Date/Time: Thu, 28 Nov 2024 16:45:50 +0000
How to Size-sync Cumulative Delta candles with VWAP candles
View Count: 467
[2023-04-14 06:45:25]
CapionDk - Posts: 4
Hi fellow Traders and Sierra Chart Admin
Sometimes I zoom in on the CD Candles to get a closer look at whats going on and sometimes i Zoom in on the VWAP candles especially in beginning of ETH to see the very small VWAP.
Therefore the Candles are much bigger/longer/wider than the CD Candles or vice versa.
How do I reset the CD Candles or vice versa so they are same height/Lenghts/Wide as each other again?
Is it the 'Scale range' setting on CD and VWAP that needs to be set to automatic? or something else?
When both are set to automatic CD seems much smaller than VWAP!?
Right now im not sure they are in sync and therefore I cant spot Micro absorbation etc.!
Please help
Best regards
Date Time Of Last Edit: 2023-04-14 08:14:46
[2023-04-14 15:59:02]
John - SC Support - Posts: 36350
We are not fully understanding the issue, as we can not reproduce anything like what you appear to be stating.
Is it just when you are using the Zoom In tool that you are having an issue, or is it after you reset from the zoom?
Can you please give us some screenshots of what you are seeing so we can better understand the exact problem.
[2023-04-14 22:40:01]
CapionDk - Posts: 4
Hi John
Thank you for the reply.
Its not Zoom in tools because you can just cancel Zoom.
I think what I am doing is called 'interactive scale range' on either CD or VWAP - how to I reset from that?
Ive attached picture where ive made on up close and the other far away - how to reset back from that?
Private File
[2023-04-17 14:50:34]
If your scale is set to "Automatic" (which is the default), then after you adjust the range to look at something, you can double-click on the Price Ladder to reset it back to what it determines fits best in Automatic mode. Refer to the following:
Chart Scale and Scale Adjusting: Resetting the Scale
