX price difference to CL-201311-NYMEX is -0.75999999. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 15 Min #8: CL-201311-NYMEX Open price on 2013-10-18 is 100.72. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 15 Min #8: CL-201312-NYMEX Open price on 2013-10-18 is 101. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 15 Min #8: CL-201311-NYMEX price difference to CL-201312-NYMEX is 0.28. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 15 Min #8: CL-201312-NYMEX Open price on 2013-11-19 is 93. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 15 Min #8: CL-201401-NYMEX Open price on 2013-11-19 is 93.64. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 15 Min #8: CL-201312-NYMEX price difference to CL-201401-NYMEX is 0.63999999. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 15 Min #8: CL-201401-NYMEX Open price on 2013-12-17 is 97.3. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 15 Min #8: CL-201402-NYMEX Open price on 2013-12-17 is 97.54. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 15 Min #8: CL-201401-NYMEX price difference to CL-201402-NYMEX is 0.23999999. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 15 Min #8: CL-201402-NYMEX Open price on 2014-01-17 is 94.17. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 15 Min #8: CL-201403-NYMEX Open price on 2014-01-17 is 94.29. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 15 Min #8: CL-201402-NYMEX price difference to CL-201403-NYMEX is 0.12. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 15 Min #8: CL-201403-NYMEX Open price on 2014-02-18 is 100.32. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 15 Min #8: CL-201404-NYMEX Open price on 2014-02-18 is 100.12. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 15 Min #8: CL-201403-NYMEX price difference to CL-201404-NYMEX is -0.2. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 15 Min #8: CL-201404-NYMEX Open price on 2014-03-18 is 97.97. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 15 Min #8: CL-201405-NYMEX Open price on 2014-03-18 is 97.46. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 15 Min #8: CL-201404-NYMEX price difference to CL-201405-NYMEX is -0.50999999. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 15 Min #8: CL-201405-NYMEX Open price on 2014-04-22 is 104.36. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 15 Min #8: CL-201405-NYMEX price difference to CL-201406-NYMEX is 0. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 15 Min #8: CL-201407-NYMEX Open price on 2014-05-19 is 101.68. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 15 Min #8: CL-201406-NYMEX price difference to CL-201407-NYMEX is 0. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 15 Min #8: CL-201407-NYMEX Open price on 2014-06-18 is 106.6. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 15 Min #8: CL-201408-NYMEX Open price on 2014-06-18 is 106.06. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 15 Min #8: CL-201407-NYMEX price difference to CL-201408-NYMEX is -0.54000002. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 15 Min #8: Back adjust amount for symbol CL-201308-NYMEX is -1.1100001. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 15 Min #8: Back adjust amount for symbol CL-201309-NYMEX is -0.90000004. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 15 Min #8: Back adjust amount for symbol CL-201310-NYMEX is -0.73000002. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 15 Min #8: Back adjust amount for symbol CL-201311-NYMEX is 0.029999912. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 15 Min #8: Back adjust amount for symbol CL-201312-NYMEX is -0.25. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 15 Min #8: Back adjust amount for symbol CL-201401-NYMEX is -0.89000005. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 15 Min #8: Back adjust amount for symbol CL-201402-NYMEX is -1.13. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 15 Min #8: Back adjust amount for symbol CL-201403-NYMEX is -1.25. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 15 Min #8: Back adjust amount for symbol CL-201404-NYMEX is -1.05. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 15 Min #8: Back adjust amount for symbol CL-201405-NYMEX is -0.54000002. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 15 Min #8: Back adjust amount for symbol CL-201406-NYMEX is -0.54000002. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 15 Min #8: Back adjust amount for symbol CL-201407-NYMEX is -0.54000002. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 60 Min #1: Performing continuous futures contract back adjustment calculations. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 60 Min #1: CL-201308-NYMEX Open price on 2013-07-18 is 106.56. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 60 Min #1: CL-201309-NYMEX Open price on 2013-07-18 is 106.35. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 60 Min #1: CL-201308-NYMEX price difference to CL-201309-NYMEX is -0.20999999. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 60 Min #1: CL-201309-NYMEX Open price on 2013-08-16 is 107.18. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 60 Min #1: CL-201310-NYMEX Open price on 2013-08-16 is 107.01. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 60 Min #1: CL-201309-NYMEX price difference to CL-201310-NYMEX is -0.17. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 60 Min #1: CL-201310-NYMEX Open price on 2013-09-18 is 105.53. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 60 Min #1: CL-201311-NYMEX Open price on 2013-09-18 is 104.77. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 60 Min #1: CL-201310-NYMEX price difference to CL-201311-NYMEX is -0.75999999. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 60 Min #1: CL-201311-NYMEX Open price on 2013-10-18 is 100.72. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 60 Min #1: CL-201312-NYMEX Open price on 2013-10-18 is 101. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 60 Min #1: CL-201311-NYMEX price difference to CL-201312-NYMEX is 0.28. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 60 Min #1: CL-201312-NYMEX Open price on 2013-11-19 is 93. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 60 Min #1: CL-201401-NYMEX Open price on 2013-11-19 is 93.64. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 60 Min #1: CL-201312-NYMEX price difference to CL-201401-NYMEX is 0.63999999. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 60 Min #1: CL-201401-NYMEX Open price on 2013-12-17 is 97.3. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 60 Min #1: CL-201402-NYMEX Open price on 2013-12-17 is 97.54. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 60 Min #1: CL-201401-NYMEX price difference to CL-201402-NYMEX is 0.23999999. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 60 Min #1: CL-201402-NYMEX Open price on 2014-01-17 is 94.17. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 60 Min #1: CL-201403-NYMEX Open price on 2014-01-17 is 94.29. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 60 Min #1: CL-201402-NYMEX price difference to CL-201403-NYMEX is 0.12. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 60 Min #1: CL-201403-NYMEX Open price on 2014-02-18 is 100.32. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 60 Min #1: CL-201404-NYMEX Open price on 2014-02-18 is 100.12. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 60 Min #1: CL-201403-NYMEX price difference to CL-201404-NYMEX is -0.2. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 60 Min #1: CL-201404-NYMEX Open price on 2014-03-18 is 97.97. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 60 Min #1: CL-201405-NYMEX Open price on 2014-03-18 is 97.46. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 60 Min #1: CL-201404-NYMEX price difference to CL-201405-NYMEX is -0.50999999. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 60 Min #1: CL-201405-NYMEX Open price on 2014-04-22 is 104.36. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 60 Min #1: CL-201405-NYMEX price difference to CL-201406-NYMEX is 0. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 60 Min #1: CL-201407-NYMEX Open price on 2014-05-19 is 101.68. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 60 Min #1: CL-201406-NYMEX price difference to CL-201407-NYMEX is 0. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 60 Min #1: CL-201407-NYMEX Open price on 2014-06-18 is 106.6. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 60 Min #1: CL-201408-NYMEX Open price on 2014-06-18 is 106.06. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 60 Min #1: CL-201407-NYMEX price difference to CL-201408-NYMEX is -0.54000002. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 60 Min #1: Back adjust amount for symbol CL-201308-NYMEX is -1.1100001. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 60 Min #1: Back adjust amount for symbol CL-201309-NYMEX is -0.90000004. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 60 Min #1: Back adjust amount for symbol CL-201310-NYMEX is -0.73000002. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 60 Min #1: Back adjust amount for symbol CL-201311-NYMEX is 0.029999912. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 60 Min #1: Back adjust amount for symbol CL-201312-NYMEX is -0.25. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 60 Min #1: Back adjust amount for symbol CL-201401-NYMEX is -0.89000005. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 60 Min #1: Back adjust amount for symbol CL-201402-NYMEX is -1.13. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 60 Min #1: Back adjust amount for symbol CL-201403-NYMEX is -1.25. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 60 Min #1: Back adjust amount for symbol CL-201404-NYMEX is -1.05. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 60 Min #1: Back adjust amount for symbol CL-201405-NYMEX is -0.54000002. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 60 Min #1: Back adjust amount for symbol CL-201406-NYMEX is -0.54000002. | 2014-06-22 09:08:52
CL-201408-NYMEX [CBV] 60 Min #1: Back adjust amount for symbol CL-201407-NYMEX is -0.54000002. | 2014-06-22 09:08:52
Date rule based rollover from CL-201302-NYMEX to next contract occurs at 2013-01-21 | 2014-06-22 09:08:53
Date rule based rollover from CL-201303-NYMEX to next contract occurs at 2013-02-19 | 2014-06-22 09:08:53
Date rule based rollover from CL-201304-NYMEX to next contract occurs at 2013-03-19 | 2014-06-22 09:08:53
Date rule based rollover from CL-201305-NYMEX to next contract occurs at 2013-04-19 | 2014-06-22 09:08:53
Date rule based rollover from CL-201306-NYMEX to next contract occurs at 2013-05-20 | 2014-06-22 09:08:53
Date rule based rollover from CL-201307-NYMEX to next contract occurs at 2013-06-19 | 2014-06-22 09:08:53
Date rule based rollover from CL-201308-NYMEX to next contract occurs at 2013-07-19 | 2014-06-22 09:08:53
Date rule based rollover from CL-201309-NYMEX to next contract occurs at 2013-08-19 | 2014-06-22 09:08:53
Date rule based rollover from CL-201310-NYMEX to next contract occurs at 2013-09-19 | 2014-06-22 09:08:53
Date rule based rollover from CL-201311-NYMEX to next contract occurs at 2013-10-21 | 2014-06-22 09:08:53
Date rule based rollover from CL-201312-NYMEX to next contract occurs at 2013-11-19 | 2014-06-22 09:08:53
Date rule based rollover from CL-201401-NYMEX to next contract occurs at 2013-12-19 | 2014-06-22 09:08:53
Date rule based rollover from CL-201402-NYMEX to next contract occurs at 2014-01-20 | 2014-06-22 09:08:53
Date rule based rollover from CL-201403-NYMEX to next contract occurs at 2014-02-19 | 2014-06-22 09:08:53
Date rule based rollover from CL-201404-NYMEX to next contract occurs at 2014-03-19 | 2014-06-22 09:08:53
Date rule based rollover from CL-201405-NYMEX to next contract occurs at 2014-04-21 | 2014-06-22 09:08:53
Date rule based rollover from CL-201406-NYMEX to next contract occurs at 2014-05-19 | 2014-06-22 09:08:53
Date rule based rollover from CL-201407-NYMEX to next contract occurs at 2014-06-19 | 2014-06-22 09:08:53
Date rule based rollover from CL-201408-NYMEX to next contract occurs at 2014-07-21 | 2014-06-22 09:08:53
Checking Intraday data file for symbol CL-201302-NYMEX for the date range from 2012-12-19 to 2013-01-21 | 2014-06-22 09:08:53
Checking Daily data file for symbol CLG13 for the date range from 2012-12-19 to 2013-01-21 | 2014-06-22 09:08:53
Checking Intraday data file for symbol CL-201303-NYMEX for the date range from 2013-01-21 to 2013-02-19 | 2014-06-22 09:08:53
Checking Daily data file for symbol CLH13 for the date range from 2013-01-21 to 2013-02-19 | 2014-06-22 09:08:53
Checking Intraday data file for symbol CL-201304-NYMEX for the date range from 2013-02-19 to 2013-03-19 | 2014-06-22 09:08:53
Checking Daily data file for symbol CLJ13 for the date range from 2013-02-19 to 2013-03-19 | 2014-06-22 09:08:53
Checking Intraday data file for symbol CL-201305-NYMEX for the date range from 2013-03-19 to 2013-04-19 | 2014-06-22 09:08:53
Checking Daily data file for symbol CLK13 for the date range from 2013-03-19 to 2013-04-19 | 2014-06-22 09:08:53
Checking Intraday data file for symbol CL-201306-NYMEX for the date range from 2013-04-19 to 2013-05-20 | 2014-06-22 09:08:53
Checking Daily data file for symbol CLM13 for the date range from 2013-04-19 to 2013-05-20 | 2014-06-22 09:08:53
Checking Intraday data file for symbol CL-201307-NYMEX for the date range from 2013-05-20 to 2013-06-19 | 2014-06-22 09:08:53
Checking Daily data file for symbol CLN13 for the date range from 2013-05-20 to 2013-06-19 | 2014-06-22 09:08:54
Checking Intraday data file for symbol CL-201308-NYMEX for the date range from 2013-06-19 to 2013-07-19 | 2014-06-22 09:08:54
Checking Daily data file for symbol CLQ13 for the date range from 2013-06-19 to 2013-07-19 | 2014-06-22 09:08:54
Checking Intraday data file for symbol CL-201309-NYMEX for the date range from 2013-07-19 to 2013-08-19 | 2014-06-22 09:08:54
Checking Daily data file for symbol CLU13 for the date range from 2013-07-19 to 2013-08-19 | 2014-06-22 09:08:54
Checking Intraday data file for symbol CL-201310-NYMEX for the date range from 2013-08-19 to 2013-09-19 | 2014-06-22 09:08:54
Checking Daily data file for symbol CLV13 for the date range from 2013-08-19 to 2013-09-19 | 2014-06-22 09:08:54
Checking Intraday data file for symbol CL-201311-NYMEX for the date range from 2013-09-19 to 2013-10-21 | 2014-06-22 09:08:54
Checking Daily data file for symbol CLX13 for the date range from 2013-09-19 to 2013-10-21 | 2014-06-22 09:08:54
Checking Intraday data file for symbol CL-201312-NYMEX for the date range from 2013-10-21 to 2013-11-19 | 2014-06-22 09:08:54
Checking Daily data file for symbol CLZ13 for the date range from 2013-10-21 to 2013-11-19 | 2014-06-22 09:08:54
Checking Intraday data file for symbol CL-201401-NYMEX for the date range from 2013-11-19 to 2013-12-19 | 2014-06-22 09:08:54
Checking Daily data file for symbol CLF14 for the date range from 2013-11-19 to 2013-12-19 | 2014-06-22 09:08:54
Checking Intraday data file for symbol CL-201402-NYMEX for the date range from 2013-12-19 to 2014-01-20 | 2014-06-22 09:08:54
Checking Daily data file for symbol CLG14 for the date range from 2013-12-19 to 2014-01-20 | 2014-06-22 09:08:54
Checking Intraday data file for symbol CL-201403-NYMEX for the date range from 2014-01-20 to 2014-02-19 | 2014-06-22 09:08:54
Checking Daily data file for symbol CLH14 for the date range from 2014-01-20 to 2014-02-19 | 2014-06-22 09:08:54
Checking Intraday data file for symbol CL-201404-NYMEX for the date range from 2014-02-19 to 2014-03-19 | 2014-06-22 09:08:54
Checking Daily data file for symbol CLJ14 for the date range from 2014-02-19 to 2014-03-19 | 2014-06-22 09:08:54
Checking Intraday data file for symbol CL-201405-NYMEX for the date range from 2014-03-19 to 2014-04-21 | 2014-06-22 09:08:54
Checking Daily data file for symbol CLK14 for the date range from 2014-03-19 to 2014-04-21 | 2014-06-22 09:08:54
Checking Intraday data file for symbol CL-201406-NYMEX for the date range from 2014-04-21 to 2014-05-19 | 2014-06-22 09:08:54
Daily data file for symbol CL-201406-NYMEX existed and is empty. Skipping download. | 2014-06-22 09:08:54
Checking Intraday data file for symbol CL-201407-NYMEX for the date range from 2014-05-19 to 2014-06-19 | 2014-06-22 09:08:54
Checking Daily data file for symbol CLN14 for the date range from 2014-05-19 to 2014-06-19 | 2014-06-22 09:08:54
Checking Intraday data file for symbol CL-201408-NYMEX for the date range from 2014-06-19 to 0 | 2014-06-22 09:08:54
Checking Daily data file for symbol CLQ14 for the date range from 2014-06-19 to 0 | 2014-06-22 09:08:54
Symbols used for CL-201408-NYMEX continuous contract chart: | 2014-06-22 09:08:54
CL-201302-NYMEX | 2014-06-22 09:08:54
CL-201303-NYMEX | 2014-06-22 09:08:54
CL-201304-NYMEX | 2014-06-22 09:08:54
CL-201305-NYMEX | 2014-06-22 09:08:54
CL-201306-NYMEX | 2014-06-22 09:08:54
CL-201307-NYMEX | 2014-06-22 09:08:54
CL-201308-NYMEX | 2014-06-22 09:08:54
CL-201309-NYMEX | 2014-06-22 09:08:54
CL-201310-NYMEX | 2014-06-22 09:08:54
CL-201311-NYMEX | 2014-06-22 09:08:54
CL-201312-NYMEX | 2014-06-22 09:08:54
CL-201401-NYMEX | 2014-06-22 09:08:54
CL-201402-NYMEX | 2014-06-22 09:08:54
CL-201403-NYMEX | 2014-06-22 09:08:54
CL-201404-NYMEX | 2014-06-22 09:08:54
CL-201405-NYMEX | 2014-06-22 09:08:54
CL-201406-NYMEX | 2014-06-22 09:08:54
CL-201407-NYMEX | 2014-06-22 09:08:54
CL-201408-NYMEX | 2014-06-22 09:08:54
Volume based rollover from CL-201302-NYMEX to CL-201303-NYMEX occurs at 2013-01-18 | 2014-06-22 09:08:54
Volume based rollover from CL-201303-NYMEX to CL-201304-NYMEX occurs at 2013-02-19 | 2014-06-22 09:08:54
Volume based rollover from CL-201304-NYMEX to CL-201305-NYMEX occurs at 2013-03-18 | 2014-06-22 09:08:54
Volume based rollover from CL-201305-NYMEX to CL-201306-NYMEX occurs at 2013-04-18 | 2014-06-22 09:08:54
Volume based rollover from CL-201306-NYMEX to CL-201307-NYMEX occurs at 2013-05-20 | 2014-06-22 09:08:54
Volume based rollover from CL-201307-NYMEX to CL-201308-NYMEX occurs at 2013-06-18 | 2014-06-22 09:08:54
Volume based rollover from CL-201308-NYMEX to CL-201309-NYMEX occurs at 2013-07-18 | 2014-06-22 09:08:54
Volume based rollover from CL-201309-NYMEX to CL-201310-NYMEX occurs at 2013-08-16 | 2014-06-22 09:08:54
Volume based rollover from CL-201310-NYMEX to CL-201311-NYMEX occurs at 2013-09-18 | 2014-06-22 09:08:54
Volume based rollover from CL-201311-NYMEX to CL-201312-NYMEX occurs at 2013-10-18 | 2014-06-22 09:08:54
Volume based rollover from CL-201312-NYMEX to CL-201401-NYMEX occurs at 2013-11-19 | 2014-06-22 09:08:54
Volume based rollover from CL-201401-NYMEX to CL-201402-NYMEX occurs at 2013-12-17 | 2014-06-22 09:08:54
Volume based rollover from CL-201402-NYMEX to CL-201403-NYMEX occurs at 2014-01-17 | 2014-06-22 09:08:54
Volume based rollover from CL-201403-NYMEX to CL-201404-NYMEX occurs at 2014-02-18 | 2014-06-22 09:08:54
Volume based rollover from CL-201404-NYMEX to CL-201405-NYMEX occurs at 2014-03-18 | 2014-06-22 09:08:54
Volume based rollover from CL-201405-NYMEX to CL-201406-NYMEX occurs at 2014-04-22 | 2014-06-22 09:08:54
Volume based rollover from CL-201406-NYMEX to CL-201407-NYMEX occurs at 0 | 2014-06-22 09:08:54
Using date based transition from CL-201406-NYMEX to CL-201407-NYMEX because volume based transition could not be determined. | 2014-06-22 09:08:54
Volume based rollover from CL-201407-NYMEX to CL-201408-NYMEX occurs at 2014-06-18 | 2014-06-22 09:08:54
CL-201408-NYMEX [CBV] 1 Min #6: Performing continuous futures contract back adjustment calculations. | 2014-06-22 09:08:54
CL-201408-NYMEX [CBV] 1 Min #6: CL-201302-NYMEX Open price on 2013-01-18 is 95.19. | 2014-06-22 09:08:54
CL-201408-NYMEX [CBV] 1 Min #6: CL-201303-NYMEX Open price on 2013-01-18 is 95.65. | 2014-06-22 09:08:54
CL-201408-NYMEX [CBV] 1 Min #6: CL-201302-NYMEX price difference to CL-201303-NYMEX is 0.46000001. | 2014-06-22 09:08:54
CL-201408-NYMEX [CBV] 1 Min #6: CL-201303-NYMEX Open price on 2013-02-19 is 95.97. | 2014-06-22 09:08:54
CL-201408-NYMEX [CBV] 1 Min #6: CL-201304-NYMEX Open price on 2013-02-19 is 96.39. | 2014-06-22 09:08:54
CL-201408-NYMEX [CBV] 1 Min #6: CL-201303-NYMEX price difference to CL-201304-NYMEX is 0.41999999. | 2014-06-22 09:08:54
CL-201408-NYMEX [CBV] 1 Min #6: CL-201304-NYMEX Open price on 2013-03-18 is 93.26. | 2014-06-22 09:08:54
CL-201408-NYMEX [CBV] 1 Min #6: CL-201305-NYMEX Open price on 2013-03-18 is 93.62. | 2014-06-22 09:08:54
CL-201408-NYMEX [CBV] 1 Min #6: CL-201304-NYMEX price difference to CL-201305-NYMEX is 0.36000001. | 2014-06-22 09:08:54
CL-201408-NYMEX [CBV] 1 Min #6: CL-201305-NYMEX Open price on 2013-04-18 is 86.39. | 2014-06-22 09:08:54
CL-201408-NYMEX [CBV] 1 Min #6: CL-201306-NYMEX Open price on 2013-04-18 is 86.6. | 2014-06-22 09:08:54
CL-201408-NYMEX [CBV] 1 Min #6: CL-201305-NYMEX price difference to CL-201306-NYMEX is 0.20999999. | 2014-06-22 09:08:54
CL-201408-NYMEX [CBV] 1 Min #6: CL-201306-NYMEX Open price on 2013-05-20 is 95.93. | 2014-06-22 09:08:54
CL-201408-NYMEX [CBV] 1 Min #6: CL-201307-NYMEX Open price on 2013-05-20 is 96.25. | 2014-06-22 09:08:54
CL-201408-NYMEX [CBV] 1 Min #6: CL-201306-NYMEX price difference to CL-201307-NYMEX is 0.31999999. | 2014-06-22 09:08:54
CL-201408-NYMEX [CBV] 1 Min #6: CL-201307-NYMEX Open price on 2013-06-18 is 97.93. | 2014-06-22 09:08:54
CL-201408-NYMEX [CBV] 1 Min #6: CL-201308-NYMEX Open price on 2013-06-18 is 98.16. | 2014-06-22 09:08:54
CL-201408-NYMEX [CBV] 1 Min #6: CL-201307-NYMEX price difference to CL-201308-NYMEX is 0.23. | 2014-06-22 09:08:54
CL-201408-NYMEX [CBV] 1 Min #6: CL-201308-NYMEX Open price on 2013-07-18 is 106.56. | 2014-06-22 09:08:54
CL-201408-NYMEX [CBV] 1 Min #6: CL-201309-NYMEX Open price on 2013-07-18 is 106.35. | 2014-06-22 09:08:54
CL-201408-NYMEX [CBV] 1 Min #6: CL-201308-NYMEX price difference to CL-201309-NYMEX is -0.20999999. | 2014-06-22 09:08:54
CL-201408-NYMEX [CBV] 1 Min #6: CL-201309-NYMEX Open price on 2013-08-16 is 107.18. | 2014-06-22 09:08:54
CL-201408-NYMEX [CBV] 1 Min #6: CL-201310-NYMEX Open price on 2013-08-16 is 107.01. | 2014-06-22 09:08:54
CL-201408-NYMEX [CBV] 1 Min #6: CL-201309-NYMEX price difference to CL-201310-NYMEX is -0.17. | 2014-06-22 09:08:54
CL-201408-NYMEX [CBV] 1 Min #6: CL-201310-NYMEX Open price on 2013-09-18 is 105.53. | 2014-06-22 09:08:54
CL-201408-NYMEX [CBV] 1 Min #6: CL-201311-NYMEX Open price on 2013-09-18 is 104.77. | 2014-06-22 09:08:54
CL-201408-NYMEX [CBV] 1 Min #6: CL-201310-NYMEX price difference to CL-201311-NYMEX is -0.75999999. | 2014-06-22 09:08:54
CL-201408-NYMEX [CBV] 1 Min #6: CL-201311-NYMEX Open price on 2013-10-18 is 100.72. | 2014-06-22 09:08:54
CL-201408-NYMEX [CBV] 1 Min #6: CL-201312-NYMEX Open price on 2013-10-18 is 101. | 2014-06-22 09:08:54
CL-201408-NYMEX [CBV] 1 Min #6: CL-201311-NYMEX price difference to CL-201312-NYMEX is 0.28. | 2014-06-22 09:08:54
CL-201408-NYMEX [CBV] 1 Min #6: CL-201312-NYMEX Open price on 2013-11-19 is 93. | 2014-06-22 09:08:54
CL-201408-NYMEX [CBV] 1 Min #6: CL-201401-NYMEX Open price on 2013-11-19 is 93.64. | 2014-06-22 09:08:54
CL-201408-NYMEX [CBV] 1 Min #6: CL-201312-NYMEX price difference to CL-201401-NYMEX is 0.63999999. | 2014-06-22 09:08:54
CL-201408-NYMEX [CBV] 1 Min #6: CL-201401-NYMEX Open price on 2013-12-17 is 97.3. | 2014-06-22 09:08:54
CL-201408-NYMEX [CBV] 1 Min #6: CL-201402-NYMEX Open price on 2013-12-17 is 97.54. | 2014-06-22 09:08:54
CL-201408-NYMEX [CBV] 1 Min #6: CL-201401-NYMEX price difference to CL-201402-NYMEX is 0.23999999. | 2014-06-22 09:08:54
CL-201408-NYMEX [CBV] 1 Min #6: CL-201402-NYMEX Open price on 2014-01-17 is 94.17. | 2014-06-22 09:08:54
CL-201408-NYMEX [CBV] 1 Min #6: CL-201403-NYMEX Open price on 2014-01-17 is 94.29. | 2014-06-22 09:08:54
CL-201408-NYMEX [CBV] 1 Min #6: CL-201402-NYMEX price difference to CL-201403-NYMEX is 0.12. | 2014-06-22 09:08:54
CL-201408-NYMEX [CBV] 1 Min #6: CL-201403-NYMEX Open price on 2014-02-18 is 100.32. | 2014-06-22 09:08:54
CL-201408-NYMEX [CBV] 1 Min #6: CL-201404-NYMEX Open price on 2014-02-18 is 100.12. | 2014-06-22 09:08:54
CL-201408-NYMEX [CBV] 1 Min #6: CL-201403-NYMEX price difference to CL-201404-NYMEX is -0.2. | 2014-06-22 09:08:54
CL-201408-NYMEX [CBV] 1 Min #6: CL-201404-NYMEX Open price on 2014-03-18 is 97.97. | 2014-06-22 09:08:54
CL-201408-NYMEX [CBV] 1 Min #6: CL-201405-NYMEX Open price on 2014-03-18 is 97.46. | 2014-06-22 09:08:54
CL-201408-NYMEX [CBV] 1 Min #6: CL-201404-NYMEX price difference to CL-201405-NYMEX is -0.50999999. | 2014-06-22 09:08:54
CL-201408-NYMEX [CBV] 1 Min #6: CL-201405-NYMEX Open price on 2014-04-22 is 104.36. | 2014-06-22 09:08:54
Error while getting daily open price with date 2014-04-25 from file. C:\SierraChart\Data\CLM14.dly. Error: Encountered end of file. | 2014-06-22 09:08:54
CL-201408-NYMEX [CBV] 1 Min #6: CL-201405-NYMEX price difference to CL-201406-NYMEX is 0. | 2014-06-22 09:08:54
Error while getting daily open price with date 2014-05-22 from file. C:\SierraChart\Data\CLM14.dly. Error: Encountered end of file. | 2014-06-22 09:08:54
CL-201408-NYMEX [CBV] 1 Min #6: CL-201407-NYMEX Open price on 2014-05-19 is 101.68. | 2014-06-22 09:08:54
CL-201408-NYMEX [CBV] 1 Min #6: CL-201406-NYMEX price difference to CL-201407-NYMEX is 0. | 2014-06-22 09:08:54
CL-201408-NYMEX [CBV] 1 Min #6: CL-201407-NYMEX Open price on 2014-06-18 is 106.6. | 2014-06-22 09:08:54
CL-201408-NYMEX [CBV] 1 Min #6: CL-201408-NYMEX Open price on 2014-06-18 is 106.06. | 2014-06-22 09:08:54
CL-201408-NYMEX [CBV] 1 Min #6: CL-201407-NYMEX price difference to CL-201408-NYMEX is -0.54000002. | 2014-06-22 09:08:54
CL-201408-NYMEX [CBV] 1 Min #6: Back adjust amount for symbol CL-201302-NYMEX is 0.88999981. | 2014-06-22 09:08:54
CL-201408-NYMEX [CBV] 1 Min #6: Back adjust amount for symbol CL-201303-NYMEX is 0.42999989. | 2014-06-22 09:08:54
CL-201408-NYMEX [CBV] 1 Min #6: Back adjust amount for symbol CL-201304-NYMEX is 0.0099999309. | 2014-06-22 09:08:54
CL-201408-NYMEX [CBV] 1 Min #6: Back adjust amount for symbol CL-201305-NYMEX is -0.35000002. | 2014-06-22 09:08:54
CL-201408-NYMEX [CBV] 1 Min #6: Back adjust amount for symbol CL-201306-NYMEX is -0.56. | 2014-06-22 09:08:54
CL-201408-NYMEX [CBV] 1 Min #6: Back adjust amount for symbol CL-201307-NYMEX is -0.88000005. | 2014-06-22 09:08:54
CL-201408-NYMEX [CBV] 1 Min #6: Back adjust amount for symbol CL-201308-NYMEX is -1.1100001. | 2014-06-22 09:08:54
CL-201408-NYMEX [CBV] 1 Min #6: Back adjust amount for symbol CL-201309-NYMEX is -0.90000004. | 2014-06-22 09:08:54
CL-201408-NYMEX [CBV] 1 Min #6: Back adjust amount for symbol CL-201310-NYMEX is -0.73000002. | 2014-06-22 09:08:54
CL-201408-NYMEX [CBV] 1 Min #6: Back adjust amount for symbol CL-201311-NYMEX is 0.029999912. | 2014-06-22 09:08:54
CL-201408-NYMEX [CBV] 1 Min #6: Back adjust amount for symbol CL-201312-NYMEX is -0.25. | 2014-06-22 09:08:54
CL-201408-NYMEX [CBV] 1 Min #6: Back adjust amount for symbol CL-201401-NYMEX is -0.89000005. | 2014-06-22 09:08:54
CL-201408-NYMEX [CBV] 1 Min #6: Back adjust amount for symbol CL-201402-NYMEX is -1.13. | 2014-06-22 09:08:54
CL-201408-NYMEX [CBV] 1 Min #6: Back adjust amount for symbol CL-201403-NYMEX is -1.25. | 2014-06-22 09:08:54
CL-201408-NYMEX [CBV] 1 Min #6: Back adjust amount for symbol CL-201404-NYMEX is -1.05. | 2014-06-22 09:08:54
CL-201408-NYMEX [CBV] 1 Min #6: Back adjust amount for symbol CL-201405-NYMEX is -0.54000002. | 2014-06-22 09:08:54
CL-201408-NYMEX [CBV] 1 Min #6: Back adjust amount for symbol CL-201406-NYMEX is -0.54000002. | 2014-06-22 09:08:54
CL-201408-NYMEX [CBV] 1 Min #6: Back adjust amount for symbol CL-201407-NYMEX is -0.54000002. | 2014-06-22 09:08:54
Mapping CL-201408-NYMEX to CLQ4. Service code: nymex | 2014-06-22 09:08:54
HD Request # 2 - Downloading Intraday chart data for CL-201408-NYMEX to the file CL-201408-NYMEX.scid. Service: nymex | 2014-06-22 09:08:55
HD Request # 2 - Download start Date-Time: 2014-06-20 14:14:49.0 | 2014-06-22 09:08:55
HD Request # 2 - Using server: scdf1.sierracharts.com port 10149 | 2014-06-22 09:08:55
Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2014-06-22 09:08:55
The network socket is connected. | 2014-06-22 09:08:55
HD Request # 2 - Sending historical data logon request message. | 2014-06-22 09:08:55
HD Request # 2 - Requesting Intraday data. Start Date-Time: 2014-06-20 14:14:49. Record interval: 0 . Symbol: CLQ4 | 2014-06-22 09:08:56
HD Request # 2 - Decompressing data. | 2014-06-22 09:08:56
HD Request # 2 - Receiving Intraday data for CL-201408-NYMEX starting at 2014-06-20 14:14:49 | 2014-06-22 09:08:56
Socket has been shutdown and closed. | 2014-06-22 09:08:56
The network socket for historical data has been closed. | 2014-06-22 09:08:56
HD Request # 2 - Historical data for CL-201408-NYMEX is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2014-06-22 09:08:56
HD Request # 2 - Received 1 record from 2014-06-20 14:14:49 to 2014-06-20 14:14:49 (0.0 seconds) and wrote 0 records for CL-201408-NYMEX | 2014-06-22 09:08:56
HD Request # 2 - Intraday download COMPLETE for CL-201408-NYMEX. Completion time: 1s | 2014-06-22 09:08:56
Date rule based rollover from CLM11 to next contract occurs at 2011-05-19 | 2014-06-22 09:19:31
Date rule based rollover from CLN11 to next contract occurs at 2011-06-20 | 2014-06-22 09:19:31
Date rule based rollover from CLQ11 to next contract occurs at 2011-07-19 | 2014-06-22 09:19:31
Date rule based rollover from CLU11 to next contract occurs at 2011-08-19 | 2014-06-22 09:19:31
Date rule based rollover from CLV11 to next contract occurs at 2011-09-19 | 2014-06-22 09:19:31
Date rule based rollover from CLX11 to next contract occurs at 2011-10-19 | 2014-06-22 09:19:31
Date rule based rollover from CLZ11 to next contract occurs at 2011-11-21 | 2014-06-22 09:19:31
Date rule based rollover from CLF12 to next contract occurs at 2011-12-19 | 2014-06-22 09:19:31
Date rule based rollover from CLG12 to next contract occurs at 2012-01-19 | 2014-06-22 09:19:31
Date rule based rollover from CLH12 to next contract occurs at 2012-02-20 | 2014-06-22 09:19:31
Date rule based rollover from CLJ12 to next contract occurs at 2012-03-19 | 2014-06-22 09:19:31
Date rule based rollover from CLK12 to next contract occurs at 2012-04-19 | 2014-06-22 09:19:31
Date rule based rollover from CLM12 to next contract occurs at 2012-05-21 | 2014-06-22 09:19:31
Date rule based rollover from CLN12 to next contract occurs at 2012-06-19 | 2014-06-22 09:19:31
Date rule based rollover from CLQ12 to next contract occurs at 2012-07-19 | 2014-06-22 09:19:31
Date rule based rollover from CLU12 to next contract occurs at 2012-08-20 | 2014-06-22 09:19:31
Date rule based rollover from CLV12 to next contract occurs at 2012-09-19 | 2014-06-22 09:19:31
Date rule based rollover from CLX12 to next contract occurs at 2012-10-19 | 2014-06-22 09:19:31
Date rule based rollover from CLZ12 to next contract occurs at 2012-11-19 | 2014-06-22 09:19:31
Date rule based rollover from CLF13 to next contract occurs at 2012-12-19 | 2014-06-22 09:19:31
Date rule based rollover from CLG13 to next contract occurs at 2013-01-21 | 2014-06-22 09:19:31
Date rule based rollover from CLH13 to next contract occurs at 2013-02-19 | 2014-06-22 09:19:31
Date rule based rollover from CLJ13 to next contract occurs at 2013-03-19 | 2014-06-22 09:19:31
Date rule based rollover from CLK13 to next contract occurs at 2013-04-19 | 2014-06-22 09:19:31
Date rule based rollover from CLM13 to next contract occurs at 2013-05-20 | 2014-06-22 09:19:31
Date rule based rollover from CLN13 to next contract occurs at 2013-06-19 | 2014-06-22 09:19:31
Date rule based rollover from CLQ13 to next contract occurs at 2013-07-19 | 2014-06-22 09:19:31
Date rule based rollover from CLU13 to next contract occurs at 2013-08-19 | 2014-06-22 09:19:31
Date rule based rollover from CLV13 to next contract occurs at 2013-09-19 | 2014-06-22 09:19:31
Date rule based rollover from CLX13 to next contract occurs at 2013-10-21 | 2014-06-22 09:19:31
Date rule based rollover from CLZ13 to next contract occurs at 2013-11-19 | 2014-06-22 09:19:31
Date rule based rollover from CLF14 to next contract occurs at 2013-12-19 | 2014-06-22 09:19:31
Date rule based rollover from CLG14 to next contract occurs at 2014-01-20 | 2014-06-22 09:19:31
Date rule based rollover from CLH14 to next contract occurs at 2014-02-19 | 2014-06-22 09:19:31
Date rule based rollover from CLJ14 to next contract occurs at 2014-03-19 | 2014-06-22 09:19:31
Date rule based rollover from CLK14 to next contract occurs at 2014-04-21 | 2014-06-22 09:19:31
Date rule based rollover from CLM14 to next contract occurs at 2014-05-19 | 2014-06-22 09:19:31
Date rule based rollover from CLN14 to next contract occurs at 2014-06-19 | 2014-06-22 09:19:31
Date rule based rollover from CLQ14 to next contract occurs at 2014-07-21 | 2014-06-22 09:19:31
Checking Daily data file for symbol CLM11 for the date range from 2011-04-19 to 2011-05-19 | 2014-06-22 09:19:31
Checking Daily data file for symbol CLN11 for the date range from 2011-05-19 to 2011-06-20 | 2014-06-22 09:19:31
Checking Daily data file for symbol CLQ11 for the date range from 2011-06-20 to 2011-07-19 | 2014-06-22 09:19:32
Checking Daily data file for symbol CLU11 for the date range from 2011-07-19 to 2011-08-19 | 2014-06-22 09:19:32
Checking Daily data file for symbol CLV11 for the date range from 2011-08-19 to 2011-09-19 | 2014-06-22 09:19:32
Checking Daily data file for symbol CLX11 for the date range from 2011-09-19 to 2011-10-19 | 2014-06-22 09:19:32
Checking Daily data file for symbol CLZ11 for the date range from 2011-10-19 to 2011-11-21 | 2014-06-22 09:19:32
Checking Daily data file for symbol CLF12 for the date range from 2011-11-21 to 2011-12-19 | 2014-06-22 09:19:32
Checking Daily data file for symbol CLG12 for the date range from 2011-12-19 to 2012-01-19 | 2014-06-22 09:19:32
Checking Daily data file for symbol CLH12 for the date range from 2012-01-19 to 2012-02-20 | 2014-06-22 09:19:32
Checking Daily data file for symbol CLJ12 for the date range from 2012-02-20 to 2012-03-19 | 2014-06-22 09:19:32
Checking Daily data file for symbol CLK12 for the date range from 2012-03-19 to 2012-04-19 | 2014-06-22 09:19:32
Checking Daily data file for symbol CLM12 for the date range from 2012-04-19 to 2012-05-21 | 2014-06-22 09:19:32
Checking Daily data file for symbol CLN12 for the date range from 2012-05-21 to 2012-06-19 | 2014-06-22 09:19:32
Checking Daily data file for symbol CLQ12 for the date range from 2012-06-19 to 2012-07-19 | 2014-06-22 09:19:32
Checking Daily data file for symbol CLU12 for the date range from 2012-07-19 to 2012-08-20 | 2014-06-22 09:19:32
Checking Daily data file for symbol CLV12 for the date range from 2012-08-20 to 2012-09-19 | 2014-06-22 09:19:32
Checking Daily data file for symbol CLX12 for the date range from 2012-09-19 to 2012-10-19 | 2014-06-22 09:19:32
Checking Daily data file for symbol CLZ12 for the date range from 2012-10-19 to 2012-11-19 | 2014-06-22 09:19:32
Checking Daily data file for symbol CLF13 for the date range from 2012-11-19 to 2012-12-19 | 2014-06-22 09:19:32
Checking Daily data file for symbol CLG13 for the date range from 2012-12-19 to 2013-01-21 | 2014-06-22 09:19:32
Checking Daily data file for symbol CLH13 for the date range from 2013-01-21 to 2013-02-19 | 2014-06-22 09:19:32
Checking Daily data file for symbol CLJ13 for the date range from 2013-02-19 to 2013-03-19 | 2014-06-22 09:19:32
Checking Daily data file for symbol CLK13 for the date range from 2013-03-19 to 2013-04-19 | 2014-06-22 09:19:32
Checking Daily data file for symbol CLM13 for the date range from 2013-04-19 to 2013-05-20 | 2014-06-22 09:19:32
Checking Daily data file for symbol CLN13 for the date range from 2013-05-20 to 2013-06-19 | 2014-06-22 09:19:32
Checking Daily data file for symbol CLQ13 for the date range from 2013-06-19 to 2013-07-19 | 2014-06-22 09:19:32
Checking Daily data file for symbol CLU13 for the date range from 2013-07-19 to 2013-08-19 | 2014-06-22 09:19:32
Checking Daily data file for symbol CLV13 for the date range from 2013-08-19 to 2013-09-19 | 2014-06-22 09:19:32
Checking Daily data file for symbol CLX13 for the date range from 2013-09-19 to 2013-10-21 | 2014-06-22 09:19:32
Checking Daily data file for symbol CLZ13 for the date range from 2013-10-21 to 2013-11-19 | 2014-06-22 09:19:32
Checking Daily data file for symbol CLF14 for the date range from 2013-11-19 to 2013-12-19 | 2014-06-22 09:19:32
Checking Daily data file for symbol CLG14 for the date range from 2013-12-19 to 2014-01-20 | 2014-06-22 09:19:32
Checking Daily data file for symbol CLH14 for the date range from 2014-01-20 to 2014-02-19 | 2014-06-22 09:19:32
Checking Daily data file for symbol CLJ14 for the date range from 2014-02-19 to 2014-03-19 | 2014-06-22 09:19:32
Checking Daily data file for symbol CLK14 for the date range from 2014-03-19 to 2014-04-21 | 2014-06-22 09:19:32
Daily data file for symbol CLM14 existed and is empty. Skipping download. | 2014-06-22 09:19:32
Checking Daily data file for symbol CLN14 for the date range from 2014-05-19 to 2014-06-19 | 2014-06-22 09:19:32
Checking Daily data file for symbol CLQ14 for the date range from 2014-06-19 to 0 | 2014-06-22 09:19:32
Symbols used for CLQ14 continuous contract chart: | 2014-06-22 09:19:32
CLM11 | 2014-06-22 09:19:32
CLN11 | 2014-06-22 09:19:32
CLQ11 | 2014-06-22 09:19:32
CLU11 | 2014-06-22 09:19:32
CLV11 | 2014-06-22 09:19:32
CLX11 | 2014-06-22 09:19:32
CLZ11 | 2014-06-22 09:19:32
CLF12 | 2014-06-22 09:19:32
CLG12 | 2014-06-22 09:19:32
CLH12 | 2014-06-22 09:19:32
CLJ12 | 2014-06-22 09:19:32
CLK12 | 2014-06-22 09:19:32
CLM12 | 2014-06-22 09:19:32
CLN12 | 2014-06-22 09:19:32
CLQ12 | 2014-06-22 09:19:32
CLU12 | 2014-06-22 09:19:32
CLV12 | 2014-06-22 09:19:32
CLX12 | 2014-06-22 09:19:32
CLZ12 | 2014-06-22 09:19:32
CLF13 | 2014-06-22 09:19:32
CLG13 | 2014-06-22 09:19:32
CLH13 | 2014-06-22 09:19:32
CLJ13 | 2014-06-22 09:19:32
CLK13 | 2014-06-22 09:19:32
CLM13 | 2014-06-22 09:19:32
CLN13 | 2014-06-22 09:19:32
CLQ13 | 2014-06-22 09:19:32
CLU13 | 2014-06-22 09:19:32
CLV13 | 2014-06-22 09:19:32
CLX13 | 2014-06-22 09:19:32
CLZ13 | 2014-06-22 09:19:32
CLF14 | 2014-06-22 09:19:32
CLG14 | 2014-06-22 09:19:32
CLH14 | 2014-06-22 09:19:32
CLJ14 | 2014-06-22 09:19:32
CLK14 | 2014-06-22 09:19:32
CLM14 | 2014-06-22 09:19:32
CLN14 | 2014-06-22 09:19:32
CLQ14 | 2014-06-22 09:19:32
Date rule based rollover from CLM02 to next contract occurs at 2002-05-20 | 2014-06-22 09:19:32
Date rule based rollover from CLN02 to next contract occurs at 2002-06-19 | 2014-06-22 09:19:32
Date rule based rollover from CLQ02 to next contract occurs at 2002-07-19 | 2014-06-22 09:19:32
Date rule based rollover from CLU02 to next contract occurs at 2002-08-19 | 2014-06-22 09:19:32
Date rule based rollover from CLV02 to next contract occurs at 2002-09-19 | 2014-06-22 09:19:32
Date rule based rollover from CLX02 to next contract occurs at 2002-10-21 | 2014-06-22 09:19:32
Date rule based rollover from CLZ02 to next contract occurs at 2002-11-19 | 2014-06-22 09:19:32
Date rule based rollover from CLF03 to next contract occurs at 2002-12-19 | 2014-06-22 09:19:32
Date rule based rollover from CLG03 to next contract occurs at 2003-01-20 | 2014-06-22 09:19:32
Date rule based rollover from CLH03 to next contract occurs at 2003-02-19 | 2014-06-22 09:19:32
Date rule based rollover from CLJ03 to next contract occurs at 2003-03-19 | 2014-06-22 09:19:32
Date rule based rollover from CLK03 to next contract occurs at 2003-04-21 | 2014-06-22 09:19:32
Date rule based rollover from CLM03 to next contract occurs at 2003-05-19 | 2014-06-22 09:19:32
Date rule based rollover from CLN03 to next contract occurs at 2003-06-19 | 2014-06-22 09:19:32
Date rule based rollover from CLQ03 to next contract occurs at 2003-07-21 | 2014-06-22 09:19:32
Date rule based rollover from CLU03 to next contract occurs at 2003-08-19 | 2014-06-22 09:19:32
Date rule based rollover from CLV03 to next contract occurs at 2003-09-19 | 2014-06-22 09:19:32
Date rule based rollover from CLX03 to next contract occurs at 2003-10-20 | 2014-06-22 09:19:32
Date rule based rollover from CLZ03 to next contract occurs at 2003-11-19 | 2014-06-22 09:19:32
Date rule based rollover from CLF04 to next contract occurs at 2003-12-19 | 2014-06-22 09:19:32
Date rule based rollover from CLG04 to next contract occurs at 2004-01-19 | 2014-06-22 09:19:32
Date rule based rollover from CLH04 to next contract occurs at 2004-02-19 | 2014-06-22 09:19:32
Date rule based rollover from CLJ04 to next contract occurs at 2004-03-19 | 2014-06-22 09:19:32
Date rule based rollover from CLK04 to next contract occurs at 2004-04-19 | 2014-06-22 09:19:32
Date rule based rollover from CLM04 to next contract occurs at 2004-05-19 | 2014-06-22 09:19:32
Date rule based rollover from CLN04 to next contract occurs at 2004-06-21 | 2014-06-22 09:19:32
Date rule based rollover from CLQ04 to next contract occurs at 2004-07-19 | 2014-06-22 09:19:32
Date rule based rollover from CLU04 to next contract occurs at 2004-08-19 | 2014-06-22 09:19:32
Date rule based rollover from CLV04 to next contract occurs at 2004-09-20 | 2014-06-22 09:19:32
Date rule based rollover from CLX04 to next contract occurs at 2004-10-19 | 2014-06-22 09:19:32
Date rule based rollover from CLZ04 to next contract occurs at 2004-11-19 | 2014-06-22 09:19:32
Date rule based rollover from CLF05 to next contract occurs at 2004-12-20 | 2014-06-22 09:19:32
Date rule based rollover from CLG05 to next contract occurs at 2005-01-19 | 2014-06-22 09:19:32
Date rule based rollover from CLH05 to next contract occurs at 2005-02-21 | 2014-06-22 09:19:32
Date rule based rollover from CLJ05 to next contract occurs at 2005-03-21 | 2014-06-22 09:19:32
Date rule based rollover from CLK05 to next contract occurs at 2005-04-19 | 2014-06-22 09:19:32
Date rule based rollover from CLM05 to next contract occurs at 2005-05-19 | 2014-06-22 09:19:32
Date rule based rollover from CLN05 to next contract occurs at 2005-06-20 | 2014-06-22 09:19:32
Date rule based rollover from CLQ05 to next contract occurs at 2005-07-19 | 2014-06-22 09:19:32
Date rule based rollover from CLU05 to next contract occurs at 2005-08-19 | 2014-06-22 09:19:32
Date rule based rollover from CLV05 to next contract occurs at 2005-09-19 | 2014-06-22 09:19:32
Date rule based rollover from CLX05 to next contract occurs at 2005-10-19 | 2014-06-22 09:19:32
Date rule based rollover from CLZ05 to next contract occurs at 2005-11-21 | 2014-06-22 09:19:32
Date rule based rollover from CLF06 to next contract occurs at 2005-12-19 | 2014-06-22 09:19:32
Date rule based rollover from CLG06 to next contract occurs at 2006-01-19 | 2014-06-22 09:19:32
Date rule based rollover from CLH06 to next contract occurs at 2006-02-20 | 2014-06-22 09:19:32
Date rule based rollover from CLJ06 to next contract occurs at 2006-03-20 | 2014-06-22 09:19:32
Date rule based rollover from CLK06 to next contract occurs at 2006-04-19 | 2014-06-22 09:19:32
Date rule based rollover from CLM06 to next contract occurs at 2006-05-19 | 2014-06-22 09:19:32
Date rule based rollover from CLN06 to next contract occurs at 2006-06-19 | 2014-06-22 09:19:32
Date rule based rollover from CLQ06 to next contract occurs at 2006-07-19 | 2014-06-22 09:19:32
Date rule based rollover from CLU06 to next contract occurs at 2006-08-21 | 2014-06-22 09:19:32
Date rule based rollover from CLV06 to next contract occurs at 2006-09-19 | 2014-06-22 09:19:32
Date rule based rollover from CLX06 to next contract occurs at 2006-10-19 | 2014-06-22 09:19:32
Date rule based rollover from CLZ06 to next contract occurs at 2006-11-20 | 2014-06-22 09:19:32
Date rule based rollover from CLF07 to next contract occurs at 2006-12-19 | 2014-06-22 09:19:32
Date rule based rollover from CLG07 to next contract occurs at 2007-01-19 | 2014-06-22 09:19:32
Date rule based rollover from CLH07 to next contract occurs at 2007-02-19 | 2014-06-22 09:19:32
Date rule based rollover from CLJ07 to next contract occurs at 2007-03-19 | 2014-06-22 09:19:32
Date rule based rollover from CLK07 to next contract occurs at 2007-04-19 | 2014-06-22 09:19:32
Date rule based rollover from CLM07 to next contract occurs at 2007-05-21 | 2014-06-22 09:19:32
Date rule based rollover from CLN07 to next contract occurs at 2007-06-19 | 2014-06-22 09:19:32
Date rule based rollover from CLQ07 to next contract occurs at 2007-07-19 | 2014-06-22 09:19:32
Date rule based rollover from CLU07 to next contract occurs at 2007-08-20 | 2014-06-22 09:19:32
Date rule based rollover from CLV07 to next contract occurs at 2007-09-19 | 2014-06-22 09:19:32
Date rule based rollover from CLX07 to next contract occurs at 2007-10-19 | 2014-06-22 09:19:32
Date rule based rollover from CLZ07 to next contract occurs at 2007-11-19 | 2014-06-22 09:19:32
Date rule based rollover from CLF08 to next contract occurs at 2007-12-19 | 2014-06-22 09:19:32
Date rule based rollover from CLG08 to next contract occurs at 2008-01-21 | 2014-06-22 09:19:32
Date rule based rollover from CLH08 to next contract occurs at 2008-02-19 | 2014-06-22 09:19:32
Date rule based rollover from CLJ08 to next contract occurs at 2008-03-19 | 2014-06-22 09:19:32
Date rule based rollover from CLK08 to next contract occurs at 2008-04-21 | 2014-06-22 09:19:32
Date rule based rollover from CLM08 to next contract occurs at 2008-05-19 | 2014-06-22 09:19:32
Date rule based rollover from CLN08 to next contract occurs at 2008-06-19 | 2014-06-22 09:19:32
Date rule based rollover from CLQ08 to next contract occurs at 2008-07-21 | 2014-06-22 09:19:32
Date rule based rollover from CLU08 to next contract occurs at 2008-08-19 | 2014-06-22 09:19:32
Date rule based rollover from CLV08 to next contract occurs at 2008-09-19 | 2014-06-22 09:19:32
Date rule based rollover from CLX08 to next contract occurs at 2008-10-20 | 2014-06-22 09:19:32
Date rule based rollover from CLZ08 to next contract occurs at 2008-11-19 | 2014-06-22 09:19:32
Date rule based rollover from CLF09 to next contract occurs at 2008-12-19 | 2014-06-22 09:19:32
Date rule based rollover from CLG09 to next contract occurs at 2009-01-19 | 2014-06-22 09:19:32
Date rule based rollover from CLH09 to next contract occurs at 2009-02-19 | 2014-06-22 09:19:32
Date rule based rollover from CLJ09 to next contract occurs at 2009-03-19 | 2014-06-22 09:19:32
Date rule based rollover from CLK09 to next contract occurs at 2009-04-20 | 2014-06-22 09:19:32
Date rule based rollover from CLM09 to next contract occurs at 2009-05-19 | 2014-06-22 09:19:32
Date rule based rollover from CLN09 to next contract occurs at 2009-06-19 | 2014-06-22 09:19:32
Date rule based rollover from CLQ09 to next contract occurs at 2009-07-20 | 2014-06-22 09:19:32
Date rule based rollover from CLU09 to next contract occurs at 2009-08-19 | 2014-06-22 09:19:32
Date rule based rollover from CLV09 to next contract occurs at 2009-09-21 | 2014-06-22 09:19:32
Date rule based rollover from CLX09 to next contract occurs at 2009-10-19 | 2014-06-22 09:19:32
Date rule based rollover from CLZ09 to next contract occurs at 2009-11-19 | 2014-06-22 09:19:32
Date rule based rollover from CLF10 to next contract occurs at 2009-12-21 | 2014-06-22 09:19:32
Date rule based rollover from CLG10 to next contract occurs at 2010-01-19 | 2014-06-22 09:19:32
Date rule based rollover from CLH10 to next contract occurs at 2010-02-19 | 2014-06-22 09:19:32
Date rule based rollover from CLJ10 to next contract occurs at 2010-03-19 | 2014-06-22 09:19:32
Date rule based rollover from CLK10 to next contract occurs at 2010-04-19 | 2014-06-22 09:19:32
Date rule based rollover from CLM10 to next contract occurs at 2010-05-19 | 2014-06-22 09:19:32
Date rule based rollover from CLN10 to next contract occurs at 2010-06-21 | 2014-06-22 09:19:32
Date rule based rollover from CLQ10 to next contract occurs at 2010-07-19 | 2014-06-22 09:19:32
Date rule based rollover from CLU10 to next contract occurs at 2010-08-19 | 2014-06-22 09:19:32
Date rule based rollover from CLV10 to next contract occurs at 2010-09-20 | 2014-06-22 09:19:32
Date rule based rollover from CLX10 to next contract occurs at 2010-10-19 | 2014-06-22 09:19:32
Date rule based rollover from CLZ10 to next contract occurs at 2010-11-19 | 2014-06-22 09:19:32
Date rule based rollover from CLF11 to next contract occurs at 2010-12-20 | 2014-06-22 09:19:32
Date rule based rollover from CLG11 to next contract occurs at 2011-01-19 | 2014-06-22 09:19:32
Date rule based rollover from CLH11 to next contract occurs at 2011-02-21 | 2014-06-22 09:19:32
Date rule based rollover from CLJ11 to next contract occurs at 2011-03-21 | 2014-06-22 09:19:32
Date rule based rollover from CLK11 to next contract occurs at 2011-04-19 | 2014-06-22 09:19:32
Date rule based rollover from CLM11 to next contract occurs at 2011-05-19 | 2014-06-22 09:19:32
Date rule based rollover from CLN11 to next contract occurs at 2011-06-20 | 2014-06-22 09:19:32
Date rule based rollover from CLQ11 to next contract occurs at 2011-07-19 | 2014-06-22 09:19:32
Date rule based rollover from CLU11 to next contract occurs at 2011-08-19 | 2014-06-22 09:19:32
Date rule based rollover from CLV11 to next contract occurs at 2011-09-19 | 2014-06-22 09:19:32
Date rule based rollover from CLX11 to next contract occurs at 2011-10-19 | 2014-06-22 09:19:32
Date rule based rollover from CLZ11 to next contract occurs at 2011-11-21 | 2014-06-22 09:19:32
Date rule based rollover from CLF12 to next contract occurs at 2011-12-19 | 2014-06-22 09:19:32
Date rule based rollover from CLG12 to next contract occurs at 2012-01-19 | 2014-06-22 09:19:32
Date rule based rollover from CLH12 to next contract occurs at 2012-02-20 | 2014-06-22 09:19:32
Date rule based rollover from CLJ12 to next contract occurs at 2012-03-19 | 2014-06-22 09:19:32
Date rule based rollover from CLK12 to next contract occurs at 2012-04-19 | 2014-06-22 09:19:32
Date rule based rollover from CLM12 to next contract occurs at 2012-05-21 | 2014-06-22 09:19:32
Date rule based rollover from CLN12 to next contract occurs at 2012-06-19 | 2014-06-22 09:19:32
Date rule based rollover from CLQ12 to next contract occurs at 2012-07-19 | 2014-06-22 09:19:32
Date rule based rollover from CLU12 to next contract occurs at 2012-08-20 | 2014-06-22 09:19:32
Date rule based rollover from CLV12 to next contract occurs at 2012-09-19 | 2014-06-22 09:19:32
Date rule based rollover from CLX12 to next contract occurs at 2012-10-19 | 2014-06-22 09:19:32
Date rule based rollover from CLZ12 to next contract occurs at 2012-11-19 | 2014-06-22 09:19:32
Date rule based rollover from CLF13 to next contract occurs at 2012-12-19 | 2014-06-22 09:19:32
Date rule based rollover from CLG13 to next contract occurs at 2013-01-21 | 2014-06-22 09:19:32
Date rule based rollover from CLH13 to next contract occurs at 2013-02-19 | 2014-06-22 09:19:32
Date rule based rollover from CLJ13 to next contract occurs at 2013-03-19 | 2014-06-22 09:19:32
Date rule based rollover from CLK13 to next contract occurs at 2013-04-19 | 2014-06-22 09:19:32
Date rule based rollover from CLM13 to next contract occurs at 2013-05-20 | 2014-06-22 09:19:32
Date rule based rollover from CLN13 to next contract occurs at 2013-06-19 | 2014-06-22 09:19:32
Date rule based rollover from CLQ13 to next contract occurs at 2013-07-19 | 2014-06-22 09:19:32
Date rule based rollover from CLU13 to next contract occurs at 2013-08-19 | 2014-06-22 09:19:32
Date rule based rollover from CLV13 to next contract occurs at 2013-09-19 | 2014-06-22 09:19:32
Date rule based rollover from CLX13 to next contract occurs at 2013-10-21 | 2014-06-22 09:19:32
Date rule based rollover from CLZ13 to next contract occurs at 2013-11-19 | 2014-06-22 09:19:32
Date rule based rollover from CLF14 to next contract occurs at 2013-12-19 | 2014-06-22 09:19:32
Date rule based rollover from CLG14 to next contract occurs at 2014-01-20 | 2014-06-22 09:19:32
Date rule based rollover from CLH14 to next contract occurs at 2014-02-19 | 2014-06-22 09:19:32
Date rule based rollover from CLJ14 to next contract occurs at 2014-03-19 | 2014-06-22 09:19:32
Date rule based rollover from CLK14 to next contract occurs at 2014-04-21 | 2014-06-22 09:19:32
Date rule based rollover from CLM14 to next contract occurs at 2014-05-19 | 2014-06-22 09:19:32
Date rule based rollover from CLN14 to next contract occurs at 2014-06-19 | 2014-06-22 09:19:32
Date rule based rollover from CLQ14 to next contract occurs at 2014-07-21 | 2014-06-22 09:19:32
Checking Daily data file for symbol CLM02 for the date range from 2002-04-19 to 2002-05-20 | 2014-06-22 09:19:32
Checking Daily data file for symbol CLN02 for the date range from 2002-05-20 to 2002-06-19 | 2014-06-22 09:19:32
Checking Daily data file for symbol CLQ02 for the date range from 2002-06-19 to 2002-07-19 | 2014-06-22 09:19:32
Checking Daily data file for symbol CLU02 for the date range from 2002-07-19 to 2002-08-19 | 2014-06-22 09:19:32
Checking Daily data file for symbol CLV02 for the date range from 2002-08-19 to 2002-09-19 | 2014-06-22 09:19:32
Checking Daily data file for symbol CLX02 for the date range from 2002-09-19 to 2002-10-21 | 2014-06-22 09:19:32
Checking Daily data file for symbol CLZ02 for the date range from 2002-10-21 to 2002-11-19 | 2014-06-22 09:19:33
Checking Daily data file for symbol CLF03 for the date range from 2002-11-19 to 2002-12-19 | 2014-06-22 09:19:33
Checking Daily data file for symbol CLG03 for the date range from 2002-12-19 to 2003-01-20 | 2014-06-22 09:19:33
Checking Daily data file for symbol CLH03 for the date range from 2003-01-20 to 2003-02-19 | 2014-06-22 09:19:33
Checking Daily data file for symbol CLJ03 for the date range from 2003-02-19 to 2003-03-19 | 2014-06-22 09:19:33
Checking Daily data file for symbol CLK03 for the date range from 2003-03-19 to 2003-04-21 | 2014-06-22 09:19:33
Checking Daily data file for symbol CLM03 for the date range from 2003-04-21 to 2003-05-19 | 2014-06-22 09:19:33
Checking Daily data file for symbol CLN03 for the date range from 2003-05-19 to 2003-06-19 | 2014-06-22 09:19:33
Checking Daily data file for symbol CLQ03 for the date range from 2003-06-19 to 2003-07-21 | 2014-06-22 09:19:33
Checking Daily data file for symbol CLU03 for the date range from 2003-07-21 to 2003-08-19 | 2014-06-22 09:19:33
Checking Daily data file for symbol CLV03 for the date range from 2003-08-19 to 2003-09-19 | 2014-06-22 09:19:33
Checking Daily data file for symbol CLX03 for the date range from 2003-09-19 to 2003-10-20 | 2014-06-22 09:19:33
Checking Daily data file for symbol CLZ03 for the date range from 2003-10-20 to 2003-11-19 | 2014-06-22 09:19:33
Checking Daily data file for symbol CLF04 for the date range from 2003-11-19 to 2003-12-19 | 2014-06-22 09:19:33
Checking Daily data file for symbol CLG04 for the date range from 2003-12-19 to 2004-01-19 | 2014-06-22 09:19:33
Checking Daily data file for symbol CLH04 for the date range from 2004-01-19 to 2004-02-19 | 2014-06-22 09:19:33
Checking Daily data file for symbol CLJ04 for the date range from 2004-02-19 to 2004-03-19 | 2014-06-22 09:19:33
Checking Daily data file for symbol CLK04 for the date range from 2004-03-19 to 2004-04-19 | 2014-06-22 09:19:33
Checking Daily data file for symbol CLM04 for the date range from 2004-04-19 to 2004-05-19 | 2014-06-22 09:19:33
Checking Daily data file for symbol CLN04 for the date range from 2004-05-19 to 2004-06-21 | 2014-06-22 09:19:33
Checking Daily data file for symbol CLQ04 for the date range from 2004-06-21 to 2004-07-19 | 2014-06-22 09:19:33
Checking Daily data file for symbol CLU04 for the date range from 2004-07-19 to 2004-08-19 | 2014-06-22 09:19:33
Checking Daily data file for symbol CLV04 for the date range from 2004-08-19 to 2004-09-20 | 2014-06-22 09:19:33
Checking Daily data file for symbol CLX04 for the date range from 2004-09-20 to 2004-10-19 | 2014-06-22 09:19:33
Checking Daily data file for symbol CLZ04 for the date range from 2004-10-19 to 2004-11-19 | 2014-06-22 09:19:33
Checking Daily data file for symbol CLF05 for the date range from 2004-11-19 to 2004-12-20 | 2014-06-22 09:19:33
Checking Daily data file for symbol CLG05 for the date range from 2004-12-20 to 2005-01-19 | 2014-06-22 09:19:33
Checking Daily data file for symbol CLH05 for the date range from 2005-01-19 to 2005-02-21 | 2014-06-22 09:19:34
Checking Daily data file for symbol CLJ05 for the date range from 2005-02-21 to 2005-03-21 | 2014-06-22 09:19:34
Checking Daily data file for symbol CLK05 for the date range from 2005-03-21 to 2005-04-19 | 2014-06-22 09:19:34
Checking Daily data file for symbol CLM05 for the date range from 2005-04-19 to 2005-05-19 | 2014-06-22 09:19:34
Checking Daily data file for symbol CLN05 for the date range from 2005-05-19 to 2005-06-20 | 2014-06-22 09:19:34
Checking Daily data file for symbol CLQ05 for the date range from 2005-06-20 to 2005-07-19 | 2014-06-22 09:19:34
Checking Daily data file for symbol CLU05 for the date range from 2005-07-19 to 2005-08-19 | 2014-06-22 09:19:34
Checking Daily data file for symbol CLV05 for the date range from 2005-08-19 to 2005-09-19 | 2014-06-22 09:19:34
Checking Daily data file for symbol CLX05 for the date range from 2005-09-19 to 2005-10-19 | 2014-06-22 09:19:34
Checking Daily data file for symbol CLZ05 for the date range from 2005-10-19 to 2005-11-21 | 2014-06-22 09:19:34
Checking Daily data file for symbol CLF06 for the date range from 2005-11-21 to 2005-12-19 | 2014-06-22 09:19:34
Checking Daily data file for symbol CLG06 for the date range from 2005-12-19 to 2006-01-19 | 2014-06-22 09:19:34
Checking Daily data file for symbol CLH06 for the date range from 2006-01-19 to 2006-02-20 | 2014-06-22 09:19:34
Checking Daily data file for symbol CLJ06 for the date range from 2006-02-20 to 2006-03-20 | 2014-06-22 09:19:34
Checking Daily data file for symbol CLK06 for the date range from 2006-03-20 to 2006-04-19 | 2014-06-22 09:19:34
Checking Daily data file for symbol CLM06 for the date range from 2006-04-19 to 2006-05-19 | 2014-06-22 09:19:34
Checking Daily data file for symbol CLN06 for the date range from 2006-05-19 to 2006-06-19 | 2014-06-22 09:19:34
Checking Daily data file for symbol CLQ06 for the date range from 2006-06-19 to 2006-07-19 | 2014-06-22 09:19:34
Checking Daily data file for symbol CLU06 for the date range from 2006-07-19 to 2006-08-21 | 2014-06-22 09:19:34
Checking Daily data file for symbol CLV06 for the date range from 2006-08-21 to 2006-09-19 | 2014-06-22 09:19:34
Checking Daily data file for symbol CLX06 for the date range from 2006-09-19 to 2006-10-19 | 2014-06-22 09:19:34
Checking Daily data file for symbol CLZ06 for the date range from 2006-10-19 to 2006-11-20 | 2014-06-22 09:19:34
Checking Daily data file for symbol CLF07 for the date range from 2006-11-20 to 2006-12-19 | 2014-06-22 09:19:34
Checking Daily data file for symbol CLG07 for the date range from 2006-12-19 to 2007-01-19 | 2014-06-22 09:19:34
Checking Daily data file for symbol CLH07 for the date range from 2007-01-19 to 2007-02-19 | 2014-06-22 09:19:34
Checking Daily data file for symbol CLJ07 for the date range from 2007-02-19 to 2007-03-19 | 2014-06-22 09:19:34
Checking Daily data file for symbol CLK07 for the date range from 2007-03-19 to 2007-04-19 | 2014-06-22 09:19:34
Checking Daily data file for symbol CLM07 for the date range from 2007-04-19 to 2007-05-21 | 2014-06-22 09:19:34
Checking Daily data file for symbol CLN07 for the date range from 2007-05-21 to 2007-06-19 | 2014-06-22 09:19:34
Checking Daily data file for symbol CLQ07 for the date range from 2007-06-19 to 2007-07-19 | 2014-06-22 09:19:35
Checking Daily data file for symbol CLU07 for the date range from 2007-07-19 to 2007-08-20 | 2014-06-22 09:19:35
Checking Daily data file for symbol CLV07 for the date range from 2007-08-20 to 2007-09-19 | 2014-06-22 09:19:35
Checking Daily data file for symbol CLX07 for the date range from 2007-09-19 to 2007-10-19 | 2014-06-22 09:19:35
Checking Daily data file for symbol CLZ07 for the date range from 2007-10-19 to 2007-11-19 | 2014-06-22 09:19:35
Checking Daily data file for symbol CLF08 for the date range from 2007-11-19 to 2007-12-19 | 2014-06-22 09:19:35
Checking Daily data file for symbol CLG08 for the date range from 2007-12-19 to 2008-01-21 | 2014-06-22 09:19:35
Checking Daily data file for symbol CLH08 for the date range from 2008-01-21 to 2008-02-19 | 2014-06-22 09:19:35
Checking Daily data file for symbol CLJ08 for the date range from 2008-02-19 to 2008-03-19 | 2014-06-22 09:19:35
Checking Daily data file for symbol CLK08 for the date range from 2008-03-19 to 2008-04-21 | 2014-06-22 09:19:35
Checking Daily data file for symbol CLM08 for the date range from 2008-04-21 to 2008-05-19 | 2014-06-22 09:19:35
Checking Daily data file for symbol CLN08 for the date range from 2008-05-19 to 2008-06-19 | 2014-06-22 09:19:35
Checking Daily data file for symbol CLQ08 for the date range from 2008-06-19 to 2008-07-21 | 2014-06-22 09:19:35
Checking Daily data file for symbol CLU08 for the date range from 2008-07-21 to 2008-08-19 | 2014-06-22 09:19:35
Checking Daily data file for symbol CLV08 for the date range from 2008-08-19 to 2008-09-19 | 2014-06-22 09:19:35
Checking Daily data file for symbol CLX08 for the date range from 2008-09-19 to 2008-10-20 | 2014-06-22 09:19:35
Checking Daily data file for symbol CLZ08 for the date range from 2008-10-20 to 2008-11-19 | 2014-06-22 09:19:35
Checking Daily data file for symbol CLF09 for the date range from 2008-11-19 to 2008-12-19 | 2014-06-22 09:19:35
Checking Daily data file for symbol CLG09 for the date range from 2008-12-19 to 2009-01-19 | 2014-06-22 09:19:35
Checking Daily data file for symbol CLH09 for the date range from 2009-01-19 to 2009-02-19 | 2014-06-22 09:19:35
Checking Daily data file for symbol CLJ09 for the date range from 2009-02-19 to 2009-03-19 | 2014-06-22 09:19:35
Checking Daily data file for symbol CLK09 for the date range from 2009-03-19 to 2009-04-20 | 2014-06-22 09:19:35
Checking Daily data file for symbol CLM09 for the date range from 2009-04-20 to 2009-05-19 | 2014-06-22 09:19:35
Checking Daily data file for symbol CLN09 for the date range from 2009-05-19 to 2009-06-19 | 2014-06-22 09:19:35
Checking Daily data file for symbol CLQ09 for the date range from 2009-06-19 to 2009-07-20 | 2014-06-22 09:19:35
Checking Daily data file for symbol CLU09 for the date range from 2009-07-20 to 2009-08-19 | 2014-06-22 09:19:35
Checking Daily data file for symbol CLV09 for the date range from 2009-08-19 to 2009-09-21 | 2014-06-22 09:19:35
Checking Daily data file for symbol CLX09 for the date range from 2009-09-21 to 2009-10-19 | 2014-06-22 09:19:36
Checking Daily data file for symbol CLZ09 for the date range from 2009-10-19 to 2009-11-19 | 2014-06-22 09:19:36
Checking Daily data file for symbol CLF10 for the date range from 2009-11-19 to 2009-12-21 | 2014-06-22 09:19:36
Checking Daily data file for symbol CLG10 for the date range from 2009-12-21 to 2010-01-19 | 2014-06-22 09:19:36
Checking Daily data file for symbol CLH10 for the date range from 2010-01-19 to 2010-02-19 | 2014-06-22 09:19:36
Checking Daily data file for symbol CLJ10 for the date range from 2010-02-19 to 2010-03-19 | 2014-06-22 09:19:36
Checking Daily data file for symbol CLK10 for the date range from 2010-03-19 to 2010-04-19 | 2014-06-22 09:19:36
Checking Daily data file for symbol CLM10 for the date range from 2010-04-19 to 2010-05-19 | 2014-06-22 09:19:36
Checking Daily data file for symbol CLN10 for the date range from 2010-05-19 to 2010-06-21 | 2014-06-22 09:19:36
Checking Daily data file for symbol CLQ10 for the date range from 2010-06-21 to 2010-07-19 | 2014-06-22 09:19:36
Checking Daily data file for symbol CLU10 for the date range from 2010-07-19 to 2010-08-19 | 2014-06-22 09:19:36
Checking Daily data file for symbol CLV10 for the date range from 2010-08-19 to 2010-09-20 | 2014-06-22 09:19:36
Checking Daily data file for symbol CLX10 for the date range from 2010-09-20 to 2010-10-19 | 2014-06-22 09:19:36
Checking Daily data file for symbol CLZ10 for the date range from 2010-10-19 to 2010-11-19 | 2014-06-22 09:19:36
Checking Daily data file for symbol CLF11 for the date range from 2010-11-19 to 2010-12-20 | 2014-06-22 09:19:36
Checking Daily data file for symbol CLG11 for the date range from 2010-12-20 to 2011-01-19 | 2014-06-22 09:19:36
Checking Daily data file for symbol CLH11 for the date range from 2011-01-19 to 2011-02-21 | 2014-06-22 09:19:36
Checking Daily data file for symbol CLJ11 for the date range from 2011-02-21 to 2011-03-21 | 2014-06-22 09:19:36
Checking Daily data file for symbol CLK11 for the date range from 2011-03-21 to 2011-04-19 | 2014-06-22 09:19:36
Checking Daily data file for symbol CLM11 for the date range from 2011-04-19 to 2011-05-19 | 2014-06-22 09:19:36
Checking Daily data file for symbol CLN11 for the date range from 2011-05-19 to 2011-06-20 | 2014-06-22 09:19:36
Checking Daily data file for symbol CLQ11 for the date range from 2011-06-20 to 2011-07-19 | 2014-06-22 09:19:36
Checking Daily data file for symbol CLU11 for the date range from 2011-07-19 to 2011-08-19 | 2014-06-22 09:19:36
Checking Daily data file for symbol CLV11 for the date range from 2011-08-19 to 2011-09-19 | 2014-06-22 09:19:36
Checking Daily data file for symbol CLX11 for the date range from 2011-09-19 to 2011-10-19 | 2014-06-22 09:19:36
Checking Daily data file for symbol CLZ11 for the date range from 2011-10-19 to 2011-11-21 | 2014-06-22 09:19:36
Checking Daily data file for symbol CLF12 for the date range from 2011-11-21 to 2011-12-19 | 2014-06-22 09:19:36
Checking Daily data file for symbol CLG12 for the date range from 2011-12-19 to 2012-01-19 | 2014-06-22 09:19:36
Checking Daily data file for symbol CLH12 for the date range from 2012-01-19 to 2012-02-20 | 2014-06-22 09:19:36
Checking Daily data file for symbol CLJ12 for the date range from 2012-02-20 to 2012-03-19 | 2014-06-22 09:19:36
Checking Daily data file for symbol CLK12 for the date range from 2012-03-19 to 2012-04-19 | 2014-06-22 09:19:36
Checking Daily data file for symbol CLM12 for the date range from 2012-04-19 to 2012-05-21 | 2014-06-22 09:19:36
Checking Daily data file for symbol CLN12 for the date range from 2012-05-21 to 2012-06-19 | 2014-06-22 09:19:36
Checking Daily data file for symbol CLQ12 for the date range from 2012-06-19 to 2012-07-19 | 2014-06-22 09:19:36
Checking Daily data file for symbol CLU12 for the date range from 2012-07-19 to 2012-08-20 | 2014-06-22 09:19:36
Checking Daily data file for symbol CLV12 for the date range from 2012-08-20 to 2012-09-19 | 2014-06-22 09:19:36
Checking Daily data file for symbol CLX12 for the date range from 2012-09-19 to 2012-10-19 | 2014-06-22 09:19:36
Checking Daily data file for symbol CLZ12 for the date range from 2012-10-19 to 2012-11-19 | 2014-06-22 09:19:36
Checking Daily data file for symbol CLF13 for the date range from 2012-11-19 to 2012-12-19 | 2014-06-22 09:19:36
Checking Daily data file for symbol CLG13 for the date range from 2012-12-19 to 2013-01-21 | 2014-06-22 09:19:36
Checking Daily data file for symbol CLH13 for the date range from 2013-01-21 to 2013-02-19 | 2014-06-22 09:19:36
Checking Daily data file for symbol CLJ13 for the date range from 2013-02-19 to 2013-03-19 | 2014-06-22 09:19:36
Checking Daily data file for symbol CLK13 for the date range from 2013-03-19 to 2013-04-19 | 2014-06-22 09:19:36
Checking Daily data file for symbol CLM13 for the date range from 2013-04-19 to 2013-05-20 | 2014-06-22 09:19:36
Checking Daily data file for symbol CLN13 for the date range from 2013-05-20 to 2013-06-19 | 2014-06-22 09:19:36
Checking Daily data file for symbol CLQ13 for the date range from 2013-06-19 to 2013-07-19 | 2014-06-22 09:19:36
Checking Daily data file for symbol CLU13 for the date range from 2013-07-19 to 2013-08-19 | 2014-06-22 09:19:36
Checking Daily data file for symbol CLV13 for the date range from 2013-08-19 to 2013-09-19 | 2014-06-22 09:19:36
Checking Daily data file for symbol CLX13 for the date range from 2013-09-19 to 2013-10-21 | 2014-06-22 09:19:36
Checking Daily data file for symbol CLZ13 for the date range from 2013-10-21 to 2013-11-19 | 2014-06-22 09:19:36
Checking Daily data file for symbol CLF14 for the date range from 2013-11-19 to 2013-12-19 | 2014-06-22 09:19:36
Checking Daily data file for symbol CLG14 for the date range from 2013-12-19 to 2014-01-20 | 2014-06-22 09:19:36
Checking Daily data file for symbol CLH14 for the date range from 2014-01-20 to 2014-02-19 | 2014-06-22 09:19:36
Checking Daily data file for symbol CLJ14 for the date range from 2014-02-19 to 2014-03-19 | 2014-06-22 09:19:36
Checking Daily data file for symbol CLK14 for the date range from 2014-03-19 to 2014-04-21 | 2014-06-22 09:19:36
Daily data file for symbol CLM14 existed and is empty. Skipping download. | 2014-06-22 09:19:36
Checking Daily data file for symbol CLN14 for the date range from 2014-05-19 to 2014-06-19 | 2014-06-22 09:19:36
Checking Daily data file for symbol CLQ14 for the date range from 2014-06-19 to 0 | 2014-06-22 09:19:36
Symbols used for CLQ14 continuous contract chart: | 2014-06-22 09:19:36
CLM02 | 2014-06-22 09:19:36
CLN02 | 2014-06-22 09:19:36
CLQ02 | 2014-06-22 09:19:36
CLU02 | 2014-06-22 09:19:36
CLV02 | 2014-06-22 09:19:36
CLX02 | 2014-06-22 09:19:36
CLZ02 | 2014-06-22 09:19:36
CLF03 | 2014-06-22 09:19:36
CLG03 | 2014-06-22 09:19:36
CLH03 | 2014-06-22 09:19:36
CLJ03 | 2014-06-22 09:19:36
CLK03 | 2014-06-22 09:19:36
CLM03 | 2014-06-22 09:19:36
CLN03 | 2014-06-22 09:19:36
CLQ03 | 2014-06-22 09:19:36
CLU03 | 2014-06-22 09:19:36
CLV03 | 2014-06-22 09:19:36
CLX03 | 2014-06-22 09:19:36
CLZ03 | 2014-06-22 09:19:36
CLF04 | 2014-06-22 09:19:36
CLG04 | 2014-06-22 09:19:36
CLH04 | 2014-06-22 09:19:36
CLJ04 | 2014-06-22 09:19:36
CLK04 | 2014-06-22 09:19:36
CLM04 | 2014-06-22 09:19:36
CLN04 | 2014-06-22 09:19:36
CLQ04 | 2014-06-22 09:19:36
CLU04 | 2014-06-22 09:19:36
CLV04 | 2014-06-22 09:19:36
CLX04 | 2014-06-22 09:19:36
CLZ04 | 2014-06-22 09:19:36
CLF05 | 2014-06-22 09:19:36
CLG05 | 2014-06-22 09:19:36
CLH05 | 2014-06-22 09:19:36
CLJ05 | 2014-06-22 09:19:36
CLK05 | 2014-06-22 09:19:36
CLM05 | 2014-06-22 09:19:36
CLN05 | 2014-06-22 09:19:36
CLQ05 | 2014-06-22 09:19:36
CLU05 | 2014-06-22 09:19:36
CLV05 | 2014-06-22 09:19:36
CLX05 | 2014-06-22 09:19:36
CLZ05 | 2014-06-22 09:19:36
CLF06 | 2014-06-22 09:19:36
CLG06 | 2014-06-22 09:19:36
CLH06 | 2014-06-22 09:19:36
CLJ06 | 2014-06-22 09:19:36
CLK06 | 2014-06-22 09:19:36
CLM06 | 2014-06-22 09:19:36
CLN06 | 2014-06-22 09:19:36
CLQ06 | 2014-06-22 09:19:36
CLU06 | 2014-06-22 09:19:36
CLV06 | 2014-06-22 09:19:36
CLX06 | 2014-06-22 09:19:36
CLZ06 | 2014-06-22 09:19:36
CLF07 | 2014-06-22 09:19:36
CLG07 | 2014-06-22 09:19:36
CLH07 | 2014-06-22 09:19:36
CLJ07 | 2014-06-22 09:19:36
CLK07 | 2014-06-22 09:19:36
CLM07 | 2014-06-22 09:19:36
CLN07 | 2014-06-22 09:19:36
CLQ07 | 2014-06-22 09:19:36
CLU07 | 2014-06-22 09:19:36
CLV07 | 2014-06-22 09:19:36
CLX07 | 2014-06-22 09:19:36
CLZ07 | 2014-06-22 09:19:36
CLF08 | 2014-06-22 09:19:36
CLG08 | 2014-06-22 09:19:36
CLH08 | 2014-06-22 09:19:36
CLJ08 | 2014-06-22 09:19:36
CLK08 | 2014-06-22 09:19:36
CLM08 | 2014-06-22 09:19:36
CLN08 | 2014-06-22 09:19:36
CLQ08 | 2014-06-22 09:19:36
CLU08 | 2014-06-22 09:19:36
CLV08 | 2014-06-22 09:19:36
CLX08 | 2014-06-22 09:19:36
CLZ08 | 2014-06-22 09:19:36
CLF09 | 2014-06-22 09:19:36
CLG09 | 2014-06-22 09:19:36
CLH09 | 2014-06-22 09:19:36
CLJ09 | 2014-06-22 09:19:36
CLK09 | 2014-06-22 09:19:36
CLM09 | 2014-06-22 09:19:36
CLN09 | 2014-06-22 09:19:36
CLQ09 | 2014-06-22 09:19:36
CLU09 | 2014-06-22 09:19:36
CLV09 | 2014-06-22 09:19:36
CLX09 | 2014-06-22 09:19:36
CLZ09 | 2014-06-22 09:19:36
CLF10 | 2014-06-22 09:19:36
CLG10 | 2014-06-22 09:19:36
CLH10 | 2014-06-22 09:19:36
CLJ10 | 2014-06-22 09:19:36
CLK10 | 2014-06-22 09:19:36
CLM10 | 2014-06-22 09:19:36
CLN10 | 2014-06-22 09:19:36
CLQ10 | 2014-06-22 09:19:36
CLU10 | 2014-06-22 09:19:36
CLV10 | 2014-06-22 09:19:36
CLX10 | 2014-06-22 09:19:36
CLZ10 | 2014-06-22 09:19:36
CLF11 | 2014-06-22 09:19:36
CLG11 | 2014-06-22 09:19:36
CLH11 | 2014-06-22 09:19:36
CLJ11 | 2014-06-22 09:19:36
CLK11 | 2014-06-22 09:19:36
CLM11 | 2014-06-22 09:19:36
CLN11 | 2014-06-22 09:19:36
CLQ11 | 2014-06-22 09:19:36
CLU11 | 2014-06-22 09:19:36
CLV11 | 2014-06-22 09:19:36
CLX11 | 2014-06-22 09:19:36
CLZ11 | 2014-06-22 09:19:36
CLF12 | 2014-06-22 09:19:36
CLG12 | 2014-06-22 09:19:36
CLH12 | 2014-06-22 09:19:36
CLJ12 | 2014-06-22 09:19:36
CLK12 | 2014-06-22 09:19:36
CLM12 | 2014-06-22 09:19:36
CLN12 | 2014-06-22 09:19:36
CLQ12 | 2014-06-22 09:19:36
CLU12 | 2014-06-22 09:19:36
CLV12 | 2014-06-22 09:19:36
CLX12 | 2014-06-22 09:19:36
CLZ12 | 2014-06-22 09:19:36
CLF13 | 2014-06-22 09:19:36
CLG13 | 2014-06-22 09:19:36
CLH13 | 2014-06-22 09:19:36
CLJ13 | 2014-06-22 09:19:36
CLK13 | 2014-06-22 09:19:36
CLM13 | 2014-06-22 09:19:36
CLN13 | 2014-06-22 09:19:36
CLQ13 | 2014-06-22 09:19:36
CLU13 | 2014-06-22 09:19:36
CLV13 | 2014-06-22 09:19:36
CLX13 | 2014-06-22 09:19:36
CLZ13 | 2014-06-22 09:19:36
CLF14 | 2014-06-22 09:19:36
CLG14 | 2014-06-22 09:19:36
CLH14 | 2014-06-22 09:19:36
CLJ14 | 2014-06-22 09:19:36
CLK14 | 2014-06-22 09:19:36
CLM14 | 2014-06-22 09:19:36
CLN14 | 2014-06-22 09:19:36
CLQ14 | 2014-06-22 09:19:36
Date rule based rollover from CLM11 to next contract occurs at 2011-05-19 | 2014-06-22 09:19:36
Date rule based rollover from CLN11 to next contract occurs at 2011-06-20 | 2014-06-22 09:19:36
Date rule based rollover from CLQ11 to next contract occurs at 2011-07-19 | 2014-06-22 09:19:36
Date rule based rollover from CLU11 to next contract occurs at 2011-08-19 | 2014-06-22 09:19:36
Date rule based rollover from CLV11 to next contract occurs at 2011-09-19 | 2014-06-22 09:19:36
Date rule based rollover from CLX11 to next contract occurs at 2011-10-19 | 2014-06-22 09:19:36
Date rule based rollover from CLZ11 to next contract occurs at 2011-11-21 | 2014-06-22 09:19:36
Date rule based rollover from CLF12 to next contract occurs at 2011-12-19 | 2014-06-22 09:19:36
Date rule based rollover from CLG12 to next contract occurs at 2012-01-19 | 2014-06-22 09:19:36
Date rule based rollover from CLH12 to next contract occurs at 2012-02-20 | 2014-06-22 09:19:36
Date rule based rollover from CLJ12 to next contract occurs at 2012-03-19 | 2014-06-22 09:19:36
Date rule based rollover from CLK12 to next contract occurs at 2012-04-19 | 2014-06-22 09:19:36
Date rule based rollover from CLM12 to next contract occurs at 2012-05-21 | 2014-06-22 09:19:36
Date rule based rollover from CLN12 to next contract occurs at 2012-06-19 | 2014-06-22 09:19:36
Date rule based rollover from CLQ12 to next contract occurs at 2012-07-19 | 2014-06-22 09:19:36
Date rule based rollover from CLU12 to next contract occurs at 2012-08-20 | 2014-06-22 09:19:36
Date rule based rollover from CLV12 to next contract occurs at 2012-09-19 | 2014-06-22 09:19:36
Date rule based rollover from CLX12 to next contract occurs at 2012-10-19 | 2014-06-22 09:19:36
Date rule based rollover from CLZ12 to next contract occurs at 2012-11-19 | 2014-06-22 09:19:36
Date rule based rollover from CLF13 to next contract occurs at 2012-12-19 | 2014-06-22 09:19:36
Date rule based rollover from CLG13 to next contract occurs at 2013-01-21 | 2014-06-22 09:19:36
Date rule based rollover from CLH13 to next contract occurs at 2013-02-19 | 2014-06-22 09:19:36
Date rule based rollover from CLJ13 to next contract occurs at 2013-03-19 | 2014-06-22 09:19:36
Date rule based rollover from CLK13 to next contract occurs at 2013-04-19 | 2014-06-22 09:19:36
Date rule based rollover from CLM13 to next contract occurs at 2013-05-20 | 2014-06-22 09:19:36
Date rule based rollover from CLN13 to next contract occurs at 2013-06-19 | 2014-06-22 09:19:36
Date rule based rollover from CLQ13 to next contract occurs at 2013-07-19 | 2014-06-22 09:19:36
Date rule based rollover from CLU13 to next contract occurs at 2013-08-19 | 2014-06-22 09:19:36
Date rule based rollover from CLV13 to next contract occurs at 2013-09-19 | 2014-06-22 09:19:36
Date rule based rollover from CLX13 to next contract occurs at 2013-10-21 | 2014-06-22 09:19:36
Date rule based rollover from CLZ13 to next contract occurs at 2013-11-19 | 2014-06-22 09:19:36
Date rule based rollover from CLF14 to next contract occurs at 2013-12-19 | 2014-06-22 09:19:36
Date rule based rollover from CLG14 to next contract occurs at 2014-01-20 | 2014-06-22 09:19:36
Date rule based rollover from CLH14 to next contract occurs at 2014-02-19 | 2014-06-22 09:19:36
Date rule based rollover from CLJ14 to next contract occurs at 2014-03-19 | 2014-06-22 09:19:36
Date rule based rollover from CLK14 to next contract occurs at 2014-04-21 | 2014-06-22 09:19:36
Date rule based rollover from CLM14 to next contract occurs at 2014-05-19 | 2014-06-22 09:19:36
Date rule based rollover from CLN14 to next contract occurs at 2014-06-19 | 2014-06-22 09:19:36
Date rule based rollover from CLQ14 to next contract occurs at 2014-07-21 | 2014-06-22 09:19:36
Date rule based rollover from CL-201302-NYMEX to next contract occurs at 2013-01-21 | 2014-06-22 09:19:36
Date rule based rollover from CL-201303-NYMEX to next contract occurs at 2013-02-19 | 2014-06-22 09:19:36
Date rule based rollover from CL-201304-NYMEX to next contract occurs at 2013-03-19 | 2014-06-22 09:19:36
Date rule based rollover from CL-201305-NYMEX to next contract occurs at 2013-04-19 | 2014-06-22 09:19:36
Date rule based rollover from CL-201306-NYMEX to next contract occurs at 2013-05-20 | 2014-06-22 09:19:36
Date rule based rollover from CL-201307-NYMEX to next contract occurs at 2013-06-19 | 2014-06-22 09:19:36
Date rule based rollover from CL-201308-NYMEX to next contract occurs at 2013-07-19 | 2014-06-22 09:19:36
Date rule based rollover from CL-201309-NYMEX to next contract occurs at 2013-08-19 | 2014-06-22 09:19:36
Date rule based rollover from CL-201310-NYMEX to next contract occurs at 2013-09-19 | 2014-06-22 09:19:36
Date rule based rollover from CL-201311-NYMEX to next contract occurs at 2013-10-21 | 2014-06-22 09:19:36
Date rule based rollover from CL-201312-NYMEX to next contract occurs at 2013-11-19 | 2014-06-22 09:19:36
Date rule based rollover from CL-201401-NYMEX to next contract occurs at 2013-12-19 | 2014-06-22 09:19:36
Date rule based rollover from CL-201402-NYMEX to next contract occurs at 2014-01-20 | 2014-06-22 09:19:36
Date rule based rollover from CL-201403-NYMEX to next contract occurs at 2014-02-19 | 2014-06-22 09:19:36
Date rule based rollover from CL-201404-NYMEX to next contract occurs at 2014-03-19 | 2014-06-22 09:19:36
Date rule based rollover from CL-201405-NYMEX to next contract occurs at 2014-04-21 | 2014-06-22 09:19:36
Date rule based rollover from CL-201406-NYMEX to next contract occurs at 2014-05-19 | 2014-06-22 09:19:36
Date rule based rollover from CL-201407-NYMEX to next contract occurs at 2014-06-19 | 2014-06-22 09:19:36
Date rule based rollover from CL-201408-NYMEX to next contract occurs at 2014-07-21 | 2014-06-22 09:19:36
Checking Intraday data file for symbol CL-201302-NYMEX for the date range from 2012-12-19 to 2013-01-21 | 2014-06-22 09:19:36
Checking Intraday data file for symbol CL-201303-NYMEX for the date range from 2013-01-21 to 2013-02-19 | 2014-06-22 09:19:36
Checking Intraday data file for symbol CL-201304-NYMEX for the date range from 2013-02-19 to 2013-03-19 | 2014-06-22 09:19:36
Checking Intraday data file for symbol CL-201305-NYMEX for the date range from 2013-03-19 to 2013-04-19 | 2014-06-22 09:19:36
Checking Intraday data file for symbol CL-201306-NYMEX for the date range from 2013-04-19 to 2013-05-20 | 2014-06-22 09:19:36
Checking Intraday data file for symbol CL-201307-NYMEX for the date range from 2013-05-20 to 2013-06-19 | 2014-06-22 09:19:36
Checking Intraday data file for symbol CL-201308-NYMEX for the date range from 2013-06-19 to 2013-07-19 | 2014-06-22 09:19:36
Checking Intraday data file for symbol CL-201309-NYMEX for the date range from 2013-07-19 to 2013-08-19 | 2014-06-22 09:19:36
Checking Intraday data file for symbol CL-201310-NYMEX for the date range from 2013-08-19 to 2013-09-19 | 2014-06-22 09:19:36
Checking Intraday data file for symbol CL-201311-NYMEX for the date range from 2013-09-19 to 2013-10-21 | 2014-06-22 09:19:36
Checking Intraday data file for symbol CL-201312-NYMEX for the date range from 2013-10-21 to 2013-11-19 | 2014-06-22 09:19:36
Checking Intraday data file for symbol CL-201401-NYMEX for the date range from 2013-11-19 to 2013-12-19 | 2014-06-22 09:19:36
Checking Intraday data file for symbol CL-201402-NYMEX for the date range from 2013-12-19 to 2014-01-20 | 2014-06-22 09:19:36
Checking Intraday data file for symbol CL-201403-NYMEX for the date range from 2014-01-20 to 2014-02-19 | 2014-06-22 09:19:36
Checking Intraday data file for symbol CL-201404-NYMEX for the date range from 2014-02-19 to 2014-03-19 | 2014-06-22 09:19:36
Checking Intraday data file for symbol CL-201405-NYMEX for the date range from 2014-03-19 to 2014-04-21 | 2014-06-22 09:19:36
Checking Intraday data file for symbol CL-201406-NYMEX for the date range from 2014-04-21 to 2014-05-19 | 2014-06-22 09:19:36
Daily data file for symbol CL-201406-NYMEX existed and is empty. Skipping download. | 2014-06-22 09:19:36
Checking Intraday data file for symbol CL-201407-NYMEX for the date range from 2014-05-19 to 2014-06-19 | 2014-06-22 09:19:36
Checking Intraday data file for symbol CL-201408-NYMEX for the date range from 2014-06-19 to 0 | 2014-06-22 09:19:36
Symbols used for CL-201408-NYMEX continuous contract chart: | 2014-06-22 09:19:36
CL-201302-NYMEX | 2014-06-22 09:19:36
CL-201303-NYMEX | 2014-06-22 09:19:36
CL-201304-NYMEX | 2014-06-22 09:19:36
CL-201305-NYMEX | 2014-06-22 09:19:36
CL-201306-NYMEX | 2014-06-22 09:19:36
CL-201307-NYMEX | 2014-06-22 09:19:36
CL-201308-NYMEX | 2014-06-22 09:19:36
CL-201309-NYMEX | 2014-06-22 09:19:36
CL-201310-NYMEX | 2014-06-22 09:19:36
CL-201311-NYMEX | 2014-06-22 09:19:36
CL-201312-NYMEX | 2014-06-22 09:19:36
CL-201401-NYMEX | 2014-06-22 09:19:36
CL-201402-NYMEX | 2014-06-22 09:19:36
CL-201403-NYMEX | 2014-06-22 09:19:36
CL-201404-NYMEX | 2014-06-22 09:19:36
CL-201405-NYMEX | 2014-06-22 09:19:36
CL-201406-NYMEX | 2014-06-22 09:19:36
CL-201407-NYMEX | 2014-06-22 09:19:36
CL-201408-NYMEX | 2014-06-22 09:19:36
Volume based rollover from CL-201302-NYMEX to CL-201303-NYMEX occurs at 2013-01-18 | 2014-06-22 09:19:36
Volume based rollover from CL-201303-NYMEX to CL-201304-NYMEX occurs at 2013-02-19 | 2014-06-22 09:19:36
Volume based rollover from CL-201304-NYMEX to CL-201305-NYMEX occurs at 2013-03-18 | 2014-06-22 09:19:36
Volume based rollover from CL-201305-NYMEX to CL-201306-NYMEX occurs at 2013-04-18 | 2014-06-22 09:19:36
Volume based rollover from CL-201306-NYMEX to CL-201307-NYMEX occurs at 2013-05-20 | 2014-06-22 09:19:36
Volume based rollover from CL-201307-NYMEX to CL-201308-NYMEX occurs at 2013-06-18 | 2014-06-22 09:19:37
Volume based rollover from CL-201308-NYMEX to CL-201309-NYMEX occurs at 2013-07-18 | 2014-06-22 09:19:37
Volume based rollover from CL-201309-NYMEX to CL-201310-NYMEX occurs at 2013-08-16 | 2014-06-22 09:19:37
Volume based rollover from CL-201310-NYMEX to CL-201311-NYMEX occurs at 2013-09-18 | 2014-06-22 09:19:37
Volume based rollover from CL-201311-NYMEX to CL-201312-NYMEX occurs at 2013-10-18 | 2014-06-22 09:19:37
Volume based rollover from CL-201312-NYMEX to CL-201401-NYMEX occurs at 2013-11-19 | 2014-06-22 09:19:37
Volume based rollover from CL-201401-NYMEX to CL-201402-NYMEX occurs at 2013-12-17 | 2014-06-22 09:19:37
Volume based rollover from CL-201402-NYMEX to CL-201403-NYMEX occurs at 2014-01-17 | 2014-06-22 09:19:37
Volume based rollover from CL-201403-NYMEX to CL-201404-NYMEX occurs at 2014-02-18 | 2014-06-22 09:19:37
Volume based rollover from CL-201404-NYMEX to CL-201405-NYMEX occurs at 2014-03-18 | 2014-06-22 09:19:37
Volume based rollover from CL-201405-NYMEX to CL-201406-NYMEX occurs at 2014-04-22 | 2014-06-22 09:19:37
Volume based rollover from CL-201406-NYMEX to CL-201407-NYMEX occurs at 0 | 2014-06-22 09:19:37
Using date based transition from CL-201406-NYMEX to CL-201407-NYMEX because volume based transition could not be determined. | 2014-06-22 09:19:37
Volume based rollover from CL-201407-NYMEX to CL-201408-NYMEX occurs at 2014-06-18 | 2014-06-22 09:19:37
CL-201408-NYMEX [CBV] 60 Min #7: Performing continuous futures contract back adjustment calculations. | 2014-06-22 09:19:37
CL-201408-NYMEX [CBV] 60 Min #7: CL-201302-NYMEX Open price on 2013-01-18 is 95.19. | 2014-06-22 09:19:37
CL-201408-NYMEX [CBV] 60 Min #7: CL-201303-NYMEX Open price on 2013-01-18 is 95.65. | 2014-06-22 09:19:37
CL-201408-NYMEX [CBV] 60 Min #7: CL-201302-NYMEX price difference to CL-201303-NYMEX is 0.46000001. | 2014-06-22 09:19:37
CL-201408-NYMEX [CBV] 60 Min #7: CL-201303-NYMEX Open price on 2013-02-19 is 95.97. | 2014-06-22 09:19:37
CL-201408-NYMEX [CBV] 60 Min #7: CL-201304-NYMEX Open price on 2013-02-19 is 96.39. | 2014-06-22 09:19:37
CL-201408-NYMEX [CBV] 60 Min #7: CL-201303-NYMEX price difference to CL-201304-NYMEX is 0.41999999. | 2014-06-22 09:19:37
CL-201408-NYMEX [CBV] 60 Min #7: CL-201304-NYMEX Open price on 2013-03-18 is 93.26. | 2014-06-22 09:19:37
CL-201408-NYMEX [CBV] 60 Min #7: CL-201305-NYMEX Open price on 2013-03-18 is 93.62. | 2014-06-22 09:19:37
CL-201408-NYMEX [CBV] 60 Min #7: CL-201304-NYMEX price difference to CL-201305-NYMEX is 0.36000001. | 2014-06-22 09:19:37
CL-201408-NYMEX [CBV] 60 Min #7: CL-201305-NYMEX Open price on 2013-04-18 is 86.39. | 2014-06-22 09:19:37
CL-201408-NYMEX [CBV] 60 Min #7: CL-201306-NYMEX Open price on 2013-04-18 is 86.6. | 2014-06-22 09:19:37
CL-201408-NYMEX [CBV] 60 Min #7: CL-201305-NYMEX price difference to CL-201306-NYMEX is 0.20999999. | 2014-06-22 09:19:37
CL-201408-NYMEX [CBV] 60 Min #7: CL-201306-NYMEX Open price on 2013-05-20 is 95.93. | 2014-06-22 09:19:37
CL-201408-NYMEX [CBV] 60 Min #7: CL-201307-NYMEX Open price on 2013-05-20 is 96.25. | 2014-06-22 09:19:37
CL-201408-NYMEX [CBV] 60 Min #7: CL-201306-NYMEX price difference to CL-201307-NYMEX is 0.31999999. | 2014-06-22 09:19:37
CL-201408-NYMEX [CBV] 60 Min #7: CL-201307-NYMEX Open price on 2013-06-18 is 97.93. | 2014-06-22 09:19:37
CL-201408-NYMEX [CBV] 60 Min #7: CL-201308-NYMEX Open price on 2013-06-18 is 98.16. | 2014-06-22 09:19:37
CL-201408-NYMEX [CBV] 60 Min #7: CL-201307-NYMEX price difference to CL-201308-NYMEX is 0.23. | 2014-06-22 09:19:37
CL-201408-NYMEX [CBV] 60 Min #7: CL-201308-NYMEX Open price on 2013-07-18 is 106.56. | 2014-06-22 09:19:37
CL-201408-NYMEX [CBV] 60 Min #7: CL-201309-NYMEX Open price on 2013-07-18 is 106.35. | 2014-06-22 09:19:37
CL-201408-NYMEX [CBV] 60 Min #7: CL-201308-NYMEX price difference to CL-201309-NYMEX is -0.20999999. | 2014-06-22 09:19:37
CL-201408-NYMEX [CBV] 60 Min #7: CL-201309-NYMEX Open price on 2013-08-16 is 107.18. | 2014-06-22 09:19:37
CL-201408-NYMEX [CBV] 60 Min #7: CL-201310-NYMEX Open price on 2013-08-16 is 107.01. | 2014-06-22 09:19:37
CL-201408-NYMEX [CBV] 60 Min #7: CL-201309-NYMEX price difference to CL-201310-NYMEX is -0.17. | 2014-06-22 09:19:37
CL-201408-NYMEX [CBV] 60 Min #7: CL-201310-NYMEX Open price on 2013-09-18 is 105.53. | 2014-06-22 09:19:37
CL-201408-NYMEX [CBV] 60 Min #7: CL-201311-NYMEX Open price on 2013-09-18 is 104.77. | 2014-06-22 09:19:37
CL-201408-NYMEX [CBV] 60 Min #7: CL-201310-NYMEX price difference to CL-201311-NYMEX is -0.75999999. | 2014-06-22 09:19:37
CL-201408-NYMEX [CBV] 60 Min #7: CL-201311-NYMEX Open price on 2013-10-18 is 100.72. | 2014-06-22 09:19:37
CL-201408-NYMEX [CBV] 60 Min #7: CL-201312-NYMEX Open price on 2013-10-18 is 101. | 2014-06-22 09:19:37
CL-201408-NYMEX [CBV] 60 Min #7: CL-201311-NYMEX price difference to CL-201312-NYMEX is 0.28. | 2014-06-22 09:19:37
CL-201408-NYMEX [CBV] 60 Min #7: CL-201312-NYMEX Open price on 2013-11-19 is 93. | 2014-06-22 09:19:37
CL-201408-NYMEX [CBV] 60 Min #7: CL-201401-NYMEX Open price on 2013-11-19 is 93.64. | 2014-06-22 09:19:37
CL-201408-NYMEX [CBV] 60 Min #7: CL-201312-NYMEX price difference to CL-201401-NYMEX is 0.63999999. | 2014-06-22 09:19:37
CL-201408-NYMEX [CBV] 60 Min #7: CL-201401-NYMEX Open price on 2013-12-17 is 97.3. | 2014-06-22 09:19:37
CL-201408-NYMEX [CBV] 60 Min #7: CL-201402-NYMEX Open price on 2013-12-17 is 97.54. | 2014-06-22 09:19:37
CL-201408-NYMEX [CBV] 60 Min #7: CL-201401-NYMEX price difference to CL-201402-NYMEX is 0.23999999. | 2014-06-22 09:19:37
CL-201408-NYMEX [CBV] 60 Min #7: CL-201402-NYMEX Open price on 2014-01-17 is 94.17. | 2014-06-22 09:19:37
CL-201408-NYMEX [CBV] 60 Min #7: CL-201403-NYMEX Open price on 2014-01-17 is 94.29. | 2014-06-22 09:19:37
CL-201408-NYMEX [CBV] 60 Min #7: CL-201402-NYMEX price difference to CL-201403-NYMEX is 0.12. | 2014-06-22 09:19:37
CL-201408-NYMEX [CBV] 60 Min #7: CL-201403-NYMEX Open price on 2014-02-18 is 100.32. | 2014-06-22 09:19:37
CL-201408-NYMEX [CBV] 60 Min #7: CL-201404-NYMEX Open price on 2014-02-18 is 100.12. | 2014-06-22 09:19:37
CL-201408-NYMEX [CBV] 60 Min #7: CL-201403-NYMEX price difference to CL-201404-NYMEX is -0.2. | 2014-06-22 09:19:37
CL-201408-NYMEX [CBV] 60 Min #7: CL-201404-NYMEX Open price on 2014-03-18 is 97.97. | 2014-06-22 09:19:37
CL-201408-NYMEX [CBV] 60 Min #7: CL-201405-NYMEX Open price on 2014-03-18 is 97.46. | 2014-06-22 09:19:37
CL-201408-NYMEX [CBV] 60 Min #7: CL-201404-NYMEX price difference to CL-201405-NYMEX is -0.50999999. | 2014-06-22 09:19:37
CL-201408-NYMEX [CBV] 60 Min #7: CL-201405-NYMEX Open price on 2014-04-22 is 104.36. | 2014-06-22 09:19:37
Error while getting daily open price with date 2014-04-25 from file. C:\SierraChart\Data\CLM14.dly. Error: Encountered end of file. | 2014-06-22 09:19:37
CL-201408-NYMEX [CBV] 60 Min #7: CL-201405-NYMEX price difference to CL-201406-NYMEX is 0. | 2014-06-22 09:19:37
Error while getting daily open price with date 2014-05-22 from file. C:\SierraChart\Data\CLM14.dly. Error: Encountered end of file. | 2014-06-22 09:19:37
CL-201408-NYMEX [CBV] 60 Min #7: CL-201407-NYMEX Open price on 2014-05-19 is 101.68. | 2014-06-22 09:19:37
CL-201408-NYMEX [CBV] 60 Min #7: CL-201406-NYMEX price difference to CL-201407-NYMEX is 0. | 2014-06-22 09:19:37
CL-201408-NYMEX [CBV] 60 Min #7: CL-201407-NYMEX Open price on 2014-06-18 is 106.6. | 2014-06-22 09:19:37
CL-201408-NYMEX [CBV] 60 Min #7: CL-201408-NYMEX Open price on 2014-06-18 is 106.06. | 2014-06-22 09:19:37
CL-201408-NYMEX [CBV] 60 Min #7: CL-201407-NYMEX price difference to CL-201408-NYMEX is -0.54000002. | 2014-06-22 09:19:37
CL-201408-NYMEX [CBV] 60 Min #7: Back adjust amount for symbol CL-201302-NYMEX is 0.88999981. | 2014-06-22 09:19:37
CL-201408-NYMEX [CBV] 60 Min #7: Back adjust amount for symbol CL-201303-NYMEX is 0.42999989. | 2014-06-22 09:19:37
CL-201408-NYMEX [CBV] 60 Min #7: Back adjust amount for symbol CL-201304-NYMEX is 0.0099999309. | 2014-06-22 09:19:37
CL-201408-NYMEX [CBV] 60 Min #7: Back adjust amount for symbol CL-201305-NYMEX is -0.35000002. | 2014-06-22 09:19:37
CL-201408-NYMEX [CBV] 60 Min #7: Back adjust amount for symbol CL-201306-NYMEX is -0.56. | 2014-06-22 09:19:37
CL-201408-NYMEX [CBV] 60 Min #7: Back adjust amount for symbol CL-201307-NYMEX is -0.88000005. | 2014-06-22 09:19:37
CL-201408-NYMEX [CBV] 60 Min #7: Back adjust amount for symbol CL-201308-NYMEX is -1.1100001. | 2014-06-22 09:19:37
CL-201408-NYMEX [CBV] 60 Min #7: Back adjust amount for symbol CL-201309-NYMEX is -0.90000004. | 2014-06-22 09:19:37
CL-201408-NYMEX [CBV] 60 Min #7: Back adjust amount for symbol CL-201310-NYMEX is -0.73000002. | 2014-06-22 09:19:37
CL-201408-NYMEX [CBV] 60 Min #7: Back adjust amount for symbol CL-201311-NYMEX is 0.029999912. | 2014-06-22 09:19:37
CL-201408-NYMEX [CBV] 60 Min #7: Back adjust amount for symbol CL-201312-NYMEX is -0.25. | 2014-06-22 09:19:37
CL-201408-NYMEX [CBV] 60 Min #7: Back adjust amount for symbol CL-201401-NYMEX is -0.89000005. | 2014-06-22 09:19:37
CL-201408-NYMEX [CBV] 60 Min #7: Back adjust amount for symbol CL-201402-NYMEX is -1.13. | 2014-06-22 09:19:37
CL-201408-NYMEX [CBV] 60 Min #7: Back adjust amount for symbol CL-201403-NYMEX is -1.25. | 2014-06-22 09:19:37
CL-201408-NYMEX [CBV] 60 Min #7: Back adjust amount for symbol CL-201404-NYMEX is -1.05. | 2014-06-22 09:19:37
CL-201408-NYMEX [CBV] 60 Min #7: Back adjust amount for symbol CL-201405-NYMEX is -0.54000002. | 2014-06-22 09:19:37
CL-201408-NYMEX [CBV] 60 Min #7: Back adjust amount for symbol CL-201406-NYMEX is -0.54000002. | 2014-06-22 09:19:37
CL-201408-NYMEX [CBV] 60 Min #7: Back adjust amount for symbol CL-201407-NYMEX is -0.54000002. | 2014-06-22 09:19:37
HD Request # 3 - Downloading Historical Daily chart data for CLZ11. Starting date: 2011-11-17. Service: ib | 2014-06-22 09:19:37
HD Request # 3 - Using user Barchart Historical data account. | 2014-06-22 09:19:37
HD Request # 3 - Requesting historical Daily data for CLZ11 starting at 2011-11-16 | 2014-06-22 09:19:37
HTTP request #1 returned the following error: Windows error code 12007: The server name or address could not be resolved | 2014-06-22 09:19:49
HD Request # 3 - Download from the SC Historical Data service failed due to a HTTP error. | 2014-06-22 09:19:49
HD Request # 3 - Error downloading historical Daily data for CLZ11. There was a communication error with the server. | 2014-06-22 09:19:49
HD Request # 3 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for CLZ11 | 2014-06-22 09:19:49
HD Request # 3 - Daily download COMPLETE for CLZ11. Completion time: 12s | 2014-06-22 09:19:49
HD Request # 4 - Downloading Historical Daily chart data for CLZ05. Starting date: 2005-11-17. Service: ib | 2014-06-22 09:19:49
HD Request # 4 - Using user Barchart Historical data account. | 2014-06-22 09:19:49
HD Request # 4 - Requesting historical Daily data for CLZ05 starting at 2005-11-16 | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: Download is complete for all contract months in chart. Proceeding with data load. | 2014-06-22 09:19:49
Volume based rollover from CLM11 to CLN11 occurs at 2011-05-18 | 2014-06-22 09:19:49
Volume based rollover from CLN11 to CLQ11 occurs at 2011-06-20 | 2014-06-22 09:19:49
Volume based rollover from CLQ11 to CLU11 occurs at 2011-07-19 | 2014-06-22 09:19:49
Volume based rollover from CLU11 to CLV11 occurs at 2011-08-19 | 2014-06-22 09:19:49
Volume based rollover from CLV11 to CLX11 occurs at 2011-09-19 | 2014-06-22 09:19:49
Volume based rollover from CLX11 to CLZ11 occurs at 2011-10-18 | 2014-06-22 09:19:49
Volume based rollover from CLZ11 to CLF12 occurs at 2011-11-17 | 2014-06-22 09:19:49
Volume based rollover from CLF12 to CLG12 occurs at 2011-12-19 | 2014-06-22 09:19:49
Volume based rollover from CLG12 to CLH12 occurs at 2012-01-19 | 2014-06-22 09:19:49
Volume based rollover from CLH12 to CLJ12 occurs at 2012-02-17 | 2014-06-22 09:19:49
Volume based rollover from CLJ12 to CLK12 occurs at 2012-03-19 | 2014-06-22 09:19:49
Volume based rollover from CLK12 to CLM12 occurs at 2012-04-19 | 2014-06-22 09:19:49
Volume based rollover from CLM12 to CLN12 occurs at 2012-05-21 | 2014-06-22 09:19:49
Volume based rollover from CLN12 to CLQ12 occurs at 2012-06-19 | 2014-06-22 09:19:49
Volume based rollover from CLQ12 to CLU12 occurs at 2012-07-19 | 2014-06-22 09:19:49
Volume based rollover from CLU12 to CLV12 occurs at 2012-08-20 | 2014-06-22 09:19:49
Volume based rollover from CLV12 to CLX12 occurs at 2012-09-19 | 2014-06-22 09:19:49
Volume based rollover from CLX12 to CLZ12 occurs at 2012-10-19 | 2014-06-22 09:19:49
Volume based rollover from CLZ12 to CLF13 occurs at 2012-11-15 | 2014-06-22 09:19:49
Volume based rollover from CLF13 to CLG13 occurs at 2012-12-18 | 2014-06-22 09:19:49
Volume based rollover from CLG13 to CLH13 occurs at 2013-01-18 | 2014-06-22 09:19:49
Volume based rollover from CLH13 to CLJ13 occurs at 2013-02-19 | 2014-06-22 09:19:49
Volume based rollover from CLJ13 to CLK13 occurs at 2013-03-18 | 2014-06-22 09:19:49
Volume based rollover from CLK13 to CLM13 occurs at 2013-04-18 | 2014-06-22 09:19:49
Volume based rollover from CLM13 to CLN13 occurs at 2013-05-20 | 2014-06-22 09:19:49
Volume based rollover from CLN13 to CLQ13 occurs at 2013-06-18 | 2014-06-22 09:19:49
Volume based rollover from CLQ13 to CLU13 occurs at 2013-07-18 | 2014-06-22 09:19:49
Volume based rollover from CLU13 to CLV13 occurs at 2013-08-16 | 2014-06-22 09:19:49
Volume based rollover from CLV13 to CLX13 occurs at 2013-09-18 | 2014-06-22 09:19:49
Volume based rollover from CLX13 to CLZ13 occurs at 2013-10-18 | 2014-06-22 09:19:49
Volume based rollover from CLZ13 to CLF14 occurs at 2013-11-19 | 2014-06-22 09:19:49
Volume based rollover from CLF14 to CLG14 occurs at 2013-12-17 | 2014-06-22 09:19:49
Volume based rollover from CLG14 to CLH14 occurs at 2014-01-17 | 2014-06-22 09:19:49
Volume based rollover from CLH14 to CLJ14 occurs at 2014-02-18 | 2014-06-22 09:19:49
Volume based rollover from CLJ14 to CLK14 occurs at 2014-03-18 | 2014-06-22 09:19:49
Volume based rollover from CLK14 to CLM14 occurs at 2014-04-22 | 2014-06-22 09:19:49
Volume based rollover from CLM14 to CLN14 occurs at 0 | 2014-06-22 09:19:49
Using date based transition from CLM14 to CLN14 because volume based transition could not be determined. | 2014-06-22 09:19:49
Volume based rollover from CLN14 to CLQ14 occurs at 2014-06-18 | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: Performing continuous futures contract back adjustment calculations. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLM11 Open price on 2011-05-18 is 97.57. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLN11 Open price on 2011-05-18 is 98.18. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLM11 price difference to CLN11 is 0.61000001. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLN11 Open price on 2011-06-20 is 92.8. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLQ11 Open price on 2011-06-20 is 93.17. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLN11 price difference to CLQ11 is 0.37. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLQ11 Open price on 2011-07-19 is 96.16. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLU11 Open price on 2011-07-19 is 96.45. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLQ11 price difference to CLU11 is 0.28999999. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLU11 Open price on 2011-08-19 is 81.3. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLV11 Open price on 2011-08-19 is 81.45. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLU11 price difference to CLV11 is 0.15000001. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLV11 Open price on 2011-09-19 is 87.75. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLX11 Open price on 2011-09-19 is 87.8. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLV11 price difference to CLX11 is 0.050000001. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLX11 Open price on 2011-10-18 is 86.2. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLZ11 Open price on 2011-10-18 is 86.3. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLX11 price difference to CLZ11 is 0.1. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLZ11 Open price on 2011-11-17 is 101.76. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLF12 Open price on 2011-11-17 is 101.74. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLZ11 price difference to CLF12 is -0.02. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLF12 Open price on 2011-12-19 is 93.76. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLG12 Open price on 2011-12-19 is 93.77. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLF12 price difference to CLG12 is 0.0099999998. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLG12 Open price on 2012-01-19 is 101.14. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLH12 Open price on 2012-01-19 is 101.35. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLG12 price difference to CLH12 is 0.20999999. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLH12 Open price on 2012-02-17 is 102.35. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLJ12 Open price on 2012-02-17 is 102.64. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLH12 price difference to CLJ12 is 0.28999999. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLJ12 Open price on 2012-03-19 is 107.18. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLK12 Open price on 2012-03-19 is 107.78. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLJ12 price difference to CLK12 is 0.60000002. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLK12 Open price on 2012-04-19 is 102.73. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLM12 Open price on 2012-04-19 is 103.21. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLK12 price difference to CLM12 is 0.47999999. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLM12 Open price on 2012-05-21 is 91.27. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLN12 Open price on 2012-05-21 is 91.71. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLM12 price difference to CLN12 is 0.44. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLN12 Open price on 2012-06-19 is 83.06. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLQ12 Open price on 2012-06-19 is 83.44. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLN12 price difference to CLQ12 is 0.38. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLQ12 Open price on 2012-07-19 is 90.08. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLU12 Open price on 2012-07-19 is 90.35. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLQ12 price difference to CLU12 is 0.27000001. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLU12 Open price on 2012-08-20 is 96.36. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLV12 Open price on 2012-08-20 is 96.64. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLU12 price difference to CLV12 is 0.28. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLV12 Open price on 2012-09-19 is 95.49. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLX12 Open price on 2012-09-19 is 95.83. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLV12 price difference to CLX12 is 0.34. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLX12 Open price on 2012-10-19 is 92.04. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLZ12 Open price on 2012-10-19 is 92.48. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLX12 price difference to CLZ12 is 0.44. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLZ12 Open price on 2012-11-15 is 86.36. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLF13 Open price on 2012-11-15 is 86.77. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLZ12 price difference to CLF13 is 0.41. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLF13 Open price on 2012-12-18 is 87.45. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLG13 Open price on 2012-12-18 is 87.94. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLF13 price difference to CLG13 is 0.49000001. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLG13 Open price on 2013-01-18 is 95.19. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLH13 Open price on 2013-01-18 is 95.65. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLG13 price difference to CLH13 is 0.46000001. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLH13 Open price on 2013-02-19 is 95.97. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLJ13 Open price on 2013-02-19 is 96.39. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLH13 price difference to CLJ13 is 0.41999999. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLJ13 Open price on 2013-03-18 is 93.26. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLK13 Open price on 2013-03-18 is 93.62. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLJ13 price difference to CLK13 is 0.36000001. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLK13 Open price on 2013-04-18 is 86.39. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLM13 Open price on 2013-04-18 is 86.6. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLK13 price difference to CLM13 is 0.20999999. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLM13 Open price on 2013-05-20 is 95.93. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLN13 Open price on 2013-05-20 is 96.25. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLM13 price difference to CLN13 is 0.31999999. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLN13 Open price on 2013-06-18 is 97.93. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLQ13 Open price on 2013-06-18 is 98.16. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLN13 price difference to CLQ13 is 0.23. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLQ13 Open price on 2013-07-18 is 106.56. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLU13 Open price on 2013-07-18 is 106.35. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLQ13 price difference to CLU13 is -0.20999999. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLU13 Open price on 2013-08-16 is 107.18. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLV13 Open price on 2013-08-16 is 107.01. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLU13 price difference to CLV13 is -0.17. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLV13 Open price on 2013-09-18 is 105.53. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLX13 Open price on 2013-09-18 is 104.77. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLV13 price difference to CLX13 is -0.75999999. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLX13 Open price on 2013-10-18 is 100.72. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLZ13 Open price on 2013-10-18 is 101. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLX13 price difference to CLZ13 is 0.28. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLZ13 Open price on 2013-11-19 is 93. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLF14 Open price on 2013-11-19 is 93.64. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLZ13 price difference to CLF14 is 0.63999999. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLF14 Open price on 2013-12-17 is 97.3. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLG14 Open price on 2013-12-17 is 97.54. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLF14 price difference to CLG14 is 0.23999999. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLG14 Open price on 2014-01-17 is 94.17. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLH14 Open price on 2014-01-17 is 94.29. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLG14 price difference to CLH14 is 0.12. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLH14 Open price on 2014-02-18 is 100.32. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLJ14 Open price on 2014-02-18 is 100.12. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLH14 price difference to CLJ14 is -0.2. | 2014-06-22 09:19:49
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLJ14 Open price on 2014-03-18 is 97.97. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLK14 Open price on 2014-03-18 is 97.46. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLJ14 price difference to CLK14 is -0.50999999. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLK14 Open price on 2014-04-22 is 104.36. | 2014-06-22 09:19:50
Error while getting daily open price with date 2014-04-25 from file. C:\SierraChart\Data\CLM14.dly. Error: Encountered end of file. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLK14 price difference to CLM14 is 0. | 2014-06-22 09:19:50
Error while getting daily open price with date 2014-05-22 from file. C:\SierraChart\Data\CLM14.dly. Error: Encountered end of file. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLN14 Open price on 2014-05-19 is 101.68. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLM14 price difference to CLN14 is 0. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLN14 Open price on 2014-06-18 is 106.6. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLQ14 Open price on 2014-06-18 is 106.06. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Daily #1: CLN14 price difference to CLQ14 is -0.54000002. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Daily #1: Back adjust amount for symbol CLM11 is 7.0799999. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Daily #1: Back adjust amount for symbol CLN11 is 6.4700003. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Daily #1: Back adjust amount for symbol CLQ11 is 6.1000004. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Daily #1: Back adjust amount for symbol CLU11 is 5.8100004. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Daily #1: Back adjust amount for symbol CLV11 is 5.6599998. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Daily #1: Back adjust amount for symbol CLX11 is 5.6100006. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Daily #1: Back adjust amount for symbol CLZ11 is 5.5100002. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Daily #1: Back adjust amount for symbol CLF12 is 5.5299997. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Daily #1: Back adjust amount for symbol CLG12 is 5.5200005. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Daily #1: Back adjust amount for symbol CLH12 is 5.3100004. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Daily #1: Back adjust amount for symbol CLJ12 is 5.0200005. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Daily #1: Back adjust amount for symbol CLK12 is 4.4200001. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Daily #1: Back adjust amount for symbol CLM12 is 3.9400005. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Daily #1: Back adjust amount for symbol CLN12 is 3.5. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Daily #1: Back adjust amount for symbol CLQ12 is 3.1200001. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Daily #1: Back adjust amount for symbol CLU12 is 2.8499999. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Daily #1: Back adjust amount for symbol CLV12 is 2.5699999. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Daily #1: Back adjust amount for symbol CLX12 is 2.2299998. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Daily #1: Back adjust amount for symbol CLZ12 is 1.7899997. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Daily #1: Back adjust amount for symbol CLF13 is 1.3799999. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Daily #1: Back adjust amount for symbol CLG13 is 0.88999981. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Daily #1: Back adjust amount for symbol CLH13 is 0.42999989. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Daily #1: Back adjust amount for symbol CLJ13 is 0.0099999309. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Daily #1: Back adjust amount for symbol CLK13 is -0.35000002. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Daily #1: Back adjust amount for symbol CLM13 is -0.56. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Daily #1: Back adjust amount for symbol CLN13 is -0.88000005. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Daily #1: Back adjust amount for symbol CLQ13 is -1.1100001. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Daily #1: Back adjust amount for symbol CLU13 is -0.90000004. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Daily #1: Back adjust amount for symbol CLV13 is -0.73000002. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Daily #1: Back adjust amount for symbol CLX13 is 0.029999912. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Daily #1: Back adjust amount for symbol CLZ13 is -0.25. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Daily #1: Back adjust amount for symbol CLF14 is -0.89000005. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Daily #1: Back adjust amount for symbol CLG14 is -1.13. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Daily #1: Back adjust amount for symbol CLH14 is -1.25. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Daily #1: Back adjust amount for symbol CLJ14 is -1.05. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Daily #1: Back adjust amount for symbol CLK14 is -0.54000002. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Daily #1: Back adjust amount for symbol CLM14 is -0.54000002. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Daily #1: Back adjust amount for symbol CLN14 is -0.54000002. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: Download is complete for all contract months in chart. Proceeding with data load. | 2014-06-22 09:19:50
Volume based rollover from CLM11 to CLN11 occurs at 2011-05-18 | 2014-06-22 09:19:50
Volume based rollover from CLN11 to CLQ11 occurs at 2011-06-20 | 2014-06-22 09:19:50
Volume based rollover from CLQ11 to CLU11 occurs at 2011-07-19 | 2014-06-22 09:19:50
Volume based rollover from CLU11 to CLV11 occurs at 2011-08-19 | 2014-06-22 09:19:50
Volume based rollover from CLV11 to CLX11 occurs at 2011-09-19 | 2014-06-22 09:19:50
Volume based rollover from CLX11 to CLZ11 occurs at 2011-10-18 | 2014-06-22 09:19:50
Volume based rollover from CLZ11 to CLF12 occurs at 2011-11-17 | 2014-06-22 09:19:50
Volume based rollover from CLF12 to CLG12 occurs at 2011-12-19 | 2014-06-22 09:19:50
Volume based rollover from CLG12 to CLH12 occurs at 2012-01-19 | 2014-06-22 09:19:50
Volume based rollover from CLH12 to CLJ12 occurs at 2012-02-17 | 2014-06-22 09:19:50
Volume based rollover from CLJ12 to CLK12 occurs at 2012-03-19 | 2014-06-22 09:19:50
Volume based rollover from CLK12 to CLM12 occurs at 2012-04-19 | 2014-06-22 09:19:50
Volume based rollover from CLM12 to CLN12 occurs at 2012-05-21 | 2014-06-22 09:19:50
Volume based rollover from CLN12 to CLQ12 occurs at 2012-06-19 | 2014-06-22 09:19:50
Volume based rollover from CLQ12 to CLU12 occurs at 2012-07-19 | 2014-06-22 09:19:50
Volume based rollover from CLU12 to CLV12 occurs at 2012-08-20 | 2014-06-22 09:19:50
Volume based rollover from CLV12 to CLX12 occurs at 2012-09-19 | 2014-06-22 09:19:50
Volume based rollover from CLX12 to CLZ12 occurs at 2012-10-19 | 2014-06-22 09:19:50
Volume based rollover from CLZ12 to CLF13 occurs at 2012-11-15 | 2014-06-22 09:19:50
Volume based rollover from CLF13 to CLG13 occurs at 2012-12-18 | 2014-06-22 09:19:50
Volume based rollover from CLG13 to CLH13 occurs at 2013-01-18 | 2014-06-22 09:19:50
Volume based rollover from CLH13 to CLJ13 occurs at 2013-02-19 | 2014-06-22 09:19:50
Volume based rollover from CLJ13 to CLK13 occurs at 2013-03-18 | 2014-06-22 09:19:50
Volume based rollover from CLK13 to CLM13 occurs at 2013-04-18 | 2014-06-22 09:19:50
Volume based rollover from CLM13 to CLN13 occurs at 2013-05-20 | 2014-06-22 09:19:50
Volume based rollover from CLN13 to CLQ13 occurs at 2013-06-18 | 2014-06-22 09:19:50
Volume based rollover from CLQ13 to CLU13 occurs at 2013-07-18 | 2014-06-22 09:19:50
Volume based rollover from CLU13 to CLV13 occurs at 2013-08-16 | 2014-06-22 09:19:50
Volume based rollover from CLV13 to CLX13 occurs at 2013-09-18 | 2014-06-22 09:19:50
Volume based rollover from CLX13 to CLZ13 occurs at 2013-10-18 | 2014-06-22 09:19:50
Volume based rollover from CLZ13 to CLF14 occurs at 2013-11-19 | 2014-06-22 09:19:50
Volume based rollover from CLF14 to CLG14 occurs at 2013-12-17 | 2014-06-22 09:19:50
Volume based rollover from CLG14 to CLH14 occurs at 2014-01-17 | 2014-06-22 09:19:50
Volume based rollover from CLH14 to CLJ14 occurs at 2014-02-18 | 2014-06-22 09:19:50
Volume based rollover from CLJ14 to CLK14 occurs at 2014-03-18 | 2014-06-22 09:19:50
Volume based rollover from CLK14 to CLM14 occurs at 2014-04-22 | 2014-06-22 09:19:50
Volume based rollover from CLM14 to CLN14 occurs at 0 | 2014-06-22 09:19:50
Using date based transition from CLM14 to CLN14 because volume based transition could not be determined. | 2014-06-22 09:19:50
Volume based rollover from CLN14 to CLQ14 occurs at 2014-06-18 | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: Performing continuous futures contract back adjustment calculations. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLM11 Open price on 2011-05-18 is 97.57. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLN11 Open price on 2011-05-18 is 98.18. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLM11 price difference to CLN11 is 0.61000001. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLN11 Open price on 2011-06-20 is 92.8. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLQ11 Open price on 2011-06-20 is 93.17. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLN11 price difference to CLQ11 is 0.37. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLQ11 Open price on 2011-07-19 is 96.16. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLU11 Open price on 2011-07-19 is 96.45. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLQ11 price difference to CLU11 is 0.28999999. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLU11 Open price on 2011-08-19 is 81.3. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLV11 Open price on 2011-08-19 is 81.45. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLU11 price difference to CLV11 is 0.15000001. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLV11 Open price on 2011-09-19 is 87.75. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLX11 Open price on 2011-09-19 is 87.8. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLV11 price difference to CLX11 is 0.050000001. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLX11 Open price on 2011-10-18 is 86.2. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLZ11 Open price on 2011-10-18 is 86.3. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLX11 price difference to CLZ11 is 0.1. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLZ11 Open price on 2011-11-17 is 101.76. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLF12 Open price on 2011-11-17 is 101.74. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLZ11 price difference to CLF12 is -0.02. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLF12 Open price on 2011-12-19 is 93.76. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLG12 Open price on 2011-12-19 is 93.77. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLF12 price difference to CLG12 is 0.0099999998. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLG12 Open price on 2012-01-19 is 101.14. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLH12 Open price on 2012-01-19 is 101.35. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLG12 price difference to CLH12 is 0.20999999. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLH12 Open price on 2012-02-17 is 102.35. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLJ12 Open price on 2012-02-17 is 102.64. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLH12 price difference to CLJ12 is 0.28999999. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLJ12 Open price on 2012-03-19 is 107.18. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLK12 Open price on 2012-03-19 is 107.78. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLJ12 price difference to CLK12 is 0.60000002. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLK12 Open price on 2012-04-19 is 102.73. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLM12 Open price on 2012-04-19 is 103.21. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLK12 price difference to CLM12 is 0.47999999. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLM12 Open price on 2012-05-21 is 91.27. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLN12 Open price on 2012-05-21 is 91.71. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLM12 price difference to CLN12 is 0.44. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLN12 Open price on 2012-06-19 is 83.06. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLQ12 Open price on 2012-06-19 is 83.44. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLN12 price difference to CLQ12 is 0.38. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLQ12 Open price on 2012-07-19 is 90.08. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLU12 Open price on 2012-07-19 is 90.35. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLQ12 price difference to CLU12 is 0.27000001. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLU12 Open price on 2012-08-20 is 96.36. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLV12 Open price on 2012-08-20 is 96.64. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLU12 price difference to CLV12 is 0.28. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLV12 Open price on 2012-09-19 is 95.49. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLX12 Open price on 2012-09-19 is 95.83. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLV12 price difference to CLX12 is 0.34. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLX12 Open price on 2012-10-19 is 92.04. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLZ12 Open price on 2012-10-19 is 92.48. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLX12 price difference to CLZ12 is 0.44. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLZ12 Open price on 2012-11-15 is 86.36. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLF13 Open price on 2012-11-15 is 86.77. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLZ12 price difference to CLF13 is 0.41. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLF13 Open price on 2012-12-18 is 87.45. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLG13 Open price on 2012-12-18 is 87.94. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLF13 price difference to CLG13 is 0.49000001. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLG13 Open price on 2013-01-18 is 95.19. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLH13 Open price on 2013-01-18 is 95.65. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLG13 price difference to CLH13 is 0.46000001. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLH13 Open price on 2013-02-19 is 95.97. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLJ13 Open price on 2013-02-19 is 96.39. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLH13 price difference to CLJ13 is 0.41999999. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLJ13 Open price on 2013-03-18 is 93.26. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLK13 Open price on 2013-03-18 is 93.62. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLJ13 price difference to CLK13 is 0.36000001. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLK13 Open price on 2013-04-18 is 86.39. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLM13 Open price on 2013-04-18 is 86.6. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLK13 price difference to CLM13 is 0.20999999. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLM13 Open price on 2013-05-20 is 95.93. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLN13 Open price on 2013-05-20 is 96.25. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLM13 price difference to CLN13 is 0.31999999. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLN13 Open price on 2013-06-18 is 97.93. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLQ13 Open price on 2013-06-18 is 98.16. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLN13 price difference to CLQ13 is 0.23. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLQ13 Open price on 2013-07-18 is 106.56. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLU13 Open price on 2013-07-18 is 106.35. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLQ13 price difference to CLU13 is -0.20999999. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLU13 Open price on 2013-08-16 is 107.18. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLV13 Open price on 2013-08-16 is 107.01. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLU13 price difference to CLV13 is -0.17. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLV13 Open price on 2013-09-18 is 105.53. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLX13 Open price on 2013-09-18 is 104.77. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLV13 price difference to CLX13 is -0.75999999. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLX13 Open price on 2013-10-18 is 100.72. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLZ13 Open price on 2013-10-18 is 101. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLX13 price difference to CLZ13 is 0.28. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLZ13 Open price on 2013-11-19 is 93. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLF14 Open price on 2013-11-19 is 93.64. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLZ13 price difference to CLF14 is 0.63999999. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLF14 Open price on 2013-12-17 is 97.3. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLG14 Open price on 2013-12-17 is 97.54. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLF14 price difference to CLG14 is 0.23999999. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLG14 Open price on 2014-01-17 is 94.17. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLH14 Open price on 2014-01-17 is 94.29. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLG14 price difference to CLH14 is 0.12. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLH14 Open price on 2014-02-18 is 100.32. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLJ14 Open price on 2014-02-18 is 100.12. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLH14 price difference to CLJ14 is -0.2. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLJ14 Open price on 2014-03-18 is 97.97. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLK14 Open price on 2014-03-18 is 97.46. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLJ14 price difference to CLK14 is -0.50999999. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLK14 Open price on 2014-04-22 is 104.36. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLK14 price difference to CLM14 is 0. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLN14 Open price on 2014-05-19 is 101.68. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLM14 price difference to CLN14 is 0. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLN14 Open price on 2014-06-18 is 106.6. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLQ14 Open price on 2014-06-18 is 106.06. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: CLN14 price difference to CLQ14 is -0.54000002. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: Back adjust amount for symbol CLM11 is 7.0799999. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: Back adjust amount for symbol CLN11 is 6.4700003. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: Back adjust amount for symbol CLQ11 is 6.1000004. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: Back adjust amount for symbol CLU11 is 5.8100004. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: Back adjust amount for symbol CLV11 is 5.6599998. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: Back adjust amount for symbol CLX11 is 5.6100006. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: Back adjust amount for symbol CLZ11 is 5.5100002. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: Back adjust amount for symbol CLF12 is 5.5299997. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: Back adjust amount for symbol CLG12 is 5.5200005. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: Back adjust amount for symbol CLH12 is 5.3100004. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: Back adjust amount for symbol CLJ12 is 5.0200005. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: Back adjust amount for symbol CLK12 is 4.4200001. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: Back adjust amount for symbol CLM12 is 3.9400005. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: Back adjust amount for symbol CLN12 is 3.5. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: Back adjust amount for symbol CLQ12 is 3.1200001. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: Back adjust amount for symbol CLU12 is 2.8499999. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: Back adjust amount for symbol CLV12 is 2.5699999. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: Back adjust amount for symbol CLX12 is 2.2299998. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: Back adjust amount for symbol CLZ12 is 1.7899997. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: Back adjust amount for symbol CLF13 is 1.3799999. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: Back adjust amount for symbol CLG13 is 0.88999981. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: Back adjust amount for symbol CLH13 is 0.42999989. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: Back adjust amount for symbol CLJ13 is 0.0099999309. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: Back adjust amount for symbol CLK13 is -0.35000002. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: Back adjust amount for symbol CLM13 is -0.56. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: Back adjust amount for symbol CLN13 is -0.88000005. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: Back adjust amount for symbol CLQ13 is -1.1100001. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: Back adjust amount for symbol CLU13 is -0.90000004. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: Back adjust amount for symbol CLV13 is -0.73000002. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: Back adjust amount for symbol CLX13 is 0.029999912. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: Back adjust amount for symbol CLZ13 is -0.25. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: Back adjust amount for symbol CLF14 is -0.89000005. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: Back adjust amount for symbol CLG14 is -1.13. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: Back adjust amount for symbol CLH14 is -1.25. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: Back adjust amount for symbol CLJ14 is -1.05. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: Back adjust amount for symbol CLK14 is -0.54000002. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: Back adjust amount for symbol CLM14 is -0.54000002. | 2014-06-22 09:19:50
CLQ14/CL-201408-NYMEX [CBV] Weekly #5: Back adjust amount for symbol CLN14 is -0.54000002. | 2014-06-22 09:19:50
HTTP request #2 returned the following error: Windows error code 12007: The server name or address could not be resolved | 2014-06-22 09:20:01
HD Request # 4 - Download from the SC Historical Data service failed due to a HTTP error. | 2014-06-22 09:20:01
HD Request # 4 - Error downloading historical Daily data for CLZ05. There was a communication error with the server. | 2014-06-22 09:20:01
HD Request # 4 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for CLZ05 | 2014-06-22 09:20:01
HD Request # 4 - Daily download COMPLETE for CLZ05. Completion time: 12s | 2014-06-22 09:20:01
HD Request # 5 - Downloading Historical Daily chart data for CLZ06. Starting date: 2006-11-16. Service: ib | 2014-06-22 09:20:01
HD Request # 5 - Using user Barchart Historical data account. | 2014-06-22 09:20:01
HD Request # 5 - Requesting historical Daily data for CLZ06 starting at 2006-11-15 | 2014-06-22 09:20:01
HD Request # 5 - Receiving historical Daily data for CLZ06 starting at 2006-11-15 | 2014-06-22 09:20:01
Writing historical Daily data for CLZ06 to the file CLZ06.dly | 2014-06-22 09:20:01
HD Request # 5 - Received 3 records from 2006-11-15 00:00:00 to 2006-11-17 00:00:00 (3.0 days) and wrote 2 records for CLZ06 | 2014-06-22 09:20:01
HD Request # 5 - Daily download COMPLETE for CLZ06. Completion time: 0s | 2014-06-22 09:20:01
HD Request # 6 - Downloading Historical Daily chart data for CLZ07. Starting date: 2007-11-15. Service: ib | 2014-06-22 09:20:01
HD Request # 6 - Using user Barchart Historical data account. | 2014-06-22 09:20:01
HD Request # 6 - Requesting historical Daily data for CLZ07 starting at 2007-11-14 | 2014-06-22 09:20:01
HD Request # 6 - Receiving historical Daily data for CLZ07 starting at 2007-11-14 | 2014-06-22 09:20:01
Writing historical Daily data for CLZ07 to the file CLZ07.dly | 2014-06-22 09:20:01
HD Request # 6 - Received 3 records from 2007-11-14 00:00:00 to 2007-11-16 00:00:00 (3.0 days) and wrote 2 records for CLZ07 | 2014-06-22 09:20:01
HD Request # 6 - Daily download COMPLETE for CLZ07. Completion time: 0s | 2014-06-22 09:20:01
HD Request # 7 - Downloading Historical Daily chart data for CLF08. Starting date: 2007-12-17. Service: ib | 2014-06-22 09:20:01
HD Request # 7 - Using user Barchart Historical data account. | 2014-06-22 09:20:01
HD Request # 7 - Requesting historical Daily data for CLF08 starting at 2007-12-16 | 2014-06-22 09:20:01
HD Request # 7 - Receiving historical Daily data for CLF08 starting at 2007-12-17 | 2014-06-22 09:20:01
Writing historical Daily data for CLF08 to the file CLF08.dly | 2014-06-22 09:20:01
HD Request # 7 - Received 2 records from 2007-12-17 00:00:00 to 2007-12-18 00:00:00 (2.0 days) and wrote 2 records for CLF08 | 2014-06-22 09:20:01
HD Request # 7 - Daily download COMPLETE for CLF08. Completion time: 0s | 2014-06-22 09:20:01
HD Request # 8 - Downloading Historical Daily chart data for CLQ14. Starting date: 2014-06-19. Service: ib | 2014-06-22 09:20:01
HD Request # 8 - Using user Barchart Historical data account. | 2014-06-22 09:20:01
HD Request # 8 - Requesting historical Daily data for CLQ14 starting at 2014-06-18 | 2014-06-22 09:20:01
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: Download is complete for all contract months in chart. Proceeding with data load. | 2014-06-22 09:20:01
Volume based rollover from CLM02 to CLN02 occurs at 2002-05-16 | 2014-06-22 09:20:01
Volume based rollover from CLN02 to CLQ02 occurs at 2002-06-06 | 2014-06-22 09:20:01
Volume based rollover from CLQ02 to CLU02 occurs at 2002-07-17 | 2014-06-22 09:20:01
Volume based rollover from CLU02 to CLV02 occurs at 2002-08-14 | 2014-06-22 09:20:01
Volume based rollover from CLV02 to CLX02 occurs at 2002-09-04 | 2014-06-22 09:20:01
Volume based rollover from CLX02 to CLZ02 occurs at 2002-10-14 | 2014-06-22 09:20:01
Volume based rollover from CLZ02 to CLF03 occurs at 2002-11-15 | 2014-06-22 09:20:01
Volume based rollover from CLF03 to CLG03 occurs at 2002-12-16 | 2014-06-22 09:20:01
Volume based rollover from CLG03 to CLH03 occurs at 2003-01-16 | 2014-06-22 09:20:01
Volume based rollover from CLH03 to CLJ03 occurs at 2003-02-18 | 2014-06-22 09:20:01
Volume based rollover from CLJ03 to CLK03 occurs at 2003-03-17 | 2014-06-22 09:20:01
Volume based rollover from CLK03 to CLM03 occurs at 2003-04-17 | 2014-06-22 09:20:01
Volume based rollover from CLM03 to CLN03 occurs at 2003-05-16 | 2014-06-22 09:20:01
Volume based rollover from CLN03 to CLQ03 occurs at 2003-06-18 | 2014-06-22 09:20:01
Volume based rollover from CLQ03 to CLU03 occurs at 2003-07-15 | 2014-06-22 09:20:02
Volume based rollover from CLU03 to CLV03 occurs at 2003-08-18 | 2014-06-22 09:20:02
Volume based rollover from CLV03 to CLX03 occurs at 2003-09-16 | 2014-06-22 09:20:02
Volume based rollover from CLX03 to CLZ03 occurs at 2003-10-10 | 2014-06-22 09:20:02
Volume based rollover from CLZ03 to CLF04 occurs at 2003-11-14 | 2014-06-22 09:20:02
Volume based rollover from CLF04 to CLG04 occurs at 2003-12-15 | 2014-06-22 09:20:02
Volume based rollover from CLG04 to CLH04 occurs at 2004-01-15 | 2014-06-22 09:20:02
Volume based rollover from CLH04 to CLJ04 occurs at 2004-02-12 | 2014-06-22 09:20:02
Volume based rollover from CLJ04 to CLK04 occurs at 2004-03-17 | 2014-06-22 09:20:02
Volume based rollover from CLK04 to CLM04 occurs at 2004-04-15 | 2014-06-22 09:20:02
Volume based rollover from CLM04 to CLN04 occurs at 2004-05-14 | 2014-06-22 09:20:02
Volume based rollover from CLN04 to CLQ04 occurs at 2004-06-15 | 2014-06-22 09:20:02
Volume based rollover from CLQ04 to CLU04 occurs at 2004-07-15 | 2014-06-22 09:20:02
Volume based rollover from CLU04 to CLV04 occurs at 2004-08-18 | 2014-06-22 09:20:02
Volume based rollover from CLV04 to CLX04 occurs at 2004-09-17 | 2014-06-22 09:20:02
Volume based rollover from CLX04 to CLZ04 occurs at 2004-10-18 | 2014-06-22 09:20:02
Volume based rollover from CLZ04 to CLF05 occurs at 2004-11-17 | 2014-06-22 09:20:02
Volume based rollover from CLF05 to CLG05 occurs at 2004-12-16 | 2014-06-22 09:20:02
Volume based rollover from CLG05 to CLH05 occurs at 2005-01-18 | 2014-06-22 09:20:02
Volume based rollover from CLH05 to CLJ05 occurs at 2005-02-16 | 2014-06-22 09:20:02
Volume based rollover from CLJ05 to CLK05 occurs at 2005-03-17 | 2014-06-22 09:20:02
Volume based rollover from CLK05 to CLM05 occurs at 2005-04-18 | 2014-06-22 09:20:02
Volume based rollover from CLM05 to CLN05 occurs at 2005-05-17 | 2014-06-22 09:20:02
Volume based rollover from CLN05 to CLQ05 occurs at 2005-06-16 | 2014-06-22 09:20:02
Volume based rollover from CLQ05 to CLU05 occurs at 2005-07-18 | 2014-06-22 09:20:02
Volume based rollover from CLU05 to CLV05 occurs at 2005-08-18 | 2014-06-22 09:20:02
Volume based rollover from CLV05 to CLX05 occurs at 2005-09-16 | 2014-06-22 09:20:02
Volume based rollover from CLX05 to CLZ05 occurs at 2005-10-14 | 2014-06-22 09:20:02
Volume based rollover from CLZ05 to CLF06 occurs at 2005-11-16 | 2014-06-22 09:20:02
Volume based rollover from CLF06 to CLG06 occurs at 2005-12-16 | 2014-06-22 09:20:02
Volume based rollover from CLG06 to CLH06 occurs at 2006-01-18 | 2014-06-22 09:20:02
Volume based rollover from CLH06 to CLJ06 occurs at 2006-02-16 | 2014-06-22 09:20:02
Volume based rollover from CLJ06 to CLK06 occurs at 2006-03-14 | 2014-06-22 09:20:02
Volume based rollover from CLK06 to CLM06 occurs at 2006-04-12 | 2014-06-22 09:20:02
Volume based rollover from CLM06 to CLN06 occurs at 2006-05-18 | 2014-06-22 09:20:02
Volume based rollover from CLN06 to CLQ06 occurs at 2006-06-19 | 2014-06-22 09:20:02
Volume based rollover from CLQ06 to CLU06 occurs at 2006-07-18 | 2014-06-22 09:20:02
Volume based rollover from CLU06 to CLV06 occurs at 2006-08-18 | 2014-06-22 09:20:02
Volume based rollover from CLV06 to CLX06 occurs at 2006-09-19 | 2014-06-22 09:20:02
Volume based rollover from CLX06 to CLZ06 occurs at 2006-10-18 | 2014-06-22 09:20:02
Volume based rollover from CLZ06 to CLF07 occurs at 2006-11-16 | 2014-06-22 09:20:02
Volume based rollover from CLF07 to CLG07 occurs at 2006-12-18 | 2014-06-22 09:20:02
Volume based rollover from CLG07 to CLH07 occurs at 2007-01-18 | 2014-06-22 09:20:02
Volume based rollover from CLH07 to CLJ07 occurs at 2007-02-16 | 2014-06-22 09:20:02
Volume based rollover from CLJ07 to CLK07 occurs at 2007-03-16 | 2014-06-22 09:20:02
Volume based rollover from CLK07 to CLM07 occurs at 2007-04-18 | 2014-06-22 09:20:02
Volume based rollover from CLM07 to CLN07 occurs at 2007-05-21 | 2014-06-22 09:20:02
Volume based rollover from CLN07 to CLQ07 occurs at 2007-06-18 | 2014-06-22 09:20:02
Volume based rollover from CLQ07 to CLU07 occurs at 2007-07-18 | 2014-06-22 09:20:02
Volume based rollover from CLU07 to CLV07 occurs at 2007-08-20 | 2014-06-22 09:20:02
Volume based rollover from CLV07 to CLX07 occurs at 2007-09-19 | 2014-06-22 09:20:02
Volume based rollover from CLX07 to CLZ07 occurs at 2007-10-18 | 2014-06-22 09:20:02
Volume based rollover from CLZ07 to CLF08 occurs at 2007-11-15 | 2014-06-22 09:20:02
Volume based rollover from CLF08 to CLG08 occurs at 2007-12-17 | 2014-06-22 09:20:02
Volume based rollover from CLG08 to CLH08 occurs at 2008-01-18 | 2014-06-22 09:20:02
Volume based rollover from CLH08 to CLJ08 occurs at 2008-02-19 | 2014-06-22 09:20:02
Volume based rollover from CLJ08 to CLK08 occurs at 2008-03-18 | 2014-06-22 09:20:02
Volume based rollover from CLK08 to CLM08 occurs at 2008-04-21 | 2014-06-22 09:20:02
Volume based rollover from CLM08 to CLN08 occurs at 2008-05-19 | 2014-06-22 09:20:02
Volume based rollover from CLN08 to CLQ08 occurs at 2008-06-19 | 2014-06-22 09:20:02
Volume based rollover from CLQ08 to CLU08 occurs at 2008-07-21 | 2014-06-22 09:20:02
Volume based rollover from CLU08 to CLV08 occurs at 2008-08-19 | 2014-06-22 09:20:02
Volume based rollover from CLV08 to CLX08 occurs at 2008-09-19 | 2014-06-22 09:20:02
Volume based rollover from CLX08 to CLZ08 occurs at 2008-10-17 | 2014-06-22 09:20:02
Volume based rollover from CLZ08 to CLF09 occurs at 2008-11-19 | 2014-06-22 09:20:02
Volume based rollover from CLF09 to CLG09 occurs at 2008-12-17 | 2014-06-22 09:20:02
Volume based rollover from CLG09 to CLH09 occurs at 2009-01-15 | 2014-06-22 09:20:02
Volume based rollover from CLH09 to CLJ09 occurs at 2009-02-17 | 2014-06-22 09:20:02
Volume based rollover from CLJ09 to CLK09 occurs at 2009-03-18 | 2014-06-22 09:20:02
Volume based rollover from CLK09 to CLM09 occurs at 2009-04-17 | 2014-06-22 09:20:02
Volume based rollover from CLM09 to CLN09 occurs at 2009-05-18 | 2014-06-22 09:20:02
Volume based rollover from CLN09 to CLQ09 occurs at 2009-06-19 | 2014-06-22 09:20:02
Volume based rollover from CLQ09 to CLU09 occurs at 2009-07-17 | 2014-06-22 09:20:02
Volume based rollover from CLU09 to CLV09 occurs at 2009-08-18 | 2014-06-22 09:20:02
Volume based rollover from CLV09 to CLX09 occurs at 2009-09-21 | 2014-06-22 09:20:02
Volume based rollover from CLX09 to CLZ09 occurs at 2009-10-19 | 2014-06-22 09:20:02
Volume based rollover from CLZ09 to CLF10 occurs at 2009-11-19 | 2014-06-22 09:20:02
Volume based rollover from CLF10 to CLG10 occurs at 2009-12-17 | 2014-06-22 09:20:02
Volume based rollover from CLG10 to CLH10 occurs at 2010-01-19 | 2014-06-22 09:20:02
Volume based rollover from CLH10 to CLJ10 occurs at 2010-02-19 | 2014-06-22 09:20:02
Volume based rollover from CLJ10 to CLK10 occurs at 2010-03-19 | 2014-06-22 09:20:02
Volume based rollover from CLK10 to CLM10 occurs at 2010-04-16 | 2014-06-22 09:20:02
Volume based rollover from CLM10 to CLN10 occurs at 2010-05-18 | 2014-06-22 09:20:02
Volume based rollover from CLN10 to CLQ10 occurs at 2010-06-18 | 2014-06-22 09:20:02
Volume based rollover from CLQ10 to CLU10 occurs at 2010-07-19 | 2014-06-22 09:20:02
Volume based rollover from CLU10 to CLV10 occurs at 2010-08-18 | 2014-06-22 09:20:02
Volume based rollover from CLV10 to CLX10 occurs at 2010-09-17 | 2014-06-22 09:20:02
Volume based rollover from CLX10 to CLZ10 occurs at 2010-10-18 | 2014-06-22 09:20:02
Volume based rollover from CLZ10 to CLF11 occurs at 2010-11-17 | 2014-06-22 09:20:02
Volume based rollover from CLF11 to CLG11 occurs at 2010-12-17 | 2014-06-22 09:20:02
Volume based rollover from CLG11 to CLH11 occurs at 2011-01-18 | 2014-06-22 09:20:02
Volume based rollover from CLH11 to CLJ11 occurs at 2011-02-17 | 2014-06-22 09:20:02
Volume based rollover from CLJ11 to CLK11 occurs at 2011-03-18 | 2014-06-22 09:20:02
Volume based rollover from CLK11 to CLM11 occurs at 2011-04-18 | 2014-06-22 09:20:02
Volume based rollover from CLM11 to CLN11 occurs at 2011-05-18 | 2014-06-22 09:20:02
Volume based rollover from CLN11 to CLQ11 occurs at 2011-06-20 | 2014-06-22 09:20:02
Volume based rollover from CLQ11 to CLU11 occurs at 2011-07-19 | 2014-06-22 09:20:02
Volume based rollover from CLU11 to CLV11 occurs at 2011-08-19 | 2014-06-22 09:20:02
Volume based rollover from CLV11 to CLX11 occurs at 2011-09-19 | 2014-06-22 09:20:02
Volume based rollover from CLX11 to CLZ11 occurs at 2011-10-18 | 2014-06-22 09:20:02
Volume based rollover from CLZ11 to CLF12 occurs at 2011-11-17 | 2014-06-22 09:20:02
Volume based rollover from CLF12 to CLG12 occurs at 2011-12-19 | 2014-06-22 09:20:02
Volume based rollover from CLG12 to CLH12 occurs at 2012-01-19 | 2014-06-22 09:20:02
Volume based rollover from CLH12 to CLJ12 occurs at 2012-02-17 | 2014-06-22 09:20:02
Volume based rollover from CLJ12 to CLK12 occurs at 2012-03-19 | 2014-06-22 09:20:02
Volume based rollover from CLK12 to CLM12 occurs at 2012-04-19 | 2014-06-22 09:20:02
Volume based rollover from CLM12 to CLN12 occurs at 2012-05-21 | 2014-06-22 09:20:02
Volume based rollover from CLN12 to CLQ12 occurs at 2012-06-19 | 2014-06-22 09:20:02
Volume based rollover from CLQ12 to CLU12 occurs at 2012-07-19 | 2014-06-22 09:20:02
Volume based rollover from CLU12 to CLV12 occurs at 2012-08-20 | 2014-06-22 09:20:02
Volume based rollover from CLV12 to CLX12 occurs at 2012-09-19 | 2014-06-22 09:20:02
Volume based rollover from CLX12 to CLZ12 occurs at 2012-10-19 | 2014-06-22 09:20:02
Volume based rollover from CLZ12 to CLF13 occurs at 2012-11-15 | 2014-06-22 09:20:02
Volume based rollover from CLF13 to CLG13 occurs at 2012-12-18 | 2014-06-22 09:20:02
Volume based rollover from CLG13 to CLH13 occurs at 2013-01-18 | 2014-06-22 09:20:02
Volume based rollover from CLH13 to CLJ13 occurs at 2013-02-19 | 2014-06-22 09:20:02
Volume based rollover from CLJ13 to CLK13 occurs at 2013-03-18 | 2014-06-22 09:20:02
Volume based rollover from CLK13 to CLM13 occurs at 2013-04-18 | 2014-06-22 09:20:02
Volume based rollover from CLM13 to CLN13 occurs at 2013-05-20 | 2014-06-22 09:20:02
Volume based rollover from CLN13 to CLQ13 occurs at 2013-06-18 | 2014-06-22 09:20:02
Volume based rollover from CLQ13 to CLU13 occurs at 2013-07-18 | 2014-06-22 09:20:02
Volume based rollover from CLU13 to CLV13 occurs at 2013-08-16 | 2014-06-22 09:20:02
Volume based rollover from CLV13 to CLX13 occurs at 2013-09-18 | 2014-06-22 09:20:02
Volume based rollover from CLX13 to CLZ13 occurs at 2013-10-18 | 2014-06-22 09:20:02
Volume based rollover from CLZ13 to CLF14 occurs at 2013-11-19 | 2014-06-22 09:20:02
Volume based rollover from CLF14 to CLG14 occurs at 2013-12-17 | 2014-06-22 09:20:02
Volume based rollover from CLG14 to CLH14 occurs at 2014-01-17 | 2014-06-22 09:20:02
Volume based rollover from CLH14 to CLJ14 occurs at 2014-02-18 | 2014-06-22 09:20:02
Volume based rollover from CLJ14 to CLK14 occurs at 2014-03-18 | 2014-06-22 09:20:02
Volume based rollover from CLK14 to CLM14 occurs at 2014-04-22 | 2014-06-22 09:20:02
Volume based rollover from CLM14 to CLN14 occurs at 0 | 2014-06-22 09:20:02
Using date based transition from CLM14 to CLN14 because volume based transition could not be determined. | 2014-06-22 09:20:02
Volume based rollover from CLN14 to CLQ14 occurs at 2014-06-18 | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: Performing continuous futures contract back adjustment calculations. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLM02 Open price on 2002-05-16 is 28.26. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLN02 Open price on 2002-05-16 is 27.4. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLM02 price difference to CLN02 is -0.86000001. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLN02 Open price on 2002-06-06 is 24.92. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLQ02 Open price on 2002-06-06 is 25.12. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLN02 price difference to CLQ02 is 0.2. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLQ02 Open price on 2002-07-17 is 27.72. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLU02 Open price on 2002-07-17 is 27.75. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLQ02 price difference to CLU02 is 0.029999999. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLU02 Open price on 2002-08-14 is 27.93. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLV02 Open price on 2002-08-14 is 27.19. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLU02 price difference to CLV02 is -0.74000001. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLV02 Open price on 2002-09-04 is 27.79. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLX02 Open price on 2002-09-04 is 27.8. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLV02 price difference to CLX02 is 0.0099999998. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLX02 Open price on 2002-10-14 is 29.45. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLZ02 Open price on 2002-10-14 is 29.44. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLX02 price difference to CLZ02 is -0.0099999998. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLZ02 Open price on 2002-11-15 is 25.35. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLF03 Open price on 2002-11-15 is 24.52. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLZ02 price difference to CLF03 is -0.82999998. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLF03 Open price on 2002-12-16 is 28.62. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLG03 Open price on 2002-12-16 is 28.56. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLF03 price difference to CLG03 is -0.059999999. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLG03 Open price on 2003-01-16 is 33.15. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLH03 Open price on 2003-01-16 is 32.45. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLG03 price difference to CLH03 is -0.69999999. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLH03 Open price on 2003-02-18 is 36.38. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLJ03 Open price on 2003-02-18 is 34.99. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLH03 price difference to CLJ03 is -1.39. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLJ03 Open price on 2003-03-17 is 35.98. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLK03 Open price on 2003-03-17 is 33.52. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLJ03 price difference to CLK03 is -2.46. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLK03 Open price on 2003-04-17 is 29.1. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLM03 Open price on 2003-04-17 is 27.53. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLK03 price difference to CLM03 is -1.5700001. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLM03 Open price on 2003-05-16 is 28.6. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLN03 Open price on 2003-05-16 is 28.3. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLM03 price difference to CLN03 is -0.30000001. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLN03 Open price on 2003-06-18 is 31.05. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLQ03 Open price on 2003-06-18 is 29.49. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLN03 price difference to CLQ03 is -1.5599999. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLQ03 Open price on 2003-07-15 is 31.34. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLU03 Open price on 2003-07-15 is 31.05. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLQ03 price difference to CLU03 is -0.28999999. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLU03 Open price on 2003-08-18 is 31.31. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLV03 Open price on 2003-08-18 is 31.3. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLU03 price difference to CLV03 is -0.0099999998. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLV03 Open price on 2003-09-16 is 28.14. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLX03 Open price on 2003-09-16 is 28.17. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLV03 price difference to CLX03 is 0.029999999. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLX03 Open price on 2003-10-10 is 31.05. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLZ03 Open price on 2003-10-10 is 31.08. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLX03 price difference to CLZ03 is 0.029999999. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLZ03 Open price on 2003-11-14 is 31.9. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLF04 Open price on 2003-11-14 is 31.49. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLZ03 price difference to CLF04 is -0.41. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLF04 Open price on 2003-12-15 is 32.04. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLG04 Open price on 2003-12-15 is 32.15. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLF04 price difference to CLG04 is 0.11. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLG04 Open price on 2004-01-15 is 34.57. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLH04 Open price on 2004-01-15 is 33.85. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLG04 price difference to CLH04 is -0.72000003. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLH04 Open price on 2004-02-12 is 34. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLJ04 Open price on 2004-02-12 is 33.15. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLH04 price difference to CLJ04 is -0.85000002. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLJ04 Open price on 2004-03-17 is 37.44. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLK04 Open price on 2004-03-17 is 36.63. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLJ04 price difference to CLK04 is -0.81. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLK04 Open price on 2004-04-15 is 36.7. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLM04 Open price on 2004-04-15 is 36.42. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLK04 price difference to CLM04 is -0.28. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLM04 Open price on 2004-05-14 is 41.08. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLN04 Open price on 2004-05-14 is 40.7. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLM04 price difference to CLN04 is -0.38. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLN04 Open price on 2004-06-15 is 37.59. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLQ04 Open price on 2004-06-15 is 37.88. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLN04 price difference to CLQ04 is 0.28999999. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLQ04 Open price on 2004-07-15 is 40.97. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLU04 Open price on 2004-07-15 is 41.15. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLQ04 price difference to CLU04 is 0.18000001. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLU04 Open price on 2004-08-18 is 46.75. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLV04 Open price on 2004-08-18 is 46.19. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLU04 price difference to CLV04 is -0.56. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLV04 Open price on 2004-09-17 is 44.01. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLX04 Open price on 2004-09-17 is 43.92. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLV04 price difference to CLX04 is -0.090000004. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLX04 Open price on 2004-10-18 is 54.8. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLZ04 Open price on 2004-10-18 is 53.97. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLX04 price difference to CLZ04 is -0.82999998. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLZ04 Open price on 2004-11-17 is 46.16. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLF05 Open price on 2004-11-17 is 46.2. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLZ04 price difference to CLF05 is 0.039999999. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLF05 Open price on 2004-12-16 is 44.3. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLG05 Open price on 2004-12-16 is 44.7. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLF05 price difference to CLG05 is 0.40000001. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLG05 Open price on 2005-01-18 is 48.6. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLH05 Open price on 2005-01-18 is 48.6. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLG05 price difference to CLH05 is 0. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLH05 Open price on 2005-02-16 is 47.28. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLJ05 Open price on 2005-02-16 is 47.8. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLH05 price difference to CLJ05 is 0.51999998. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLJ05 Open price on 2005-03-17 is 56.45. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLK05 Open price on 2005-03-17 is 57.05. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLJ05 price difference to CLK05 is 0.60000002. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLK05 Open price on 2005-04-18 is 50.43. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLM05 Open price on 2005-04-18 is 52. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLK05 price difference to CLM05 is 1.5700001. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLM05 Open price on 2005-05-17 is 48.64. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLN05 Open price on 2005-05-17 is 50.25. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLM05 price difference to CLN05 is 1.61. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLN05 Open price on 2005-06-16 is 55.51. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLQ05 Open price on 2005-06-16 is 56.35. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLN05 price difference to CLQ05 is 0.83999997. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLQ05 Open price on 2005-07-18 is 58. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLU05 Open price on 2005-07-18 is 59.04. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLQ05 price difference to CLU05 is 1.04. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLU05 Open price on 2005-08-18 is 63.33. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLV05 Open price on 2005-08-18 is 64.4. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLU05 price difference to CLV05 is 1.0700001. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLV05 Open price on 2005-09-16 is 64.7. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLX05 Open price on 2005-09-16 is 65.12. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLV05 price difference to CLX05 is 0.41999999. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLX05 Open price on 2005-10-14 is 63.05. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLZ05 Open price on 2005-10-14 is 62.65. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLX05 price difference to CLZ05 is -0.40000001. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLZ05 Open price on 2005-11-16 is 56.98. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLF06 Open price on 2005-11-16 is 57.71. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLZ05 price difference to CLF06 is 0.73000002. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLF06 Open price on 2005-12-16 is 59.9. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLG06 Open price on 2005-12-16 is 61.05. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLF06 price difference to CLG06 is 1.15. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLG06 Open price on 2006-01-18 is 66.35. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLH06 Open price on 2006-01-18 is 67. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLG06 price difference to CLH06 is 0.64999998. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLH06 Open price on 2006-02-16 is 57.7. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLJ06 Open price on 2006-02-16 is 59.6. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLH06 price difference to CLJ06 is 1.9. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLJ06 Open price on 2006-03-14 is 61.75. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLK06 Open price on 2006-03-14 is 63.7. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLJ06 price difference to CLK06 is 1.95. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLK06 Open price on 2006-04-12 is 68.95. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLM06 Open price on 2006-04-12 is 70.37. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLK06 price difference to CLM06 is 1.42. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLM06 Open price on 2006-05-18 is 68.65. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLN06 Open price on 2006-05-18 is 69.65. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLM06 price difference to CLN06 is 1. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLN06 Open price on 2006-06-19 is 69.87. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLQ06 Open price on 2006-06-19 is 70.22. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLN06 price difference to CLQ06 is 0.34999999. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLQ06 Open price on 2006-07-18 is 75.2. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLU06 Open price on 2006-07-18 is 76.81. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLQ06 price difference to CLU06 is 1.61. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLU06 Open price on 2006-08-18 is 70.48. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLV06 Open price on 2006-08-18 is 71.96. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLU06 price difference to CLV06 is 1.48. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLV06 Open price on 2006-09-19 is 63.85. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLX06 Open price on 2006-09-19 is 64.5. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLV06 price difference to CLX06 is 0.64999998. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLX06 Open price on 2006-10-18 is 59.1. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLZ06 Open price on 2006-10-18 is 60.96. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLX06 price difference to CLZ06 is 1.86. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLZ06 Open price on 2006-11-16 is 58.77. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLF07 Open price on 2006-11-16 is 60.72. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLZ06 price difference to CLF07 is 1.95. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLF07 Open price on 2006-12-18 is 63.2. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLG07 Open price on 2006-12-18 is 63.62. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLF07 price difference to CLG07 is 0.41999999. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLG07 Open price on 2007-01-18 is 52.4. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLH07 Open price on 2007-01-18 is 53.15. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLG07 price difference to CLH07 is 0.75. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLH07 Open price on 2007-02-16 is 58.04. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLJ07 Open price on 2007-02-16 is 58.57. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLH07 price difference to CLJ07 is 0.52999997. | 2014-06-22 09:20:02
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLJ07 Open price on 2007-03-16 is 57.53. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLK07 Open price on 2007-03-16 is 59.96. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLJ07 price difference to CLK07 is 2.4300001. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLK07 Open price on 2007-04-18 is 63.25. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLM07 Open price on 2007-04-18 is 64.64. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLK07 price difference to CLM07 is 1.39. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLM07 Open price on 2007-05-21 is 64.95. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLN07 Open price on 2007-05-21 is 65.94. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLM07 price difference to CLN07 is 0.99000001. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLN07 Open price on 2007-06-18 is 68.13. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLQ07 Open price on 2007-06-18 is 68.71. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLN07 price difference to CLQ07 is 0.57999998. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLQ07 Open price on 2007-07-18 is 74.21. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLU07 Open price on 2007-07-18 is 74.28. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLQ07 price difference to CLU07 is 0.07. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLU07 Open price on 2007-08-20 is 71.77. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLV07 Open price on 2007-08-20 is 71.51. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLU07 price difference to CLV07 is -0.25999999. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLV07 Open price on 2007-09-19 is 82.17. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLX07 Open price on 2007-09-19 is 80.98. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLV07 price difference to CLX07 is -1.1900001. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLX07 Open price on 2007-10-18 is 87.1. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLZ07 Open price on 2007-10-18 is 85.9. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLX07 price difference to CLZ07 is -1.2. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLZ07 Open price on 2007-11-15 is 93.95. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLF08 Open price on 2007-11-15 is 92.7. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLZ07 price difference to CLF08 is -1.25. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLF08 Open price on 2007-12-17 is 91.43. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLG08 Open price on 2007-12-17 is 91.55. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLF08 price difference to CLG08 is 0.12. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLG08 Open price on 2008-01-18 is 89.9. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLH08 Open price on 2008-01-18 is 89.38. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLG08 price difference to CLH08 is -0.51999998. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLH08 Open price on 2008-02-19 is 95.37. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLJ08 Open price on 2008-02-19 is 95.46. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLH08 price difference to CLJ08 is 0.090000004. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLJ08 Open price on 2008-03-18 is 106.15. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLK08 Open price on 2008-03-18 is 104.64. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLJ08 price difference to CLK08 is -1.51. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLK08 Open price on 2008-04-21 is 116.93. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLM08 Open price on 2008-04-21 is 116.54. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLK08 price difference to CLM08 is -0.38999999. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLM08 Open price on 2008-05-19 is 126.35. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLN08 Open price on 2008-05-19 is 126.15. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLM08 price difference to CLN08 is -0.2. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLN08 Open price on 2008-06-19 is 136.09. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLQ08 Open price on 2008-06-19 is 138. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLN08 price difference to CLQ08 is 1.91. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLQ08 Open price on 2008-07-21 is 128.88. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLU08 Open price on 2008-07-21 is 129.5. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLQ08 price difference to CLU08 is 0.62. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLU08 Open price on 2008-08-19 is 113.11. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLV08 Open price on 2008-08-19 is 113.2. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLU08 price difference to CLV08 is 0.090000004. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLV08 Open price on 2008-09-19 is 97.95. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLX08 Open price on 2008-09-19 is 97.58. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLV08 price difference to CLX08 is -0.37. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLX08 Open price on 2008-10-17 is 72.3. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLZ08 Open price on 2008-10-17 is 72.68. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLX08 price difference to CLZ08 is 0.38. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLZ08 Open price on 2008-11-19 is 54.7. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLF09 Open price on 2008-11-19 is 55.08. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLZ08 price difference to CLF09 is 0.38. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLF09 Open price on 2008-12-17 is 43.75. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLG09 Open price on 2008-12-17 is 46.82. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLF09 price difference to CLG09 is 3.0699999. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLG09 Open price on 2009-01-15 is 37.34. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLH09 Open price on 2009-01-15 is 44.45. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLG09 price difference to CLH09 is 7.1100001. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLH09 Open price on 2009-02-17 is 37.81. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLJ09 Open price on 2009-02-17 is 42.08. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLH09 price difference to CLJ09 is 4.27. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLJ09 Open price on 2009-03-18 is 48.67. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLK09 Open price on 2009-03-18 is 49.41. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLJ09 price difference to CLK09 is 0.74000001. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLK09 Open price on 2009-04-17 is 49.93. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLM09 Open price on 2009-04-17 is 52. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLK09 price difference to CLM09 is 2.0699999. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLM09 Open price on 2009-05-18 is 56.47. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLN09 Open price on 2009-05-18 is 57.22. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLM09 price difference to CLN09 is 0.75. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLN09 Open price on 2009-06-19 is 71.35. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLQ09 Open price on 2009-06-19 is 71.88. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLN09 price difference to CLQ09 is 0.52999997. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLQ09 Open price on 2009-07-17 is 62.24. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLU09 Open price on 2009-07-17 is 63.1. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLQ09 price difference to CLU09 is 0.86000001. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLU09 Open price on 2009-08-18 is 66.8. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLV09 Open price on 2009-08-18 is 68.81. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLU09 price difference to CLV09 is 2.01. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLV09 Open price on 2009-09-21 is 71.78. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLX09 Open price on 2009-09-21 is 72.21. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLV09 price difference to CLX09 is 0.43000001. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLX09 Open price on 2009-10-19 is 78.56. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLZ09 Open price on 2009-10-19 is 79.12. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLX09 price difference to CLZ09 is 0.56. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLZ09 Open price on 2009-11-19 is 79.63. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLF10 Open price on 2009-11-19 is 80.16. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLZ09 price difference to CLF10 is 0.52999997. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLF10 Open price on 2009-12-17 is 72.74. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLG10 Open price on 2009-12-17 is 74.51. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLF10 price difference to CLG10 is 1.77. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLG10 Open price on 2010-01-19 is 77.85. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLH10 Open price on 2010-01-19 is 78.21. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLG10 price difference to CLH10 is 0.36000001. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLH10 Open price on 2010-02-19 is 78.37. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLJ10 Open price on 2010-02-19 is 78.83. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLH10 price difference to CLJ10 is 0.46000001. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLJ10 Open price on 2010-03-19 is 82.17. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLK10 Open price on 2010-03-19 is 82.46. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLJ10 price difference to CLK10 is 0.28999999. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLK10 Open price on 2010-04-16 is 85.35. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLM10 Open price on 2010-04-16 is 86.56. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLK10 price difference to CLM10 is 1.21. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLM10 Open price on 2010-05-18 is 70.5. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLN10 Open price on 2010-05-18 is 73.87. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLM10 price difference to CLN10 is 3.3699999. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLN10 Open price on 2010-06-18 is 76.55. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLQ10 Open price on 2010-06-18 is 77.89. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLN10 price difference to CLQ10 is 1.34. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLQ10 Open price on 2010-07-19 is 75.72. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLU10 Open price on 2010-07-19 is 76.07. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLQ10 price difference to CLU10 is 0.34999999. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLU10 Open price on 2010-08-18 is 75.45. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLV10 Open price on 2010-08-18 is 75.8. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLU10 price difference to CLV10 is 0.34999999. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLV10 Open price on 2010-09-17 is 74.47. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLX10 Open price on 2010-09-17 is 75.63. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLV10 price difference to CLX10 is 1.16. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLX10 Open price on 2010-10-18 is 81.38. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLZ10 Open price on 2010-10-18 is 82.2. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLX10 price difference to CLZ10 is 0.81999999. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLZ10 Open price on 2010-11-17 is 82.44. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLF11 Open price on 2010-11-17 is 82.86. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLZ10 price difference to CLF11 is 0.41999999. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLF11 Open price on 2010-12-17 is 87.87. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLG11 Open price on 2010-12-17 is 88.5. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLF11 price difference to CLG11 is 0.63. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLG11 Open price on 2011-01-18 is 91.51. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLH11 Open price on 2011-01-18 is 92.55. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLG11 price difference to CLH11 is 1.04. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLH11 Open price on 2011-02-17 is 85.25. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLJ11 Open price on 2011-02-17 is 88.12. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLH11 price difference to CLJ11 is 2.8699999. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLJ11 Open price on 2011-03-18 is 101.78. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLK11 Open price on 2011-03-18 is 102.8. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLJ11 price difference to CLK11 is 1.02. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLK11 Open price on 2011-04-18 is 109.43. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLM11 Open price on 2011-04-18 is 110.05. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLK11 price difference to CLM11 is 0.62. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLM11 Open price on 2011-05-18 is 97.57. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLN11 Open price on 2011-05-18 is 98.18. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLM11 price difference to CLN11 is 0.61000001. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLN11 Open price on 2011-06-20 is 92.8. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLQ11 Open price on 2011-06-20 is 93.17. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLN11 price difference to CLQ11 is 0.37. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLQ11 Open price on 2011-07-19 is 96.16. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLU11 Open price on 2011-07-19 is 96.45. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLQ11 price difference to CLU11 is 0.28999999. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLU11 Open price on 2011-08-19 is 81.3. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLV11 Open price on 2011-08-19 is 81.45. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLU11 price difference to CLV11 is 0.15000001. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLV11 Open price on 2011-09-19 is 87.75. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLX11 Open price on 2011-09-19 is 87.8. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLV11 price difference to CLX11 is 0.050000001. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLX11 Open price on 2011-10-18 is 86.2. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLZ11 Open price on 2011-10-18 is 86.3. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLX11 price difference to CLZ11 is 0.1. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLZ11 Open price on 2011-11-17 is 101.76. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLF12 Open price on 2011-11-17 is 101.74. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLZ11 price difference to CLF12 is -0.02. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLF12 Open price on 2011-12-19 is 93.76. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLG12 Open price on 2011-12-19 is 93.77. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLF12 price difference to CLG12 is 0.0099999998. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLG12 Open price on 2012-01-19 is 101.14. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLH12 Open price on 2012-01-19 is 101.35. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLG12 price difference to CLH12 is 0.20999999. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLH12 Open price on 2012-02-17 is 102.35. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLJ12 Open price on 2012-02-17 is 102.64. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLH12 price difference to CLJ12 is 0.28999999. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLJ12 Open price on 2012-03-19 is 107.18. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLK12 Open price on 2012-03-19 is 107.78. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLJ12 price difference to CLK12 is 0.60000002. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLK12 Open price on 2012-04-19 is 102.73. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLM12 Open price on 2012-04-19 is 103.21. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLK12 price difference to CLM12 is 0.47999999. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLM12 Open price on 2012-05-21 is 91.27. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLN12 Open price on 2012-05-21 is 91.71. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLM12 price difference to CLN12 is 0.44. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLN12 Open price on 2012-06-19 is 83.06. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLQ12 Open price on 2012-06-19 is 83.44. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLN12 price difference to CLQ12 is 0.38. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLQ12 Open price on 2012-07-19 is 90.08. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLU12 Open price on 2012-07-19 is 90.35. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLQ12 price difference to CLU12 is 0.27000001. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLU12 Open price on 2012-08-20 is 96.36. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLV12 Open price on 2012-08-20 is 96.64. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLU12 price difference to CLV12 is 0.28. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLV12 Open price on 2012-09-19 is 95.49. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLX12 Open price on 2012-09-19 is 95.83. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLV12 price difference to CLX12 is 0.34. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLX12 Open price on 2012-10-19 is 92.04. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLZ12 Open price on 2012-10-19 is 92.48. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLX12 price difference to CLZ12 is 0.44. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLZ12 Open price on 2012-11-15 is 86.36. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLF13 Open price on 2012-11-15 is 86.77. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLZ12 price difference to CLF13 is 0.41. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLF13 Open price on 2012-12-18 is 87.45. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLG13 Open price on 2012-12-18 is 87.94. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLF13 price difference to CLG13 is 0.49000001. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLG13 Open price on 2013-01-18 is 95.19. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLH13 Open price on 2013-01-18 is 95.65. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLG13 price difference to CLH13 is 0.46000001. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLH13 Open price on 2013-02-19 is 95.97. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLJ13 Open price on 2013-02-19 is 96.39. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLH13 price difference to CLJ13 is 0.41999999. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLJ13 Open price on 2013-03-18 is 93.26. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLK13 Open price on 2013-03-18 is 93.62. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLJ13 price difference to CLK13 is 0.36000001. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLK13 Open price on 2013-04-18 is 86.39. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLM13 Open price on 2013-04-18 is 86.6. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLK13 price difference to CLM13 is 0.20999999. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLM13 Open price on 2013-05-20 is 95.93. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLN13 Open price on 2013-05-20 is 96.25. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLM13 price difference to CLN13 is 0.31999999. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLN13 Open price on 2013-06-18 is 97.93. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLQ13 Open price on 2013-06-18 is 98.16. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLN13 price difference to CLQ13 is 0.23. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLQ13 Open price on 2013-07-18 is 106.56. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLU13 Open price on 2013-07-18 is 106.35. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLQ13 price difference to CLU13 is -0.20999999. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLU13 Open price on 2013-08-16 is 107.18. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLV13 Open price on 2013-08-16 is 107.01. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLU13 price difference to CLV13 is -0.17. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLV13 Open price on 2013-09-18 is 105.53. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLX13 Open price on 2013-09-18 is 104.77. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLV13 price difference to CLX13 is -0.75999999. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLX13 Open price on 2013-10-18 is 100.72. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLZ13 Open price on 2013-10-18 is 101. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLX13 price difference to CLZ13 is 0.28. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLZ13 Open price on 2013-11-19 is 93. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLF14 Open price on 2013-11-19 is 93.64. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLZ13 price difference to CLF14 is 0.63999999. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLF14 Open price on 2013-12-17 is 97.3. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLG14 Open price on 2013-12-17 is 97.54. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLF14 price difference to CLG14 is 0.23999999. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLG14 Open price on 2014-01-17 is 94.17. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLH14 Open price on 2014-01-17 is 94.29. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLG14 price difference to CLH14 is 0.12. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLH14 Open price on 2014-02-18 is 100.32. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLJ14 Open price on 2014-02-18 is 100.12. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLH14 price difference to CLJ14 is -0.2. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLJ14 Open price on 2014-03-18 is 97.97. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLK14 Open price on 2014-03-18 is 97.46. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLJ14 price difference to CLK14 is -0.50999999. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLK14 Open price on 2014-04-22 is 104.36. | 2014-06-22 09:20:03
Error while getting daily open price with date 2014-04-25 from file. C:\SierraChart\Data\CLM14.dly. Error: Encountered end of file. | 2014-06-22 09:20:03
CLQ14/CL-201408-NYMEX [CBV] Monthly #4: CLK14 price difference to CLM14 is 0. | 2014-06-22 09:20:03
Error while getting daily open price with date 2014-05-22 from file. C:\SierraChart\Data\CLM14.dly. Error: Encounte
[2014-06-22 20:34:06]
Select File >> Open Historical Chart and delete this file:
CLM14.dly
Restart Sierra Chart, open a chart that you want to replay. Just one chart please. It will confuse us, if you open more than one chart.
Select Edit >> Delete All Data and Download.
Provide a copy of the Message Log by following these instructions:
https://www.sierrachart.com/index.php?l=PostingInformation.php#log
Date Time Of Last Edit: 2014-06-22 20:44:48
[2014-06-22 22:21:47]
ged - Posts: 233
Appreciate your help.
Above steps taken. Here is the Message Log from the one selected chart:
Software version: 1143 | 2014-06-22 15:17:02
Usage end date: 2014-07-31 | 2014-06-22 15:17:02
Enabled for: Advanced Features. | 2014-06-22 15:17:02
Enabled for: Sierra Chart Historical Data Service. | 2014-06-22 15:17:02
Enabled for: Sierra Chart Real-Time Exchange Data Feed. | 2014-06-22 15:17:02
Enabled for: CME, CBOT, NYMEX, COMEX exchanges. | 2014-06-22 15:17:02
Enabled for: US EQUITIES exchanges. | 2014-06-22 15:17:02
Received 1 data feed usernames. | 2014-06-22 15:17:02
Allow Support for Sierra Chart Data Feeds is enabled. | 2014-06-22 15:17:02
Active service: Interactive Brokers | 2014-06-22 15:17:02
Time Zone: -07:00:00 (PST-08PDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2014-06-22 15:17:02
2014-06-22 15:17:02 Local computer clock time | 2014-06-22 15:17:02
2014-06-22 22:17:02 GMT time | 2014-06-22 15:17:02
2014-06-22 15:17:02 Time zone adjusted time | 2014-06-22 15:17:02
Time difference to server time: 1 seconds. | 2014-06-22 15:17:02
Program path: C:\SierraChart\ | 2014-06-22 15:17:02
Data Files path: C:\SierraChart\Data\ | 2014-06-22 15:17:02
OS Version Number: 6.1 | 2014-06-22 15:17:02
Checking for new symbol settings for ib | 2014-06-22 15:17:02
Symbol settings are up-to-date for ib | 2014-06-22 15:17:03
Date rule based rollover from CL-201406-NYMEX to next contract occurs at 2014-05-19 | 2014-06-22 15:17:09
Date rule based rollover from CL-201407-NYMEX to next contract occurs at 2014-06-19 | 2014-06-22 15:17:09
Date rule based rollover from CL-201408-NYMEX to next contract occurs at 2014-07-21 | 2014-06-22 15:17:09
Checking Intraday data file for symbol CL-201406-NYMEX for the date range from 2014-04-21 to 2014-05-19 | 2014-06-22 15:17:09
Daily data file for symbol CL-201406-NYMEX existed and is empty. Skipping download. | 2014-06-22 15:17:09
Checking Intraday data file for symbol CL-201407-NYMEX for the date range from 2014-05-19 to 2014-06-19 | 2014-06-22 15:17:09
Checking Daily data file for symbol CLN14 for the date range from 2014-05-19 to 2014-06-19 | 2014-06-22 15:17:09
Checking Intraday data file for symbol CL-201408-NYMEX for the date range from 2014-06-19 to 0 | 2014-06-22 15:17:09
Checking Daily data file for symbol CLQ14 for the date range from 2014-06-19 to 0 | 2014-06-22 15:17:09
Symbols used for CL-201408-NYMEX continuous contract chart: | 2014-06-22 15:17:09
CL-201406-NYMEX | 2014-06-22 15:17:09
CL-201407-NYMEX | 2014-06-22 15:17:09
CL-201408-NYMEX | 2014-06-22 15:17:09
Volume based rollover from CL-201406-NYMEX to CL-201407-NYMEX occurs at 0 | 2014-06-22 15:17:09
Using date based transition from CL-201406-NYMEX to CL-201407-NYMEX because volume based transition could not be determined. | 2014-06-22 15:17:09
Volume based rollover from CL-201407-NYMEX to CL-201408-NYMEX occurs at 2014-06-18 | 2014-06-22 15:17:09
CL-201408-NYMEX [CBV] 5 Min #2: Performing continuous futures contract back adjustment calculations. | 2014-06-22 15:17:09
Error while getting daily open price with date 2014-05-22 from file. C:\SierraChart\Data\CLM14.dly. Error: Encountered end of file. | 2014-06-22 15:17:09
CL-201408-NYMEX [CBV] 5 Min #2: CL-201407-NYMEX Open price on 2014-05-19 is 101.68. | 2014-06-22 15:17:09
CL-201408-NYMEX [CBV] 5 Min #2: CL-201406-NYMEX price difference to CL-201407-NYMEX is 0. | 2014-06-22 15:17:09
CL-201408-NYMEX [CBV] 5 Min #2: CL-201407-NYMEX Open price on 2014-06-18 is 106.6. | 2014-06-22 15:17:09
CL-201408-NYMEX [CBV] 5 Min #2: CL-201408-NYMEX Open price on 2014-06-18 is 106.06. | 2014-06-22 15:17:09
CL-201408-NYMEX [CBV] 5 Min #2: CL-201407-NYMEX price difference to CL-201408-NYMEX is -0.54000002. | 2014-06-22 15:17:09
CL-201408-NYMEX [CBV] 5 Min #2: Back adjust amount for symbol CL-201406-NYMEX is -0.54000002. | 2014-06-22 15:17:09
CL-201408-NYMEX [CBV] 5 Min #2: Back adjust amount for symbol CL-201407-NYMEX is -0.54000002. | 2014-06-22 15:17:09
CL-201408-NYMEX [CBV] 1 Min #6: Performing continuous futures contract back adjustment calculations. | 2014-06-22 15:17:09
CL-201408-NYMEX [CBV] 1 Min #6: CL-201407-NYMEX Open price on 2014-05-19 is 101.68. | 2014-06-22 15:17:09
CL-201408-NYMEX [CBV] 1 Min #6: CL-201406-NYMEX price difference to CL-201407-NYMEX is 0. | 2014-06-22 15:17:09
CL-201408-NYMEX [CBV] 1 Min #6: CL-201407-NYMEX Open price on 2014-06-18 is 106.6. | 2014-06-22 15:17:09
CL-201408-NYMEX [CBV] 1 Min #6: CL-201408-NYMEX Open price on 2014-06-18 is 106.06. | 2014-06-22 15:17:09
CL-201408-NYMEX [CBV] 1 Min #6: CL-201407-NYMEX price difference to CL-201408-NYMEX is -0.54000002. | 2014-06-22 15:17:09
CL-201408-NYMEX [CBV] 1 Min #6: Back adjust amount for symbol CL-201406-NYMEX is -0.54000002. | 2014-06-22 15:17:09
CL-201408-NYMEX [CBV] 1 Min #6: Back adjust amount for symbol CL-201407-NYMEX is -0.54000002. | 2014-06-22 15:17:09
Mapping CL-201408-NYMEX to CLQ4. Service code: nymex | 2014-06-22 15:17:11
HD Request # 2 - Downloading Intraday chart data for CL-201408-NYMEX to the file CL-201408-NYMEX.scid. Service: nymex | 2014-06-22 15:17:12
HD Request # 2 - Download start Date-Time: 2014-06-22 15:00:31.0 | 2014-06-22 15:17:12
HD Request # 2 - Using server: scdf2.sierracharts.com port 10149 | 2014-06-22 15:17:12
Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2014-06-22 15:17:12
The network socket is connected. | 2014-06-22 15:17:12
HD Request # 2 - Sending historical data logon request message. | 2014-06-22 15:17:12
HD Request # 2 - Requesting Intraday data. Start Date-Time: 2014-06-22 15:00:31. Record interval: 0 . Symbol: CLQ4 | 2014-06-22 15:17:13
HD Request # 2 - Decompressing data. | 2014-06-22 15:17:13
HD Request # 2 - Receiving Intraday data for CL-201408-NYMEX starting at 2014-06-22 15:00:31 | 2014-06-22 15:17:13
HD Request # 2 - Timestamp of first Intraday data file record written: 2014-06-22 15:00:32 | 2014-06-22 15:17:13
Socket has been shutdown and closed. | 2014-06-22 15:17:13
The network socket for historical data has been closed. | 2014-06-22 15:17:13
HD Request # 2 - Historical data for CL-201408-NYMEX is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2014-06-22 15:17:13
HD Request # 2 - Received 965 records from 2014-06-22 15:00:31 to 2014-06-22 15:07:11 (6.7 minutes) and wrote 964 records for CL-201408-NYMEX | 2014-06-22 15:17:13
HD Request # 2 - Intraday download COMPLETE for CL-201408-NYMEX. Completion time: 0s | 2014-06-22 15:17:13
Date rule based rollover from CL-201308-NYMEX to next contract occurs at 2013-07-19 | 2014-06-22 15:17:55
Date rule based rollover from CL-201309-NYMEX to next contract occurs at 2013-08-19 | 2014-06-22 15:17:55
Date rule based rollover from CL-201310-NYMEX to next contract occurs at 2013-09-19 | 2014-06-22 15:17:55
Date rule based rollover from CL-201311-NYMEX to next contract occurs at 2013-10-21 | 2014-06-22 15:17:55
Date rule based rollover from CL-201312-NYMEX to next contract occurs at 2013-11-19 | 2014-06-22 15:17:55
Date rule based rollover from CL-201401-NYMEX to next contract occurs at 2013-12-19 | 2014-06-22 15:17:55
Date rule based rollover from CL-201402-NYMEX to next contract occurs at 2014-01-20 | 2014-06-22 15:17:55
Date rule based rollover from CL-201403-NYMEX to next contract occurs at 2014-02-19 | 2014-06-22 15:17:55
Date rule based rollover from CL-201404-NYMEX to next contract occurs at 2014-03-19 | 2014-06-22 15:17:55
Date rule based rollover from CL-201405-NYMEX to next contract occurs at 2014-04-21 | 2014-06-22 15:17:55
Date rule based rollover from CL-201406-NYMEX to next contract occurs at 2014-05-19 | 2014-06-22 15:17:55
Date rule based rollover from CL-201407-NYMEX to next contract occurs at 2014-06-19 | 2014-06-22 15:17:55
Date rule based rollover from CL-201408-NYMEX to next contract occurs at 2014-07-21 | 2014-06-22 15:17:55
Checking Intraday data file for symbol CL-201308-NYMEX for the date range from 2013-06-19 to 2013-07-19 | 2014-06-22 15:17:55
Checking Daily data file for symbol CLQ13 for the date range from 2013-06-19 to 2013-07-19 | 2014-06-22 15:17:55
Checking Intraday data file for symbol CL-201309-NYMEX for the date range from 2013-07-19 to 2013-08-19 | 2014-06-22 15:17:55
Checking Daily data file for symbol CLU13 for the date range from 2013-07-19 to 2013-08-19 | 2014-06-22 15:17:55
Checking Intraday data file for symbol CL-201310-NYMEX for the date range from 2013-08-19 to 2013-09-19 | 2014-06-22 15:17:55
Checking Daily data file for symbol CLV13 for the date range from 2013-08-19 to 2013-09-19 | 2014-06-22 15:17:55
Checking Intraday data file for symbol CL-201311-NYMEX for the date range from 2013-09-19 to 2013-10-21 | 2014-06-22 15:17:55
Checking Daily data file for symbol CLX13 for the date range from 2013-09-19 to 2013-10-21 | 2014-06-22 15:17:55
Checking Intraday data file for symbol CL-201312-NYMEX for the date range from 2013-10-21 to 2013-11-19 | 2014-06-22 15:17:55
Checking Daily data file for symbol CLZ13 for the date range from 2013-10-21 to 2013-11-19 | 2014-06-22 15:17:55
Checking Intraday data file for symbol CL-201401-NYMEX for the date range from 2013-11-19 to 2013-12-19 | 2014-06-22 15:17:55
Checking Daily data file for symbol CLF14 for the date range from 2013-11-19 to 2013-12-19 | 2014-06-22 15:17:55
Checking Intraday data file for symbol CL-201402-NYMEX for the date range from 2013-12-19 to 2014-01-20 | 2014-06-22 15:17:55
Checking Daily data file for symbol CLG14 for the date range from 2013-12-19 to 2014-01-20 | 2014-06-22 15:17:55
Checking Intraday data file for symbol CL-201403-NYMEX for the date range from 2014-01-20 to 2014-02-19 | 2014-06-22 15:17:55
Checking Daily data file for symbol CLH14 for the date range from 2014-01-20 to 2014-02-19 | 2014-06-22 15:17:55
Checking Intraday data file for symbol CL-201404-NYMEX for the date range from 2014-02-19 to 2014-03-19 | 2014-06-22 15:17:55
Checking Daily data file for symbol CLJ14 for the date range from 2014-02-19 to 2014-03-19 | 2014-06-22 15:17:55
Checking Intraday data file for symbol CL-201405-NYMEX for the date range from 2014-03-19 to 2014-04-21 | 2014-06-22 15:17:55
Checking Daily data file for symbol CLK14 for the date range from 2014-03-19 to 2014-04-21 | 2014-06-22 15:17:55
Checking Intraday data file for symbol CL-201406-NYMEX for the date range from 2014-04-21 to 2014-05-19 | 2014-06-22 15:17:55
Daily data file for symbol CL-201406-NYMEX existed and is empty. Skipping download. | 2014-06-22 15:17:55
Checking Intraday data file for symbol CL-201407-NYMEX for the date range from 2014-05-19 to 2014-06-19 | 2014-06-22 15:17:55
Checking Daily data file for symbol CLN14 for the date range from 2014-05-19 to 2014-06-19 | 2014-06-22 15:17:55
Checking Intraday data file for symbol CL-201408-NYMEX for the date range from 2014-06-19 to 0 | 2014-06-22 15:17:55
Checking Daily data file for symbol CLQ14 for the date range from 2014-06-19 to 0 | 2014-06-22 15:17:55
Symbols used for CL-201408-NYMEX continuous contract chart: | 2014-06-22 15:17:55
CL-201308-NYMEX | 2014-06-22 15:17:55
CL-201309-NYMEX | 2014-06-22 15:17:55
CL-201310-NYMEX | 2014-06-22 15:17:55
CL-201311-NYMEX | 2014-06-22 15:17:55
CL-201312-NYMEX | 2014-06-22 15:17:55
CL-201401-NYMEX | 2014-06-22 15:17:55
CL-201402-NYMEX | 2014-06-22 15:17:55
CL-201403-NYMEX | 2014-06-22 15:17:55
CL-201404-NYMEX | 2014-06-22 15:17:55
CL-201405-NYMEX | 2014-06-22 15:17:55
CL-201406-NYMEX | 2014-06-22 15:17:55
CL-201407-NYMEX | 2014-06-22 15:17:55
CL-201408-NYMEX | 2014-06-22 15:17:55
Volume based rollover from CL-201308-NYMEX to CL-201309-NYMEX occurs at 2013-07-18 | 2014-06-22 15:17:55
Volume based rollover from CL-201309-NYMEX to CL-201310-NYMEX occurs at 2013-08-16 | 2014-06-22 15:17:55
Volume based rollover from CL-201310-NYMEX to CL-201311-NYMEX occurs at 2013-09-18 | 2014-06-22 15:17:55
Volume based rollover from CL-201311-NYMEX to CL-201312-NYMEX occurs at 2013-10-18 | 2014-06-22 15:17:55
Volume based rollover from CL-201312-NYMEX to CL-201401-NYMEX occurs at 2013-11-19 | 2014-06-22 15:17:55
Volume based rollover from CL-201401-NYMEX to CL-201402-NYMEX occurs at 2013-12-17 | 2014-06-22 15:17:55
Volume based rollover from CL-201402-NYMEX to CL-201403-NYMEX occurs at 2014-01-17 | 2014-06-22 15:17:55
Volume based rollover from CL-201403-NYMEX to CL-201404-NYMEX occurs at 2014-02-18 | 2014-06-22 15:17:55
Volume based rollover from CL-201404-NYMEX to CL-201405-NYMEX occurs at 2014-03-18 | 2014-06-22 15:17:55
Volume based rollover from CL-201405-NYMEX to CL-201406-NYMEX occurs at 2014-04-22 | 2014-06-22 15:17:55
Volume based rollover from CL-201406-NYMEX to CL-201407-NYMEX occurs at 0 | 2014-06-22 15:17:55
Using date based transition from CL-201406-NYMEX to CL-201407-NYMEX because volume based transition could not be determined. | 2014-06-22 15:17:55
Volume based rollover from CL-201407-NYMEX to CL-201408-NYMEX occurs at 2014-06-18 | 2014-06-22 15:17:55
CL-201408-NYMEX [CBV] [M] 5 Min #2: Performing continuous futures contract back adjustment calculations. | 2014-06-22 15:17:55
CL-201408-NYMEX [CBV] [M] 5 Min #2: CL-201308-NYMEX Open price on 2013-07-18 is 106.56. | 2014-06-22 15:17:55
CL-201408-NYMEX [CBV] [M] 5 Min #2: CL-201309-NYMEX Open price on 2013-07-18 is 106.35. | 2014-06-22 15:17:55
CL-201408-NYMEX [CBV] [M] 5 Min #2: CL-201308-NYMEX price difference to CL-201309-NYMEX is -0.20999999. | 2014-06-22 15:17:55
CL-201408-NYMEX [CBV] [M] 5 Min #2: CL-201309-NYMEX Open price on 2013-08-16 is 107.18. | 2014-06-22 15:17:55
CL-201408-NYMEX [CBV] [M] 5 Min #2: CL-201310-NYMEX Open price on 2013-08-16 is 107.01. | 2014-06-22 15:17:55
CL-201408-NYMEX [CBV] [M] 5 Min #2: CL-201309-NYMEX price difference to CL-201310-NYMEX is -0.17. | 2014-06-22 15:17:55
CL-201408-NYMEX [CBV] [M] 5 Min #2: CL-201310-NYMEX Open price on 2013-09-18 is 105.53. | 2014-06-22 15:17:55
CL-201408-NYMEX [CBV] [M] 5 Min #2: CL-201311-NYMEX Open price on 2013-09-18 is 104.77. | 2014-06-22 15:17:55
CL-201408-NYMEX [CBV] [M] 5 Min #2: CL-201310-NYMEX price difference to CL-201311-NYMEX is -0.75999999. | 2014-06-22 15:17:55
CL-201408-NYMEX [CBV] [M] 5 Min #2: CL-201311-NYMEX Open price on 2013-10-18 is 100.72. | 2014-06-22 15:17:55
CL-201408-NYMEX [CBV] [M] 5 Min #2: CL-201312-NYMEX Open price on 2013-10-18 is 101. | 2014-06-22 15:17:55
CL-201408-NYMEX [CBV] [M] 5 Min #2: CL-201311-NYMEX price difference to CL-201312-NYMEX is 0.28. | 2014-06-22 15:17:55
CL-201408-NYMEX [CBV] [M] 5 Min #2: CL-201312-NYMEX Open price on 2013-11-19 is 93. | 2014-06-22 15:17:55
CL-201408-NYMEX [CBV] [M] 5 Min #2: CL-201401-NYMEX Open price on 2013-11-19 is 93.64. | 2014-06-22 15:17:55
CL-201408-NYMEX [CBV] [M] 5 Min #2: CL-201312-NYMEX price difference to CL-201401-NYMEX is 0.63999999. | 2014-06-22 15:17:55
CL-201408-NYMEX [CBV] [M] 5 Min #2: CL-201401-NYMEX Open price on 2013-12-17 is 97.3. | 2014-06-22 15:17:55
CL-201408-NYMEX [CBV] [M] 5 Min #2: CL-201402-NYMEX Open price on 2013-12-17 is 97.54. | 2014-06-22 15:17:55
CL-201408-NYMEX [CBV] [M] 5 Min #2: CL-201401-NYMEX price difference to CL-201402-NYMEX is 0.23999999. | 2014-06-22 15:17:55
CL-201408-NYMEX [CBV] [M] 5 Min #2: CL-201402-NYMEX Open price on 2014-01-17 is 94.17. | 2014-06-22 15:17:55
CL-201408-NYMEX [CBV] [M] 5 Min #2: CL-201403-NYMEX Open price on 2014-01-17 is 94.29. | 2014-06-22 15:17:55
CL-201408-NYMEX [CBV] [M] 5 Min #2: CL-201402-NYMEX price difference to CL-201403-NYMEX is 0.12. | 2014-06-22 15:17:55
CL-201408-NYMEX [CBV] [M] 5 Min #2: CL-201403-NYMEX Open price on 2014-02-18 is 100.32. | 2014-06-22 15:17:55
CL-201408-NYMEX [CBV] [M] 5 Min #2: CL-201404-NYMEX Open price on 2014-02-18 is 100.12. | 2014-06-22 15:17:55
CL-201408-NYMEX [CBV] [M] 5 Min #2: CL-201403-NYMEX price difference to CL-201404-NYMEX is -0.2. | 2014-06-22 15:17:55
CL-201408-NYMEX [CBV] [M] 5 Min #2: CL-201404-NYMEX Open price on 2014-03-18 is 97.97. | 2014-06-22 15:17:55
CL-201408-NYMEX [CBV] [M] 5 Min #2: CL-201405-NYMEX Open price on 2014-03-18 is 97.46. | 2014-06-22 15:17:55
CL-201408-NYMEX [CBV] [M] 5 Min #2: CL-201404-NYMEX price difference to CL-201405-NYMEX is -0.50999999. | 2014-06-22 15:17:55
CL-201408-NYMEX [CBV] [M] 5 Min #2: CL-201405-NYMEX Open price on 2014-04-22 is 104.36. | 2014-06-22 15:17:55
Error while getting daily open price with date 2014-04-25 from file. C:\SierraChart\Data\CLM14.dly. Error: Encountered end of file. | 2014-06-22 15:17:55
CL-201408-NYMEX [CBV] [M] 5 Min #2: CL-201405-NYMEX price difference to CL-201406-NYMEX is 0. | 2014-06-22 15:17:55
Error while getting daily open price with date 2014-05-22 from file. C:\SierraChart\Data\CLM14.dly. Error: Encountered end of file. | 2014-06-22 15:17:55
CL-201408-NYMEX [CBV] [M] 5 Min #2: CL-201407-NYMEX Open price on 2014-05-19 is 101.68. | 2014-06-22 15:17:55
CL-201408-NYMEX [CBV] [M] 5 Min #2: CL-201406-NYMEX price difference to CL-201407-NYMEX is 0. | 2014-06-22 15:17:55
CL-201408-NYMEX [CBV] [M] 5 Min #2: CL-201407-NYMEX Open price on 2014-06-18 is 106.6. | 2014-06-22 15:17:55
CL-201408-NYMEX [CBV] [M] 5 Min #2: CL-201408-NYMEX Open price on 2014-06-18 is 106.06. | 2014-06-22 15:17:55
CL-201408-NYMEX [CBV] [M] 5 Min #2: CL-201407-NYMEX price difference to CL-201408-NYMEX is -0.54000002. | 2014-06-22 15:17:55
CL-201408-NYMEX [CBV] [M] 5 Min #2: Back adjust amount for symbol CL-201308-NYMEX is -1.1100001. | 2014-06-22 15:17:55
CL-201408-NYMEX [CBV] [M] 5 Min #2: Back adjust amount for symbol CL-201309-NYMEX is -0.90000004. | 2014-06-22 15:17:55
CL-201408-NYMEX [CBV] [M] 5 Min #2: Back adjust amount for symbol CL-201310-NYMEX is -0.73000002. | 2014-06-22 15:17:55
CL-201408-NYMEX [CBV] [M] 5 Min #2: Back adjust amount for symbol CL-201311-NYMEX is 0.029999912. | 2014-06-22 15:17:55
CL-201408-NYMEX [CBV] [M] 5 Min #2: Back adjust amount for symbol CL-201312-NYMEX is -0.25. | 2014-06-22 15:17:55
CL-201408-NYMEX [CBV] [M] 5 Min #2: Back adjust amount for symbol CL-201401-NYMEX is -0.89000005. | 2014-06-22 15:17:55
CL-201408-NYMEX [CBV] [M] 5 Min #2: Back adjust amount for symbol CL-201402-NYMEX is -1.13. | 2014-06-22 15:17:55
CL-201408-NYMEX [CBV] [M] 5 Min #2: Back adjust amount for symbol CL-201403-NYMEX is -1.25. | 2014-06-22 15:17:55
CL-201408-NYMEX [CBV] [M] 5 Min #2: Back adjust amount for symbol CL-201404-NYMEX is -1.05. | 2014-06-22 15:17:55
CL-201408-NYMEX [CBV] [M] 5 Min #2: Back adjust amount for symbol CL-201405-NYMEX is -0.54000002. | 2014-06-22 15:17:55
CL-201408-NYMEX [CBV] [M] 5 Min #2: Back adjust amount for symbol CL-201406-NYMEX is -0.54000002. | 2014-06-22 15:17:55
CL-201408-NYMEX [CBV] [M] 5 Min #2: Back adjust amount for symbol CL-201407-NYMEX is -0.54000002. | 2014-06-22 15:17:55
HD Request # 3 - Downloading Intraday chart data for CL-201408-NYMEX to the file CL-201408-NYMEX.scid. Service: nymex | 2014-06-22 15:18:53
HD Request # 3 - Download start Date-Time: 2014-06-16 16:59:59.0 | 2014-06-22 15:18:53
HD Request # 3 - Using server: scdf1.sierracharts.com port 10149 | 2014-06-22 15:18:53
HD Request # 4 - Downloading Historical Daily chart data for CLQ13. Starting date: 2013-07-19. Service: ib | 2014-06-22 15:18:53
HD Request # 4 - Using user Barchart Historical data account. | 2014-06-22 15:18:53
HD Request # 4 - Requesting historical Daily data for CLQ13 starting at 2013-07-18 | 2014-06-22 15:18:53
Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2014-06-22 15:18:53
The network socket is connected. | 2014-06-22 15:18:53
HD Request # 3 - Sending historical data logon request message. | 2014-06-22 15:18:53
HD Request # 3 - Requesting Intraday data. Start Date-Time: 2014-06-16 16:59:59. Record interval: 0 . Symbol: CLQ4 | 2014-06-22 15:18:54
HD Request # 3 - Decompressing data. | 2014-06-22 15:18:54
HD Request # 3 - Receiving Intraday data for CL-201408-NYMEX starting at 2014-06-16 17:00:02 | 2014-06-22 15:18:54
HD Request # 3 - Timestamp of first Intraday data file record written: 2014-06-16 17:00:02 | 2014-06-22 15:18:54
HD Request # 4 - Receiving historical Daily data for CLQ13 starting at 2013-07-18 | 2014-06-22 15:18:55
Writing historical Daily data for CLQ13 to the file CLQ13.dly | 2014-06-22 15:18:55
HD Request # 4 - Received 3 records from 2013-07-18 00:00:00 to 2013-07-22 00:00:00 (5.0 days) and wrote 2 records for CLQ13 | 2014-06-22 15:18:55
HD Request # 4 - Daily download COMPLETE for CLQ13. Completion time: 2s | 2014-06-22 15:18:55
HD Request # 3 - Historical data for CL-201408-NYMEX is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2014-06-22 15:18:55
Socket has been shutdown and closed. | 2014-06-22 15:18:55
The network socket for historical data has been closed. | 2014-06-22 15:18:55
HD Request # 3 - Received 409338 records from 2014-06-16 17:00:02 to 2014-06-22 15:08:41 (5.9 days) and wrote 409338 records for CL-201408-NYMEX | 2014-06-22 15:18:55
HD Request # 3 - Intraday download COMPLETE for CL-201408-NYMEX. Completion time: 3s | 2014-06-22 15:18:56
CL-201408-NYMEX [CBV] [M] 5 Min #2: Download is complete for all contract months in chart. Proceeding with data load. | 2014-06-22 15:18:56
Volume based rollover from CL-201308-NYMEX to CL-201309-NYMEX occurs at 2013-07-18 | 2014-06-22 15:18:56
Volume based rollover from CL-201309-NYMEX to CL-201310-NYMEX occurs at 2013-08-16 | 2014-06-22 15:18:56
Volume based rollover from CL-201310-NYMEX to CL-201311-NYMEX occurs at 2013-09-18 | 2014-06-22 15:18:56
Volume based rollover from CL-201311-NYMEX to CL-201312-NYMEX occurs at 2013-10-18 | 2014-06-22 15:18:56
Volume based rollover from CL-201312-NYMEX to CL-201401-NYMEX occurs at 2013-11-19 | 2014-06-22 15:18:56
Volume based rollover from CL-201401-NYMEX to CL-201402-NYMEX occurs at 2013-12-17 | 2014-06-22 15:18:56
Volume based rollover from CL-201402-NYMEX to CL-201403-NYMEX occurs at 2014-01-17 | 2014-06-22 15:18:56
Volume based rollover from CL-201403-NYMEX to CL-201404-NYMEX occurs at 2014-02-18 | 2014-06-22 15:18:56
Volume based rollover from CL-201404-NYMEX to CL-201405-NYMEX occurs at 2014-03-18 | 2014-06-22 15:18:56
Volume based rollover from CL-201405-NYMEX to CL-201406-NYMEX occurs at 2014-04-22 | 2014-06-22 15:18:56
Volume based rollover from CL-201406-NYMEX to CL-201407-NYMEX occurs at 0 | 2014-06-22 15:18:56
Using date based transition from CL-201406-NYMEX to CL-201407-NYMEX because volume based transition could not be determined. | 2014-06-22 15:18:56
Volume based rollover from CL-201407-NYMEX to CL-201408-NYMEX occurs at 2014-06-18 | 2014-06-22 15:18:56
CL-201408-NYMEX [CBV] [M] 5 Min #2: Performing continuous futures contract back adjustment calculations. | 2014-06-22 15:18:56
CL-201408-NYMEX [CBV] [M] 5 Min #2: CL-201308-NYMEX Open price on 2013-07-18 is 106.56. | 2014-06-22 15:18:56
CL-201408-NYMEX [CBV] [M] 5 Min #2: CL-201309-NYMEX Open price on 2013-07-18 is 106.35. | 2014-06-22 15:18:56
CL-201408-NYMEX [CBV] [M] 5 Min #2: CL-201308-NYMEX price difference to CL-201309-NYMEX is -0.20999999. | 2014-06-22 15:18:56
CL-201408-NYMEX [CBV] [M] 5 Min #2: CL-201309-NYMEX Open price on 2013-08-16 is 107.18. | 2014-06-22 15:18:56
CL-201408-NYMEX [CBV] [M] 5 Min #2: CL-201310-NYMEX Open price on 2013-08-16 is 107.01. | 2014-06-22 15:18:56
CL-201408-NYMEX [CBV] [M] 5 Min #2: CL-201309-NYMEX price difference to CL-201310-NYMEX is -0.17. | 2014-06-22 15:18:56
CL-201408-NYMEX [CBV] [M] 5 Min #2: CL-201310-NYMEX Open price on 2013-09-18 is 105.53. | 2014-06-22 15:18:56
CL-201408-NYMEX [CBV] [M] 5 Min #2: CL-201311-NYMEX Open price on 2013-09-18 is 104.77. | 2014-06-22 15:18:56
CL-201408-NYMEX [CBV] [M] 5 Min #2: CL-201310-NYMEX price difference to CL-201311-NYMEX is -0.75999999. | 2014-06-22 15:18:56
CL-201408-NYMEX [CBV] [M] 5 Min #2: CL-201311-NYMEX Open price on 2013-10-18 is 100.72. | 2014-06-22 15:18:56
CL-201408-NYMEX [CBV] [M] 5 Min #2: CL-201312-NYMEX Open price on 2013-10-18 is 101. | 2014-06-22 15:18:56
CL-201408-NYMEX [CBV] [M] 5 Min #2: CL-201311-NYMEX price difference to CL-201312-NYMEX is 0.28. | 2014-06-22 15:18:56
CL-201408-NYMEX [CBV] [M] 5 Min #2: CL-201312-NYMEX Open price on 2013-11-19 is 93. | 2014-06-22 15:18:56
CL-201408-NYMEX [CBV] [M] 5 Min #2: CL-201401-NYMEX Open price on 2013-11-19 is 93.64. | 2014-06-22 15:18:56
CL-201408-NYMEX [CBV] [M] 5 Min #2: CL-201312-NYMEX price difference to CL-201401-NYMEX is 0.63999999. | 2014-06-22 15:18:56
CL-201408-NYMEX [CBV] [M] 5 Min #2: CL-201401-NYMEX Open price on 2013-12-17 is 97.3. | 2014-06-22 15:18:56
CL-201408-NYMEX [CBV] [M] 5 Min #2: CL-201402-NYMEX Open price on 2013-12-17 is 97.54. | 2014-06-22 15:18:56
CL-201408-NYMEX [CBV] [M] 5 Min #2: CL-201401-NYMEX price difference to CL-201402-NYMEX is 0.23999999. | 2014-06-22 15:18:56
CL-201408-NYMEX [CBV] [M] 5 Min #2: CL-201402-NYMEX Open price on 2014-01-17 is 94.17. | 2014-06-22 15:18:56
CL-201408-NYMEX [CBV] [M] 5 Min #2: CL-201403-NYMEX Open price on 2014-01-17 is 94.29. | 2014-06-22 15:18:56
CL-201408-NYMEX [CBV] [M] 5 Min #2: CL-201402-NYMEX price difference to CL-201403-NYMEX is 0.12. | 2014-06-22 15:18:56
CL-201408-NYMEX [CBV] [M] 5 Min #2: CL-201403-NYMEX Open price on 2014-02-18 is 100.32. | 2014-06-22 15:18:56
CL-201408-NYMEX [CBV] [M] 5 Min #2: CL-201404-NYMEX Open price on 2014-02-18 is 100.12. | 2014-06-22 15:18:56
CL-201408-NYMEX [CBV] [M] 5 Min #2: CL-201403-NYMEX price difference to CL-201404-NYMEX is -0.2. | 2014-06-22 15:18:56
CL-201408-NYMEX [CBV] [M] 5 Min #2: CL-201404-NYMEX Open price on 2014-03-18 is 97.97. | 2014-06-22 15:18:56
CL-201408-NYMEX [CBV] [M] 5 Min #2: CL-201405-NYMEX Open price on 2014-03-18 is 97.46. | 2014-06-22 15:18:56
CL-201408-NYMEX [CBV] [M] 5 Min #2: CL-201404-NYMEX price difference to CL-201405-NYMEX is -0.50999999. | 2014-06-22 15:18:56
CL-201408-NYMEX [CBV] [M] 5 Min #2: CL-201405-NYMEX Open price on 2014-04-22 is 104.36. | 2014-06-22 15:18:56
Error while getting daily open price with date 2014-04-25 from file. C:\SierraChart\Data\CLM14.dly. Error: Encountered end of file. | 2014-06-22 15:18:56
CL-201408-NYMEX [CBV] [M] 5 Min #2: CL-201405-NYMEX price difference to CL-201406-NYMEX is -0.54000002. | 2014-06-22 15:18:56
Error while getting daily open price with date 2014-05-22 from file. C:\SierraChart\Data\CLM14.dly. Error: Encountered end of file. | 2014-06-22 15:18:56
CL-201408-NYMEX [CBV] [M] 5 Min #2: CL-201407-NYMEX Open price on 2014-05-19 is 101.68. | 2014-06-22 15:18:56
CL-201408-NYMEX [CBV] [M] 5 Min #2: CL-201406-NYMEX price difference to CL-201407-NYMEX is -0.54000002. | 2014-06-22 15:18:56
CL-201408-NYMEX [CBV] [M] 5 Min #2: CL-201407-NYMEX Open price on 2014-06-18 is 106.6. | 2014-06-22 15:18:56
CL-201408-NYMEX [CBV] [M] 5 Min #2: CL-201408-NYMEX Open price on 2014-06-18 is 106.06. | 2014-06-22 15:18:56
CL-201408-NYMEX [CBV] [M] 5 Min #2: CL-201407-NYMEX price difference to CL-201408-NYMEX is -0.54000002. | 2014-06-22 15:18:56
CL-201408-NYMEX [CBV] [M] 5 Min #2: Back adjust amount for symbol CL-201308-NYMEX is -2.1900001. | 2014-06-22 15:18:56
CL-201408-NYMEX [CBV] [M] 5 Min #2: Back adjust amount for symbol CL-201309-NYMEX is -1.98. | 2014-06-22 15:18:56
CL-201408-NYMEX [CBV] [M] 5 Min #2: Back adjust amount for symbol CL-201310-NYMEX is -1.8099999. | 2014-06-22 15:18:56
CL-201408-NYMEX [CBV] [M] 5 Min #2: Back adjust amount for symbol CL-201311-NYMEX is -1.0500002. | 2014-06-22 15:18:56
CL-201408-NYMEX [CBV] [M] 5 Min #2: Back adjust amount for symbol CL-201312-NYMEX is -1.33. | 2014-06-22 15:18:56
CL-201408-NYMEX [CBV] [M] 5 Min #2: Back adjust amount for symbol CL-201401-NYMEX is -1.97. | 2014-06-22 15:18:56
CL-201408-NYMEX [CBV] [M] 5 Min #2: Back adjust amount for symbol CL-201402-NYMEX is -2.21. | 2014-06-22 15:18:56
CL-201408-NYMEX [CBV] [M] 5 Min #2: Back adjust amount for symbol CL-201403-NYMEX is -2.3299999. | 2014-06-22 15:18:56
CL-201408-NYMEX [CBV] [M] 5 Min #2: Back adjust amount for symbol CL-201404-NYMEX is -2.1299999. | 2014-06-22 15:18:56
CL-201408-NYMEX [CBV] [M] 5 Min #2: Back adjust amount for symbol CL-201405-NYMEX is -1.6200001. | 2014-06-22 15:18:56
CL-201408-NYMEX [CBV] [M] 5 Min #2: Back adjust amount for symbol CL-201406-NYMEX is -1.08. | 2014-06-22 15:18:56
CL-201408-NYMEX [CBV] [M] 5 Min #2: Back adjust amount for symbol CL-201407-NYMEX is -0.54000002. | 2014-06-22 15:18:56
[2014-06-22 22:35:16]
ged - Posts: 233
I think one chart may have been behind the chart I created the message log from. Sorry if that is the case. I know you wanted just one chart.
Each time I try to close that hidden chart it causes the chart I want to make the message log from to close as well.
Hope the above log will suffice.
Also, though I set the chart to download 300 days of data, it appears that it only downloaded a handful of days.
[2014-06-23 19:28:10]
ged - Posts: 233
Below is the current Message Log with the hidden chart deleted:
Software version: 1143 | 2014-06-23 04:49:40
Usage end date: 2014-07-31 | 2014-06-23 04:49:40
Enabled for: Advanced Features. | 2014-06-23 04:49:40
Enabled for: Sierra Chart Historical Data Service. | 2014-06-23 04:49:40
Enabled for: Sierra Chart Real-Time Exchange Data Feed. | 2014-06-23 04:49:40
Enabled for: CME, CBOT, NYMEX, COMEX exchanges. | 2014-06-23 04:49:40
Enabled for: US EQUITIES exchanges. | 2014-06-23 04:49:40
Received 1 data feed usernames. | 2014-06-23 04:49:40
Allow Support for Sierra Chart Data Feeds is enabled. | 2014-06-23 04:49:40
Active service: Interactive Brokers | 2014-06-23 04:49:40
Time Zone: -07:00:00 (PST-08PDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2014-06-23 04:49:40
2014-06-23 04:49:40 Local computer clock time | 2014-06-23 04:49:40
2014-06-23 11:49:40 GMT time | 2014-06-23 04:49:40
2014-06-23 04:49:40 Time zone adjusted time | 2014-06-23 04:49:40
Time difference to server time: 1 seconds. | 2014-06-23 04:49:40
Program path: C:\SierraChart\ | 2014-06-23 04:49:40
Data Files path: C:\SierraChart\Data\ | 2014-06-23 04:49:40
OS Version Number: 6.1 | 2014-06-23 04:49:40
Checking for new symbol settings for ib | 2014-06-23 04:49:40
Symbol settings are up-to-date for ib | 2014-06-23 04:49:40
Date rule based rollover from CL-201308-NYMEX to next contract occurs at 2013-07-19 | 2014-06-23 04:49:54
Date rule based rollover from CL-201309-NYMEX to next contract occurs at 2013-08-19 | 2014-06-23 04:49:54
Date rule based rollover from CL-201310-NYMEX to next contract occurs at 2013-09-19 | 2014-06-23 04:49:54
Date rule based rollover from CL-201311-NYMEX to next contract occurs at 2013-10-21 | 2014-06-23 04:49:54
Date rule based rollover from CL-201312-NYMEX to next contract occurs at 2013-11-19 | 2014-06-23 04:49:54
Date rule based rollover from CL-201401-NYMEX to next contract occurs at 2013-12-19 | 2014-06-23 04:49:54
Date rule based rollover from CL-201402-NYMEX to next contract occurs at 2014-01-20 | 2014-06-23 04:49:54
Date rule based rollover from CL-201403-NYMEX to next contract occurs at 2014-02-19 | 2014-06-23 04:49:54
Date rule based rollover from CL-201404-NYMEX to next contract occurs at 2014-03-19 | 2014-06-23 04:49:54
Date rule based rollover from CL-201405-NYMEX to next contract occurs at 2014-04-21 | 2014-06-23 04:49:54
Date rule based rollover from CL-201406-NYMEX to next contract occurs at 2014-05-19 | 2014-06-23 04:49:54
Date rule based rollover from CL-201407-NYMEX to next contract occurs at 2014-06-19 | 2014-06-23 04:49:54
Date rule based rollover from CL-201408-NYMEX to next contract occurs at 2014-07-21 | 2014-06-23 04:49:54
Checking Intraday data file for symbol CL-201308-NYMEX for the date range from 2013-06-19 to 2013-07-19 | 2014-06-23 04:49:54
Checking Daily data file for symbol CLQ13 for the date range from 2013-06-19 to 2013-07-19 | 2014-06-23 04:49:54
Checking Intraday data file for symbol CL-201309-NYMEX for the date range from 2013-07-19 to 2013-08-19 | 2014-06-23 04:49:54
Checking Daily data file for symbol CLU13 for the date range from 2013-07-19 to 2013-08-19 | 2014-06-23 04:49:54
Checking Intraday data file for symbol CL-201310-NYMEX for the date range from 2013-08-19 to 2013-09-19 | 2014-06-23 04:49:54
Checking Daily data file for symbol CLV13 for the date range from 2013-08-19 to 2013-09-19 | 2014-06-23 04:49:54
Checking Intraday data file for symbol CL-201311-NYMEX for the date range from 2013-09-19 to 2013-10-21 | 2014-06-23 04:49:54
Checking Daily data file for symbol CLX13 for the date range from 2013-09-19 to 2013-10-21 | 2014-06-23 04:49:54
Checking Intraday data file for symbol CL-201312-NYMEX for the date range from 2013-10-21 to 2013-11-19 | 2014-06-23 04:49:55
Checking Daily data file for symbol CLZ13 for the date range from 2013-10-21 to 2013-11-19 | 2014-06-23 04:49:55
Checking Intraday data file for symbol CL-201401-NYMEX for the date range from 2013-11-19 to 2013-12-19 | 2014-06-23 04:49:55
Checking Daily data file for symbol CLF14 for the date range from 2013-11-19 to 2013-12-19 | 2014-06-23 04:49:55
Checking Intraday data file for symbol CL-201402-NYMEX for the date range from 2013-12-19 to 2014-01-20 | 2014-06-23 04:49:55
Checking Daily data file for symbol CLG14 for the date range from 2013-12-19 to 2014-01-20 | 2014-06-23 04:49:55
Checking Intraday data file for symbol CL-201403-NYMEX for the date range from 2014-01-20 to 2014-02-19 | 2014-06-23 04:49:55
Checking Daily data file for symbol CLH14 for the date range from 2014-01-20 to 2014-02-19 | 2014-06-23 04:49:55
Checking Intraday data file for symbol CL-201404-NYMEX for the date range from 2014-02-19 to 2014-03-19 | 2014-06-23 04:49:55
Checking Daily data file for symbol CLJ14 for the date range from 2014-02-19 to 2014-03-19 | 2014-06-23 04:49:55
Checking Intraday data file for symbol CL-201405-NYMEX for the date range from 2014-03-19 to 2014-04-21 | 2014-06-23 04:49:55
Checking Daily data file for symbol CLK14 for the date range from 2014-03-19 to 2014-04-21 | 2014-06-23 04:49:55
Checking Intraday data file for symbol CL-201406-NYMEX for the date range from 2014-04-21 to 2014-05-19 | 2014-06-23 04:49:55
Daily data file for symbol CL-201406-NYMEX existed and is empty. Skipping download. | 2014-06-23 04:49:55
Checking Intraday data file for symbol CL-201407-NYMEX for the date range from 2014-05-19 to 2014-06-19 | 2014-06-23 04:49:55
Checking Daily data file for symbol CLN14 for the date range from 2014-05-19 to 2014-06-19 | 2014-06-23 04:49:55
Checking Intraday data file for symbol CL-201408-NYMEX for the date range from 2014-06-19 to 0 | 2014-06-23 04:49:55
Checking Daily data file for symbol CLQ14 for the date range from 2014-06-19 to 0 | 2014-06-23 04:49:55
Symbols used for CL-201408-NYMEX continuous contract chart: | 2014-06-23 04:49:55
CL-201308-NYMEX | 2014-06-23 04:49:55
CL-201309-NYMEX | 2014-06-23 04:49:55
CL-201310-NYMEX | 2014-06-23 04:49:55
CL-201311-NYMEX | 2014-06-23 04:49:55
CL-201312-NYMEX | 2014-06-23 04:49:55
CL-201401-NYMEX | 2014-06-23 04:49:55
CL-201402-NYMEX | 2014-06-23 04:49:55
CL-201403-NYMEX | 2014-06-23 04:49:55
CL-201404-NYMEX | 2014-06-23 04:49:55
CL-201405-NYMEX | 2014-06-23 04:49:55
CL-201406-NYMEX | 2014-06-23 04:49:55
CL-201407-NYMEX | 2014-06-23 04:49:55
CL-201408-NYMEX | 2014-06-23 04:49:55
Volume based rollover from CL-201308-NYMEX to CL-201309-NYMEX occurs at 2013-07-18 | 2014-06-23 04:49:55
Volume based rollover from CL-201309-NYMEX to CL-201310-NYMEX occurs at 2013-08-16 | 2014-06-23 04:49:55
Volume based rollover from CL-201310-NYMEX to CL-201311-NYMEX occurs at 2013-09-18 | 2014-06-23 04:49:55
Volume based rollover from CL-201311-NYMEX to CL-201312-NYMEX occurs at 2013-10-18 | 2014-06-23 04:49:55
Volume based rollover from CL-201312-NYMEX to CL-201401-NYMEX occurs at 2013-11-19 | 2014-06-23 04:49:55
Volume based rollover from CL-201401-NYMEX to CL-201402-NYMEX occurs at 2013-12-17 | 2014-06-23 04:49:55
Volume based rollover from CL-201402-NYMEX to CL-201403-NYMEX occurs at 2014-01-17 | 2014-06-23 04:49:55
Volume based rollover from CL-201403-NYMEX to CL-201404-NYMEX occurs at 2014-02-18 | 2014-06-23 04:49:55
Volume based rollover from CL-201404-NYMEX to CL-201405-NYMEX occurs at 2014-03-18 | 2014-06-23 04:49:55
Volume based rollover from CL-201405-NYMEX to CL-201406-NYMEX occurs at 2014-04-22 | 2014-06-23 04:49:55
Volume based rollover from CL-201406-NYMEX to CL-201407-NYMEX occurs at 0 | 2014-06-23 04:49:55
Using date based transition from CL-201406-NYMEX to CL-201407-NYMEX because volume based transition could not be determined. | 2014-06-23 04:49:55
Volume based rollover from CL-201407-NYMEX to CL-201408-NYMEX occurs at 2014-06-18 | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 5 Min #2: Performing continuous futures contract back adjustment calculations. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 5 Min #2: CL-201308-NYMEX Open price on 2013-07-18 is 106.56. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 5 Min #2: CL-201309-NYMEX Open price on 2013-07-18 is 106.35. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 5 Min #2: CL-201308-NYMEX price difference to CL-201309-NYMEX is -0.20999999. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 5 Min #2: CL-201309-NYMEX Open price on 2013-08-16 is 107.18. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 5 Min #2: CL-201310-NYMEX Open price on 2013-08-16 is 107.01. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 5 Min #2: CL-201309-NYMEX price difference to CL-201310-NYMEX is -0.17. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 5 Min #2: CL-201310-NYMEX Open price on 2013-09-18 is 105.53. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 5 Min #2: CL-201311-NYMEX Open price on 2013-09-18 is 104.77. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 5 Min #2: CL-201310-NYMEX price difference to CL-201311-NYMEX is -0.75999999. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 5 Min #2: CL-201311-NYMEX Open price on 2013-10-18 is 100.72. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 5 Min #2: CL-201312-NYMEX Open price on 2013-10-18 is 101. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 5 Min #2: CL-201311-NYMEX price difference to CL-201312-NYMEX is 0.28. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 5 Min #2: CL-201312-NYMEX Open price on 2013-11-19 is 93. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 5 Min #2: CL-201401-NYMEX Open price on 2013-11-19 is 93.64. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 5 Min #2: CL-201312-NYMEX price difference to CL-201401-NYMEX is 0.63999999. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 5 Min #2: CL-201401-NYMEX Open price on 2013-12-17 is 97.3. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 5 Min #2: CL-201402-NYMEX Open price on 2013-12-17 is 97.54. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 5 Min #2: CL-201401-NYMEX price difference to CL-201402-NYMEX is 0.23999999. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 5 Min #2: CL-201402-NYMEX Open price on 2014-01-17 is 94.17. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 5 Min #2: CL-201403-NYMEX Open price on 2014-01-17 is 94.29. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 5 Min #2: CL-201402-NYMEX price difference to CL-201403-NYMEX is 0.12. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 5 Min #2: CL-201403-NYMEX Open price on 2014-02-18 is 100.32. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 5 Min #2: CL-201404-NYMEX Open price on 2014-02-18 is 100.12. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 5 Min #2: CL-201403-NYMEX price difference to CL-201404-NYMEX is -0.2. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 5 Min #2: CL-201404-NYMEX Open price on 2014-03-18 is 97.97. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 5 Min #2: CL-201405-NYMEX Open price on 2014-03-18 is 97.46. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 5 Min #2: CL-201404-NYMEX price difference to CL-201405-NYMEX is -0.50999999. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 5 Min #2: CL-201405-NYMEX Open price on 2014-04-22 is 104.36. | 2014-06-23 04:49:55
Error while getting daily open price with date 2014-04-25 from file. C:\SierraChart\Data\CLM14.dly. Error: Encountered end of file. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 5 Min #2: CL-201405-NYMEX price difference to CL-201406-NYMEX is 0. | 2014-06-23 04:49:55
Error while getting daily open price with date 2014-05-22 from file. C:\SierraChart\Data\CLM14.dly. Error: Encountered end of file. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 5 Min #2: CL-201407-NYMEX Open price on 2014-05-19 is 101.68. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 5 Min #2: CL-201406-NYMEX price difference to CL-201407-NYMEX is 0. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 5 Min #2: CL-201407-NYMEX Open price on 2014-06-18 is 106.6. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 5 Min #2: CL-201408-NYMEX Open price on 2014-06-18 is 106.06. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 5 Min #2: CL-201407-NYMEX price difference to CL-201408-NYMEX is -0.54000002. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 5 Min #2: Back adjust amount for symbol CL-201308-NYMEX is -1.1100001. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 5 Min #2: Back adjust amount for symbol CL-201309-NYMEX is -0.90000004. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 5 Min #2: Back adjust amount for symbol CL-201310-NYMEX is -0.73000002. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 5 Min #2: Back adjust amount for symbol CL-201311-NYMEX is 0.029999912. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 5 Min #2: Back adjust amount for symbol CL-201312-NYMEX is -0.25. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 5 Min #2: Back adjust amount for symbol CL-201401-NYMEX is -0.89000005. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 5 Min #2: Back adjust amount for symbol CL-201402-NYMEX is -1.13. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 5 Min #2: Back adjust amount for symbol CL-201403-NYMEX is -1.25. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 5 Min #2: Back adjust amount for symbol CL-201404-NYMEX is -1.05. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 5 Min #2: Back adjust amount for symbol CL-201405-NYMEX is -0.54000002. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 5 Min #2: Back adjust amount for symbol CL-201406-NYMEX is -0.54000002. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 5 Min #2: Back adjust amount for symbol CL-201407-NYMEX is -0.54000002. | 2014-06-23 04:49:55
Date rule based rollover from CL-201308-NYMEX to next contract occurs at 2013-07-19 | 2014-06-23 04:49:55
Date rule based rollover from CL-201309-NYMEX to next contract occurs at 2013-08-19 | 2014-06-23 04:49:55
Date rule based rollover from CL-201310-NYMEX to next contract occurs at 2013-09-19 | 2014-06-23 04:49:55
Date rule based rollover from CL-201311-NYMEX to next contract occurs at 2013-10-21 | 2014-06-23 04:49:55
Date rule based rollover from CL-201312-NYMEX to next contract occurs at 2013-11-19 | 2014-06-23 04:49:55
Date rule based rollover from CL-201401-NYMEX to next contract occurs at 2013-12-19 | 2014-06-23 04:49:55
Date rule based rollover from CL-201402-NYMEX to next contract occurs at 2014-01-20 | 2014-06-23 04:49:55
Date rule based rollover from CL-201403-NYMEX to next contract occurs at 2014-02-19 | 2014-06-23 04:49:55
Date rule based rollover from CL-201404-NYMEX to next contract occurs at 2014-03-19 | 2014-06-23 04:49:55
Date rule based rollover from CL-201405-NYMEX to next contract occurs at 2014-04-21 | 2014-06-23 04:49:55
Date rule based rollover from CL-201406-NYMEX to next contract occurs at 2014-05-19 | 2014-06-23 04:49:55
Date rule based rollover from CL-201407-NYMEX to next contract occurs at 2014-06-19 | 2014-06-23 04:49:55
Date rule based rollover from CL-201408-NYMEX to next contract occurs at 2014-07-21 | 2014-06-23 04:49:55
Checking Intraday data file for symbol CL-201308-NYMEX for the date range from 2013-06-19 to 2013-07-19 | 2014-06-23 04:49:55
Checking Daily data file for symbol CLQ13 for the date range from 2013-06-19 to 2013-07-19 | 2014-06-23 04:49:55
Checking Intraday data file for symbol CL-201309-NYMEX for the date range from 2013-07-19 to 2013-08-19 | 2014-06-23 04:49:55
Checking Daily data file for symbol CLU13 for the date range from 2013-07-19 to 2013-08-19 | 2014-06-23 04:49:55
Checking Intraday data file for symbol CL-201310-NYMEX for the date range from 2013-08-19 to 2013-09-19 | 2014-06-23 04:49:55
Checking Daily data file for symbol CLV13 for the date range from 2013-08-19 to 2013-09-19 | 2014-06-23 04:49:55
Checking Intraday data file for symbol CL-201311-NYMEX for the date range from 2013-09-19 to 2013-10-21 | 2014-06-23 04:49:55
Checking Daily data file for symbol CLX13 for the date range from 2013-09-19 to 2013-10-21 | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 1 Min #3: Performing continuous futures contract back adjustment calculations. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 1 Min #3: CL-201308-NYMEX Open price on 2013-07-18 is 106.56. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 1 Min #3: CL-201309-NYMEX Open price on 2013-07-18 is 106.35. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 1 Min #3: CL-201308-NYMEX price difference to CL-201309-NYMEX is -0.20999999. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 1 Min #3: CL-201309-NYMEX Open price on 2013-08-16 is 107.18. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 1 Min #3: CL-201310-NYMEX Open price on 2013-08-16 is 107.01. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 1 Min #3: CL-201309-NYMEX price difference to CL-201310-NYMEX is -0.17. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 1 Min #3: CL-201310-NYMEX Open price on 2013-09-18 is 105.53. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 1 Min #3: CL-201311-NYMEX Open price on 2013-09-18 is 104.77. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 1 Min #3: CL-201310-NYMEX price difference to CL-201311-NYMEX is -0.75999999. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 1 Min #3: CL-201311-NYMEX Open price on 2013-10-18 is 100.72. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 1 Min #3: CL-201312-NYMEX Open price on 2013-10-18 is 101. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 1 Min #3: CL-201311-NYMEX price difference to CL-201312-NYMEX is 0.28. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 1 Min #3: CL-201312-NYMEX Open price on 2013-11-19 is 93. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 1 Min #3: CL-201401-NYMEX Open price on 2013-11-19 is 93.64. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 1 Min #3: CL-201312-NYMEX price difference to CL-201401-NYMEX is 0.63999999. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 1 Min #3: CL-201401-NYMEX Open price on 2013-12-17 is 97.3. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 1 Min #3: CL-201402-NYMEX Open price on 2013-12-17 is 97.54. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 1 Min #3: CL-201401-NYMEX price difference to CL-201402-NYMEX is 0.23999999. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 1 Min #3: CL-201402-NYMEX Open price on 2014-01-17 is 94.17. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 1 Min #3: CL-201403-NYMEX Open price on 2014-01-17 is 94.29. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 1 Min #3: CL-201402-NYMEX price difference to CL-201403-NYMEX is 0.12. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 1 Min #3: CL-201403-NYMEX Open price on 2014-02-18 is 100.32. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 1 Min #3: CL-201404-NYMEX Open price on 2014-02-18 is 100.12. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 1 Min #3: CL-201403-NYMEX price difference to CL-201404-NYMEX is -0.2. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 1 Min #3: CL-201404-NYMEX Open price on 2014-03-18 is 97.97. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 1 Min #3: CL-201405-NYMEX Open price on 2014-03-18 is 97.46. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 1 Min #3: CL-201404-NYMEX price difference to CL-201405-NYMEX is -0.50999999. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 1 Min #3: CL-201405-NYMEX Open price on 2014-04-22 is 104.36. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 1 Min #3: CL-201405-NYMEX price difference to CL-201406-NYMEX is 0. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 1 Min #3: CL-201407-NYMEX Open price on 2014-05-19 is 101.68. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 1 Min #3: CL-201406-NYMEX price difference to CL-201407-NYMEX is 0. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 1 Min #3: CL-201407-NYMEX Open price on 2014-06-18 is 106.6. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 1 Min #3: CL-201408-NYMEX Open price on 2014-06-18 is 106.06. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 1 Min #3: CL-201407-NYMEX price difference to CL-201408-NYMEX is -0.54000002. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 1 Min #3: Back adjust amount for symbol CL-201308-NYMEX is -1.1100001. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 1 Min #3: Back adjust amount for symbol CL-201309-NYMEX is -0.90000004. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 1 Min #3: Back adjust amount for symbol CL-201310-NYMEX is -0.73000002. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 1 Min #3: Back adjust amount for symbol CL-201311-NYMEX is 0.029999912. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 1 Min #3: Back adjust amount for symbol CL-201312-NYMEX is -0.25. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 1 Min #3: Back adjust amount for symbol CL-201401-NYMEX is -0.89000005. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 1 Min #3: Back adjust amount for symbol CL-201402-NYMEX is -1.13. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 1 Min #3: Back adjust amount for symbol CL-201403-NYMEX is -1.25. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 1 Min #3: Back adjust amount for symbol CL-201404-NYMEX is -1.05. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 1 Min #3: Back adjust amount for symbol CL-201405-NYMEX is -0.54000002. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 1 Min #3: Back adjust amount for symbol CL-201406-NYMEX is -0.54000002. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 1 Min #3: Back adjust amount for symbol CL-201407-NYMEX is -0.54000002. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 30 Min #7: Performing continuous futures contract back adjustment calculations. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 30 Min #7: CL-201308-NYMEX Open price on 2013-07-18 is 106.56. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 30 Min #7: CL-201309-NYMEX Open price on 2013-07-18 is 106.35. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 30 Min #7: CL-201308-NYMEX price difference to CL-201309-NYMEX is -0.20999999. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 30 Min #7: CL-201309-NYMEX Open price on 2013-08-16 is 107.18. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 30 Min #7: CL-201310-NYMEX Open price on 2013-08-16 is 107.01. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 30 Min #7: CL-201309-NYMEX price difference to CL-201310-NYMEX is -0.17. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 30 Min #7: CL-201310-NYMEX Open price on 2013-09-18 is 105.53. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 30 Min #7: CL-201311-NYMEX Open price on 2013-09-18 is 104.77. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 30 Min #7: CL-201310-NYMEX price difference to CL-201311-NYMEX is -0.75999999. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 30 Min #7: CL-201311-NYMEX Open price on 2013-10-18 is 100.72. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 30 Min #7: CL-201312-NYMEX Open price on 2013-10-18 is 101. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 30 Min #7: CL-201311-NYMEX price difference to CL-201312-NYMEX is 0.28. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 30 Min #7: CL-201312-NYMEX Open price on 2013-11-19 is 93. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 30 Min #7: CL-201401-NYMEX Open price on 2013-11-19 is 93.64. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 30 Min #7: CL-201312-NYMEX price difference to CL-201401-NYMEX is 0.63999999. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 30 Min #7: CL-201401-NYMEX Open price on 2013-12-17 is 97.3. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 30 Min #7: CL-201402-NYMEX Open price on 2013-12-17 is 97.54. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 30 Min #7: CL-201401-NYMEX price difference to CL-201402-NYMEX is 0.23999999. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 30 Min #7: CL-201402-NYMEX Open price on 2014-01-17 is 94.17. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 30 Min #7: CL-201403-NYMEX Open price on 2014-01-17 is 94.29. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 30 Min #7: CL-201402-NYMEX price difference to CL-201403-NYMEX is 0.12. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 30 Min #7: CL-201403-NYMEX Open price on 2014-02-18 is 100.32. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 30 Min #7: CL-201404-NYMEX Open price on 2014-02-18 is 100.12. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 30 Min #7: CL-201403-NYMEX price difference to CL-201404-NYMEX is -0.2. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 30 Min #7: CL-201404-NYMEX Open price on 2014-03-18 is 97.97. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 30 Min #7: CL-201405-NYMEX Open price on 2014-03-18 is 97.46. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 30 Min #7: CL-201404-NYMEX price difference to CL-201405-NYMEX is -0.50999999. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 30 Min #7: CL-201405-NYMEX Open price on 2014-04-22 is 104.36. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 30 Min #7: CL-201405-NYMEX price difference to CL-201406-NYMEX is 0. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 30 Min #7: CL-201407-NYMEX Open price on 2014-05-19 is 101.68. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 30 Min #7: CL-201406-NYMEX price difference to CL-201407-NYMEX is 0. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 30 Min #7: CL-201407-NYMEX Open price on 2014-06-18 is 106.6. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 30 Min #7: CL-201408-NYMEX Open price on 2014-06-18 is 106.06. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 30 Min #7: CL-201407-NYMEX price difference to CL-201408-NYMEX is -0.54000002. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 30 Min #7: Back adjust amount for symbol CL-201308-NYMEX is -1.1100001. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 30 Min #7: Back adjust amount for symbol CL-201309-NYMEX is -0.90000004. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 30 Min #7: Back adjust amount for symbol CL-201310-NYMEX is -0.73000002. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 30 Min #7: Back adjust amount for symbol CL-201311-NYMEX is 0.029999912. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 30 Min #7: Back adjust amount for symbol CL-201312-NYMEX is -0.25. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 30 Min #7: Back adjust amount for symbol CL-201401-NYMEX is -0.89000005. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 30 Min #7: Back adjust amount for symbol CL-201402-NYMEX is -1.13. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 30 Min #7: Back adjust amount for symbol CL-201403-NYMEX is -1.25. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 30 Min #7: Back adjust amount for symbol CL-201404-NYMEX is -1.05. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 30 Min #7: Back adjust amount for symbol CL-201405-NYMEX is -0.54000002. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 30 Min #7: Back adjust amount for symbol CL-201406-NYMEX is -0.54000002. | 2014-06-23 04:49:55
CL-201408-NYMEX [CBV] 30 Min #7: Back adjust amount for symbol CL-201407-NYMEX is -0.54000002. | 2014-06-23 04:49:55
Volume based rollover from CL-201310-NYMEX to CL-201311-NYMEX occurs at 2013-09-18 | 2014-06-23 04:49:56
Volume based rollover from CL-201311-NYMEX to CL-201312-NYMEX occurs at 2013-10-18 | 2014-06-23 04:49:56
Volume based rollover from CL-201312-NYMEX to CL-201401-NYMEX occurs at 2013-11-19 | 2014-06-23 04:49:56
Volume based rollover from CL-201401-NYMEX to CL-201402-NYMEX occurs at 2013-12-17 | 2014-06-23 04:49:56
Volume based rollover from CL-201402-NYMEX to CL-201403-NYMEX occurs at 2014-01-17 | 2014-06-23 04:49:56
Volume based rollover from CL-201403-NYMEX to CL-201404-NYMEX occurs at 2014-02-18 | 2014-06-23 04:49:56
Volume based rollover from CL-201404-NYMEX to CL-201405-NYMEX occurs at 2014-03-18 | 2014-06-23 04:49:56
Volume based rollover from CL-201405-NYMEX to CL-201406-NYMEX occurs at 2014-04-22 | 2014-06-23 04:49:56
Volume based rollover from CL-201406-NYMEX to CL-201407-NYMEX occurs at 0 | 2014-06-23 04:49:56
Using date based transition from CL-201406-NYMEX to CL-201407-NYMEX because volume based transition could not be determined. | 2014-06-23 04:49:56
Volume based rollover from CL-201407-NYMEX to CL-201408-NYMEX occurs at 2014-06-18 | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 15 Min #8: Performing continuous futures contract back adjustment calculations. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 15 Min #8: CL-201308-NYMEX Open price on 2013-07-18 is 106.56. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 15 Min #8: CL-201309-NYMEX Open price on 2013-07-18 is 106.35. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 15 Min #8: CL-201308-NYMEX price difference to CL-201309-NYMEX is -0.20999999. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 15 Min #8: CL-201309-NYMEX Open price on 2013-08-16 is 107.18. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 15 Min #8: CL-201310-NYMEX Open price on 2013-08-16 is 107.01. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 15 Min #8: CL-201309-NYMEX price difference to CL-201310-NYMEX is -0.17. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 15 Min #8: CL-201310-NYMEX Open price on 2013-09-18 is 105.53. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 15 Min #8: CL-201311-NYMEX Open price on 2013-09-18 is 104.77. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 15 Min #8: CL-201310-NYMEX price difference to CL-201311-NYMEX is -0.75999999. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 15 Min #8: CL-201311-NYMEX Open price on 2013-10-18 is 100.72. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 15 Min #8: CL-201312-NYMEX Open price on 2013-10-18 is 101. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 15 Min #8: CL-201311-NYMEX price difference to CL-201312-NYMEX is 0.28. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 15 Min #8: CL-201312-NYMEX Open price on 2013-11-19 is 93. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 15 Min #8: CL-201401-NYMEX Open price on 2013-11-19 is 93.64. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 15 Min #8: CL-201312-NYMEX price difference to CL-201401-NYMEX is 0.63999999. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 15 Min #8: CL-201401-NYMEX Open price on 2013-12-17 is 97.3. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 15 Min #8: CL-201402-NYMEX Open price on 2013-12-17 is 97.54. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 15 Min #8: CL-201401-NYMEX price difference to CL-201402-NYMEX is 0.23999999. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 15 Min #8: CL-201402-NYMEX Open price on 2014-01-17 is 94.17. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 15 Min #8: CL-201403-NYMEX Open price on 2014-01-17 is 94.29. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 15 Min #8: CL-201402-NYMEX price difference to CL-201403-NYMEX is 0.12. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 15 Min #8: CL-201403-NYMEX Open price on 2014-02-18 is 100.32. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 15 Min #8: CL-201404-NYMEX Open price on 2014-02-18 is 100.12. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 15 Min #8: CL-201403-NYMEX price difference to CL-201404-NYMEX is -0.2. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 15 Min #8: CL-201404-NYMEX Open price on 2014-03-18 is 97.97. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 15 Min #8: CL-201405-NYMEX Open price on 2014-03-18 is 97.46. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 15 Min #8: CL-201404-NYMEX price difference to CL-201405-NYMEX is -0.50999999. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 15 Min #8: CL-201405-NYMEX Open price on 2014-04-22 is 104.36. | 2014-06-23 04:49:56
Error while getting daily open price with date 2014-04-25 from file. C:\SierraChart\Data\CLM14.dly. Error: Encountered end of file. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 15 Min #8: CL-201405-NYMEX price difference to CL-201406-NYMEX is 0. | 2014-06-23 04:49:56
Error while getting daily open price with date 2014-05-22 from file. C:\SierraChart\Data\CLM14.dly. Error: Encountered end of file. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 15 Min #8: CL-201407-NYMEX Open price on 2014-05-19 is 101.68. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 15 Min #8: CL-201406-NYMEX price difference to CL-201407-NYMEX is 0. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 15 Min #8: CL-201407-NYMEX Open price on 2014-06-18 is 106.6. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 15 Min #8: CL-201408-NYMEX Open price on 2014-06-18 is 106.06. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 15 Min #8: CL-201407-NYMEX price difference to CL-201408-NYMEX is -0.54000002. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 15 Min #8: Back adjust amount for symbol CL-201308-NYMEX is -1.1100001. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 15 Min #8: Back adjust amount for symbol CL-201309-NYMEX is -0.90000004. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 15 Min #8: Back adjust amount for symbol CL-201310-NYMEX is -0.73000002. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 15 Min #8: Back adjust amount for symbol CL-201311-NYMEX is 0.029999912. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 15 Min #8: Back adjust amount for symbol CL-201312-NYMEX is -0.25. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 15 Min #8: Back adjust amount for symbol CL-201401-NYMEX is -0.89000005. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 15 Min #8: Back adjust amount for symbol CL-201402-NYMEX is -1.13. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 15 Min #8: Back adjust amount for symbol CL-201403-NYMEX is -1.25. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 15 Min #8: Back adjust amount for symbol CL-201404-NYMEX is -1.05. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 15 Min #8: Back adjust amount for symbol CL-201405-NYMEX is -0.54000002. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 15 Min #8: Back adjust amount for symbol CL-201406-NYMEX is -0.54000002. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 15 Min #8: Back adjust amount for symbol CL-201407-NYMEX is -0.54000002. | 2014-06-23 04:49:56
Date rule based rollover from CL-201308-NYMEX to next contract occurs at 2013-07-19 | 2014-06-23 04:49:56
Date rule based rollover from CL-201309-NYMEX to next contract occurs at 2013-08-19 | 2014-06-23 04:49:56
Date rule based rollover from CL-201310-NYMEX to next contract occurs at 2013-09-19 | 2014-06-23 04:49:56
Date rule based rollover from CL-201311-NYMEX to next contract occurs at 2013-10-21 | 2014-06-23 04:49:56
Date rule based rollover from CL-201312-NYMEX to next contract occurs at 2013-11-19 | 2014-06-23 04:49:56
Date rule based rollover from CL-201401-NYMEX to next contract occurs at 2013-12-19 | 2014-06-23 04:49:56
Date rule based rollover from CL-201402-NYMEX to next contract occurs at 2014-01-20 | 2014-06-23 04:49:56
Date rule based rollover from CL-201403-NYMEX to next contract occurs at 2014-02-19 | 2014-06-23 04:49:56
Date rule based rollover from CL-201404-NYMEX to next contract occurs at 2014-03-19 | 2014-06-23 04:49:56
Date rule based rollover from CL-201405-NYMEX to next contract occurs at 2014-04-21 | 2014-06-23 04:49:56
Date rule based rollover from CL-201406-NYMEX to next contract occurs at 2014-05-19 | 2014-06-23 04:49:56
Date rule based rollover from CL-201407-NYMEX to next contract occurs at 2014-06-19 | 2014-06-23 04:49:56
Date rule based rollover from CL-201408-NYMEX to next contract occurs at 2014-07-21 | 2014-06-23 04:49:56
Checking Intraday data file for symbol CL-201308-NYMEX for the date range from 2013-06-19 to 2013-07-19 | 2014-06-23 04:49:56
Checking Daily data file for symbol CLQ13 for the date range from 2013-06-19 to 2013-07-19 | 2014-06-23 04:49:56
Checking Intraday data file for symbol CL-201309-NYMEX for the date range from 2013-07-19 to 2013-08-19 | 2014-06-23 04:49:56
Checking Daily data file for symbol CLU13 for the date range from 2013-07-19 to 2013-08-19 | 2014-06-23 04:49:56
Checking Intraday data file for symbol CL-201310-NYMEX for the date range from 2013-08-19 to 2013-09-19 | 2014-06-23 04:49:56
Checking Daily data file for symbol CLV13 for the date range from 2013-08-19 to 2013-09-19 | 2014-06-23 04:49:56
Checking Intraday data file for symbol CL-201311-NYMEX for the date range from 2013-09-19 to 2013-10-21 | 2014-06-23 04:49:56
Checking Daily data file for symbol CLX13 for the date range from 2013-09-19 to 2013-10-21 | 2014-06-23 04:49:56
Checking Intraday data file for symbol CL-201312-NYMEX for the date range from 2013-10-21 to 2013-11-19 | 2014-06-23 04:49:56
Checking Daily data file for symbol CLZ13 for the date range from 2013-10-21 to 2013-11-19 | 2014-06-23 04:49:56
Checking Intraday data file for symbol CL-201401-NYMEX for the date range from 2013-11-19 to 2013-12-19 | 2014-06-23 04:49:56
Checking Daily data file for symbol CLF14 for the date range from 2013-11-19 to 2013-12-19 | 2014-06-23 04:49:56
Checking Intraday data file for symbol CL-201402-NYMEX for the date range from 2013-12-19 to 2014-01-20 | 2014-06-23 04:49:56
Checking Daily data file for symbol CLG14 for the date range from 2013-12-19 to 2014-01-20 | 2014-06-23 04:49:56
Checking Intraday data file for symbol CL-201403-NYMEX for the date range from 2014-01-20 to 2014-02-19 | 2014-06-23 04:49:56
Checking Daily data file for symbol CLH14 for the date range from 2014-01-20 to 2014-02-19 | 2014-06-23 04:49:56
Checking Intraday data file for symbol CL-201404-NYMEX for the date range from 2014-02-19 to 2014-03-19 | 2014-06-23 04:49:56
Checking Daily data file for symbol CLJ14 for the date range from 2014-02-19 to 2014-03-19 | 2014-06-23 04:49:56
Checking Intraday data file for symbol CL-201405-NYMEX for the date range from 2014-03-19 to 2014-04-21 | 2014-06-23 04:49:56
Checking Daily data file for symbol CLK14 for the date range from 2014-03-19 to 2014-04-21 | 2014-06-23 04:49:56
Checking Intraday data file for symbol CL-201406-NYMEX for the date range from 2014-04-21 to 2014-05-19 | 2014-06-23 04:49:56
Daily data file for symbol CL-201406-NYMEX existed and is empty. Skipping download. | 2014-06-23 04:49:56
Checking Intraday data file for symbol CL-201407-NYMEX for the date range from 2014-05-19 to 2014-06-19 | 2014-06-23 04:49:56
Checking Daily data file for symbol CLN14 for the date range from 2014-05-19 to 2014-06-19 | 2014-06-23 04:49:56
Checking Intraday data file for symbol CL-201408-NYMEX for the date range from 2014-06-19 to 0 | 2014-06-23 04:49:56
Checking Daily data file for symbol CLQ14 for the date range from 2014-06-19 to 0 | 2014-06-23 04:49:56
Symbols used for CL-201408-NYMEX continuous contract chart: | 2014-06-23 04:49:56
CL-201308-NYMEX | 2014-06-23 04:49:56
CL-201309-NYMEX | 2014-06-23 04:49:56
CL-201310-NYMEX | 2014-06-23 04:49:56
CL-201311-NYMEX | 2014-06-23 04:49:56
CL-201312-NYMEX | 2014-06-23 04:49:56
CL-201401-NYMEX | 2014-06-23 04:49:56
CL-201402-NYMEX | 2014-06-23 04:49:56
CL-201403-NYMEX | 2014-06-23 04:49:56
CL-201404-NYMEX | 2014-06-23 04:49:56
CL-201405-NYMEX | 2014-06-23 04:49:56
CL-201406-NYMEX | 2014-06-23 04:49:56
CL-201407-NYMEX | 2014-06-23 04:49:56
CL-201408-NYMEX | 2014-06-23 04:49:56
Volume based rollover from CL-201308-NYMEX to CL-201309-NYMEX occurs at 2013-07-18 | 2014-06-23 04:49:56
Volume based rollover from CL-201309-NYMEX to CL-201310-NYMEX occurs at 2013-08-16 | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 60 Min #1: Performing continuous futures contract back adjustment calculations. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 60 Min #1: CL-201308-NYMEX Open price on 2013-07-18 is 106.56. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 60 Min #1: CL-201309-NYMEX Open price on 2013-07-18 is 106.35. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 60 Min #1: CL-201308-NYMEX price difference to CL-201309-NYMEX is -0.20999999. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 60 Min #1: CL-201309-NYMEX Open price on 2013-08-16 is 107.18. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 60 Min #1: CL-201310-NYMEX Open price on 2013-08-16 is 107.01. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 60 Min #1: CL-201309-NYMEX price difference to CL-201310-NYMEX is -0.17. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 60 Min #1: CL-201310-NYMEX Open price on 2013-09-18 is 105.53. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 60 Min #1: CL-201311-NYMEX Open price on 2013-09-18 is 104.77. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 60 Min #1: CL-201310-NYMEX price difference to CL-201311-NYMEX is -0.75999999. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 60 Min #1: CL-201311-NYMEX Open price on 2013-10-18 is 100.72. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 60 Min #1: CL-201312-NYMEX Open price on 2013-10-18 is 101. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 60 Min #1: CL-201311-NYMEX price difference to CL-201312-NYMEX is 0.28. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 60 Min #1: CL-201312-NYMEX Open price on 2013-11-19 is 93. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 60 Min #1: CL-201401-NYMEX Open price on 2013-11-19 is 93.64. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 60 Min #1: CL-201312-NYMEX price difference to CL-201401-NYMEX is 0.63999999. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 60 Min #1: CL-201401-NYMEX Open price on 2013-12-17 is 97.3. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 60 Min #1: CL-201402-NYMEX Open price on 2013-12-17 is 97.54. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 60 Min #1: CL-201401-NYMEX price difference to CL-201402-NYMEX is 0.23999999. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 60 Min #1: CL-201402-NYMEX Open price on 2014-01-17 is 94.17. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 60 Min #1: CL-201403-NYMEX Open price on 2014-01-17 is 94.29. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 60 Min #1: CL-201402-NYMEX price difference to CL-201403-NYMEX is 0.12. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 60 Min #1: CL-201403-NYMEX Open price on 2014-02-18 is 100.32. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 60 Min #1: CL-201404-NYMEX Open price on 2014-02-18 is 100.12. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 60 Min #1: CL-201403-NYMEX price difference to CL-201404-NYMEX is -0.2. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 60 Min #1: CL-201404-NYMEX Open price on 2014-03-18 is 97.97. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 60 Min #1: CL-201405-NYMEX Open price on 2014-03-18 is 97.46. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 60 Min #1: CL-201404-NYMEX price difference to CL-201405-NYMEX is -0.50999999. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 60 Min #1: CL-201405-NYMEX Open price on 2014-04-22 is 104.36. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 60 Min #1: CL-201405-NYMEX price difference to CL-201406-NYMEX is 0. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 60 Min #1: CL-201407-NYMEX Open price on 2014-05-19 is 101.68. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 60 Min #1: CL-201406-NYMEX price difference to CL-201407-NYMEX is 0. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 60 Min #1: CL-201407-NYMEX Open price on 2014-06-18 is 106.6. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 60 Min #1: CL-201408-NYMEX Open price on 2014-06-18 is 106.06. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 60 Min #1: CL-201407-NYMEX price difference to CL-201408-NYMEX is -0.54000002. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 60 Min #1: Back adjust amount for symbol CL-201308-NYMEX is -1.1100001. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 60 Min #1: Back adjust amount for symbol CL-201309-NYMEX is -0.90000004. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 60 Min #1: Back adjust amount for symbol CL-201310-NYMEX is -0.73000002. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 60 Min #1: Back adjust amount for symbol CL-201311-NYMEX is 0.029999912. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 60 Min #1: Back adjust amount for symbol CL-201312-NYMEX is -0.25. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 60 Min #1: Back adjust amount for symbol CL-201401-NYMEX is -0.89000005. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 60 Min #1: Back adjust amount for symbol CL-201402-NYMEX is -1.13. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 60 Min #1: Back adjust amount for symbol CL-201403-NYMEX is -1.25. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 60 Min #1: Back adjust amount for symbol CL-201404-NYMEX is -1.05. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 60 Min #1: Back adjust amount for symbol CL-201405-NYMEX is -0.54000002. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 60 Min #1: Back adjust amount for symbol CL-201406-NYMEX is -0.54000002. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 60 Min #1: Back adjust amount for symbol CL-201407-NYMEX is -0.54000002. | 2014-06-23 04:49:56
Date rule based rollover from CL-201302-NYMEX to next contract occurs at 2013-01-21 | 2014-06-23 04:49:56
Date rule based rollover from CL-201303-NYMEX to next contract occurs at 2013-02-19 | 2014-06-23 04:49:56
Date rule based rollover from CL-201304-NYMEX to next contract occurs at 2013-03-19 | 2014-06-23 04:49:56
Date rule based rollover from CL-201305-NYMEX to next contract occurs at 2013-04-19 | 2014-06-23 04:49:56
Date rule based rollover from CL-201306-NYMEX to next contract occurs at 2013-05-20 | 2014-06-23 04:49:56
Date rule based rollover from CL-201307-NYMEX to next contract occurs at 2013-06-19 | 2014-06-23 04:49:56
Checking Intraday data file for symbol CL-201302-NYMEX for the date range from 2012-12-19 to 2013-01-21 | 2014-06-23 04:49:56
Checking Daily data file for symbol CLG13 for the date range from 2012-12-19 to 2013-01-21 | 2014-06-23 04:49:56
Checking Intraday data file for symbol CL-201303-NYMEX for the date range from 2013-01-21 to 2013-02-19 | 2014-06-23 04:49:56
Checking Daily data file for symbol CLH13 for the date range from 2013-01-21 to 2013-02-19 | 2014-06-23 04:49:56
Checking Intraday data file for symbol CL-201304-NYMEX for the date range from 2013-02-19 to 2013-03-19 | 2014-06-23 04:49:56
Checking Daily data file for symbol CLJ13 for the date range from 2013-02-19 to 2013-03-19 | 2014-06-23 04:49:56
Checking Intraday data file for symbol CL-201305-NYMEX for the date range from 2013-03-19 to 2013-04-19 | 2014-06-23 04:49:56
Checking Daily data file for symbol CLK13 for the date range from 2013-03-19 to 2013-04-19 | 2014-06-23 04:49:56
Checking Intraday data file for symbol CL-201306-NYMEX for the date range from 2013-04-19 to 2013-05-20 | 2014-06-23 04:49:56
Checking Daily data file for symbol CLM13 for the date range from 2013-04-19 to 2013-05-20 | 2014-06-23 04:49:56
Checking Intraday data file for symbol CL-201307-NYMEX for the date range from 2013-05-20 to 2013-06-19 | 2014-06-23 04:49:56
Checking Daily data file for symbol CLN13 for the date range from 2013-05-20 to 2013-06-19 | 2014-06-23 04:49:56
CL-201302-NYMEX | 2014-06-23 04:49:56
CL-201303-NYMEX | 2014-06-23 04:49:56
CL-201304-NYMEX | 2014-06-23 04:49:56
CL-201305-NYMEX | 2014-06-23 04:49:56
CL-201306-NYMEX | 2014-06-23 04:49:56
CL-201307-NYMEX | 2014-06-23 04:49:56
Volume based rollover from CL-201302-NYMEX to CL-201303-NYMEX occurs at 2013-01-18 | 2014-06-23 04:49:56
Volume based rollover from CL-201303-NYMEX to CL-201304-NYMEX occurs at 2013-02-19 | 2014-06-23 04:49:56
Volume based rollover from CL-201304-NYMEX to CL-201305-NYMEX occurs at 2013-03-18 | 2014-06-23 04:49:56
Volume based rollover from CL-201305-NYMEX to CL-201306-NYMEX occurs at 2013-04-18 | 2014-06-23 04:49:56
Volume based rollover from CL-201306-NYMEX to CL-201307-NYMEX occurs at 2013-05-20 | 2014-06-23 04:49:56
Volume based rollover from CL-201307-NYMEX to CL-201308-NYMEX occurs at 2013-06-18 | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 1 Min #6: Performing continuous futures contract back adjustment calculations. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 1 Min #6: CL-201302-NYMEX Open price on 2013-01-18 is 95.19. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 1 Min #6: CL-201303-NYMEX Open price on 2013-01-18 is 95.65. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 1 Min #6: CL-201302-NYMEX price difference to CL-201303-NYMEX is 0.46000001. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 1 Min #6: CL-201303-NYMEX Open price on 2013-02-19 is 95.97. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 1 Min #6: CL-201304-NYMEX Open price on 2013-02-19 is 96.39. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 1 Min #6: CL-201303-NYMEX price difference to CL-201304-NYMEX is 0.41999999. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 1 Min #6: CL-201304-NYMEX Open price on 2013-03-18 is 93.26. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 1 Min #6: CL-201305-NYMEX Open price on 2013-03-18 is 93.62. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 1 Min #6: CL-201304-NYMEX price difference to CL-201305-NYMEX is 0.36000001. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 1 Min #6: CL-201305-NYMEX Open price on 2013-04-18 is 86.39. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 1 Min #6: CL-201306-NYMEX Open price on 2013-04-18 is 86.6. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 1 Min #6: CL-201305-NYMEX price difference to CL-201306-NYMEX is 0.20999999. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 1 Min #6: CL-201306-NYMEX Open price on 2013-05-20 is 95.93. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 1 Min #6: CL-201307-NYMEX Open price on 2013-05-20 is 96.25. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 1 Min #6: CL-201306-NYMEX price difference to CL-201307-NYMEX is 0.31999999. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 1 Min #6: CL-201307-NYMEX Open price on 2013-06-18 is 97.93. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 1 Min #6: CL-201308-NYMEX Open price on 2013-06-18 is 98.16. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 1 Min #6: CL-201307-NYMEX price difference to CL-201308-NYMEX is 0.23. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 1 Min #6: CL-201308-NYMEX Open price on 2013-07-18 is 106.56. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 1 Min #6: CL-201309-NYMEX Open price on 2013-07-18 is 106.35. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 1 Min #6: CL-201308-NYMEX price difference to CL-201309-NYMEX is -0.20999999. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 1 Min #6: CL-201309-NYMEX Open price on 2013-08-16 is 107.18. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 1 Min #6: CL-201310-NYMEX Open price on 2013-08-16 is 107.01. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 1 Min #6: CL-201309-NYMEX price difference to CL-201310-NYMEX is -0.17. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 1 Min #6: CL-201310-NYMEX Open price on 2013-09-18 is 105.53. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 1 Min #6: CL-201311-NYMEX Open price on 2013-09-18 is 104.77. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 1 Min #6: CL-201310-NYMEX price difference to CL-201311-NYMEX is -0.75999999. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 1 Min #6: CL-201311-NYMEX Open price on 2013-10-18 is 100.72. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 1 Min #6: CL-201312-NYMEX Open price on 2013-10-18 is 101. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 1 Min #6: CL-201311-NYMEX price difference to CL-201312-NYMEX is 0.28. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 1 Min #6: CL-201312-NYMEX Open price on 2013-11-19 is 93. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 1 Min #6: CL-201401-NYMEX Open price on 2013-11-19 is 93.64. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 1 Min #6: CL-201312-NYMEX price difference to CL-201401-NYMEX is 0.63999999. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 1 Min #6: CL-201401-NYMEX Open price on 2013-12-17 is 97.3. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 1 Min #6: CL-201402-NYMEX Open price on 2013-12-17 is 97.54. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 1 Min #6: CL-201401-NYMEX price difference to CL-201402-NYMEX is 0.23999999. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 1 Min #6: CL-201402-NYMEX Open price on 2014-01-17 is 94.17. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 1 Min #6: CL-201403-NYMEX Open price on 2014-01-17 is 94.29. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 1 Min #6: CL-201402-NYMEX price difference to CL-201403-NYMEX is 0.12. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 1 Min #6: CL-201403-NYMEX Open price on 2014-02-18 is 100.32. | 2014-06-23 04:49:56
CL-201408-NYMEX [CBV] 1 Min #6: CL-201404-NYMEX Open price on 2014-02-18 is 100.12. | 2014-06-23 04:49:57
CL-201408-NYMEX [CBV] 1 Min #6: CL-201403-NYMEX price difference to CL-201404-NYMEX is -0.2. | 2014-06-23 04:49:57
CL-201408-NYMEX [CBV] 1 Min #6: CL-201404-NYMEX Open price on 2014-03-18 is 97.97. | 2014-06-23 04:49:57
CL-201408-NYMEX [CBV] 1 Min #6: CL-201405-NYMEX Open price on 2014-03-18 is 97.46. | 2014-06-23 04:49:57
CL-201408-NYMEX [CBV] 1 Min #6: CL-201404-NYMEX price difference to CL-201405-NYMEX is -0.50999999. | 2014-06-23 04:49:57
CL-201408-NYMEX [CBV] 1 Min #6: CL-201405-NYMEX Open price on 2014-04-22 is 104.36. | 2014-06-23 04:49:57
Error while getting daily open price with date 2014-04-25 from file. C:\SierraChart\Data\CLM14.dly. Error: Encountered end of file. | 2014-06-23 04:49:57
CL-201408-NYMEX [CBV] 1 Min #6: CL-201405-NYMEX price difference to CL-201406-NYMEX is 0. | 2014-06-23 04:49:57
Error while getting daily open price with date 2014-05-22 from file. C:\SierraChart\Data\CLM14.dly. Error: Encountered end of file. | 2014-06-23 04:49:57
CL-201408-NYMEX [CBV] 1 Min #6: CL-201407-NYMEX Open price on 2014-05-19 is 101.68. | 2014-06-23 04:49:57
CL-201408-NYMEX [CBV] 1 Min #6: CL-201406-NYMEX price difference to CL-201407-NYMEX is 0. | 2014-06-23 04:49:57
CL-201408-NYMEX [CBV] 1 Min #6: CL-201407-NYMEX Open price on 2014-06-18 is 106.6. | 2014-06-23 04:49:57
CL-201408-NYMEX [CBV] 1 Min #6: CL-201408-NYMEX Open price on 2014-06-18 is 106.06. | 2014-06-23 04:49:57
CL-201408-NYMEX [CBV] 1 Min #6: CL-201407-NYMEX price difference to CL-201408-NYMEX is -0.54000002. | 2014-06-23 04:49:57
CL-201408-NYMEX [CBV] 1 Min #6: Back adjust amount for symbol CL-201302-NYMEX is 0.88999981. | 2014-06-23 04:49:57
CL-201408-NYMEX [CBV] 1 Min #6: Back adjust amount for symbol CL-201303-NYMEX is 0.42999989. | 2014-06-23 04:49:57
CL-201408-NYMEX [CBV] 1 Min #6: Back adjust amount for symbol CL-201304-NYMEX is 0.0099999309. | 2014-06-23 04:49:57
CL-201408-NYMEX [CBV] 1 Min #6: Back adjust amount for symbol CL-201305-NYMEX is -0.35000002. | 2014-06-23 04:49:57
CL-201408-NYMEX [CBV] 1 Min #6: Back adjust amount for symbol CL-201306-NYMEX is -0.56. | 2014-06-23 04:49:57
CL-201408-NYMEX [CBV] 1 Min #6: Back adjust amount for symbol CL-201307-NYMEX is -0.88000005. | 2014-06-23 04:49:57
CL-201408-NYMEX [CBV] 1 Min #6: Back adjust amount for symbol CL-201308-NYMEX is -1.1100001. | 2014-06-23 04:49:57
CL-201408-NYMEX [CBV] 1 Min #6: Back adjust amount for symbol CL-201309-NYMEX is -0.90000004. | 2014-06-23 04:49:57
CL-201408-NYMEX [CBV] 1 Min #6: Back adjust amount for symbol CL-201310-NYMEX is -0.73000002. | 2014-06-23 04:49:57
CL-201408-NYMEX [CBV] 1 Min #6: Back adjust amount for symbol CL-201311-NYMEX is 0.029999912. | 2014-06-23 04:49:57
CL-201408-NYMEX [CBV] 1 Min #6: Back adjust amount for symbol CL-201312-NYMEX is -0.25. | 2014-06-23 04:49:57
CL-201408-NYMEX [CBV] 1 Min #6: Back adjust amount for symbol CL-201401-NYMEX is -0.89000005. | 2014-06-23 04:49:57
CL-201408-NYMEX [CBV] 1 Min #6: Back adjust amount for symbol CL-201402-NYMEX is -1.13. | 2014-06-23 04:49:57
CL-201408-NYMEX [CBV] 1 Min #6: Back adjust amount for symbol CL-201403-NYMEX is -1.25. | 2014-06-23 04:49:57
CL-201408-NYMEX [CBV] 1 Min #6: Back adjust amount for symbol CL-201404-NYMEX is -1.05. | 2014-06-23 04:49:57
CL-201408-NYMEX [CBV] 1 Min #6: Back adjust amount for symbol CL-201405-NYMEX is -0.54000002. | 2014-06-23 04:49:57
CL-201408-NYMEX [CBV] 1 Min #6: Back adjust amount for symbol CL-201406-NYMEX is -0.54000002. | 2014-06-23 04:49:57
CL-201408-NYMEX [CBV] 1 Min #6: Back adjust amount for symbol CL-201407-NYMEX is -0.54000002. | 2014-06-23 04:49:57
Mapping CL-201408-NYMEX to CLQ4. Service code: nymex | 2014-06-23 04:49:57
HD Request # 2 - Downloading Intraday chart data for CL-201408-NYMEX to the file CL-201408-NYMEX.scid. Service: nymex | 2014-06-23 04:49:57
HD Request # 2 - Download start Date-Time: 2014-06-22 21:54:55.0 | 2014-06-23 04:49:57
HD Request # 2 - Using server: scdf2.sierracharts.com port 10149 | 2014-06-23 04:49:57
Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2014-06-23 04:49:57
The network socket is connected. | 2014-06-23 04:49:57
HD Request # 2 - Sending historical data logon request message. | 2014-06-23 04:49:57
HD Request # 2 - Requesting Intraday data. Start Date-Time: 2014-06-22 21:54:55. Record interval: 0 . Symbol: CLQ4 | 2014-06-23 04:49:58
HD Request # 2 - Decompressing data. | 2014-06-23 04:49:58
HD Request # 2 - Receiving Intraday data for CL-201408-NYMEX starting at 2014-06-22 21:54:55 | 2014-06-23 04:49:58
HD Request # 2 - Timestamp of first Intraday data file record written: 2014-06-22 21:55:27 | 2014-06-23 04:49:58
Socket has been shutdown and closed. | 2014-06-23 04:49:59
The network socket for historical data has been closed. | 2014-06-23 04:49:59
HD Request # 2 - Historical data for CL-201408-NYMEX is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2014-06-23 04:49:59
HD Request # 2 - Received 12039 records from 2014-06-22 21:54:55 to 2014-06-23 04:39:56 (6.8 hours) and wrote 12038 records for CL-201408-NYMEX | 2014-06-23 04:49:59
HD Request # 2 - Intraday download COMPLETE for CL-201408-NYMEX. Completion time: 2s | 2014-06-23 04:49:59
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-06-23 04:55:48
The network socket is connected. | 2014-06-23 04:55:48
Socket connected to TWS. Sending client version: 62. Waiting for acceptance. | 2014-06-23 04:55:48
TWS server version: 70 | 2014-06-23 04:55:49
IB: Connected. Waiting for account information. | 2014-06-23 04:55:49
IB Account information received. | 2014-06-23 04:55:49
Connected to IB Demo or Simulated account. | 2014-06-23 04:55:49
Interactive Brokers: Requesting Trade Positions for account: DU148803 | 2014-06-23 04:55:49
Next valid order ID: 10203 | 2014-06-23 04:55:49
Message from IB: Market data farm connection is OK:usfuture. IB Error Code: 2104. Request ID: -1. | 2014-06-23 04:55:49
Message from IB: Market data farm connection is OK:usfarm. IB Error Code: 2104. Request ID: -1. | 2014-06-23 04:55:49
Message from IB: HMDS data farm connection is OK:ilhmds. IB Error Code: 2106. Request ID: -1. | 2014-06-23 04:55:49
Message from IB: HMDS data farm connection is OK:ushmds. IB Error Code: 2106. Request ID: -1. | 2014-06-23 04:55:49
Interactive Brokers: Received Trade Positions download end message for account DU148803 | 2014-06-23 04:55:49
Mapping CL-201408-NYMEX to CLQ4. Service code: nymex | 2014-06-23 04:55:49
SC Exchange Data - Starting real-time market data updates for: CLQ4. ID: 1 | 2014-06-23 04:55:49
Using username 0 | 2014-06-23 04:55:49
SC Exchange Data: Connecting to the server scdf2.sierracharts.com. Port 443 | 2014-06-23 04:55:49
Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2014-06-23 04:55:49
HD Request # 3 - Downloading Intraday chart data for CL-201408-NYMEX to the file CL-201408-NYMEX.scid. Service: nymex | 2014-06-23 04:55:49
HD Request # 3 - Download start Date-Time: 2014-06-23 04:39:56.0 | 2014-06-23 04:55:49
HD Request # 3 - Using server: scdf1.sierracharts.com port 10149 | 2014-06-23 04:55:49
The network socket is connected. | 2014-06-23 04:55:49
SC Exchange Data: Connected to server. | 2014-06-23 04:55:49
SC Exchange Data: Sending logon request message. | 2014-06-23 04:55:49
Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2014-06-23 04:55:49
HD Request # 3 - Sending historical data logon request message. | 2014-06-23 04:55:49
SC Exchange Data Server Info - Server Name: . Server Version: . Provider Name: . | 2014-06-23 04:55:50
SC Exchange Data - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2014-06-23 04:55:50
SC Exchange Data - Successfully connected. | 2014-06-23 04:55:50
SC Exchange Data - Restarting real-time data updates for symbol: CL-201408-NYMEX -> CLQ4 | 2014-06-23 04:55:50
HD Request # 3 - Requesting Intraday data. Start Date-Time: 2014-06-23 04:39:56. Record interval: 0 . Symbol: CLQ4 | 2014-06-23 04:55:50
HD Request # 3 - Decompressing data. | 2014-06-23 04:55:50
HD Request # 3 - Receiving Intraday data for CL-201408-NYMEX starting at 2014-06-23 04:39:56 | 2014-06-23 04:55:50
HD Request # 3 - Timestamp of first Intraday data file record written: 2014-06-23 04:39:59 | 2014-06-23 04:55:50
Socket has been shutdown and closed. | 2014-06-23 04:55:50
The network socket for historical data has been closed. | 2014-06-23 04:55:50
HD Request # 3 - Received 1422 records from 2014-06-23 04:39:56 to 2014-06-23 04:55:46 (15.8 minutes) and wrote 1413 records for CL-201408-NYMEX | 2014-06-23 04:55:50
HD Request # 3 - Intraday download COMPLETE for CL-201408-NYMEX. Completion time: 1s | 2014-06-23 04:55:50
Real-time Intraday chart data file updates started for CL-201408-NYMEX | 2014-06-23 04:55:50
IB: Requesting historical order fills for account DU148803 | 2014-06-23 04:55:54
Interactive Brokers: Received Open orders end message. | 2014-06-23 04:55:54
Date rule based rollover from CL-201109-NYMEX to next contract occurs at 2011-08-19 | 2014-06-23 07:48:55
Date rule based rollover from CL-201110-NYMEX to next contract occurs at 2011-09-19 | 2014-06-23 07:48:55
Date rule based rollover from CL-201111-NYMEX to next contract occurs at 2011-10-19 | 2014-06-23 07:48:55
Date rule based rollover from CL-201112-NYMEX to next contract occurs at 2011-11-21 | 2014-06-23 07:48:55
Date rule based rollover from CL-201201-NYMEX to next contract occurs at 2011-12-19 | 2014-06-23 07:48:55
Date rule based rollover from CL-201202-NYMEX to next contract occurs at 2012-01-19 | 2014-06-23 07:48:55
Date rule based rollover from CL-201203-NYMEX to next contract occurs at 2012-02-20 | 2014-06-23 07:48:55
Date rule based rollover from CL-201204-NYMEX to next contract occurs at 2012-03-19 | 2014-06-23 07:48:55
Date rule based rollover from CL-201205-NYMEX to next contract occurs at 2012-04-19 | 2014-06-23 07:48:55
Date rule based rollover from CL-201206-NYMEX to next contract occurs at 2012-05-21 | 2014-06-23 07:48:55
Date rule based rollover from CL-201207-NYMEX to next contract occurs at 2012-06-19 | 2014-06-23 07:48:55
Date rule based rollover from CL-201208-NYMEX to next contract occurs at 2012-07-19 | 2014-06-23 07:48:55
Date rule based rollover from CL-201209-NYMEX to next contract occurs at 2012-08-20 | 2014-06-23 07:48:55
Date rule based rollover from CL-201210-NYMEX to next contract occurs at 2012-09-19 | 2014-06-23 07:48:55
Date rule based rollover from CL-201211-NYMEX to next contract occurs at 2012-10-19 | 2014-06-23 07:48:55
Date rule based rollover from CL-201212-NYMEX to next contract occurs at 2012-11-19 | 2014-06-23 07:48:55
Date rule based rollover from CL-201301-NYMEX to next contract occurs at 2012-12-19 | 2014-06-23 07:48:55
Date rule based rollover from CL-201302-NYMEX to next contract occurs at 2013-01-21 | 2014-06-23 07:48:55
Date rule based rollover from CL-201303-NYMEX to next contract occurs at 2013-02-19 | 2014-06-23 07:48:55
Date rule based rollover from CL-201304-NYMEX to next contract occurs at 2013-03-19 | 2014-06-23 07:48:55
Date rule based rollover from CL-201305-NYMEX to next contract occurs at 2013-04-19 | 2014-06-23 07:48:55
Date rule based rollover from CL-201306-NYMEX to next contract occurs at 2013-05-20 | 2014-06-23 07:48:55
Date rule based rollover from CL-201307-NYMEX to next contract occurs at 2013-06-19 | 2014-06-23 07:48:55
Date rule based rollover from CL-201308-NYMEX to next contract occurs at 2013-07-19 | 2014-06-23 07:48:55
Date rule based rollover from CL-201309-NYMEX to next contract occurs at 2013-08-19 | 2014-06-23 07:48:55
Date rule based rollover from CL-201310-NYMEX to next contract occurs at 2013-09-19 | 2014-06-23 07:48:55
Date rule based rollover from CL-201311-NYMEX to next contract occurs at 2013-10-21 | 2014-06-23 07:48:55
Date rule based rollover from CL-201312-NYMEX to next contract occurs at 2013-11-19 | 2014-06-23 07:48:55
Date rule based rollover from CL-201401-NYMEX to next contract occurs at 2013-12-19 | 2014-06-23 07:48:55
Date rule based rollover from CL-201402-NYMEX to next contract occurs at 2014-01-20 | 2014-06-23 07:48:55
Date rule based rollover from CL-201403-NYMEX to next contract occurs at 2014-02-19 | 2014-06-23 07:48:55
Date rule based rollover from CL-201404-NYMEX to next contract occurs at 2014-03-19 | 2014-06-23 07:48:55
Date rule based rollover from CL-201405-NYMEX to next contract occurs at 2014-04-21 | 2014-06-23 07:48:55
Date rule based rollover from CL-201406-NYMEX to next contract occurs at 2014-05-19 | 2014-06-23 07:48:55
Date rule based rollover from CL-201407-NYMEX to next contract occurs at 2014-06-19 | 2014-06-23 07:48:55
Date rule based rollover from CL-201408-NYMEX to next contract occurs at 2014-07-21 | 2014-06-23 07:48:55
Checking Intraday data file for symbol CL-201109-NYMEX for the date range from 2011-07-19 to 2011-08-19 | 2014-06-23 07:48:55
Checking Daily data file for symbol CLU11 for the date range from 2011-07-19 to 2011-08-19 | 2014-06-23 07:48:55
Checking Intraday data file for symbol CL-201110-NYMEX for the date range from 2011-08-19 to 2011-09-19 | 2014-06-23 07:48:55
Checking Daily data file for symbol CLV11 for the date range from 2011-08-19 to 2011-09-19 | 2014-06-23 07:48:55
Checking Intraday data file for symbol CL-201111-NYMEX for the date range from 2011-09-19 to 2011-10-19 | 2014-06-23 07:48:55
Checking Daily data file for symbol CLX11 for the date range from 2011-09-19 to 2011-10-19 | 2014-06-23 07:48:55
Checking Intraday data file for symbol CL-201112-NYMEX for the date range from 2011-10-19 to 2011-11-21 | 2014-06-23 07:48:55
Checking Daily data file for symbol CLZ11 for the date range from 2011-10-19 to 2011-11-21 | 2014-06-23 07:48:55
Checking Intraday data file for symbol CL-201201-NYMEX for the date range from 2011-11-21 to 2011-12-19 | 2014-06-23 07:48:55
Checking Daily data file for symbol CLF12 for the date range from 2011-11-21 to 2011-12-19 | 2014-06-23 07:48:55
Checking Intraday data file for symbol CL-201202-NYMEX for the date range from 2011-12-19 to 2012-01-19 | 2014-06-23 07:48:55
Checking Daily data file for symbol CLG12 for the date range from 2011-12-19 to 2012-01-19 | 2014-06-23 07:48:55
Checking Intraday data file for symbol CL-201203-NYMEX for the date range from 2012-01-19 to 2012-02-20 | 2014-06-23 07:48:55
Checking Daily data file for symbol CLH12 for the date range from 2012-01-19 to 2012-02-20 | 2014-06-23 07:48:55
Checking Intraday data file for symbol CL-201204-NYMEX for the date range from 2012-02-20 to 2012-03-19 | 2014-06-23 07:48:55
Checking Daily data file for symbol CLJ12 for the date range from 2012-02-20 to 2012-03-19 | 2014-06-23 07:48:55
Checking Intraday data file for symbol CL-201205-NYMEX for the date range from 2012-03-19 to 2012-04-19 | 2014-06-23 07:48:55
Checking Daily data file for symbol CLK12 for the date range from 2012-03-19 to 2012-04-19 | 2014-06-23 07:48:55
Checking Intraday data file for symbol CL-201206-NYMEX for the date range from 2012-04-19 to 2012-05-21 | 2014-06-23 07:48:55
Checking Daily data file for symbol CLM12 for the date range from 2012-04-19 to 2012-05-21 | 2014-06-23 07:48:55
Checking Intraday data file for symbol CL-201207-NYMEX for the date range from 2012-05-21 to 2012-06-19 | 2014-06-23 07:48:55
Checking Daily data file for symbol CLN12 for the date range from 2012-05-21 to 2012-06-19 | 2014-06-23 07:48:55
Checking Intraday data file for symbol CL-201208-NYMEX for the date range from 2012-06-19 to 2012-07-19 | 2014-06-23 07:48:55
Checking Daily data file for symbol CLQ12 for the date range from 2012-06-19 to 2012-07-19 | 2014-06-23 07:48:55
Checking Intraday data file for symbol CL-201209-NYMEX for the date range from 2012-07-19 to 2012-08-20 | 2014-06-23 07:48:55
Checking Daily data file for symbol CLU12 for the date range from 2012-07-19 to 2012-08-20 | 2014-06-23 07:48:55
Checking Intraday data file for symbol CL-201210-NYMEX for the date range from 2012-08-20 to 2012-09-19 | 2014-06-23 07:48:55
Checking Daily data file for symbol CLV12 for the date range from 2012-08-20 to 2012-09-19 | 2014-06-23 07:48:55
Checking Intraday data file for symbol CL-201211-NYMEX for the date range from 2012-09-19 to 2012-10-19 | 2014-06-23 07:48:55
Checking Daily data file for symbol CLX12 for the date range from 2012-09-19 to 2012-10-19 | 2014-06-23 07:48:55
Checking Intraday data file for symbol CL-201212-NYMEX for the date range from 2012-10-19 to 2012-11-19 | 2014-06-23 07:48:55
Checking Daily data file for symbol CLZ12 for the date range from 2012-10-19 to 2012-11-19 | 2014-06-23 07:48:55
Checking Intraday data file for symbol CL-201301-NYMEX for the date range from 2012-11-19 to 2012-12-19 | 2014-06-23 07:48:55
Checking Daily data file for symbol CLF13 for the date range from 2012-11-19 to 2012-12-19 | 2014-06-23 07:48:55
Checking Intraday data file for symbol CL-201302-NYMEX for the date range from 2012-12-19 to 2013-01-21 | 2014-06-23 07:48:55
Checking Daily data file for symbol CLG13 for the date range from 2012-12-19 to 2013-01-21 | 2014-06-23 07:48:55
Checking Intraday data file for symbol CL-201303-NYMEX for the date range from 2013-01-21 to 2013-02-19 | 2014-06-23 07:48:55
Checking Daily data file for symbol CLH13 for the date range from 2013-01-21 to 2013-02-19 | 2014-06-23 07:48:55
Checking Intraday data file for symbol CL-201304-NYMEX for the date range from 2013-02-19 to 2013-03-19 | 2014-06-23 07:48:55
Checking Daily data file for symbol CLJ13 for the date range from 2013-02-19 to 2013-03-19 | 2014-06-23 07:48:55
Checking Intraday data file for symbol CL-201305-NYMEX for the date range from 2013-03-19 to 2013-04-19 | 2014-06-23 07:48:55
Checking Daily data file for symbol CLK13 for the date range from 2013-03-19 to 2013-04-19 | 2014-06-23 07:48:55
Checking Intraday data file for symbol CL-201306-NYMEX for the date range from 2013-04-19 to 2013-05-20 | 2014-06-23 07:48:55
Checking Daily data file for symbol CLM13 for the date range from 2013-04-19 to 2013-05-20 | 2014-06-23 07:48:55
Checking Intraday data file for symbol CL-201307-NYMEX for the date range from 2013-05-20 to 2013-06-19 | 2014-06-23 07:48:55
Checking Daily data file for symbol CLN13 for the date range from 2013-05-20 to 2013-06-19 | 2014-06-23 07:48:55
Checking Intraday data file for symbol CL-201308-NYMEX for the date range from 2013-06-19 to 2013-07-19 | 2014-06-23 07:48:55
Checking Daily data file for symbol CLQ13 for the date range from 2013-06-19 to 2013-07-19 | 2014-06-23 07:48:55
Checking Intraday data file for symbol CL-201309-NYMEX for the date range from 2013-07-19 to 2013-08-19 | 2014-06-23 07:48:55
Checking Daily data file for symbol CLU13 for the date range from 2013-07-19 to 2013-08-19 | 2014-06-23 07:48:55
Checking Intraday data file for symbol CL-201310-NYMEX for the date range from 2013-08-19 to 2013-09-19 | 2014-06-23 07:48:55
Checking Daily data file for symbol CLV13 for the date range from 2013-08-19 to 2013-09-19 | 2014-06-23 07:48:55
Checking Intraday data file for symbol CL-201311-NYMEX for the date range from 2013-09-19 to 2013-10-21 | 2014-06-23 07:48:55
Checking Daily data file for symbol CLX13 for the date range from 2013-09-19 to 2013-10-21 | 2014-06-23 07:48:55
Checking Intraday data file for symbol CL-201312-NYMEX for the date range from 2013-10-21 to 2013-11-19 | 2014-06-23 07:48:55
Checking Daily data file for symbol CLZ13 for the date range from 2013-10-21 to 2013-11-19 | 2014-06-23 07:48:55
Checking Intraday data file for symbol CL-201401-NYMEX for the date range from 2013-11-19 to 2013-12-19 | 2014-06-23 07:48:55
Checking Daily data file for symbol CLF14 for the date range from 2013-11-19 to 2013-12-19 | 2014-06-23 07:48:55
Checking Intraday data file for symbol CL-201402-NYMEX for the date range from 2013-12-19 to 2014-01-20 | 2014-06-23 07:48:55
Checking Daily data file for symbol CLG14 for the date range from 2013-12-19 to 2014-01-20 | 2014-06-23 07:48:55
Checking Intraday data file for symbol CL-201403-NYMEX for the date range from 2014-01-20 to 2014-02-19 | 2014-06-23 07:48:55
Checking Daily data file for symbol CLH14 for the date range from 2014-01-20 to 2014-02-19 | 2014-06-23 07:48:55
Checking Intraday data file for symbol CL-201404-NYMEX for the date range from 2014-02-19 to 2014-03-19 | 2014-06-23 07:48:55
Checking Daily data file for symbol CLJ14 for the date range from 2014-02-19 to 2014-03-19 | 2014-06-23 07:48:55
Checking Intraday data file for symbol CL-201405-NYMEX for the date range from 2014-03-19 to 2014-04-21 | 2014-06-23 07:48:55
Checking Daily data file for symbol CLK14 for the date range from 2014-03-19 to 2014-04-21 | 2014-06-23 07:48:55
Checking Intraday data file for symbol CL-201406-NYMEX for the date range from 2014-04-21 to 2014-05-19 | 2014-06-23 07:48:55
Daily data file for symbol CL-201406-NYMEX existed and is empty. Skipping download. | 2014-06-23 07:48:55
Checking Intraday data file for symbol CL-201407-NYMEX for the date range from 2014-05-19 to 2014-06-19 | 2014-06-23 07:48:55
Checking Daily data file for symbol CLN14 for the date range from 2014-05-19 to 2014-06-19 | 2014-06-23 07:48:55
Checking Intraday data file for symbol CL-201408-NYMEX for the date range from 2014-06-19 to 0 | 2014-06-23 07:48:55
Checking Daily data file for symbol CLQ14 for the date range from 2014-06-19 to 0 | 2014-06-23 07:48:55
Symbols used for CL-201408-NYMEX continuous contract chart: | 2014-06-23 07:48:55
CL-201109-NYMEX | 2014-06-23 07:48:55
CL-201110-NYMEX | 2014-06-23 07:48:55
CL-201111-NYMEX | 2014-06-23 07:48:55
CL-201112-NYMEX | 2014-06-23 07:48:55
CL-201201-NYMEX | 2014-06-23 07:48:55
CL-201202-NYMEX | 2014-06-23 07:48:55
CL-201203-NYMEX | 2014-06-23 07:48:55
CL-201204-NYMEX | 2014-06-23 07:48:55
CL-201205-NYMEX | 2014-06-23 07:48:55
CL-201206-NYMEX | 2014-06-23 07:48:55
CL-201207-NYMEX | 2014-06-23 07:48:55
CL-201208-NYMEX | 2014-06-23 07:48:55
CL-201209-NYMEX | 2014-06-23 07:48:55
CL-201210-NYMEX | 2014-06-23 07:48:55
CL-201211-NYMEX | 2014-06-23 07:48:55
CL-201212-NYMEX | 2014-06-23 07:48:55
CL-201301-NYMEX | 2014-06-23 07:48:55
CL-201302-NYMEX | 2014-06-23 07:48:55
CL-201303-NYMEX | 2014-06-23 07:48:55
CL-201304-NYMEX | 2014-06-23 07:48:55
CL-201305-NYMEX | 2014-06-23 07:48:55
CL-201306-NYMEX | 2014-06-23 07:48:55
CL-201307-NYMEX | 2014-06-23 07:48:55
CL-201308-NYMEX | 2014-06-23 07:48:55
CL-201309-NYMEX | 2014-06-23 07:48:55
CL-201310-NYMEX | 2014-06-23 07:48:55
CL-201311-NYMEX | 2014-06-23 07:48:55
CL-201312-NYMEX | 2014-06-23 07:48:55
CL-201401-NYMEX | 2014-06-23 07:48:55
CL-201402-NYMEX | 2014-06-23 07:48:55
CL-201403-NYMEX | 2014-06-23 07:48:55
CL-201404-NYMEX | 2014-06-23 07:48:55
CL-201405-NYMEX | 2014-06-23 07:48:55
CL-201406-NYMEX | 2014-06-23 07:48:55
CL-201407-NYMEX | 2014-06-23 07:48:55
CL-201408-NYMEX | 2014-06-23 07:48:55
Checking Daily data file for symbol CLK13 for the date range from 2013-03-19 to 2013-04-19 | 2014-06-23 07:48:56
Checking Intraday data file for symbol CL-201306-NYMEX for the date range from 2013-04-19 to 2013-05-20 | 2014-06-23 07:48:56
Checking Daily data file for symbol CLM13 for the date range from 2013-04-19 to 2013-05-20 | 2014-06-23 07:48:56
Checking Intraday data file for symbol CL-201307-NYMEX for the date range from 2013-05-20 to 2013-06-19 | 2014-06-23 07:48:56
Checking Daily data file for symbol CLN13 for the date range from 2013-05-20 to 2013-06-19 | 2014-06-23 07:48:56
Checking Intraday data file for symbol CL-201308-NYMEX for the date range from 2013-06-19 to 2013-07-19 | 2014-06-23 07:48:56
Checking Daily data file for symbol CLQ13 for the date range from 2013-06-19 to 2013-07-19 | 2014-06-23 07:48:56
Checking Intraday data file for symbol CL-201309-NYMEX for the date range from 2013-07-19 to 2013-08-19 | 2014-06-23 07:48:56
Checking Daily data file for symbol CLU13 for the date range from 2013-07-19 to 2013-08-19 | 2014-06-23 07:48:56
Checking Intraday data file for symbol CL-201310-NYMEX for the date range from 2013-08-19 to 2013-09-19 | 2014-06-23 07:48:56
Checking Daily data file for symbol CLV13 for the date range from 2013-08-19 to 2013-09-19 | 2014-06-23 07:48:56
Checking Intraday data file for symbol CL-201311-NYMEX for the date range from 2013-09-19 to 2013-10-21 | 2014-06-23 07:48:56
Checking Daily data file for symbol CLX13 for the date range from 2013-09-19 to 2013-10-21 | 2014-06-23 07:48:56
Checking Intraday data file for symbol CL-201312-NYMEX for the date range from 2013-10-21 to 2013-11-19 | 2014-06-23 07:48:56
Checking Daily data file for symbol CLZ13 for the date range from 2013-10-21 to 2013-11-19 | 2014-06-23 07:48:56
Checking Intraday data file for symbol CL-201401-NYMEX for the date range from 2013-11-19 to 2013-12-19 | 2014-06-23 07:48:56
Checking Daily data file for symbol CLF14 for the date range from 2013-11-19 to 2013-12-19 | 2014-06-23 07:48:56
Checking Intraday data file for symbol CL-201402-NYMEX for the date range from 2013-12-19 to 2014-01-20 | 2014-06-23 07:48:56
Checking Daily data file for symbol CLG14 for the date range from 2013-12-19 to 2014-01-20 | 2014-06-23 07:48:56
Checking Intraday data file for symbol CL-201403-NYMEX for the date range from 2014-01-20 to 2014-02-19 | 2014-06-23 07:48:56
Checking Daily data file for symbol CLH14 for the date range from 2014-01-20 to 2014-02-19 | 2014-06-23 07:48:56
Checking Intraday data file for symbol CL-201404-NYMEX for the date range from 2014-02-19 to 2014-03-19 | 2014-06-23 07:48:56
Checking Daily data file for symbol CLJ14 for the date range from 2014-02-19 to 2014-03-19 | 2014-06-23 07:48:56
Checking Intraday data file for symbol CL-201405-NYMEX for the date range from 2014-03-19 to 2014-04-21 | 2014-06-23 07:48:56
Checking Daily data file for symbol CLK14 for the date range from 2014-03-19 to 2014-04-21 | 2014-06-23 07:48:56
Checking Intraday data file for symbol CL-201406-NYMEX for the date range from 2014-04-21 to 2014-05-19 | 2014-06-23 07:48:56
Daily data file for symbol CL-201406-NYMEX existed and is empty. Skipping download. | 2014-06-23 07:48:56
Checking Intraday data file for symbol CL-201407-NYMEX for the date range from 2014-05-19 to 2014-06-19 | 2014-06-23 07:48:56
Checking Daily data file for symbol CLN14 for the date range from 2014-05-19 to 2014-06-19 | 2014-06-23 07:48:56
Checking Intraday data file for symbol CL-201408-NYMEX for the date range from 2014-06-19 to 0 | 2014-06-23 07:48:56
Checking Daily data file for symbol CLQ14 for the date range from 2014-06-19 to 0 | 2014-06-23 07:48:56
Symbols used for CL-201408-NYMEX continuous contract chart: | 2014-06-23 07:48:56
CL-201302-NYMEX | 2014-06-23 07:48:56
CL-201303-NYMEX | 2014-06-23 07:48:56
CL-201304-NYMEX | 2014-06-23 07:48:56
CL-201305-NYMEX | 2014-06-23 07:48:56
CL-201306-NYMEX | 2014-06-23 07:48:56
CL-201307-NYMEX | 2014-06-23 07:48:56
CL-201308-NYMEX | 2014-06-23 07:48:56
CL-201309-NYMEX | 2014-06-23 07:48:56
CL-201310-NYMEX | 2014-06-23 07:48:56
CL-201311-NYMEX | 2014-06-23 07:48:56
CL-201312-NYMEX | 2014-06-23 07:48:56
CL-201401-NYMEX | 2014-06-23 07:48:56
CL-201402-NYMEX | 2014-06-23 07:48:56
CL-201403-NYMEX | 2014-06-23 07:48:56
CL-201404-NYMEX | 2014-06-23 07:48:56
CL-201405-NYMEX | 2014-06-23 07:48:56
CL-201406-NYMEX | 2014-06-23 07:48:56
CL-201407-NYMEX | 2014-06-23 07:48:56
CL-201408-NYMEX | 2014-06-23 07:48:56
Volume based rollover from CL-201302-NYMEX to CL-201303-NYMEX occurs at 2013-01-18 | 2014-06-23 07:48:56
Volume based rollover from CL-201303-NYMEX to CL-201304-NYMEX occurs at 2013-02-19 | 2014-06-23 07:48:56
Volume based rollover from CL-201304-NYMEX to CL-201305-NYMEX occurs at 2013-03-18 | 2014-06-23 07:48:56
Volume based rollover from CL-201305-NYMEX to CL-201306-NYMEX occurs at 2013-04-18 | 2014-06-23 07:48:56
Volume based rollover from CL-201306-NYMEX to CL-201307-NYMEX occurs at 2013-05-20 | 2014-06-23 07:48:56
Volume based rollover from CL-201307-NYMEX to CL-201308-NYMEX occurs at 2013-06-18 | 2014-06-23 07:48:56
Volume based rollover from CL-201308-NYMEX to CL-201309-NYMEX occurs at 2013-07-18 | 2014-06-23 07:48:56
Volume based rollover from CL-201309-NYMEX to CL-201310-NYMEX occurs at 2013-08-16 | 2014-06-23 07:48:56
Volume based rollover from CL-201310-NYMEX to CL-201311-NYMEX occurs at 2013-09-18 | 2014-06-23 07:48:56
Volume based rollover from CL-201311-NYMEX to CL-201312-NYMEX occurs at 2013-10-18 | 2014-06-23 07:48:56
Volume based rollover from CL-201312-NYMEX to CL-201401-NYMEX occurs at 2013-11-19 | 2014-06-23 07:48:56
Volume based rollover from CL-201401-NYMEX to CL-201402-NYMEX occurs at 2013-12-17 | 2014-06-23 07:48:56
Volume based rollover from CL-201402-NYMEX to CL-201403-NYMEX occurs at 2014-01-17 | 2014-06-23 07:48:56
Volume based rollover from CL-201403-NYMEX to CL-201404-NYMEX occurs at 2014-02-18 | 2014-06-23 07:48:56
Volume based rollover from CL-201404-NYMEX to CL-201405-NYMEX occurs at 2014-03-18 | 2014-06-23 07:48:56
Volume based rollover from CL-201405-NYMEX to CL-201406-NYMEX occurs at 2014-04-22 | 2014-06-23 07:48:56
Volume based rollover from CL-201406-NYMEX to CL-201407-NYMEX occurs at 0 | 2014-06-23 07:48:56
Using date based transition from CL-201406-NYMEX to CL-201407-NYMEX because volume based transition could not be determined. | 2014-06-23 07:48:56
Volume based rollover from CL-201407-NYMEX to CL-201408-NYMEX occurs at 2014-06-18 | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 30 Min #4: Performing continuous futures contract back adjustment calculations. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 30 Min #4: CL-201302-NYMEX Open price on 2013-01-18 is 95.19. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 30 Min #4: CL-201303-NYMEX Open price on 2013-01-18 is 95.65. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 30 Min #4: CL-201302-NYMEX price difference to CL-201303-NYMEX is 0.46000001. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 30 Min #4: CL-201303-NYMEX Open price on 2013-02-19 is 95.97. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 30 Min #4: CL-201304-NYMEX Open price on 2013-02-19 is 96.39. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 30 Min #4: CL-201303-NYMEX price difference to CL-201304-NYMEX is 0.41999999. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 30 Min #4: CL-201304-NYMEX Open price on 2013-03-18 is 93.26. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 30 Min #4: CL-201305-NYMEX Open price on 2013-03-18 is 93.62. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 30 Min #4: CL-201304-NYMEX price difference to CL-201305-NYMEX is 0.36000001. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 30 Min #4: CL-201305-NYMEX Open price on 2013-04-18 is 86.39. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 30 Min #4: CL-201306-NYMEX Open price on 2013-04-18 is 86.6. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 30 Min #4: CL-201305-NYMEX price difference to CL-201306-NYMEX is 0.20999999. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 30 Min #4: CL-201306-NYMEX Open price on 2013-05-20 is 95.93. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 30 Min #4: CL-201307-NYMEX Open price on 2013-05-20 is 96.25. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 30 Min #4: CL-201306-NYMEX price difference to CL-201307-NYMEX is 0.31999999. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 30 Min #4: CL-201307-NYMEX Open price on 2013-06-18 is 97.93. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 30 Min #4: CL-201308-NYMEX Open price on 2013-06-18 is 98.16. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 30 Min #4: CL-201307-NYMEX price difference to CL-201308-NYMEX is 0.23. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 30 Min #4: CL-201308-NYMEX Open price on 2013-07-18 is 106.56. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 30 Min #4: CL-201309-NYMEX Open price on 2013-07-18 is 106.35. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 30 Min #4: CL-201308-NYMEX price difference to CL-201309-NYMEX is -0.20999999. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 30 Min #4: CL-201309-NYMEX Open price on 2013-08-16 is 107.18. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 30 Min #4: CL-201310-NYMEX Open price on 2013-08-16 is 107.01. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 30 Min #4: CL-201309-NYMEX price difference to CL-201310-NYMEX is -0.17. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 30 Min #4: CL-201310-NYMEX Open price on 2013-09-18 is 105.53. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 30 Min #4: CL-201311-NYMEX Open price on 2013-09-18 is 104.77. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 30 Min #4: CL-201310-NYMEX price difference to CL-201311-NYMEX is -0.75999999. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 30 Min #4: CL-201311-NYMEX Open price on 2013-10-18 is 100.72. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 30 Min #4: CL-201312-NYMEX Open price on 2013-10-18 is 101. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 30 Min #4: CL-201311-NYMEX price difference to CL-201312-NYMEX is 0.28. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 30 Min #4: CL-201312-NYMEX Open price on 2013-11-19 is 93. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 30 Min #4: CL-201401-NYMEX Open price on 2013-11-19 is 93.64. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 30 Min #4: CL-201312-NYMEX price difference to CL-201401-NYMEX is 0.63999999. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 30 Min #4: CL-201401-NYMEX Open price on 2013-12-17 is 97.3. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 30 Min #4: CL-201402-NYMEX Open price on 2013-12-17 is 97.54. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 30 Min #4: CL-201401-NYMEX price difference to CL-201402-NYMEX is 0.23999999. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 30 Min #4: CL-201402-NYMEX Open price on 2014-01-17 is 94.17. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 30 Min #4: CL-201403-NYMEX Open price on 2014-01-17 is 94.29. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 30 Min #4: CL-201402-NYMEX price difference to CL-201403-NYMEX is 0.12. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 30 Min #4: CL-201403-NYMEX Open price on 2014-02-18 is 100.32. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 30 Min #4: CL-201404-NYMEX Open price on 2014-02-18 is 100.12. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 30 Min #4: CL-201403-NYMEX price difference to CL-201404-NYMEX is -0.2. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 30 Min #4: CL-201404-NYMEX Open price on 2014-03-18 is 97.97. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 30 Min #4: CL-201405-NYMEX Open price on 2014-03-18 is 97.46. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 30 Min #4: CL-201404-NYMEX price difference to CL-201405-NYMEX is -0.50999999. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 30 Min #4: CL-201405-NYMEX Open price on 2014-04-22 is 104.36. | 2014-06-23 07:48:56
Error while getting daily open price with date 2014-04-25 from file. C:\SierraChart\Data\CLM14.dly. Error: Encountered end of file. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 30 Min #4: CL-201405-NYMEX price difference to CL-201406-NYMEX is 0. | 2014-06-23 07:48:56
Error while getting daily open price with date 2014-05-22 from file. C:\SierraChart\Data\CLM14.dly. Error: Encountered end of file. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 30 Min #4: CL-201407-NYMEX Open price on 2014-05-19 is 101.68. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 30 Min #4: CL-201406-NYMEX price difference to CL-201407-NYMEX is 0. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 30 Min #4: CL-201407-NYMEX Open price on 2014-06-18 is 106.6. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 30 Min #4: CL-201408-NYMEX Open price on 2014-06-18 is 106.06. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 30 Min #4: CL-201407-NYMEX price difference to CL-201408-NYMEX is -0.54000002. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 30 Min #4: Back adjust amount for symbol CL-201302-NYMEX is 0.88999981. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 30 Min #4: Back adjust amount for symbol CL-201303-NYMEX is 0.42999989. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 30 Min #4: Back adjust amount for symbol CL-201304-NYMEX is 0.0099999309. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 30 Min #4: Back adjust amount for symbol CL-201305-NYMEX is -0.35000002. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 30 Min #4: Back adjust amount for symbol CL-201306-NYMEX is -0.56. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 30 Min #4: Back adjust amount for symbol CL-201307-NYMEX is -0.88000005. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 30 Min #4: Back adjust amount for symbol CL-201308-NYMEX is -1.1100001. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 30 Min #4: Back adjust amount for symbol CL-201309-NYMEX is -0.90000004. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 30 Min #4: Back adjust amount for symbol CL-201310-NYMEX is -0.73000002. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 30 Min #4: Back adjust amount for symbol CL-201311-NYMEX is 0.029999912. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 30 Min #4: Back adjust amount for symbol CL-201312-NYMEX is -0.25. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 30 Min #4: Back adjust amount for symbol CL-201401-NYMEX is -0.89000005. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 30 Min #4: Back adjust amount for symbol CL-201402-NYMEX is -1.13. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 30 Min #4: Back adjust amount for symbol CL-201403-NYMEX is -1.25. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 30 Min #4: Back adjust amount for symbol CL-201404-NYMEX is -1.05. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 30 Min #4: Back adjust amount for symbol CL-201405-NYMEX is -0.54000002. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 30 Min #4: Back adjust amount for symbol CL-201406-NYMEX is -0.54000002. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 30 Min #4: Back adjust amount for symbol CL-201407-NYMEX is -0.54000002. | 2014-06-23 07:48:56
Date rule based rollover from CL-201302-NYMEX to next contract occurs at 2013-01-21 | 2014-06-23 07:48:56
Date rule based rollover from CL-201303-NYMEX to next contract occurs at 2013-02-19 | 2014-06-23 07:48:56
Date rule based rollover from CL-201304-NYMEX to next contract occurs at 2013-03-19 | 2014-06-23 07:48:56
Date rule based rollover from CL-201305-NYMEX to next contract occurs at 2013-04-19 | 2014-06-23 07:48:56
Date rule based rollover from CL-201306-NYMEX to next contract occurs at 2013-05-20 | 2014-06-23 07:48:56
Date rule based rollover from CL-201307-NYMEX to next contract occurs at 2013-06-19 | 2014-06-23 07:48:56
Date rule based rollover from CL-201308-NYMEX to next contract occurs at 2013-07-19 | 2014-06-23 07:48:56
Date rule based rollover from CL-201309-NYMEX to next contract occurs at 2013-08-19 | 2014-06-23 07:48:56
Date rule based rollover from CL-201310-NYMEX to next contract occurs at 2013-09-19 | 2014-06-23 07:48:56
Date rule based rollover from CL-201311-NYMEX to next contract occurs at 2013-10-21 | 2014-06-23 07:48:56
Date rule based rollover from CL-201312-NYMEX to next contract occurs at 2013-11-19 | 2014-06-23 07:48:56
Date rule based rollover from CL-201401-NYMEX to next contract occurs at 2013-12-19 | 2014-06-23 07:48:56
Date rule based rollover from CL-201402-NYMEX to next contract occurs at 2014-01-20 | 2014-06-23 07:48:56
Date rule based rollover from CL-201403-NYMEX to next contract occurs at 2014-02-19 | 2014-06-23 07:48:56
Date rule based rollover from CL-201404-NYMEX to next contract occurs at 2014-03-19 | 2014-06-23 07:48:56
Date rule based rollover from CL-201405-NYMEX to next contract occurs at 2014-04-21 | 2014-06-23 07:48:56
Date rule based rollover from CL-201406-NYMEX to next contract occurs at 2014-05-19 | 2014-06-23 07:48:56
Date rule based rollover from CL-201407-NYMEX to next contract occurs at 2014-06-19 | 2014-06-23 07:48:56
Date rule based rollover from CL-201408-NYMEX to next contract occurs at 2014-07-21 | 2014-06-23 07:48:56
Checking Intraday data file for symbol CL-201302-NYMEX for the date range from 2012-12-19 to 2013-01-21 | 2014-06-23 07:48:56
Checking Daily data file for symbol CLG13 for the date range from 2012-12-19 to 2013-01-21 | 2014-06-23 07:48:56
Checking Intraday data file for symbol CL-201303-NYMEX for the date range from 2013-01-21 to 2013-02-19 | 2014-06-23 07:48:56
Checking Daily data file for symbol CLH13 for the date range from 2013-01-21 to 2013-02-19 | 2014-06-23 07:48:56
Checking Intraday data file for symbol CL-201304-NYMEX for the date range from 2013-02-19 to 2013-03-19 | 2014-06-23 07:48:56
Checking Daily data file for symbol CLJ13 for the date range from 2013-02-19 to 2013-03-19 | 2014-06-23 07:48:56
Checking Intraday data file for symbol CL-201305-NYMEX for the date range from 2013-03-19 to 2013-04-19 | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 15 Min #5: Performing continuous futures contract back adjustment calculations. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 15 Min #5: CL-201302-NYMEX Open price on 2013-01-18 is 95.19. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 15 Min #5: CL-201303-NYMEX Open price on 2013-01-18 is 95.65. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 15 Min #5: CL-201302-NYMEX price difference to CL-201303-NYMEX is 0.46000001. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 15 Min #5: CL-201303-NYMEX Open price on 2013-02-19 is 95.97. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 15 Min #5: CL-201304-NYMEX Open price on 2013-02-19 is 96.39. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 15 Min #5: CL-201303-NYMEX price difference to CL-201304-NYMEX is 0.41999999. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 15 Min #5: CL-201304-NYMEX Open price on 2013-03-18 is 93.26. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 15 Min #5: CL-201305-NYMEX Open price on 2013-03-18 is 93.62. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 15 Min #5: CL-201304-NYMEX price difference to CL-201305-NYMEX is 0.36000001. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 15 Min #5: CL-201305-NYMEX Open price on 2013-04-18 is 86.39. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 15 Min #5: CL-201306-NYMEX Open price on 2013-04-18 is 86.6. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 15 Min #5: CL-201305-NYMEX price difference to CL-201306-NYMEX is 0.20999999. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 15 Min #5: CL-201306-NYMEX Open price on 2013-05-20 is 95.93. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 15 Min #5: CL-201307-NYMEX Open price on 2013-05-20 is 96.25. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 15 Min #5: CL-201306-NYMEX price difference to CL-201307-NYMEX is 0.31999999. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 15 Min #5: CL-201307-NYMEX Open price on 2013-06-18 is 97.93. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 15 Min #5: CL-201308-NYMEX Open price on 2013-06-18 is 98.16. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 15 Min #5: CL-201307-NYMEX price difference to CL-201308-NYMEX is 0.23. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 15 Min #5: CL-201308-NYMEX Open price on 2013-07-18 is 106.56. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 15 Min #5: CL-201309-NYMEX Open price on 2013-07-18 is 106.35. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 15 Min #5: CL-201308-NYMEX price difference to CL-201309-NYMEX is -0.20999999. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 15 Min #5: CL-201309-NYMEX Open price on 2013-08-16 is 107.18. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 15 Min #5: CL-201310-NYMEX Open price on 2013-08-16 is 107.01. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 15 Min #5: CL-201309-NYMEX price difference to CL-201310-NYMEX is -0.17. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 15 Min #5: CL-201310-NYMEX Open price on 2013-09-18 is 105.53. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 15 Min #5: CL-201311-NYMEX Open price on 2013-09-18 is 104.77. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 15 Min #5: CL-201310-NYMEX price difference to CL-201311-NYMEX is -0.75999999. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 15 Min #5: CL-201311-NYMEX Open price on 2013-10-18 is 100.72. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 15 Min #5: CL-201312-NYMEX Open price on 2013-10-18 is 101. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 15 Min #5: CL-201311-NYMEX price difference to CL-201312-NYMEX is 0.28. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 15 Min #5: CL-201312-NYMEX Open price on 2013-11-19 is 93. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 15 Min #5: CL-201401-NYMEX Open price on 2013-11-19 is 93.64. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 15 Min #5: CL-201312-NYMEX price difference to CL-201401-NYMEX is 0.63999999. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 15 Min #5: CL-201401-NYMEX Open price on 2013-12-17 is 97.3. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 15 Min #5: CL-201402-NYMEX Open price on 2013-12-17 is 97.54. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 15 Min #5: CL-201401-NYMEX price difference to CL-201402-NYMEX is 0.23999999. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 15 Min #5: CL-201402-NYMEX Open price on 2014-01-17 is 94.17. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 15 Min #5: CL-201403-NYMEX Open price on 2014-01-17 is 94.29. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 15 Min #5: CL-201402-NYMEX price difference to CL-201403-NYMEX is 0.12. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 15 Min #5: CL-201403-NYMEX Open price on 2014-02-18 is 100.32. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 15 Min #5: CL-201404-NYMEX Open price on 2014-02-18 is 100.12. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 15 Min #5: CL-201403-NYMEX price difference to CL-201404-NYMEX is -0.2. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 15 Min #5: CL-201404-NYMEX Open price on 2014-03-18 is 97.97. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 15 Min #5: CL-201405-NYMEX Open price on 2014-03-18 is 97.46. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 15 Min #5: CL-201404-NYMEX price difference to CL-201405-NYMEX is -0.50999999. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 15 Min #5: CL-201405-NYMEX Open price on 2014-04-22 is 104.36. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 15 Min #5: CL-201405-NYMEX price difference to CL-201406-NYMEX is 0. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 15 Min #5: CL-201407-NYMEX Open price on 2014-05-19 is 101.68. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 15 Min #5: CL-201406-NYMEX price difference to CL-201407-NYMEX is 0. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 15 Min #5: CL-201407-NYMEX Open price on 2014-06-18 is 106.6. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 15 Min #5: CL-201408-NYMEX Open price on 2014-06-18 is 106.06. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 15 Min #5: CL-201407-NYMEX price difference to CL-201408-NYMEX is -0.54000002. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 15 Min #5: Back adjust amount for symbol CL-201302-NYMEX is 0.88999981. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 15 Min #5: Back adjust amount for symbol CL-201303-NYMEX is 0.42999989. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 15 Min #5: Back adjust amount for symbol CL-201304-NYMEX is 0.0099999309. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 15 Min #5: Back adjust amount for symbol CL-201305-NYMEX is -0.35000002. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 15 Min #5: Back adjust amount for symbol CL-201306-NYMEX is -0.56. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 15 Min #5: Back adjust amount for symbol CL-201307-NYMEX is -0.88000005. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 15 Min #5: Back adjust amount for symbol CL-201308-NYMEX is -1.1100001. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 15 Min #5: Back adjust amount for symbol CL-201309-NYMEX is -0.90000004. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 15 Min #5: Back adjust amount for symbol CL-201310-NYMEX is -0.73000002. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 15 Min #5: Back adjust amount for symbol CL-201311-NYMEX is 0.029999912. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 15 Min #5: Back adjust amount for symbol CL-201312-NYMEX is -0.25. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 15 Min #5: Back adjust amount for symbol CL-201401-NYMEX is -0.89000005. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 15 Min #5: Back adjust amount for symbol CL-201402-NYMEX is -1.13. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 15 Min #5: Back adjust amount for symbol CL-201403-NYMEX is -1.25. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 15 Min #5: Back adjust amount for symbol CL-201404-NYMEX is -1.05. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 15 Min #5: Back adjust amount for symbol CL-201405-NYMEX is -0.54000002. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 15 Min #5: Back adjust amount for symbol CL-201406-NYMEX is -0.54000002. | 2014-06-23 07:48:56
CL-201408-NYMEX [CBV] 15 Min #5: Back adjust amount for symbol CL-201407-NYMEX is -0.54000002. | 2014-06-23 07:48:56
HD Request # 4 - Downloading Historical Daily chart data for CLZ11. Starting date: 2011-11-17. Service: ib | 2014-06-23 07:48:56
HD Request # 4 - Using user Barchart Historical data account. | 2014-06-23 07:48:56
HD Request # 4 - Requesting historical Daily data for CLZ11 starting at 2011-11-16 | 2014-06-23 07:48:56
Mapping CL-201212-NYMEX to CLZ2. Service code: nymex | 2014-06-23 07:48:56
HD Request # 5 - Downloading Intraday chart data for CL-201212-NYMEX to the file CL-201212-NYMEX.scid. Service: nymex | 2014-06-23 07:48:56
HD Request # 5 - Download start Date-Time: 2012-11-16 11:29:58.0 | 2014-06-23 07:48:56
HD Request # 5 - Using server: scdf2.sierracharts.com port 10149 | 2014-06-23 07:48:56
Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2014-06-23 07:48:56
The network socket is connected. | 2014-06-23 07:48:56
HD Request # 5 - Sending historical data logon request message. | 2014-06-23 07:48:56
HD Request # 4 - Receiving historical Daily data for CLZ11 starting at 2011-11-16 | 2014-06-23 07:48:57
Writing historical Daily data for CLZ11 to the file CLZ11.dly | 2014-06-23 07:48:57
HD Request # 4 - Received 3 records from 2011-11-16 00:00:00 to 2011-11-18 00:00:00 (3.0 days) and wrote 2 records for CLZ11 | 2014-06-23 07:48:57
HD Request # 4 - Daily download COMPLETE for CLZ11. Completion time: 1s | 2014-06-23 07:48:57
HD Request # 5 - Requesting Intraday data. Start Date-Time: 2012-11-16 11:29:58. Record interval: 0 . Symbol: CLZ2 | 2014-06-23 07:48:58
HD Request # 5 - Decompressing data. | 2014-06-23 07:48:58
HD Request # 5 - Receiving Intraday data for CL-201212-NYMEX starting at 2012-11-16 11:29:58 | 2014-06-23 07:48:58
Socket has been shutdown and closed. | 2014-06-23 07:48:58
The network socket for historical data has been closed. | 2014-06-23 07:48:58
HD Request # 5 - Received 1 record from 2012-11-16 11:29:58 to 2012-11-16 11:29:58 (0.0 seconds) and wrote 0 records for CL-201212-NYMEX | 2014-06-23 07:48:58
HD Request # 5 - Intraday download COMPLETE for CL-201212-NYMEX. Completion time: 2s | 2014-06-23 07:48:58
Real-time Intraday chart data file updates started for CL-201212-NYMEX | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: Download is complete for all contract months in chart. Proceeding with data load. | 2014-06-23 07:48:58
Volume based rollover from CL-201109-NYMEX to CL-201110-NYMEX occurs at 2011-08-19 | 2014-06-23 07:48:58
Volume based rollover from CL-201110-NYMEX to CL-201111-NYMEX occurs at 2011-09-19 | 2014-06-23 07:48:58
Volume based rollover from CL-201111-NYMEX to CL-201112-NYMEX occurs at 2011-10-18 | 2014-06-23 07:48:58
Volume based rollover from CL-201112-NYMEX to CL-201201-NYMEX occurs at 2011-11-17 | 2014-06-23 07:48:58
Volume based rollover from CL-201201-NYMEX to CL-201202-NYMEX occurs at 2011-12-19 | 2014-06-23 07:48:58
Volume based rollover from CL-201202-NYMEX to CL-201203-NYMEX occurs at 2012-01-19 | 2014-06-23 07:48:58
Volume based rollover from CL-201203-NYMEX to CL-201204-NYMEX occurs at 2012-02-17 | 2014-06-23 07:48:58
Volume based rollover from CL-201204-NYMEX to CL-201205-NYMEX occurs at 2012-03-19 | 2014-06-23 07:48:58
Volume based rollover from CL-201205-NYMEX to CL-201206-NYMEX occurs at 2012-04-19 | 2014-06-23 07:48:58
Volume based rollover from CL-201206-NYMEX to CL-201207-NYMEX occurs at 2012-05-21 | 2014-06-23 07:48:58
Volume based rollover from CL-201207-NYMEX to CL-201208-NYMEX occurs at 2012-06-19 | 2014-06-23 07:48:58
Volume based rollover from CL-201208-NYMEX to CL-201209-NYMEX occurs at 2012-07-19 | 2014-06-23 07:48:58
Volume based rollover from CL-201209-NYMEX to CL-201210-NYMEX occurs at 2012-08-20 | 2014-06-23 07:48:58
Volume based rollover from CL-201210-NYMEX to CL-201211-NYMEX occurs at 2012-09-19 | 2014-06-23 07:48:58
Volume based rollover from CL-201211-NYMEX to CL-201212-NYMEX occurs at 2012-10-19 | 2014-06-23 07:48:58
Volume based rollover from CL-201212-NYMEX to CL-201301-NYMEX occurs at 2012-11-15 | 2014-06-23 07:48:58
Volume based rollover from CL-201301-NYMEX to CL-201302-NYMEX occurs at 2012-12-18 | 2014-06-23 07:48:58
Volume based rollover from CL-201302-NYMEX to CL-201303-NYMEX occurs at 2013-01-18 | 2014-06-23 07:48:58
Volume based rollover from CL-201303-NYMEX to CL-201304-NYMEX occurs at 2013-02-19 | 2014-06-23 07:48:58
Volume based rollover from CL-201304-NYMEX to CL-201305-NYMEX occurs at 2013-03-18 | 2014-06-23 07:48:58
Volume based rollover from CL-201305-NYMEX to CL-201306-NYMEX occurs at 2013-04-18 | 2014-06-23 07:48:58
Volume based rollover from CL-201306-NYMEX to CL-201307-NYMEX occurs at 2013-05-20 | 2014-06-23 07:48:58
Volume based rollover from CL-201307-NYMEX to CL-201308-NYMEX occurs at 2013-06-18 | 2014-06-23 07:48:58
Volume based rollover from CL-201308-NYMEX to CL-201309-NYMEX occurs at 2013-07-18 | 2014-06-23 07:48:58
Volume based rollover from CL-201309-NYMEX to CL-201310-NYMEX occurs at 2013-08-16 | 2014-06-23 07:48:58
Volume based rollover from CL-201310-NYMEX to CL-201311-NYMEX occurs at 2013-09-18 | 2014-06-23 07:48:58
Volume based rollover from CL-201311-NYMEX to CL-201312-NYMEX occurs at 2013-10-18 | 2014-06-23 07:48:58
Volume based rollover from CL-201312-NYMEX to CL-201401-NYMEX occurs at 2013-11-19 | 2014-06-23 07:48:58
Volume based rollover from CL-201401-NYMEX to CL-201402-NYMEX occurs at 2013-12-17 | 2014-06-23 07:48:58
Volume based rollover from CL-201402-NYMEX to CL-201403-NYMEX occurs at 2014-01-17 | 2014-06-23 07:48:58
Volume based rollover from CL-201403-NYMEX to CL-201404-NYMEX occurs at 2014-02-18 | 2014-06-23 07:48:58
Volume based rollover from CL-201404-NYMEX to CL-201405-NYMEX occurs at 2014-03-18 | 2014-06-23 07:48:58
Volume based rollover from CL-201405-NYMEX to CL-201406-NYMEX occurs at 2014-04-22 | 2014-06-23 07:48:58
Volume based rollover from CL-201406-NYMEX to CL-201407-NYMEX occurs at 0 | 2014-06-23 07:48:58
Using date based transition from CL-201406-NYMEX to CL-201407-NYMEX because volume based transition could not be determined. | 2014-06-23 07:48:58
Volume based rollover from CL-201407-NYMEX to CL-201408-NYMEX occurs at 2014-06-18 | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: Performing continuous futures contract back adjustment calculations. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201109-NYMEX Open price on 2011-08-19 is 81.3. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201110-NYMEX Open price on 2011-08-19 is 81.45. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201109-NYMEX price difference to CL-201110-NYMEX is 0.15000001. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201110-NYMEX Open price on 2011-09-19 is 87.75. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201111-NYMEX Open price on 2011-09-19 is 87.8. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201110-NYMEX price difference to CL-201111-NYMEX is 0.050000001. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201111-NYMEX Open price on 2011-10-18 is 86.2. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201112-NYMEX Open price on 2011-10-18 is 86.3. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201111-NYMEX price difference to CL-201112-NYMEX is 0.1. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201112-NYMEX Open price on 2011-11-17 is 101.76. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201201-NYMEX Open price on 2011-11-17 is 101.74. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201112-NYMEX price difference to CL-201201-NYMEX is -0.02. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201201-NYMEX Open price on 2011-12-19 is 93.76. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201202-NYMEX Open price on 2011-12-19 is 93.77. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201201-NYMEX price difference to CL-201202-NYMEX is 0.0099999998. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201202-NYMEX Open price on 2012-01-19 is 101.14. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201203-NYMEX Open price on 2012-01-19 is 101.35. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201202-NYMEX price difference to CL-201203-NYMEX is 0.20999999. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201203-NYMEX Open price on 2012-02-17 is 102.35. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201204-NYMEX Open price on 2012-02-17 is 102.64. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201203-NYMEX price difference to CL-201204-NYMEX is 0.28999999. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201204-NYMEX Open price on 2012-03-19 is 107.18. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201205-NYMEX Open price on 2012-03-19 is 107.78. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201204-NYMEX price difference to CL-201205-NYMEX is 0.60000002. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201205-NYMEX Open price on 2012-04-19 is 102.73. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201206-NYMEX Open price on 2012-04-19 is 103.21. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201205-NYMEX price difference to CL-201206-NYMEX is 0.47999999. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201206-NYMEX Open price on 2012-05-21 is 91.27. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201207-NYMEX Open price on 2012-05-21 is 91.71. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201206-NYMEX price difference to CL-201207-NYMEX is 0.44. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201207-NYMEX Open price on 2012-06-19 is 83.06. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201208-NYMEX Open price on 2012-06-19 is 83.44. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201207-NYMEX price difference to CL-201208-NYMEX is 0.38. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201208-NYMEX Open price on 2012-07-19 is 90.08. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201209-NYMEX Open price on 2012-07-19 is 90.35. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201208-NYMEX price difference to CL-201209-NYMEX is 0.27000001. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201209-NYMEX Open price on 2012-08-20 is 96.36. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201210-NYMEX Open price on 2012-08-20 is 96.64. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201209-NYMEX price difference to CL-201210-NYMEX is 0.28. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201210-NYMEX Open price on 2012-09-19 is 95.49. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201211-NYMEX Open price on 2012-09-19 is 95.83. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201210-NYMEX price difference to CL-201211-NYMEX is 0.34. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201211-NYMEX Open price on 2012-10-19 is 92.04. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201212-NYMEX Open price on 2012-10-19 is 92.48. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201211-NYMEX price difference to CL-201212-NYMEX is 0.44. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201212-NYMEX Open price on 2012-11-15 is 86.36. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201301-NYMEX Open price on 2012-11-15 is 86.77. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201212-NYMEX price difference to CL-201301-NYMEX is 0.41. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201301-NYMEX Open price on 2012-12-18 is 87.45. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201302-NYMEX Open price on 2012-12-18 is 87.94. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201301-NYMEX price difference to CL-201302-NYMEX is 0.49000001. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201302-NYMEX Open price on 2013-01-18 is 95.19. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201303-NYMEX Open price on 2013-01-18 is 95.65. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201302-NYMEX price difference to CL-201303-NYMEX is 0.46000001. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201303-NYMEX Open price on 2013-02-19 is 95.97. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201304-NYMEX Open price on 2013-02-19 is 96.39. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201303-NYMEX price difference to CL-201304-NYMEX is 0.41999999. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201304-NYMEX Open price on 2013-03-18 is 93.26. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201305-NYMEX Open price on 2013-03-18 is 93.62. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201304-NYMEX price difference to CL-201305-NYMEX is 0.36000001. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201305-NYMEX Open price on 2013-04-18 is 86.39. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201306-NYMEX Open price on 2013-04-18 is 86.6. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201305-NYMEX price difference to CL-201306-NYMEX is 0.20999999. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201306-NYMEX Open price on 2013-05-20 is 95.93. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201307-NYMEX Open price on 2013-05-20 is 96.25. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201306-NYMEX price difference to CL-201307-NYMEX is 0.31999999. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201307-NYMEX Open price on 2013-06-18 is 97.93. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201308-NYMEX Open price on 2013-06-18 is 98.16. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201307-NYMEX price difference to CL-201308-NYMEX is 0.23. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201308-NYMEX Open price on 2013-07-18 is 106.56. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201309-NYMEX Open price on 2013-07-18 is 106.35. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201308-NYMEX price difference to CL-201309-NYMEX is -0.20999999. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201309-NYMEX Open price on 2013-08-16 is 107.18. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201310-NYMEX Open price on 2013-08-16 is 107.01. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201309-NYMEX price difference to CL-201310-NYMEX is -0.17. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201310-NYMEX Open price on 2013-09-18 is 105.53. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201311-NYMEX Open price on 2013-09-18 is 104.77. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201310-NYMEX price difference to CL-201311-NYMEX is -0.75999999. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201311-NYMEX Open price on 2013-10-18 is 100.72. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201312-NYMEX Open price on 2013-10-18 is 101. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201311-NYMEX price difference to CL-201312-NYMEX is 0.28. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201312-NYMEX Open price on 2013-11-19 is 93. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201401-NYMEX Open price on 2013-11-19 is 93.64. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201312-NYMEX price difference to CL-201401-NYMEX is 0.63999999. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201401-NYMEX Open price on 2013-12-17 is 97.3. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201402-NYMEX Open price on 2013-12-17 is 97.54. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201401-NYMEX price difference to CL-201402-NYMEX is 0.23999999. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201402-NYMEX Open price on 2014-01-17 is 94.17. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201403-NYMEX Open price on 2014-01-17 is 94.29. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201402-NYMEX price difference to CL-201403-NYMEX is 0.12. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201403-NYMEX Open price on 2014-02-18 is 100.32. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201404-NYMEX Open price on 2014-02-18 is 100.12. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201403-NYMEX price difference to CL-201404-NYMEX is -0.2. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201404-NYMEX Open price on 2014-03-18 is 97.97. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201405-NYMEX Open price on 2014-03-18 is 97.46. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201404-NYMEX price difference to CL-201405-NYMEX is -0.50999999. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201405-NYMEX Open price on 2014-04-22 is 104.36. | 2014-06-23 07:48:58
Error while getting daily open price with date 2014-04-25 from file. C:\SierraChart\Data\CLM14.dly. Error: Encountered end of file. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201405-NYMEX price difference to CL-201406-NYMEX is 0. | 2014-06-23 07:48:58
Error while getting daily open price with date 2014-05-22 from file. C:\SierraChart\Data\CLM14.dly. Error: Encountered end of file. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201407-NYMEX Open price on 2014-05-19 is 101.68. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201406-NYMEX price difference to CL-201407-NYMEX is 0. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201407-NYMEX Open price on 2014-06-18 is 106.6. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201408-NYMEX Open price on 2014-06-18 is 106.06. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: CL-201407-NYMEX price difference to CL-201408-NYMEX is -0.54000002. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: Back adjust amount for symbol CL-201109-NYMEX is 5.8100004. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: Back adjust amount for symbol CL-201110-NYMEX is 5.6599998. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: Back adjust amount for symbol CL-201111-NYMEX is 5.6100006. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: Back adjust amount for symbol CL-201112-NYMEX is 5.5100002. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: Back adjust amount for symbol CL-201201-NYMEX is 5.5299997. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: Back adjust amount for symbol CL-201202-NYMEX is 5.5200005. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: Back adjust amount for symbol CL-201203-NYMEX is 5.3100004. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: Back adjust amount for symbol CL-201204-NYMEX is 5.0200005. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: Back adjust amount for symbol CL-201205-NYMEX is 4.4200001. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: Back adjust amount for symbol CL-201206-NYMEX is 3.9400005. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: Back adjust amount for symbol CL-201207-NYMEX is 3.5. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: Back adjust amount for symbol CL-201208-NYMEX is 3.1200001. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: Back adjust amount for symbol CL-201209-NYMEX is 2.8499999. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: Back adjust amount for symbol CL-201210-NYMEX is 2.5699999. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: Back adjust amount for symbol CL-201211-NYMEX is 2.2299998. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: Back adjust amount for symbol CL-201212-NYMEX is 1.7899997. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: Back adjust amount for symbol CL-201301-NYMEX is 1.3799999. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: Back adjust amount for symbol CL-201302-NYMEX is 0.88999981. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: Back adjust amount for symbol CL-201303-NYMEX is 0.42999989. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: Back adjust amount for symbol CL-201304-NYMEX is 0.0099999309. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: Back adjust amount for symbol CL-201305-NYMEX is -0.35000002. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: Back adjust amount for symbol CL-201306-NYMEX is -0.56. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: Back adjust amount for symbol CL-201307-NYMEX is -0.88000005. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: Back adjust amount for symbol CL-201308-NYMEX is -1.1100001. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: Back adjust amount for symbol CL-201309-NYMEX is -0.90000004. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: Back adjust amount for symbol CL-201310-NYMEX is -0.73000002. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: Back adjust amount for symbol CL-201311-NYMEX is 0.029999912. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: Back adjust amount for symbol CL-201312-NYMEX is -0.25. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: Back adjust amount for symbol CL-201401-NYMEX is -0.89000005. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: Back adjust amount for symbol CL-201402-NYMEX is -1.13. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: Back adjust amount for symbol CL-201403-NYMEX is -1.25. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: Back adjust amount for symbol CL-201404-NYMEX is -1.05. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: Back adjust amount for symbol CL-201405-NYMEX is -0.54000002. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: Back adjust amount for symbol CL-201406-NYMEX is -0.54000002. | 2014-06-23 07:48:58
CL-201408-NYMEX [CBV] 5 Min #1: Back adjust amount for symbol CL-201407-NYMEX is -0.54000002. | 2014-06-23 07:48:58
Interactive Brokers: Received Open orders end message. | 2014-06-23 08:49:39
Date rule based rollover from CL-201406-NYMEX to next contract occurs at 2014-05-19 | 2014-06-23 12:22:22
Date rule based rollover from CL-201407-NYMEX to next contract occurs at 2014-06-19 | 2014-06-23 12:22:22
Date rule based rollover from CL-201408-NYMEX to next contract occurs at 2014-07-21 | 2014-06-23 12:22:22
Checking Intraday data file for symbol CL-201406-NYMEX for the date range from 2014-04-21 to 2014-05-19 | 2014-06-23 12:22:22
Daily data file for symbol CL-201406-NYMEX existed and is empty. Skipping download. | 2014-06-23 12:22:22
Checking Intraday data file for symbol CL-201407-NYMEX for the date range from 2014-05-19 to 2014-06-19 | 2014-06-23 12:22:22
Checking Daily data file for symbol CLN14 for the date range from 2014-05-19 to 2014-06-19 | 2014-06-23 12:22:22
Checking Intraday data file for symbol CL-201408-NYMEX for the date range from 2014-06-19 to 0 | 2014-06-23 12:22:22
Checking Daily data file for symbol CLQ14 for the date range from 2014-06-19 to 0 | 2014-06-23 12:22:22
Symbols used for CL-201408-NYMEX continuous contract chart: | 2014-06-23 12:22:22
CL-201406-NYMEX | 2014-06-23 12:22:22
CL-201407-NYMEX | 2014-06-23 12:22:22
CL-201408-NYMEX | 2014-06-23 12:22:22
Volume based rollover from CL-201406-NYMEX to CL-201407-NYMEX occurs at 0 | 2014-06-23 12:22:22
Using date based transition from CL-201406-NYMEX to CL-201407-NYMEX because volume based transition could not be determined. | 2014-06-23 12:22:22
Volume based rollover from CL-201407-NYMEX to CL-201408-NYMEX occurs at 2014-06-18 | 2014-06-23 12:22:22
CL-201408-NYMEX [CBV] 5 Min #2: Performing continuous futures contract back adjustment calculations. | 2014-06-23 12:22:22
Error while getting daily open price with date 2014-05-22 from file. C:\SierraChart\Data\CLM14.dly. Error: Encountered end of file. | 2014-06-23 12:22:22
CL-201408-NYMEX [CBV] 5 Min #2: CL-201407-NYMEX Open price on 2014-05-19 is 101.68. | 2014-06-23 12:22:22
CL-201408-NYMEX [CBV] 5 Min #2: CL-201406-NYMEX price difference to CL-201407-NYMEX is 0. | 2014-06-23 12:22:22
CL-201408-NYMEX [CBV] 5 Min #2: CL-201407-NYMEX Open price on 2014-06-18 is 106.6. | 2014-06-23 12:22:22
CL-201408-NYMEX [CBV] 5 Min #2: CL-201408-NYMEX Open price on 2014-06-18 is 106.06. | 2014-06-23 12:22:22
CL-201408-NYMEX [CBV] 5 Min #2: CL-201407-NYMEX price difference to CL-201408-NYMEX is -0.54000002. | 2014-06-23 12:22:22
CL-201408-NYMEX [CBV] 5 Min #2: Back adjust amount for symbol CL-201406-NYMEX is -0.54000002. | 2014-06-23 12:22:22
CL-201408-NYMEX [CBV] 5 Min #2: Back adjust amount for symbol CL-201407-NYMEX is -0.54000002. | 2014-06-23 12:22:22
CL-201408-NYMEX [CBV] 1 Min #6: Performing continuous futures contract back adjustment calculations. | 2014-06-23 12:22:22
CL-201408-NYMEX [CBV] 1 Min #6: CL-201407-NYMEX Open price on 2014-05-19 is 101.68. | 2014-06-23 12:22:22
CL-201408-NYMEX [CBV] 1 Min #6: CL-201406-NYMEX price difference to CL-201407-NYMEX is 0. | 2014-06-23 12:22:22
CL-201408-NYMEX [CBV] 1 Min #6: CL-201407-NYMEX Open price on 2014-06-18 is 106.6. | 2014-06-23 12:22:22
CL-201408-NYMEX [CBV] 1 Min #6: CL-201408-NYMEX Open price on 2014-06-18 is 106.06. | 2014-06-23 12:22:22
CL-201408-NYMEX [CBV] 1 Min #6: CL-201407-NYMEX price difference to CL-201408-NYMEX is -0.54000002. | 2014-06-23 12:22:22
CL-201408-NYMEX [CBV] 1 Min #6: Back adjust amount for symbol CL-201406-NYMEX is -0.54000002. | 2014-06-23 12:22:22
CL-201408-NYMEX [CBV] 1 Min #6: Back adjust amount for symbol CL-201407-NYMEX is -0.54000002. | 2014-06-23 12:22:22
[2014-06-23 22:18:24]
OK, it does not appear as though our instructions are being followed. These logs are quite large and it is difficult for us to go through them and we do not see a full re-download of data.
It is best that we contact you and help you using remote assistance with whatever remaining problem you currently have.
Our schedule is full for today but we will have time tomorrow.
We have your contact information and contact you tomorrow afternoon or evening.
Date Time Of Last Edit: 2014-06-23 22:22:42
[2014-06-23 23:59:40]
ged - Posts: 233
It is one chart, but it has a number of text studies I've created for it. That is probably what you are seeing.
I noticed today that my period timer, for the 5 min chart I provided to you, counts down every 5 seconds: 4:35; 4:30; 4:25, etc. Perhaps this info will help.
I believe I followed the instructions in the link you provided regarding downloading the data. Not sure why it is incomplete.
I want to make it as easy on your end as possible. If calling tomorrow is best we can do that. To reach me when I am at my computer the afternoon will be best (PDT).
Thanks much, Ged
[2014-06-24 17:36:36]
ged - Posts: 233
I am at my computer; done trading. If you are able to call in the next couple of hours that would work out well.
[2014-06-24 18:04:02]
We can call in about 15 minutes.
[2014-06-24 18:15:28]
ged - Posts: 233
Ok
