Date/Time: Thu, 28 Nov 2024 15:46:36 +0000
SC order fills not showing.
View Count: 543
[2023-04-14 00:54:21] |
User910963 - Posts: 80 |
Hello. I am on Rithmic trading an evaluation account with topstep. I now can't see my order fills even though the option is checked. I can see my order fills when I sign into my regular CQG trading account but not on Rithmic. Any ideas? |
[2023-04-14 09:11:19] |
Sierra_Chart Engineering - Posts: 17201 |
Do you mean displaying the order fills on the chart? Refer to: Chart Trading and the Chart DOM: Displaying Order Fills on the Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-04-18 01:57:24] |
Yes. That's what I'm looking to do.
[2023-04-18 03:40:14] |
Go through all of the instructions here: Chart Trading and the Chart DOM: Displaying Order Fills on the Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-04-18 13:16:02] |
I followed those instructions, however they did not work.
[2023-04-18 16:32:07] |
You stated that you can only see the fills when connected to CQG. You will only be able to see the order fills for the selected trading account. When you are connected to your Rithmic account, you will not be able to see order fills (or orders) that are done with your CQG account, and vice versa.
[2023-04-18 16:58:11] |
I am logged into my Rithmic account and still can't see the fills.
[2023-04-18 17:06:33] |
You are not able to see the fills for the Rithmic account when logged into your Rithmic account? Make sure you have the correct Trading Account selected on your Trade Window. Refer to the following: Basic Trading and the Trade Window: Main/C >> Trade Account (Selecting Trade Account for Chart / Trade DOM) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-04-19 04:38:46] |
Yes it is correct and Topstep says it may be a limitation.
[2023-04-19 13:55:14] |
If the Order Fills are in the Trade Activity Log and if you have the correct account selected, then as long as you have gone through the items from Post #4, you should see the Order Fills. Please do the following for us - find 1 order fill in your Trade Activity Log and tell us the Date/Time of that fill. Then, ensuring you have the order fills set to be displayed, scroll your chart to that date/time and take a screenshot for us by following these instructions: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) One other thing to check is that the chart you are viewing this one does not have the option for Trade >> Only Orders from Chart enabled. If it is, turn this off. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
